Arris DCX3520e-M HDD Upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-06-2018, 03:21 PM - Thread Starter
Liked: 0
Wink Arris DCX3520e-M HDD Upgrade
Looking to upgrade the internal drive in my 500GB DCX3520e-M with a 2TB one.
Has anyone done any internal upgrades before on this, or the DCX3400/DCX3500 line?
If so, what steps are there (besides the obvious of swapping the drive out)? I've done some searching but wasn't really able to find anything specific about it.
I'm wanting to try to swap it out tomorrow, but the only thing I'm really aware of doing is formatting it using a PC into basically any format, swapping it out, then (maybe?) using the clear HDD option on the unit...or am I totally wrong about all this?
Warranties are not an issue etc etc...
NightLink42 is offline
Reply HDTV Recorders
arris , hdd , Motorola , upgrade
