Best and Easiest way to transfer DVR to blu ray or hard drive - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By JDLIVE
post #1 of 7 Old 06-13-2015, 06:42 AM - Thread Starter
Quoted: 24 Post(s)
Liked: 0
What is the best way to transfer stuff off of my dvr to another storage place like a blu ray or another hard drive?
filmkr27 is offline
post #2 of 7 Old 06-13-2015, 12:23 PM
Aleron Ives's Avatar
Quoted: 1871 Post(s)
Liked: 1670
Which DVR do you have? They're all different. The best ones will let you transfer recordings to your PC over your home network. Cable DVRs often don't let you do that, so you'd have to connect the DVR to a capture card with component cables to capture every recording in realtime one by one.
Aleron Ives is offline
post #3 of 7 Old 06-13-2015, 01:26 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 0
I have a directv and a also a verizon fios
filmkr27 is offline
post #4 of 7 Old 06-13-2015, 03:30 PM
Kelson's Avatar
Quoted: 2322 Post(s)
Liked: 1434
For the Verizon FIOS, buy a TiVo and get a FIOS cable card. FIOS does not protect the non-premium channels so you can do a network transfer of the recording from the TiVo using kmttg which strips off the .tivo wrapper and leaves a plain vanilla .mpg file that can be played on just about anything. You can then edit out commercials and store on a HDD and/or burn to a BD-R.
For DirecTV you'll have to buy a PC capture device. Their DVR is locked down.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #5 of 7 Old 06-15-2015, 09:13 AM
JDLIVE's Avatar
Quoted: 115 Post(s)
Liked: 64
Send a message via Yahoo to JDLIVE
Or you can get a network based cable card tuner such as the Silicon Dust HD Homerun Prime and you don't even have to "transfer" those recordings, they are already on the PC.
Referring to your FiOS content, obviously, not DirecTV.
Kelson likes this.
JDLIVE is online now
post #6 of 7 Old 06-16-2015, 09:13 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 0
Thanks, I hate that there isn't a simple technology like the videotape to preserve recorded tv
filmkr27 is offline
post #7 of 7 Old 06-17-2015, 07:36 PM
olyteddy's Avatar
Quoted: 537 Post(s)
Liked: 945
I've seen plenty of VCRs at the goodwill.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply HDTV Recorders
