AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Microsoft UltimateTV PVR (https://www.avsforum.com/forum/41-microsoft-ultimatetv-pvr/)
-   -   Tinkering w/ UTV (https://www.avsforum.com/forum/41-microsoft-ultimatetv-pvr/1358466-tinkering-w-utv.html)
eea123 09-05-2011 07:39 AM
Picked up a 40Gb UTV off of fleabay for $10 w/free shipping this spring. I knew it would have a bad tuner, but didn't know they'd pack it in plastic mailing envelope. Front face broke, back panel dented enough that the printed circuit board for the power supply was flexed up.
I fed it a new face plate from a dead unit donated by a member here, and pressed the circuit board back in. Darn thing powered up. Fan was noisey, so I swapped that out. Only one tuner passed the self-test and my run of RG-59 to an upstairs bedroom proved to have too much loss to support it, but hey it works.
lgodave 09-05-2011 04:19 PM
Good to hear people can still find UTVs.
Sounds like a Cable Coupler, some Electrical Tape, a spool of RG-6, and a few RG-6 Cable Ends (after you feed/pull the cable though) gets you the enjoyment of UTV in the Bedroom.
Got some parts/spare UTVs here... should you need more replacement components.
eea123 09-07-2011 03:05 AM
Thanks for the offer. The run of RG-59 is in an upstairs wall, running all of the way to the basement. I can't remember if it has any bends or not.
I may just 4-way split / multiplex the home-run LNB feed before the existing 4-way multiplexer and feed it from an attic drop. My existing 4-way is non-powered, so it might be good to power the new one upstream?
My primary UTV is on my longest run, some 80'+ per cable and rings 92 and 89on signal strength. Would a second grounding block hurt? It would help add some cable play for the splice of my original 2 RG-6 runs from the LNB to the existing multiplexer.
lgodave 09-07-2011 11:54 AM
DirecTV insisted in stopping over and testing my setup before replacing one of my Dead Tuner Sony UTVs. They were kind enough to realize my Cascade of Multi-Switches in the basement hadn't done any favors for the Sony. (Even if when it was working the Reported Signal Strength seemed OK) So they swapped out two non-powered 4 port switches for a single non-powered 8 port. Also confirmed a diplexer I've upstairs is the cause of a low tuner reading. (So I might just use one of the newly freed up 4 ports to see if I can get a better signal reading to the UTV. Or possibly run a fresh cable run.)
The Tech was OK with leaving my Powered 8 port alone (tested as acceptable).
So +1 on the Powered switch here. I'm not certain, but I think many Switches have a screw for a Grounding connection if you decide it's needed. It should be helpful to "boost" the original non-powered 4-way (Particularly on a long run). Could also be nice depending on the model you get... To have the extra feed inputs/outputs.
keogh 07-09-2015 10:07 PM
upping post count
upping post count.
keogh 07-09-2015 10:08 PM
dgs
dfhgf
hfnfgf
keogh 07-09-2015 10:09 PM
gfhgf
jhgjfk
dgjhd
hgfhdghf
keogh 07-09-2015 10:10 PM
hdfgfd
dgdsfhgdhg
fhjfj
fjdfhhf
kjfmhgk
srfrdan 10-13-2015 02:44 PM
just to let u know theres not much channels left working on the old sets prior to 2003 0before u hookup and pay for service and attempt repairs.
twilburn 10-28-2015 12:16 PM
I had 2 fully working units until a few weeks ago. At least they were working when I turned them off in '07. I offered them here on the forum with all the original accessories and packaging if anyone wanted them. Sadly there were no takers so they went to eWaste. RIP UTV!
lgodave 12-11-2015 07:14 AM
:( RIP UTV... Sorry I missed it. Haven't tinkered with my UTVs for a while. But with the Genie randomly acting up it'd be nice sometimes if I still had a couple UTVs connected as Standby.
eea123 03-09-2016 04:37 AM
Good to see the forum still kind of alive.
lgodave 03-09-2016 05:33 AM
My Genie seems to have Stabilized recently (regular firmware/OS updates play a part I suspect). But still miss the "simple" things that UTV got right and while Genie does most of them it has to layer it behind a few extra keystrokes or convoluted menus. Also like UTV in the loss of Features over time. Having various Internet features that Directv decided to takeaway unexpectedly. Just like UTV... there is plenty of potential under the hood... if only we could use it all.
DavidinCT 03-09-2016 05:31 PM
I still have one here, sitting in a stack of old AV gear.... sigh, I should sell it....if any one wants it...You can even have my old Simpsons episodes that were on the drive when it got shut down for the last time :-\
G_Moore 03-10-2016 06:47 AM
I still have one UTV running and using it daily.
Since you can no longer download from MSN, when they go down that is it.
eea123 05-12-2016 05:02 PM
Man, kinda sad.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
