Originally Posted by
JoeKustra
I call it the SNL virus. It has been a constant with SNL, but I saw it with The Tonight Show from last night. I'm going to guess that you are hitting play from My Shows. The condition does not happen if you right arrow on the program and then select Play. I saved SNL shows from earlier this year and they still have the problem. I can transfer them to another Roamio and they still have that BSC.
That said, my Roamio failed to get its update yesterday (once) and today (twice). I did a manual connection without any problems. Today I'm going to change my internet connection and see if there is any failure tomorrow.
This condition has been observed on TCF also.
Your guesses are usually pretty good, but not this time, because I never even knew that pressing Play from My Shows would do anything. Thanks for the tip!
It was happening after pressing Select on a series while in My Shows. Then again after selecting a show and pressing Select. If I recall correctly, when pressing Select on the Play option for the recording, play would begin immediately. Now, whatever I try, even on shows that exhibited this issue, there is no lag.
This same issue happened months ago after one of the TiVo updates, although the spinning circle appeared for only 5 or 10 seconds (as I recall). Lots of folks were complaining about it, so I did not try anything to fix it. At some point, maybe after another update, the problem went away.
Kelson
I experience that on occasion. It seems like the Roamio is caught doing some sort of system operation in the background that it can't push off. For me however, it is a 1-off event that occurs infrequently.
Your post did remind me that I can't remember the last time I may have rebooted any of the TiVo's in the house. I like to do that every couple months or so but sometimes it just slips by. I'm going to make a note to myself to reboot them all tonight. thanks
Yeah, I see the lag now and then too, always short lived, and not lasting for days. Definitely of little concern. This time, I thought the same thing as you, that the TiVo was busy doing something "important", but it kept it up for several days so that's unlikely. The TiVo did have trouble calling home during that time, and I had to reboot the router, modem, and TiVo. After that it was able to connect to the network, but the long lag continued.
The very first day after I got the TiVo, I had to call tech support because the darn thing quit connecting to the TiVo network. The guy had me Cold Boot it, and all was well after that. After that I've done a few Warm Restarts, but I think only to force an update at that time.
