AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Sound Group - Loudspeakers and Subwoofers (https://www.avsforum.com/forum/401-diy-sound-group-loudspeakers-subwoofers/)
-   -   Birth of a set of 893's (https://www.avsforum.com/forum/401-diy-sound-group-loudspeakers-subwoofers/2446834-birth-set-893s.html)
ls1ssz 05-07-2016 12:04 PM
2 Attachment(s)
Just completed my set of 893's. Just started to listen to just 2 channel for now. Waiting of the house to be completed before they go to their final resting place in my new theater. I can't believe how easy the build was with the flat packs and the x-over boards from MGT90. I don't have a professional ear. To many years in the sound reinforcement and the car audio industry. I think these guys sound great. I've been listening to some rock, music with a lot of vocals and now I'm off to some classical piano. Over all they image well and very accurate for the money. I had Martin Logan L,C,R in my last theater and these sound every bit a good for a 1/3 of the price. I'm pleasantly surprised. The nice thing is I don't have to have nearly as much power. I have them running off of an Emotiva XPA 3. I'm sure it's over kill for these speakers but isn't that part of the fun with DIY. I was enjoying my Volt 6's but the 893's are in a new league. They do need a sub but the mid bass punch is outstanding. I was a little concerned how they would mate with an 18" sub. After listening for a while I don't think it will be any issue. I'm off to my next project. Mini Marty's for a pair of 18" SI DS4's. While it's taken a lot more time than just swiping a credit card it's well worth the time investment for the sound quality.
luisev 05-08-2016 05:58 AM
They look great! What did you use as a finish?
ls1ssz 05-08-2016 06:27 AM
5 coats of the same paint I'm going to use for the media room. That's why the Volts are grey and the mains are black. I'm using a matte finish paint.
luisev 05-08-2016 06:31 AM
Gotcha... looking forward to seeing them in the room.
tuxedocivic 05-08-2016 07:23 AM
Awesome. Thanks for the feedback and glad they met your expectations. :)
Sent from my SGH-I747M using Tapatalk
fabulousfrankie 05-09-2016 11:01 AM
Which model Martin Logan's are you talking about?
ls1ssz 05-09-2016 04:26 PM
I had an older set of SL-3's with the matching center channel. I was using the Script's as the rear surround in a 5.1 system. I was using Macintosh 5 channel amp on a Denon receiver.
ja00 05-09-2016 06:59 PM
Looks great. I see that on the Volt 6's you have the ports on top, which I actually considered when building mine but decided to go the conventional route. How do you the look?
I am currently doing an 893 build as well, and so far very happy with the results. Not finished yet, can't wait to get it done. In the meantime I am using the Volts as my mains.
ls1ssz 05-10-2016 04:42 AM
I decided to put the port on top since the Volt's will be on speaker stands. I didn't want them to be top heavy on the stands. Given their size it probably won't make much of a difference. Good luck with you build. As painful as it is take your time it will pay off in the long run. I'm now trying to figure out what I'm going to use for my ceiling speakers.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
