1299 crossovers build - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Erich H
  • 1 Post By tuxedocivic
post #1 of 12 Old 05-26-2016, 12:42 PM - Thread Starter
Quoted: 140 Post(s)
Liked: 208
Anybody has the schematics? I received my kits and I am eager to start building (and documenting) those.
Thank you
Alex
partcrash is offline
post #2 of 12 Old 05-26-2016, 02:11 PM
tuxedocivic's Avatar
Quoted: 2300 Post(s)
Liked: 2224
Didn't come with one? I can dif it up tonight.
Sent from my SGH-I747M using Tapatalk
My youtube channel: Impulse Audio
tuxedocivic is offline
post #3 of 12 Old 05-26-2016, 02:47 PM - Thread Starter
Quoted: 140 Post(s)
Liked: 208
I opened one of the kits and there was no schematics inside. Unless it is tucked somewhere and I missed it...
post #4 of 12 Old 05-26-2016, 06:35 PM
Liked: 2224
Might be in one of the other boxes. But Ill have a look at my old emails. Im sure i sent Erich a XO.
post #5 of 12 Old 05-26-2016, 06:37 PM
Erich H's Avatar
Quoted: 1845 Post(s)
Liked: 2631
Open your other packages sir.
I get a lot of emails from people that say they looked everywhere and didn't get their crossover boards with their Volt kits......then find them wrapped up inside the woofer cutout on the baffle.
Modicen likes this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #6 of 12 Old 05-27-2016, 10:21 AM
vRAE's Avatar
I got the crossover diagram for my 1299 - and it was indeed well packaged :-)
Andrew
vRAE is offline
post #7 of 12 Old 05-28-2016, 07:06 PM
Liked: 2224
So, today I took apart my XO along with the 893 to double check things, cause there were some concerns about the 893. I couldn't find anything wrong with the 893 but I worried I wrote the wrong polarity when I wrote the schematic. Can you tell me if the mids are shown as positive polarity? I wrote down reverse (negative) polarity but I have it wired as positive while the tweeter is supposed to be reverse.
I can't imagine another polarity fiasco Thankfully only a few have gone out. If it gets wired wrong it'll have a hole in the response at 300hz and the response won't be a flat around 500hz.
post #8 of 12 Old 05-28-2016, 07:23 PM - Thread Starter
Quoted: 140 Post(s)
Liked: 208
Ryan,
You are talking about the 1299 XOs? I will take a pic of the diagram I found neatly tucked between the woofer boxes of the -other- box and will post it here for your reference lol...
Alex
post #9 of 12 Old 05-29-2016, 05:36 AM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Here's the schematic from the 893 thread. Are you saying that the mids might be listed with the incorrect polarity?
DIYSG 893 | Emotiva ERD-1 | Dual DIY 18" Subs
Emotiva XMC-1 | XPA-2 | XPA-5 | Dual Crown XLS 2502
Samsung 58" Plasma | BenQ HT1075 100" Screen
Nvidia Shield | Oppo BDP-103 Bluray Player
luisev is offline
post #10 of 12 Old 05-29-2016, 06:56 AM
Liked: 2224
No the 893 XO checked out perfectly. Well, i had one value that was slightly off but nothing out of normal tolerances. I took apart the 1299 while i was at it and because i saw this thread and think i wrote down the priorities wrong. Thw 1099 has mids reversed but this has tweeter reversed. So i think i had a brain fart while writing it.
luisev likes this.
post #11 of 12 Old 05-31-2016, 12:25 AM
Nexgen76's Avatar
Quoted: 727 Post(s)
Liked: 216
Did your come with a cut sheet ?
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is online now
post #12 of 12 Old 05-31-2016, 06:15 AM
vRAE's Avatar
Ryan,
This is what I got with my 1299
https://drive.google.com/file/d/0B2M...ew?usp=sharing
Andrew
vRAE is offline
