Matching SVS ultra center with Kef Q150 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By SouthernCA
  • 1 Post By Ed Mullen
post #1 of 3 Old 09-23-2019, 01:25 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 8
I know tonality and timbre are talked about a lot when setting up your front three speakers but is there a remote chance that I can match my Kef Q150 bookshelves with a SVS Ultra center? Thanks !
m001john is offline
post #2 of 3 Old 09-23-2019, 08:21 PM
Quoted: 956 Post(s)
Liked: 288
Why would you like to do that. Most likely it won't match. And that will show the most when you use them to play multichannel music. Not as much during movies as most sound comes from center channel in an HT set up
Ed Mullen and m001john like this.
SouthernCA is offline
post #3 of 3 Old 09-25-2019, 09:03 AM
Ed Mullen's Avatar
Quoted: 340 Post(s)
Liked: 780
Agree with above - I would use another Q150 if it will fit - then you will have perfect timbre match and voicing across the front stage. This will be the most cost-effective solution.
If you want to migrate to the Ultra Center, then I would also recommend the Ultra Bookshelf for a timbre match.
m001john likes this.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
Reply SVS Community on AVS Forum®
