Channel Master DVR+ Owners Thread - Page 272 - AVS Forum | Home Theater Discussions And Reviews
 4492Likes
post #8131 of 17444 Old 04-23-2015, 12:20 PM
P Smith's Avatar
Quoted: 1147 Post(s)
Liked: 530
It's never ending promises !
P Smith is offline
post #8132 of 17444 Old 04-23-2015, 12:32 PM
LenL's Avatar
Location: Randolph, NJ, 725' above sea level, 30 miles west of ESB
Quoted: 471 Post(s)
Liked: 339
What should be even more alarming is they can't talk about it.....when you can't talk about something it must mean what? Seems they could talk about it at one time and now they can't.
LenL is offline
post #8133 of 17444 Old 04-23-2015, 12:35 PM
Kelson's Avatar
Quoted: 2316 Post(s)
Liked: 1430
Don't forget, CM is about a lot more than just the DVR+. There is nothing in that statement that implies the new opportunity they have diverted resources to has anything to do with the DVR+.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #8134 of 17444 Old 04-23-2015, 01:14 PM
P Smith's Avatar
Liked: 530
and don't forget - they are just a middleman between e* and customers; they would reproduce only what e* will say ...
P Smith is offline
post #8135 of 17444 Old 04-23-2015, 04:01 PM
jericko76's Avatar
Quoted: 154 Post(s)
Liked: 71
Originally Posted by pachinko View Post
On the CM Facebook page today:
Here is a more recent update:
Channel Master Wowza! Ok, here's some things that we actually CAN say. When it comes to software updates, keep in mind that your DVR+ is an operator-quality DVR. It's got a Linux-based closed system and an advanced Broadcom chip. It's every bit as powerful as the Comcast X1 or DISH's Hopper. So from a software standpoint we can't compare it to streaming devices like Apple TV or Roku, etc. DVRs are touchy, complicated animals! If we rush updates or try to do several in a short time frame, we could run the risk of introducing bugs. And the amount of man-hours that go into a DVR sofware update are generally 10 times what goes into, say, a mobile app or smartphone update. Your software updates are thoroughly tested in a closed Beta environment for weeks before you get them - cuz we want only the best for you guys. The DVR+ is capable of SO many things, and we're truly just getting started. The added value you guys will get over time with this product is just amazing. And, thank you Craig for putting it so well when we couldn't... yes, our current negotiations preclude us from launching what we already have. Now we've probably said too much!
pachinko likes this.
jericko76 is offline
post #8136 of 17444 Old 04-23-2015, 04:20 PM
Quoted: 1129 Post(s)
Liked: 459
That is a very strange paragraph.
JoeKustra is offline
post #8137 of 17444 Old 04-23-2015, 05:00 PM
pachinko's Avatar
Quoted: 1022 Post(s)
Liked: 560
And another comment today, by CM, on their facebook page:
Our Beta program (U.S. and Canada) was set up nearly two years ago and has remained closed. If we open it for expansion, which we've talked about, the first place we'll go is this Facebook page! You guys are the power users!
Power Users? I suppose they are just playing to the crowd on their facebook page, but I see no comparison between the facebook commenters, and the many contributors to this thread. Just my 2 cents worth!
JHBrandt, Donald1800 and jericko76 like this.
pachinko is online now
post #8138 of 17444 Old 04-23-2015, 06:33 PM
fshagan's Avatar
Quoted: 454 Post(s)
Liked: 213
The Facebook page is full of people happy with the DVR+ while here there are people complaining about bugs. If they were smart, they would use people complaining about bugs in their beta program for two reasons: 1) they are likely to find other bugs that need to be fixed because they look with a critical eye and 2) the NDA would get them to shut up about the bugs here! Not sure which reason is more compelling to them
I'm not sure what the other opportunity with a short window of opportunity could be, and it might be on the antenna side rather than the DVR+ side. It could be anything, like a merger, buyout, or a program deal with Sling or something of that nature.
fshagan is offline
post #8139 of 17444 Old 04-23-2015, 07:21 PM
Sandman905's Avatar
Quoted: 29 Post(s)
Liked: 34
Originally Posted by blakepro View Post
Is your DVR+ Connected with wifi or ethernet? I'm just curious if we can narrow this problem down to certain connection types. I use a wired connection and have never experienced this particular glitch.
I'm using a wired connection and I've experienced this several times.
Sandman905 is offline
post #8140 of 17444 Old 04-23-2015, 09:08 PM
Quoted: 20 Post(s)
Liked: 2
Seagate SRD00F2 Drive (2tb) won't work
A friend just bought a Seagate SRD00F2 (2tb) drive for his DVR+ and it doesn't work. I brought it home and plugged it into my own DVR+ and experienced the same issue. Very frustrating that a run of the mill 2tb drive by ChannelMaster's seemingly favorite hard drive manufacturer doesn't work.
Plug in the drive. It says that it sees the drive and asks if you'd like to use it instead of the internal device. You say yes and it says it will need to .. oh, format, prepare, whatever it says. You say yes. It then goes to a screen that says "Installing USB Storage Device - The detected device will be used for DVR storage. Do you now wish to install this as a DVR storage device?" But the only prompt is the CANCEL prompt. There's no OK prompt to choose and no progress indicator showing anything happening. If you do nothing then in about 30 seconds or so it times out and defaults to cancel. The device is not used, and the internal device is still active.
I plugged the drive into a Windows 7 machine and it sees the drive just fine, including the few "utilities" that Seagate puts in the root. It's a 1863.01 GB NTFS partition. I'm thinking about nuking the partition and then trying it again to see if DVR+ will reformat.
t_f_s is offline
post #8141 of 17444 Old 04-23-2015, 09:25 PM
Quoted: 20 Post(s)
Liked: 2
No joy. Same issue. Deleted the partition on a Windows 7 machine and then inserted the drive back into DVR+. It sees it and asks if I'd like to use it. Says it needs to be formatted (same as it said before - no difference). But it just sits there with only an option to cancel. Then times out. Nuts!
Edit: And just to complete the circle. Plugged it back into Windows 7. Showed as unpartitioned space. Repartitioned and formatted NTFS. Copied root files back in place from the backup I made. Works like new.
Darn you ChannelMaster! This is the only consumer device like it I've ever heard of that this persnickity about liking one hard drive and not another drive which is all but identical.
t_f_s is offline
post #8142 of 17444 Old 04-23-2015, 09:40 PM
pachinko's Avatar
Liked: 560
See post 7927 by Mitchum at 03-16-2015, 02:13 PM. The discussion actually starts at post 7909, but 7927 pretty much says it all about some 2TB drives on the DVR+.
post #8143 of 17444 Old 04-24-2015, 04:35 AM
P Smith's Avatar
Liked: 530
CM is just plain does cheating us!
The DVR's FW do running less then 10 task simultaneously, it is not that much more complicated then modern smartphons especially these whar does play or record 4k video.
Talking about beta testing - it's PATHETIC!!! Any participant here knew that.
What is posted on FB done marketing ppl. I do trust not to one word from them.
LenL likes this.
P Smith is offline
post #8144 of 17444 Old 04-24-2015, 05:32 AM
Pete-N2's Avatar
Quoted: 138 Post(s)
Liked: 61
CM or E*?
Pete-N2 is offline
post #8145 of 17444 Old 04-24-2015, 05:32 AM
Kelson's Avatar
Liked: 1430
They are pandering to their sheep. I doubt they pay much attention to this thread. They don't even have a support forum on their own website. Their Facebook page is the visible outlet they can control and as P.Smith has noted, it is primarily a marketing tool -- they say nothing of substance on it but just enough to keep people hanging on, and hoping.
LenL and Donald1800 like this.
- kelson h
Kelson is offline
post #8146 of 17444 Old 04-24-2015, 06:34 AM
jericko76's Avatar
Quoted: 154 Post(s)
Liked: 71
I have run into quite a few issues getting certain SSDs to work in some of my Linux servers at work. Try running Diskpart in Windows on the drive before attaching it to the DVR+, but be careful as you can wipe one of your main Hard Drives
  1. On the command prompt type diskpart and answer to any possible UAC prompt.
  2. On the new diskpart prompt, type list disk. Note the Disk ### column.
  3. Type, select disk ### (with ### being the partition you wish to delete.
  4. Finish by typing, clean.
This will wipe the drives and any hidden partitions Windows can not see. Useful on SD cards Android has carved up into hidden partitions as well.
post #8147 of 17444 Old 04-24-2015, 08:04 AM
Quoted: 20 Post(s)
Liked: 2
Too late. I took it back to his house last night with the NTFS partition back on it and overnight started a 800 gig data copy from his existing external (backup purposed) WD 3TB USB drive to the 2TB Seagate drive. Once that data copy is done I'll switch the roles of the 2TB drive that the DVR+ doesn't like, and the 3TB Western Digital drive that the DVR+ will most likely accept.
By hook or by crook!
t_f_s is offline
post #8148 of 17444 Old 04-24-2015, 08:08 AM
JHBrandt's Avatar
Quoted: 2976 Post(s)
Liked: 1442
Thanks for posting the model. This is a known bug with some Seagate 2TB drives but I don't think the earlier posters identified the specific model to avoid. Most 2TB drives, including Seagate drives, have been reported to work OK; but if we don't know which one doesn't work, the only remaining option was to avoid all Seagate 2TB drives just to make sure we don't get stuck with the "bad" model.
JHBrandt is offline
post #8149 of 17444 Old 04-24-2015, 09:42 AM
Charles R's Avatar
Liked: 882
I always recommend doing a list disk after the select disk and looking for the asterisk... that way you can verify you didn't have a typo.
| 125" Projection | 5.2.4 Audio | Shield TV | CoreELEC/ODROID-C2 Kodi Media Client | Ubuntu/ODROID-XU4 NAS/Server | 65" OLED TV | TiVo | Shield TV | Fire TV 4K |
| Water cooled Threadripper & Radeon VII, NVMe PC - 43" 4K IPS Panel |
Charles R is offline
post #8150 of 17444 Old 04-24-2015, 11:28 AM
JHBrandt's Avatar
Liked: 1442
And as a bonus, he'll get slightly more storage space for his recordings!
JHBrandt is offline
post #8151 of 17444 Old 04-24-2015, 12:08 PM
dishrag2's Avatar
Quoted: 61 Post(s)
Liked: 43
On the CM Facebook page today: "...Right now we're working on a possible opportunity that popped up unexpectedly with a short window. In order to take advantage of this, we've had to place the Linear rollout on temporary hold. There are very good reasons for this and we wish we could tell you more but we just absolutely cannot talk about it! If all goes well, you'll be more than pleased with the update when it comes out."
-->This tells me that their Linear offering will be extra great due to this delay...like, ability-to-record great! If, a month from now, this ends up not being the case, I am going to be really PO'd.
dishrag2 is offline
post #8152 of 17444 Old 04-24-2015, 12:48 PM
Charles R's Avatar
Liked: 882
You purchased this box based on some promise that might not be met? I thought everyone learned that lesson a long time ago...
wizwor and MKS13 like this.
post #8153 of 17444 Old 04-24-2015, 04:08 PM
Quoted: 20 Post(s)
Liked: 2
You're very welcome. Just to clarify if there's any new folks lurking... the "bug" is not in the hard drives but in the DVR+ and its inability to use many widely available external hard drives. I doubt CM refers to it as a bug, but it sure is a severe weakness.
t_f_s is offline
post #8154 of 17444 Old 04-24-2015, 06:16 PM
JHBrandt's Avatar
Liked: 1442
I'm not sure the word "many" is fair ... AFAIK the bug you encountered only occurs with certain models of Seagate 2TB drives. If anyone has experienced this with a WD or Toshiba drive or any drive of another size, they haven't mentioned it here.
I do think the term "bug" is correct, though; although I doubt CM would publicly admit it, since doing so could oblige them to fix it. Hopefully they'll fix it anyway, then they can admit it was indeed a bug.
In contrast, the 2.2 TB limit is sort of the opposite. It applies to any drive over that size, so it's a much bigger issue - but you could reasonably argue that strictly speaking, it isn't a "bug."
artisticimaging likes this.
JHBrandt is offline
post #8155 of 17444 Old 04-24-2015, 07:15 PM
MKS13's Avatar
Quoted: 92 Post(s)
Liked: 82
CM selected Seagate drives for use with the DVR+, in particular the 1TB and 3TB drives and they support the ones that they have recommended. (yes I know of the limitations with the 3TB drive)
They have stated that they do not support any other manufactures drives.
They have made it known that there could be problems with the 2TB Seagate drives, and recommend it not being used, and it has been endlessly reported on this thread.
I took a chance on a Toshiba Canvio 2TB drive and it's working fine. Purchased it from Sam's Club for $90 and it came with a 32GB flash drive. If it hadn't worked it would have been my problem not CM's.
The DVR+ is what it is, not what everyone thinks or wants it to be. BUT.. I guess it's fun to wish and complain.. EVEN if you don't own or use one..
See.. now I feel better..
MKS13 is offline
post #8156 of 17444 Old 04-25-2015, 11:59 AM
badsede's Avatar
Seagate 2TB and cloning
We just got a 2TB Seagate drive (STBX2000401) and it works perfectly, so that one can be excluded from the problematic list of 2 TB drives.
A couple of notes on migration/cloning to the new drive.
I tried the copy method first (let the DVR+ format the new drive, connect both drives to a computer with ext3 access, copy over files) but it didn't work. The drive just came through as empty afterward
I then tried Clonezilla to do a whole drive to whole drive clone. It worked great, except the it did not expand the recordings partition, so I still just had a 500GB drive to use. I'm just not facile enough with linux to figure out the right settings to make it expand the recordings partition to fill the drive.
So then I let the DVR+ format the new drive and did a partition to partition clone with clonezilla. Unfortunately, the DVR+ created a slightly smaller 1 GB "info" drive on the 2TB than it had on the 500 GB, so Clonezilla couldn't do the clone on that partition, just the recordings partition. Again, I don't know linux well enough to get Clonezilla to ignore the discrepancy.
Ultimately, the method that worked for me was that I let the DVR+ format the new drive. I used Clonezilla's partition to partition function to clone the recordings partition. Then I manually copied the files on the info partition. It was hackneyed, but it worked. I don't know why the manual copying method didn't work the first time. If I were to do it again, I would give the manual copy one more try before going through all the rigamarole that I ultimately went through.
A final note on Clonezilla. If you have attached your DVR+ drive to a computer, your computer might add a GPT to the MBR. If it does, then Clonezilla won't work. Clonezilla tells you how to destroy the GPT and keep just the MBR. I did that with no ill effect.
badsede is offline
post #8157 of 17444 Old 04-25-2015, 02:13 PM
qz3fwd's Avatar
Quoted: 320 Post(s)
Liked: 136
It sure seems like a bug. I would guess that they are using a really old linux kernel which does not suport partitions/drives over 2.2 TB? They should be competent enough to bring the OS up to current levels and enjoy all the benefits it brings along. Apparently not though. I meam really with 8TB drives avaliable, being limited to 2.2TB is kinda pathetic considering video takes up more space than just about any other application a consumer would typically used a hard rdrive for.
qz3fwd is offline
post #8158 of 17444 Old 04-25-2015, 04:05 PM
Zonker007's Avatar
Quoted: 79 Post(s)
Liked: 31
How long until the release? 2 Weeks!
Originally Posted by Kelson View Post
Just to be clear. It's going to be 2-3 weeks before you hear from them again on the subject. That should stir up the hornets on their facebook page.
Is anyone surprised?
As I predicted... just like the movie the Money Pit - 2 Weeks!
https://www.avsforum.com/forum/42-hdt...l#post33144953
Zonker007 is offline
post #8159 of 17444 Old 04-25-2015, 04:57 PM
JHBrandt's Avatar
Liked: 1442
You could argue it either way. It's not a "bug" in the technical sense of a programming error, but it is a "bug" in the practical sense that large HDDs don't work as a reasonable user would expect.
But whatever you call it, I agree it's unacceptable and should have been addressed before CM even thought about selling 3 TB drives for the DVR+. But it wasn't, so now they need a fix that won't require reformatting, and losing your recordings, to reclaim unused space on large HDDs. We discussed some possible solutions earlier, but just adding support for >2.2 TB partitions isn't enough anymore.
JHBrandt is offline
post #8160 of 17444 Old 04-25-2015, 05:34 PM
Aleron Ives's Avatar
Quoted: 1870 Post(s)
Liked: 1670
They're using MBR instead of GPT, and the 2TiB partition size limit is one of MBR's defining characteristics. It's not a bug in the sense that MBR is working properly within the limitations of its specifications. It's a bug in the sense that CM lies in its product advertising by saying that you can use a 3TB drive to increase your storage capacity by 50% over a 2TB drive, when in reality you can't do that, because the DVR+ won't use all the extra space that a 3TB drive provides. If CM had just been honest by saying that 2TB was the maximum supported drive size, then all would be well, at least as far as false advertising concerns go.
Aleron Ives is offline
Reply HDTV Recorders
578 , 999 , Channel Master , dvr+ , maintanance restart , maintenance restart , P552UI-B2 , vid posts 576/578 , vizio 4k
