White noise normal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-02-2020, 08:21 AM - Thread Starter
Liked: 0
White noise normal?
I just purchased two PB2000s and they both seem to make a white noise/hissing type sound when idle. Even disconnected from the avr the only way to get it to stop is to kill the power, it doesn't return when powered back on until it's been used. One also seems louder than the other.
Spyle311 is offline
post #2 of 3 Old 03-04-2020, 07:02 AM
Ed Mullen's Avatar
Quoted: 566 Post(s)
Liked: 1152
A faint white noise at idle is normal - it should only be audible with your ear near the subwoofer - and not at the main listening position.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #3 of 3 Old 03-05-2020, 02:20 PM
Theheadsn's Avatar
Quoted: 122 Post(s)
Liked: 62
It means your power from the outlet is "dirty". Do you have anything else running in the house that would take a lot of juice? How old is the wiring? Is it properly grounded? Try adding a power conditioner and see if it makes a difference
Theheadsn is online now
Reply SVS Community on AVS Forum®
