1099 Crossover Question - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By HFGuy
post #1 of 6 Old 05-18-2016, 07:34 AM - Thread Starter
Quoted: 21 Post(s)
Is there an "official" 1099 crossover layout? I have noticed several different versions as I dig around the web. I don't want inductors interfering with each other if there happens to be some "optimal" layout I can go with. I even considered two or three separate boards, if that is the better way to go.
Dr. Fosgate is offline
post #2 of 6 Old 05-18-2016, 12:46 PM
rondi's Avatar
Quoted: 66 Post(s)
Liked: 56
It's worth it to go with mtg90 xovr pc board. all connections correct--you just plug in the components and solder. and if you want an easier way to go--have him build the boards for you
https://www.avsforum.com/forum/401-di...iysg-kits.html
hth
rondi is offline
post #3 of 6 Old 05-18-2016, 01:02 PM - Thread Starter
Quoted: 21 Post(s)
I don't want an easier way to go. Building the crossovers is one of my favorite parts of doing DIY speakers. I just want to be sure to go with the best (most current) accepted layout.
post #4 of 6 Old 05-18-2016, 01:45 PM
BCRSS's Avatar
Quoted: 490 Post(s)
Liked: 455
Not sure if current on layout but is easy layout that works. https://www.avsforum.com/forum/155-di...l#post26291609 Print out, cut in half and follow wires. Done
BCRSS is offline
post #5 of 6 Old 05-18-2016, 01:54 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3527
These are what I just used. And hey came out perfectly!
Brian Fineberg is offline
post #6 of 6 Old 05-20-2016, 11:00 AM
HFGuy's Avatar
Quoted: 228 Post(s)
Liked: 244
My layout
csmithny06 likes this.
HFGuy is offline
