Channel Master DVR+ Owners Thread - Page 563 - AVS Forum | Home Theater Discussions And Reviews
 4252Likes
post #16861 of 16899 Old 11-08-2019, 12:49 PM
mellaby1's Avatar
I had to refresh my guide also. It's only goes out to Nov 20.
mellaby1 is offline
post #16862 of 16899 Old 11-08-2019, 02:19 PM
Arenal04's Avatar
Quoted: 139 Post(s)
Liked: 84
You've probably noticed this by now, but once CM stopped using Rovi for guide info, 11 to 12 days has become the new norm. When it's working...
Arenal04 is offline
post #16863 of 16899 Old 11-08-2019, 05:36 PM
JHBrandt's Avatar
Quoted: 2850 Post(s)
Liked: 1386
It's gotten a lot like the Windows Media Center guide: 11-12 days, with a lot of outages where it drops below a week.
BTW the WMC is going away completely in January, as it happens. I hope the DVR+ guide doesn't follow suit.
JHBrandt is offline
post #16864 of 16899 Old 11-08-2019, 05:48 PM
JHBrandt's Avatar
Liked: 1386
Oh, geez; how stupid!
Originally Posted by JHBrandt View Post
Channel Master TV "officially" ended some time ago. But if you had activated it before it ended, the few remaining channels had been working nonetheless.
Looks like that's no longer the case. Every CMTV channel just gives me an "Internet Channel Error" now. And the guide doesn't even show what the channels are, although if you try them the error message lists the channel's title, so the DVR+ still "knows" what they are.
Pandora's still working, so it's not a problem with my Internet connection.
This was expected, of course; and there wasn't much worth watching left on CMTV anyway, but it's still a bit of a disappointment. The colored and "Apps" (Home on the flat remote) buttons on my remote now have no useful function outside the DVR menu.
At least the Internet guide still works. Or does it? Mine only goes out to 5:30 AM on the 13th; hmm, I'd better try a refresh - we may be in real trouble here....
And, the way the firmware is written, you can't even deactivate CMTV now that there's no CMTV server, so I can't even take the now-useless channels off my guide!
I'm going to try a "custom" factory reset to reset only Internet Channel Settings; maybe that will do the trick....
Factory Reset in progress - please wait.
JHBrandt is offline
post #16865 of 16899 Old 11-08-2019, 05:56 PM
JHBrandt's Avatar
Liked: 1386
OK; it's rebooting now. Checking the guide....
No joy. Everything's still there, and of course it still doesn't work.
One thing that might work is a full channel rescan. (In the past, that has "unhidden" any Internet channels and/or apps in the process.) But I don't want to do that now.
Guess my only remaining option is to hide every Internet channel individually.
JHBrandt is offline
post #16866 of 16899 Old 11-08-2019, 07:37 PM
pachinko's Avatar
Quoted: 1007 Post(s)
Liked: 553
How about install a really old DVR+ version, then 135R? Maybe???
pachinko is offline
post #16867 of 16899 Old 11-08-2019, 07:46 PM
Liked: 1
Newbie question here, can I insert a 1TB (or larger) HD into a CM7500GB16? I have a 5 year old CM7500TB1 which I swapped out with a new HD, so I am somewhat familiar with the innards. My question specifically is can I remove or replace the 16GB with 1TB (or larger) HD, leave it in place (soldered or part of the board?) and add the 1TB HD using existing connections, "MacGyver" the HD external to be internal, or best to use the CM7500GB16 as is, purchasing external HD from Fry's or MicroCenter? I am anticipating the WMC changeover, or it being dropped entirely come January 2020 (WMC worked well for about 15 years on a HP Z565) Thanks, Dave
Dave's Q&A is offline
post #16868 of 16899 Old 11-08-2019, 10:04 PM
Liked: 1
Forgot to mention that I'm looking into purchasing a CM7500GB16 in addition to the one I already have. A 16GB unit is cheaper than a 1TB unit, looking at second hand used prices.
post #16869 of 16899 Old 11-08-2019, 10:54 PM
P Smith's Avatar
Quoted: 1092 Post(s)
Liked: 506
Arrow
Find my posts with pictures of the 16GB DVR'S main PCBA and read about adding internal HDD to it … should be in first 100 posts part of the thread...
I hope your intention related to SSD not HDD... SSD would be better choice: less power requirement and less heat inside
pilotart likes this.
P Smith is offline
post #16870 of 16899 Old 11-09-2019, 09:28 AM
JHBrandt's Avatar
Liked: 1386
If it weren't for the Internet program guide, I'd roll back to 114R since I don't have a 4K TV. 114R is a better match for what's still working on the DVR+ (no CMTV, no Sling), I'd get a one-button CC toggle and search (the green button), and I prefer being able to delete unwanted channels over hiding them (given that I can only have one of those choices).
I'd have to relearn how to navigate the (PSIP) guide, since 114R used the other three colored buttons for that function, but I'm sure I could get used to it again.
JHBrandt is offline
post #16871 of 16899 Old 11-09-2019, 09:42 AM
JHBrandt's Avatar
Liked: 1386
I had to refresh my guide also. It only goes out to Nov 20.
BTW, it still only goes out to Nov. 20 a day later.
TBH, 11 days isn't that bad. As long as it stays over a week, everything seems fine. But with 11 days, even a 4-day interruption in updates gets us down to the 1-week level, so there's less margin for error.
JHBrandt is offline
post #16872 of 16899 Old 11-09-2019, 01:39 PM
Liked: 1
Thanks P Smith, I found your teardown of the 7500GB16, but as I can decipher from yours and other postings, the board is not outfitted with a direct SATA connection as the 7500TB1 is (a hypothesis, due to lack of side by side comparison). But you mention installing a SSD (I agree, less mentioned issues), so you "almost" indicate that a 2.5 SSD can be installed in a 7500GB16. Without opening up my 7500TB1 (which is online / in use), would I find the same board design? I saw pics of the board with leads to where the HD goes, but terminate where they would connect the HD. Am I wrong about this? Or would I need to solder a HD connector onto the board? My recall of swapping HD's is that the HD rests in a bracket with the HD connector right there (took about 10 minutes, next time less than 5). Is this conversion modification worth my time & efforts, or shall I simply use the USB port with an external HD? Or "pay the piper" for a 7500TB1 when available and go from there? PS: went through the first 40 pages / 1200 posts, finding some valuable info here and there, with transferring CM7500 to Windows the most curious. Albeit rare, would like to save perhaps 5-10 recordings per year ... and now I know it can be done! January 2020 around the corner though, hoping CM7500 is the failsafe way until the "dust settles" with WMC.
post #16873 of 16899 Old 11-09-2019, 02:50 PM
Liked: 1
Found This / Hoping links transpose:
post #20 of 44Old 06-20-2017, 03:31 PM
pachinko
pachinko's Avatar
Quoted: 1005 Post(s)
Liked: 550
Originally Posted by tech1966 View Post
Does anyone know where I can get the internal SMD SATA female connector for the DVR+? I would like to have the HDD inside the unit to eliminate excess cable clutter. I hope someone cane answer this .
Click HERE for P Smith's post with information and photos of the 16GB model guts.
Click HERE for Iowanative's post with photos of the 1TB internal HDD model's guts.
I seem to recall reading somewhere that there are other electronic components that you will need as well. There's also a bracket to hold the HDD in place (click HERE for a sketch and a photo), although you can rig your own. I'm guessing, but @P Smith may know more about what you are trying to do. If you succeed, please describe everything in detail, including photos!
Edit 1 (added quotes, with links, below):
Four capacitors 10nF, one spare resistor 10K (just for self spinning the drive), SATA combo connector - all SMD; plastic holder (see my drawing).
There was my old post with pertinent info of restoring of required SATA components;
I took the SMD SATA connector from one of portable SATA enclosures.
Unfortunately that time FW of diskless DVR+ didn't work with internal SATA HDD and DVR+ model with HDD wasn't exist.
Like
DVR+ Lister for Channel Master DVR+ (copy recordings to a computer) .. How to copy all DVR+ recordings to another DVR+ USB HDD .. Make AVS Forum Links that work for all posts per page settings
Last edited by pachinko; 06-21-2017 at 08:23 AM. Reason: Added quotes from P Smith
So, does this answer my question? Add these and voila!?
"Four capacitors 10nF, one spare resistor 10K (just for self spinning the drive), SATA combo connector - all SMD; plastic holder"
Don't have these laying around, a trip to Micro Center or Fry's will do if so (Radio Shack now defunct) ... or seek out 7500TB1? Testing my competency in soldering correctly and which goes where!
post #16874 of 16899 Old 11-09-2019, 03:10 PM
pachinko's Avatar
Liked: 553
On 03-01-2016, Iowanative posted pics of the inside of the 1TB model (Click HERE)
pachinko is offline
post #16875 of 16899 Old 11-09-2019, 09:02 PM
OTA-DVR-guy's Avatar
Quoted: 198 Post(s)
Liked: 33
I have three Channel Master DVRs - two 16-gig units, and one old CM7000PAL. I have previously run them all entirely over the air, with tremendous success. I still run them OTA, but this past week added Ethernet cables to all three. On the two 16-gig units, the streaming channels work fine - I watched a Vudu program on each as a test. But the Rovi guide and the CM internet channels didn’t work.
I logged a ticket with CM customer support. Of course they told me that the internet channels no longer exist, and advised they could help me get them out of my list. My list is empty, so that’s not an issue.
They said the OTA guide provider is doing maintenance, and they hope that will be done by the morning of 11/13, at which time the OTA guide should download to my units.
Of course the CM7000PAL would only use it’s new internet connection for guide information, since that model has never had a software upgrade, and doesn’t do streaming channels like Vudu.
OTA-DVR-guy is offline
post #16876 of 16899 Old 11-09-2019, 09:31 PM
Liked: 1
Thanks pachinko, I placed Iowanative pics and davezats / P Smith's pics side x side in two different Windows, leading me to believe each the 7500GB16 & 7500TB1 boards are the same, however, the TB1 has the HD connection right there along with the mounting bracket. Using KISS theory & inadequate knowledge of parameters Channel Master uses, I'm better off finding a used 7500TB1 than to attempt such a procedure as I intended. Still, it looks possible, but why chance it for a few bucks. Thanks everybody for your inputs!
P Smith
P Smith's Avatar
Quoted: 1090 Post(s)
Liked: 505
OK, lets get technical info about its guts:
Engineering sample [DVT/PVT ?] posted by davezats:
Short BOM:
CPU: U1: BROADCOM BCM72131ZBKFEBA03G/TN1333 P22/313468 P3A
RAM:U3/U4: NANYA NT5CC256M116CP-D1 {2x512 MB DDR3? memory 256 Mx16bit}
NAND Flash: U6: SPANSION ML02G100BHI00/327BB407 A [SLC NAND Flash parallel 3/3.3V 2Gbit 256Mx8bit 20 nS]
Serial Flash: U7: WINBOND 25Q64FVCIP/1222/6205/6540 [3V 64M-BIT SERIAL FLASH MEMORY WITH DUAL /QUAD SPI & QPI]
Flash: U10: KINGSTON 2400096-004.A00G/1318 2552971/KE4CN4K6A {16 GB ?}
TUNER:U15/U19: MXL603/52322.22 http://www.maxlinear.com/press-release-07-23-12/
DEMOD: U11/U14: MN88436/335P4123 http://www.semicon.panasonic.co.jp/e.../dtv_frontend/
Note: info in square brackets taken from mfg sheets, in {} - suggestions.
Photos of production device, to dismantle it just unscrew 8 screws at bottom:
Notes:
- production PCB has green color
- production DVR+ has BUILD CONFIG "ABBB" ; engineering sample [was it PVT ?] - " AKF"
HiRes pictures:
K77_PCB_1 642k .JPG file K77_PCB_2 1704k .JPG file K77_PCB_3 1702k .JPG file K77_PCB_4 1702k .JPG file K77_PCB_5 1705k .JPG file K77_PCB_6 413k .JPG file K77_PCB_7 1719k .JPG file K77_PCB_8 1711k .JPG file K77_PCB_9 1717k .JPG file K77_PCB_A 1715k .JPG file
ID: 74734 Click image for larger version
ID: 74735 Click image for larger version
ID: 74736 Click image for larger version
ID: 74737 Click image for larger version
ID: 74812 Click image for larger version
ID: 74813 Click image for larger version
ID: 74814 Click image for larger version
ID: 74815 Click image for larger version
post #16877 of 16899 Old 11-10-2019, 12:00 AM
Greasemonkey's Avatar
Quoted: 551 Post(s)
Liked: 295
If you have never had them connected to the Internet before, make sure you have the latest and final firmware upgrade installed on all your DVR+ units. It's v135R, and the Internet guide--no longer Rovi, won't work with any other FW version.
Greasemonkey is offline
post #16878 of 16899 Old 11-10-2019, 12:05 AM
Liked: 1
Sorry to bring ATSC 3.0 format to the board, but it appears that 3.0 will render ALL CM tuning devices (and all others) obsolete once implemented. My take on this is once OTA broadcasting is changed over from 1.0 to 3.0, broadcasters will have 5 years transmitting both 1.0 & 3.0, then we'll need tv's & recorders that have new 3.0 tuners, as 3.0 is not backward compatible with 1.0, what is used today. So much for my hunt of a 2nd CM7500TB1 if the tuners go obsolete. 4K is on the way, with 8K not far behind ... that's progress / every age has it's era (another reason to be glad I'm old, I've seen enough!).
https://www.atsc.org/newsletter/atsc...here-we-stand/
645824 likes this.
post #16879 of 16899 Old 11-10-2019, 03:44 AM
Quoted: 198 Post(s)
Liked: 33
Thanks. When I try to do a software upgrade, it says Unable to download, Unknown error, Latest software detected. But when I check Version info, it is 134R (0.5). How do I get 135R downloaded?
I reported this error to Channel Master Customer Support, and they said it only means that the latest software version is installed. But we didn’t discuss specific version information.
However, you referred to “firmware”. Would there be a different process to updating firmware than software?
post #16880 of 16899 Old 11-10-2019, 06:28 AM
P Smith's Avatar
Liked: 506
here FW is equal SW
P Smith is offline
post #16881 of 16899 Old 11-10-2019, 10:29 AM
richart's Avatar
Quoted: 186 Post(s)
Liked: 79
UPDATE: The default factory reset seems to have resolved the problem I was having.
_______________
DVR+ Dies When Scrolling Channel Guide
Recently my DVR+ is exhibiting some strange behavior. When watching live TV and scrolling the channel guide a line at a time or a page at a time, the TV screen will go blank gray with no audio and the DVR+ is completely unresponsive to the flat remote. This had not happened when playing back any recordings.
I have tried both a warm boot and a cold boot and the problem still occurs. The only change I have made in recent months is that I moved the unit from one room to another. In the new location there is no wired internet connection so I installed the Channel Master wi-fi adapter that came with my unit when I first purchased it.
For my next step, I plan to:
..unplug the DVR+ power
..disconnect the external hard drive
..disconnect the wi-fi adapter
..repower the DVR+
..perform a default factory reset
..reinstall the external hard drive
..reinstall the wi-fi adapter
If that does not work, I suppose the next step is to replace the external hard drive. I seem to recall some comments that a hard drive going bad will cause the DVR+ to lock up. The hard drive is a Toshiba unit (a model recommended by Channel Master) that is now about five years old. It may have reached its end of life.
Any other thoughts?
richart is offline
post #16882 of 16899 Old 11-10-2019, 01:17 PM
Quoted: 198 Post(s)
Liked: 33
Let me tell you what I learned the hard way about external hard drives on Channel Master DVR’s. Many of you probably already know this, but for the sake of those who may not...
No matter what brand of hard drive you purchase, there are two ways they can “fill up”.
Obviously they can get to 100% on used space.
But they can also max out on number of files. My testing and research indicate that that number is roughly one thousand files. Once I discovered that, I found out all of the old drives I thought had gone bad, are now suddenly reusable again. I have used Seagate, Western Digital, and of course the fan favorite Toshiba (both the 1TB an 2TB varieties). The way around this problem is to double up on recordings. If I want to record several shows in a row, I do a manual recording to get them all into one file, and then rename it to something descriptive.
Prior to discovering the above, all of my drives would get to somewhere between 40% and 60% full, after which all recordings would error out. No longer could you write anything to the drive, but you could still watch what had been previously recorded, and could delete previous recordings. I have since deleted a lot of little files from them. I am now recording big (longer in time) files, and consequently I am able to make the percent full rise above where it had previously maxed out.
post #16883 of 16899 Old 11-10-2019, 02:58 PM
LensClock's Avatar
Quoted: 33 Post(s)
Liked: 29
Hard to get to 1000 on a 1TB if all you tape is 30 & 60 minute shows...
The title says it all - your experience got me curious as to how close I am to that ~1000 file limit.
The answer: The way I record, and with my 1TB drive, I'll never get near that limit.
I am currently at 95% capacity, about normal for me.
My list of recordings is 144 lines long (~18 screens @ 8 lines/screen).
When I add up the number of recordings on all the lines that have multiple recordings, I get 379.
Added to 144=523 recordings total (actually less than that, since I am double-counting each line that has multiple recordings).
So I am a long ways to 1000 recordings, and the way I use the 1TB drive on my DVR+, I'll never even get close.
That's because 99% of my recordings are 30 and 60 minute shows.
And if you record longer shows, like Ken Burn's documentaries, sports and/or award ceremonies, your recording count will be even smaller!
So, I'm assuming that this recording limit is only an issue with 2TB drives.
(Unless you are very fond of recording 2-reel Three Stooges shorts.)
Do you really need to quote the entire post in your reply?
Channel Master DVR+, LG Plasma, Samsung UN60J6200 LED, Yamaha HTR-5860 & RX-V595 AV Receivers, SiriusXM, Infinity RS-9's, Klipsh 12" & Polk 10" SubWoofs, Sony STR-DE635, EPI 100's, Polk RTi8's
LensClock is offline
post #16884 of 16899 Old 11-10-2019, 03:20 PM
Quoted: 551 Post(s)
Liked: 295
You can download all the versions using the link in this post:
Previous DVR+ FW versions
Use a flash drive formatted as FAT, not NTFS. Make sure the FW file is in the root directory. Disconnect any external hard drives or dongles that are plugged into the USB ports. I don't remember if you plug the flash drive in then power up the DVR+, or if you can plug it in while it is already on. Once it starts, it's all pretty hands off until it finishes.
post #16885 of 16899 Old 11-10-2019, 04:18 PM
pachinko's Avatar
Liked: 553
Sorry your just now discovering this as it's been known, and mentioned, for many years. The limit is actually 999 as that's all the slots provided in the DVR+'s REI file (the file size is always the same size of 868,024 bytes). There's actually 1000 slots but the software does not use the 1st slot (no strm0000 files).
There is another limit that determines the maximum number of allowed Scheduled Recordings, and that is 54 (some think it's 55 but it's not, it's 54).
pachinko is offline
post #16886 of 16899 Old 11-10-2019, 10:05 PM
P Smith's Avatar
Liked: 506
I've seen the "strm0000" files on the HDD at PC screen when disconnect DVR from power during recording, after rebooting DVR with the drive the files never seen.
As to reaching file limit [999] related to number of recordings, DVR recording long show by chunks [2GB ?] so one long 1080i show with high bitrate could produce many files ...
P Smith is offline
post #16887 of 16899 Old 11-10-2019, 10:09 PM
fshagan's Avatar
Quoted: 442 Post(s)
Liked: 209
Looks like my DVR+ will no longer pass sound. Checked all the usual suspects - HDMI cable, HDMI port in TV, DVR+ settings (both the "stereo" and the more advanced audio setting), TV, antenna connections, and coax connection into the DVR+. reset, etc.
fshagan is online now
post #16888 of 16899 Old 11-10-2019, 10:14 PM
JHBrandt's Avatar
Liked: 1386
It's come up before. At this point the consensus seems to be that ATSC 1.0 isn't going away anytime soon. We probably have much longer than five years; that's just the minimum the FCC is guaranteeing.
There are a number of obstacles to widespread adoption of ATSC 3.0, including the lack of an FCC mandate for either stations or tuners (IOW, it's purely voluntary), competing technologies such as 5G, the lack of spectrum with which to make the transition, and the likely adoption of "digital rights management" schemes that will raise prices, narrow choices, and generally make ATSC 3.0 less attractive. (Who would want a DVR that couldn't skip commercials? Might as well just stream the content on demand.)
I used to be pretty worried about it, but now I believe ATSC 3.0 will "succeed" only as a niche market, a la HD radio. I'm following the development of the technology, but not letting worries about ATSC 3.0 stop me from buying ATSC 1.0 equipment.
artisticimaging likes this.
JHBrandt is offline
post #16889 of 16899 Old 11-10-2019, 10:19 PM
JHBrandt's Avatar
Liked: 1386
I've seen it too - my guess is that entry 0000 is used for buffering the channel being watched, so buffering still works even if you have all 999 recordings in use.
JHBrandt is offline
post #16890 of 16899 Old 11-10-2019, 10:23 PM
JHBrandt's Avatar
Liked: 1386
Ouch. I suppose the one remaining possibility would be using the DVR+'s optical audio output. You'd need an optical cable and an AVR that could accept it, but that still could be cheaper than replacing the DVR+.
JHBrandt is offline
Reply HDTV Recorders
578 , 999 , Channel Master , dvr+ , maintanance restart , maintenance restart , P552UI-B2 , vid posts 576/578 , vizio 4k
