Channel Master Stream+ (pre-release & speculation) - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 287Likes
post #361 of 682 Old 01-15-2018, 06:09 AM
schneid's Avatar
Quoted: 83 Post(s)
Liked: 37
Here is another MicroSD to SD adapter:
https://www.newegg.com/Product/Produ...B&gclsrc=aw.ds
But do they work?
schneid is offline
post #362 of 682 Old 01-15-2018, 06:17 AM
P Smith's Avatar
Quoted: 1056 Post(s)
Liked: 492
Question
Originally Posted by fshagan View Post
Nothing direct to me so far. The only update I've seen is on this page: https://www.channelmaster.com/Stream_Plus_p/cm-7600.htm
damn ! another month of rumors and speculations ...
anybody catch its mfg model number ? I would try to tracking the cargo by discovering a bill of lading...
P Smith is offline
post #363 of 682 Old 01-15-2018, 06:18 AM
P Smith's Avatar
Liked: 492
But do they work?
usually the adapters working fine - it's just dumb plastic sleeve with pin to pin connection
P Smith is offline
post #364 of 682 Old 01-15-2018, 06:25 AM
schneid's Avatar
Quoted: 83 Post(s)
Liked: 37
Here's another. Amazon, prime shipping, and good rating. Wish I'd found this first:
https://www.amazon.com/Extension-Ada...A0C8D7886MP753
And another from Amazon like my original post. No ribbon:
https://www.amazon.com/dp/B0143QFXYO..._t1_B06X3Y4BBB
schneid is offline
post #365 of 682 Old 01-15-2018, 06:51 AM
flaquito's Avatar
But do they work?
Yeah, SD and micro-SD are pin-for-pin identical, it's just the physical size that's different. The only issue would be whether the adapter is able to slide far enough in to the Stream+, since the slot is a bit recessed. That's actually a really good idea, since this device doesn't need to be portable, and as you say, standard SD is a lot cheaper. Good suggestion!
pilotart likes this.
flaquito is offline
post #366 of 682 Old 01-15-2018, 07:26 AM
schneid's Avatar
Quoted: 83 Post(s)
Liked: 37
CM-7600
https://s3-us-west-2.amazonaws.com/d...Jan+9+2018.pdf
schneid is offline
post #367 of 682 Old 01-15-2018, 07:50 AM
P Smith's Avatar
Liked: 492
the PDF should be attached to first post ... anyway, to avoid broken URL I did upload the PDF here at https://www.avsforum.com/forum/42-hdt...l#post55482014
as to the "CM-7600" id, nay ... it's CM's model, not the mfg ... not gonna help in research
perhaps there is a white label at bottom with mfg's ID
P Smith is offline
post #368 of 682 Old 01-15-2018, 09:26 AM
mdavej's Avatar
Quoted: 3022 Post(s)
Liked: 1369
The microSD adapter is a great idea. I was actually trying to go a step further and find some conglomeration of adapters to go from microSD to USB in order to ultimately plug a USB drive into the microSD port. So far, no luck. As far as I can tell, the only adapters that exist only go the other way, plugging a microSD into a USB port.
mdavej is online now
post #369 of 682 Old 01-15-2018, 03:20 PM
kent2174's Avatar
Quoted: 46 Post(s)
Liked: 32
Don’t think I’ve seen this link posted yet from few days ago.
Not much new learned but nice article.
http://televisions.reviewed.com/feat...apple-tv-to-be
Paul210, mdavej, Ray77085 and 1 others like this.
kent2174 is offline
post #370 of 682 Old 01-15-2018, 04:04 PM
Ray77085's Avatar
Quoted: 177 Post(s)
Liked: 174
Thanks for your post. I found this to be very informative. My concern with the unit is, will it be able record movies and shows other than Over The Air channels ?
MY 5.4.4 SET UP (Dolby Atmos)
Onkyo TX-NR809, Denon X4200 (Klipsch-KF-28 mains),( Center KC-25), (side surrounds Primus P363), 2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs. 4 ea Over head in ceiling 8" speakers.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000. Samsung BD-8500 Blu-Player
Ray77085 is offline
post #371 of 682 Old 01-15-2018, 04:48 PM - Thread Starter
pachinko's Avatar
Quoted: 998 Post(s)
Liked: 546
Where you been, that URL has been on the first post for a week or so!!! FYI, I've been updating post 1 as things happen, even though eventually this thread will be replaced with a brand spanking new Stream+ thread (hopefully) to get rid of all the speculation.
pachinko is online now
post #372 of 682 Old 01-15-2018, 05:15 PM - Thread Starter
pachinko's Avatar
Quoted: 998 Post(s)
Liked: 546
Thanks for the article! One thing hiding as a caption of one of the pics is the statement "With a microSD card the Stream+ can record two shows at once and supports pause/rewind/fast forward." That's the first time I've seen "Fast Forward" mentioned (even though there is a button on the remote control). In all CM documentation, that wording is missing, making me an others wonder if they crippled Fast Forward to prevent commercial skipping. Still, this is not conclusive evidence, so we still have to wait for the Stream+ to meet the hands of an AVS member!
It will NOT record any streaming shows (see the article kent2174 linked).
post #373 of 682 Old 01-16-2018, 01:34 AM
Ray77085's Avatar
Quoted: 177 Post(s)
Liked: 174
Pachinko,
Do you think there could be work around something similar like in your signature ?
Ray77085 is offline
post #374 of 682 Old 01-16-2018, 06:28 AM
P Smith's Avatar
Liked: 492
Pachinko,
That would be Android hack !
P Smith is offline
post #375 of 682 Old 01-16-2018, 07:44 AM
therabbit78's Avatar
Quoted: 27 Post(s)
Liked: 5
As far as Fast Forward, that picture even shows 4X on the screen of the demo...which is basically fast forward at 4 times the regular play speed (or some equivalent). That looks to be from the CES event and not just some stock photo, so that is good news. That would be poor to showcase it like that and then strip that option away. So, I feel pretty confident we will see FF.
therabbit78 is offline
post #376 of 682 Old 01-16-2018, 09:42 AM
LenL's Avatar
Location: Randolph, NJ, 725' above sea level, 30 miles west of ESB
Quoted: 447 Post(s)
Liked: 318
Channel Master has a history with the DVR+ of making promises or alluding to enhancements that either never materialized or did not work as advertised.
So don't buy into all the hype from them and don't get too excited!
Marketing and selling something and then delivering are different skills!
LenL is offline
post #377 of 682 Old 01-16-2018, 12:51 PM - Thread Starter
pachinko's Avatar
Quoted: 998 Post(s)
Liked: 546
Pachinko,
If you mean being able to copy recordings to a computer where you would be able to do whatever you want with them (like you should be able to do with OTA), then probably not. What little I know about Android is what I've learned from this thread, and that doesn't look good. What I managed to do with DVR+ wasn't true hacking, rather it was simply reading data from unprotected binary files, with no decryption required.
And for hacking a way to record or copy streaming content, I wouldn't do that (at least not for public use) even if I could, not because I think it would be wrong, but because I value my freedom!
I hope you're right, and I think it would be a dumb move if the Stream+ doesn't FF, or if FF is crippled during commercials, at least on OTA content!
post #378 of 682 Old 01-16-2018, 11:32 PM
P Smith's Avatar
Liked: 492
Exclamation
I'm really inclined to rename current thread to "Speculations around CM-7600" !
P Smith is offline
post #379 of 682 Old 01-17-2018, 05:01 AM
Alanlee's Avatar
Quoted: 439 Post(s)
Liked: 276
I absolutely agree with you. The main reason I buy DVR's is to be able to fast forward the endless stream of commercials that are foisted on viewers. A secondary reason would be delayed viewing, but most of the stuff I record from over the air (OTA) sources is watched within a few hours of the original recording and then erased. An example would be news programs. Nearly all of the entertainment programs that come OTA are not directed to my view interests.
Actually the vast majority of stuff I watch is on demand from streaming sources which do not have commercials. I would much rather pay a monthly fee to Netflix or other streaming service than be exposed to the mind numbing experience of commercial TV. I subscribed to CBS online so I could watch STAR TREK. It's five bucks a month with limited commercials. Next Star Trek season I am going to pay the nine bucks a month for no commercials and binge watch the series. I can only survive limited exposure to those ridiculous Geico commercials.
7.4.6 system with Denon 8500, Additional Amps: Emotiva (front and center) and NAD (wide), classic Klipsch speakers.
Alanlee is offline
post #380 of 682 Old 01-17-2018, 05:15 AM
danlshane's Avatar
Quoted: 239 Post(s)
Liked: 198
Does some who paid, ordered S+ got ETA ?
I ordered two the day after the device was announced. No ETA as yet.
Dan Shane
LG 65EF9500 & LG 65UH8500
God gave us two eyes for a reason.
danlshane is offline
post #381 of 682 Old 01-17-2018, 05:55 AM - Thread Starter
pachinko's Avatar
Quoted: 998 Post(s)
Liked: 546
I put in a request to rename this thread to "Channel Master Stream+ Pre-Release Speculation", and if possible will have it locked when the Stream+ is released and a new thread is created.
Since I do not plan to purchase the Stream+, hopefully someone else will start a new "Channel Master Stream+" thread that will be based upon accurate hands on information.
post #382 of 682 Old 01-17-2018, 08:56 AM
criggs's Avatar
Quoted: 363 Post(s)
Liked: 98
Good idea. That way we won't have to pore through endless pages of speculation to get to the real info that starts pouring in when one of these units finally shows up in someone's mailbox.
Of course, at that time, I hope the mods will post a final message on the thread directing folks to the new thread.
criggs is offline
post #383 of 682 Old 01-17-2018, 09:54 AM
fshagan's Avatar
Quoted: 429 Post(s)
Liked: 205
Should we nominate someone to start that thread with a sticky at the top to NOT post in it until the Stream+ is delivered?
fshagan is offline
post #384 of 682 Old 01-17-2018, 10:29 AM
P Smith's Avatar
Liked: 492
Exclamation
just make public promise keep your hand tight for now
who will got real S+ first, will open new thread
pachinko, pilotart and danlshane like this.
P Smith is offline
post #385 of 682 Old 01-17-2018, 11:21 AM
Alanlee's Avatar
Quoted: 439 Post(s)
Liked: 276
I do not disagree with you, however if you look over the dvr+ thread, which did actually exist, you will witness many posts that are based on speculation about why something works or not, whether this hard drive will work or not, what’s going on with the online schedule, etc, etc.
It is true that there are folks who deliver good info, but even they tend to speculate, and some of the speculation is due to poor communication by corporations. For instance, Channel Master was not up front about the death of the dvr+. They wanted to sell off their existing stock before they announced the new device. They told me on the phone they were waiting for a new shipment of the dvr+ and I would be the first to know when the shipment came in. I am still waiting for that email.
I found out about the new device on this thread, not from Channel Master. The speculation can be maddening, but occasionally there is a thread or maybe a post of truth.
LenL likes this.
Alanlee is offline
post #386 of 682 Old 01-18-2018, 04:27 AM
LenL's Avatar
Quoted: 447 Post(s)
Liked: 318
We should start a new thread called the "Channel Master Speculation" thread.
It would quickly fill up with over a thousand posts of remembered promises, or suggested changes, and suggested remedies either from phone calls, emails, their website, CES, FAQs, etc.
That would be very telling and scary!
P Smith and JHBrandt like this.
LenL is offline
post #387 of 682 Old 01-18-2018, 08:38 AM
Quoted: 115 Post(s)
Liked: 62
I posted earlier that I phoned CM after it mentioned here about the delayed ship date, and they confirmed the first pre-orders will ship mid February.
Since then, several people, including myself, tweeted to the official Channel Master Twitter account, questioning the reason for the delay. The official response,
"Just your standard shipping delays. Manufacturing fun. Initial inventory can be tricky to estimate! Sorry for the delay"
Check tweets and replies on the Channel Master Twitter account for other interesting details on the EPG, Google Live Channels etc. Not all necessarily new, but official.
merman9393 is offline
post #388 of 682 Old 01-18-2018, 04:03 PM
Greasemonkey's Avatar
Quoted: 508 Post(s)
Liked: 275
There has been a lot of speculation here about whether or not the Stream+ is a replacement for the DVR+, and a fair amount of back and forth between CM and people who have already ordered a Stream+. But has anyone asked CM if *they* consider the Stream+ to be a replacement for the DVR+? It's clear that consumers, i.e. "we" don't consider it to be a replacement. But if CM would give a straight answer to that question it would clear up one aspect of that speculation very quickly. If CM does consider the Stream+ to be a DVR+ replacement we would know once and for all that CM doesn't have any plans for a new OTA oriented recording unit. If they don't consider it to be a replacement, then it would give hope to a lot of the people who participate in both threads. But I wonder if they would even give us a definitive answer to the question.
Greasemonkey is online now
post #389 of 682 Old 01-18-2018, 04:33 PM - Thread Starter
pachinko's Avatar
Quoted: 998 Post(s)
Liked: 546
Some Images of the Stream+ internals
For what they are worth, here's a couple of images of the internals (captured from a video).
post #390 of 682 Old 01-18-2018, 04:39 PM
Dargent0628's Avatar
Quoted: 219 Post(s)
Liked: 121
Originally Posted by Greasemonkey View Post
There has been a lot of speculation here about whether or not the Stream+ is a replacement for the DVR+, and a fair amount of back and forth between CM and people who have already ordered a Stream+. But has anyone asked CM if *they* consider the Stream+ to be a replacement for the DVR+? It's clear that consumers, i.e. "we" don't consider it to be a replacement. But if CM would give a straight answer to that question it would clear up one aspect of that speculation very quickly. If CM does consider the Stream+ to be a DVR+ replacement we would know once and for all that CM doesn't have any plans for a new OTA oriented recording unit. If they don't consider it to be a replacement, then it would give hope to a lot of the people who participate in both threads. But I wonder if they would even give us a definitive answer to the question.i
That's an interesting take on the Stream+, as I have pre-ordered precisely because I consider it an OTA-oriented recording unit that hopefully will suit my needs. I really am not thinking of it as a streaming device, as I think that Roku, Fire, ATV etc most likely provide a superior experience in that regard. Certainly, I will explore it's capabilities as I've never had an Android box and I'll be curious about how it might perform in that regard. It seems from many posts that there is a great deal of disappointment that the Stream+ will not offer greater storage capacity, and that recordings will not be transportable or accessible across a home network.
Dargent0628 is offline
Closed Thread HDTV Recorders
