*** Official - Tivo: Bolt *** - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 96Likes
post #481 of 495 Old 06-15-2019, 03:35 PM
bekindrewind's Avatar
Quoted: 287 Post(s)
Liked: 97
Originally Posted by bekindrewind View Post
OTA Bolt 500GB white, having issues with youtube app. Audio/video dropouts including lip sync issues till I lose signal and "Loading" appears. I switched IP carriers 3 months ago from AT&T 29Mbps to Xfinity 60Mbps using Netgear C7000 modem router. No problems when I had AT&T, but for the last month the youtube issue now with Xfinity. Which is strange because I went from 29Mbps to 60Mbps. Not sure it's related to Xfinity, because I don't have the youtube problem on my iMac or app in the tv which is using Xfinity. Just pointing that out. The youtube issue only happens with the Bolt. Same youtube program on my iMac plays fine. Called Tivo, went though all the settings in my AVR, TV and Bolt. Tivo can't find the problem. Bolt to AVR to TV, YouTube problem. Bolt to TV, youtube problem. Youtube app in tv plays fine, as plays fine on my iMac. So seems it with the Bolt, right?
Is the youtube app in the Bolt bad or do I have a bad Bolt? Tivo says nothing they can do about the youtube app. Did a factory refresh, no help.
Wanted to follow up and thank all those who participated in helping me. Seems I had a bad Bolt. Bad Bolt bad, lol. Tivo replaced the box with a refurbished one. All apps work fine now. Although, aka but, new issue came with the refurbished replacement. The fan noise is now very noticeable. Starts loud, fast speed, then slows down but still hear the noise, which is a combination of fan and electronic noise. I've done some reading about Bolt fan noise issue. Easy fix is take the cover off, unplug the fan from the circuit board, leave the cover off. Other option, replace the fan with a quieter one. I've ordered the recommended fan, Noiseblocker blacksilentfan XS-2. Two ways to replace the stock fan. Plug replacement fan into the factory plug where the orginal fan goes, same two speed situation. Or splice a usb plug in the XS-2 and plug it into the usb jack on the Bolt. Usb route, one speed, fan doesn't spin as fast as stock, but so quiet you can't hear it. Put case on.
happyness ;>)
bekindrewind is offline
post #482 of 495 Old 07-03-2019, 08:09 PM
dturturro's Avatar
Quoted: 33 Post(s)
I have several Bolts, Minis and one RoamiOTA. I see TE4.6 looks a lot cleaner than the old Hydra SW. I downgraded to TE3 a while ago on all boxes. If I upgrade now, will I lose any recordings?
dturturro is offline
post #483 of 495 Old 07-03-2019, 08:12 PM
krkaufman's Avatar
Quoted: 50 Post(s)
Liked: 24
You don't lose anything (recordings/settings) on the upgrade, just if/when you rollback (again). Hopefully you're fully versed on the shortcomings, in some opinions, of TE4.
krkaufman is offline
post #484 of 495 Old 07-04-2019, 04:16 AM
dturturro's Avatar
Quoted: 33 Post(s)
I know I didn’t like it when I first tried it. Has the interface gotten any smoother? The video I saw looked like it was a bit more intuitive, with my shows popping up on the left. Any current users have a pro/con list for TE4/TE3?
post #485 of 495 Old 07-10-2019, 10:22 AM
dturturro's Avatar
Quoted: 33 Post(s)
Apologies for cross posting, but I have an issue covering multiple platforms. I’m planning on changing from Verizon FiOS to Optimum by Altice for TV, Internet, and Phone, and I wanted to address some concerns before pulling the trigger.
TiVo
1. I have several TiVo Bolts and a Premiere box that require cable cards. I remember the original Cablevision Cable Cards were single stream and did not always mate well with TiVo. Has Altice/Optimum improved those cards?
2. On a related topic, has anyone had experience changing cards from Verizon to Altice/Optimum? Do you have any tips to make the provisioning go easier?
3. When I change service providers on the TiVo’s, will the season passes (SPs) update to record on the correct channel, or will I need to manually update each one? I know when I’ve moved SPs from my OTA to Cable Bolt, they have correctly selected ABC/CBS, etc.. but I haven’t changed actual video providers since TiVo stated allowing SP transfers.
Network
4. I had Optimum Online several years ago, and the speed dropped significantly at night. I’ve heard from some neighbors that this is no longer an issue now that Altice/Optimum added more nodes to our neighborhood. Is there a site that I could get true network performance for a specific area?
5. I currently use a Google Wi-Fi Mesh system for my routing and wireless coverage. Has anyone had issues using the Google system with Altice/Optimum?
Phone
6. I eventually plan on purchasing my own modem to reduce my monthly charges. In addition to the Google system, I also have 2 phone numbers for the house. What modem(s) work with Altice/Optimum, Google Wi-Fi and are capable of handling 2 separate phone lines?
Apple TV
7. Does Altice/Optimum have single sign-on with Apple TV?
8. Do any networks not allow Apple TV access with Altice/Optimum?
post #486 of 495 Old 07-10-2019, 12:16 PM
Quoted: 1099 Post(s)
Liked: 448
You can post here too: https://www.dslreports.com/forum/ool
dturturro likes this.
JoeKustra is offline
post #487 of 495 Old 07-10-2019, 09:24 PM
NxNW's Avatar
Quoted: 74 Post(s)
Liked: 80
Can I get a straight answer: as of July 2019 Does the Amazon app on the Tivo Bolt (non-Vox) "do" HDR?
Note 4K is not the same as HDR. 4K works, I get that. And I understand the hardware is theoretically capable of HDR support for all apps.
Also their support page at https://support.tivo.com/articles/Fe...UHD-Resolution specifically mentions Netflix and Youtube right now but does *not* mention Amazon..
Anyone had success with this yet?
NxNW is offline
post #488 of 495 Old 07-10-2019, 11:36 PM
tapokata's Avatar
Quoted: 17 Post(s)
Correct. The Amazon app will handle 4K source material, but does not process any flavor of HDR.
tapokata is offline
post #489 of 495 Old 07-11-2019, 12:09 AM
NxNW's Avatar
Quoted: 74 Post(s)
Liked: 80
Thank you for the prompt reply, but of course now I have to ask, has anyone had any success wih the other two apps mentioned (Netflix, YouTube)? For that matter has anyone ever seen any HDR come out of a Bolt? Ever?
NxNW is offline
post #490 of 495 Old 07-11-2019, 07:40 AM
tapokata's Avatar
Quoted: 17 Post(s)
I don't have a Netflix 4K upgrade on my account, so no experience with that. The TiVo YouTube app does not support HDR.
tapokata is offline
post #491 of 495 Old 07-11-2019, 08:54 AM
tcramer's Avatar
Quoted: 388 Post(s)
Liked: 203
My hunch is you will never see HDR out of the Bolt.
tcramer is offline
post #492 of 495 Old 07-11-2019, 11:00 AM
UHD Addict
aaronwt's Avatar
Quoted: 8952 Post(s)
Liked: 5728
???? I had HLG HDR from my Bolt, with the May NASCAR UHD broadcast on FiOS.
49TB unRAID1a--53TB unRAID2--70TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #493 of 495 Old 07-11-2019, 12:23 PM
tcramer's Avatar
Quoted: 388 Post(s)
Liked: 203
Oh I stand corrected. I just assumed we'd never see it.
tcramer is offline
post #494 of 495 Old 07-12-2019, 08:21 PM
NxNW's Avatar
Quoted: 74 Post(s)
Liked: 80
Still, waiting around for a stray NASCAR race is hardly the same as accessing, whenever you like, whatever UHD content you may have paid specific providers for. Every recent generation of Tivo has been billed as a cord cutters dream, an all-purpose streamer, One Ring to Rule Them All. But now I keep finding, one by one, the things I used to use it for (Xfinity on Demand, MLB) or things I had planned to use it for (HDR) are not supported. Pretty soon we'll be partying like it's 1999. Woo hoo: Pause Live TV!
NxNW is offline
post #495 of 495 Old 07-13-2019, 05:42 AM
Kelson's Avatar
Quoted: 2226 Post(s)
Liked: 1366
You are right, Tivo is not perfect. It doesn't do everything that everybody wants but, at least for me, it does more of what I want than any of the other boxes. For all the things it doesn't do that I want, I have a separate box. Unlike many others, I am not averse to changing the HDMI input on my AVR -- especially when all I have to do is press a button on my Harmony and it takes care of the rest.
Dave Vaughn, dturturro and jtrippe like this.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
Reply HDTV Recorders
