DVR+ Lister for Channel Master DVR+ - Page 19 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Do you move DVR+ recordings to a computer (multiple choices allowed)
Yes, Windows 45 48.39%
Yes, Linux 11 11.83%
Yes, Mac 5 5.38%
Yes, Other OS 1 1.08%
No 35 37.63%
Multiple Choice Poll. Voters: 93. You may not vote on this poll
 104Likes
post #541 of 552 Old 09-19-2019, 05:41 PM
Quoted: 212 Post(s)
Liked: 48
Unhappy
Originally Posted by P Smith View Post
Seems to me it's possible (practically you can change anything - for PAL DVR I did a procedure/script for add movies from DVD files), but for episodes' flags... it would require change tables in NVRAM. Eg need to find EJTAG or DEBUG port to access EEPROM chip.
I could try to help you from EE standpoint, but I have only European "DVR+" eg HDT-610R, what have not the same HW.
Thanks. It looks like far too much trouble, so I guess I'll forget about it.
[Signature not found -- or just not clever enough.]
SirCrow is offline
post #542 of 552 Old 10-05-2019, 05:26 AM
Liked: 0
Need to format?
I've relabeled the external hard drive and Windows sees it but when I click on it to explore I get a message that I need to format the disk before I can use it. I don't want to do that because I assume that will wipe it. Am I missing a step? Thanks.
Joseph Desmond is offline
post #543 of 552 Old 10-05-2019, 08:36 AM
P Smith's Avatar
Quoted: 1112 Post(s)
Liked: 514
"relabeled" ? why ? You could damaged MBR
Reread @pachinko instructions in the thread from beginning ! You must FOLLOW them !
P Smith is offline
post #544 of 552 Old 10-05-2019, 02:07 PM
Liked: 0
I used the Ext2Fsd program to assign two letters to each of the external hard drive partitions, so to me they are relabeled. Now the PC can see them but says they need to be formatted. I am assuming that would wipe them so I didn't do it. Just wondering if this is a common problem and if there might be a solution; I didn't see it anywhere else in this thread.
post #545 of 552 Old 10-06-2019, 12:34 AM
P Smith's Avatar
Liked: 514
Well, you're going by a path of regular Windows user … do not continue it. Discard any request from the OS regarding the HDD.
After Ext2Fsd assigned labels (it is not re-labeled per se) run pachinko's program - forget about Windows for while
P Smith is offline
post #546 of 552 Old 10-07-2019, 04:00 AM
Liked: 0
Thank you. However, I got the same message about reformatting when I tried to select the drive from Pachinko's program through the drop down menu. The external works fine on the Channel Master and I do disconnect it through the device before physically disconnecting it. It's fine again once re-connected. Sounds like it's not a common problem, which does help to know.
post #547 of 552 Old 10-07-2019, 10:04 AM
P Smith's Avatar
Liked: 514
Make and post screenshot of the request here ...
P Smith is offline
post #548 of 552 Old 10-08-2019, 05:37 PM - Thread Starter
pachinko's Avatar
Quoted: 1008 Post(s)
Liked: 553
I really would like to help you, but I just to have the time. What version of EXT2FSD are you using? I do NOT recommend the newer versions. Try the old version 0.64 (that's what I use).
Last edited by pachinko; 10-11-2019 at 06:36 PM. Reason: Wrong version Num - Should be 0.64
pachinko is offline
post #549 of 552 Old 10-20-2019, 04:46 AM
Liked: 0
Thanks all for looking at it. I was using ext2fsd64, and the partitions did appear in the directory with letters (screen shot attached). I would note in looking at the help/about menu I see that ext2fsd shows as not started while ext2fsd seems to be running (also attached). Not sure if that affected the functionality since it did assign letters to the two drives, but I still could not access the hard drive from the PC since the PC said I had to format.
Unfortunately, over this weekend I had to re-format the same external hard drive through the Channel Master so I lost all of the recordings I was trying to save. I got an error code on the drive and disconnected it through the CM menu, and then it would not reconnect without formatting. Too bad. But thank you to all who tried to help!
Name:	Annotation 2019-10-20 063806.jpg
ID:	2629616   Click image for larger version
Name:	Annotation 2019-10-20 063948.jpg
post #550 of 552 Old 10-20-2019, 05:43 AM
P Smith's Avatar
Liked: 514
Did you try run the Lister+ program or trying to use Win Explorer ?
P Smith is offline
post #551 of 552 Old 10-20-2019, 08:12 PM
Liked: 0
Yes, I tried both and they each said that the disc needed to be re-formatted. I could not access the contents of the drive.
post #552 of 552 Old 10-21-2019, 01:21 AM
P Smith's Avatar
Liked: 514
Cool a call for the master
Lister+ did ask for reformatting ?!!!
That's a case for pachinko's intervention here !
P Smith is offline
Reply HDTV Recorders
