Iview Cyber Box - Android 7.1 w/tuner - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #61 of 91 Old 01-19-2020, 04:20 PM
jeajea's Avatar
Quoted: 18 Post(s)
I still haven’t found a way to get 5.1 audio over HDMI from the cyber box.
I tried connecting the cyber box directly to the AVR and do not get surround sound.
The only settings I have found for surround sound are
“Quick settings”
“Surround Sound”
The options are “Auto, Always and never”.
None of the options enable surround sound over HDMI. The AVR indicates it is getting two
channel PCM either directly via HDMI or through the TV via optical.
On my Iview 3500 surround sound works going HDMI to the TV and
optical to the AVR.
Surround sound is recorded and is available using Kodi to play the cyber box recordings on
my Shield TV.
Does surround sound from a broadcast channel require a Dolby license?
The next thing I am going to try is installing Kodi on the cyber box.
I will also try sending email to Iview support about surround sound and
previous channel (return).
Other observations:
The connector on the flash drive I am using for recordings gets very warm. I decided to use
a short USB extension cable between the drive and the cyber box.
The box won’t record unless it is left on.
jeajea is offline
post #62 of 91 Old 01-20-2020, 11:28 AM
JHBrandt's Avatar
Quoted: 3062 Post(s)
Liked: 1475
I think I saw a setting for this, but I'm at work now and can't remember where it was. I'm pretty sure it was somewhere in the DTV app's menus though.
I do remember the options being something like:
  • PCM
  • SPDIF raw
  • HDMI raw
It defaulted to PCM which I'm pretty sure is stereo only. You probably have to set the output to one of the other two options, depending on which output you want DD5.1 on.
SPDIF refers to the Cyberbox's digital audio jack. If you have optical, I think you need an adapter to convert the SPDIF's electrical output to optical (the adapter is basically just an LED; you may already have one for your 3500).
I think decoding any audio from a digital broadcast channel used to require a Dolby license. But I think the patents ran out a year or two ago.
But ironically, you don't want the Cyberbox to decode the audio. You want to pass it through unmodified and let your AVR decode it instead. That's why I think you need one of the "raw" options.
The connector on the flash drive I am using for recordings gets very warm. I decided to use a short USB extension cable between the drive and the cyber box.
That's a good idea. I may do that myself.
Uh-oh; that's not good! It's a small thing but it could be a show-stopper for some. I know of at least one person who uses a Cable Matters HDD dock with his mStar box and relies on the box being off when it's not recording (having the box off lets the dock connect to his home network and act as a media server, so he can watch the shows it's recorded).
JHBrandt is offline
post #63 of 91 Old 01-21-2020, 06:46 AM - Thread Starter
eherberg's Avatar
Quoted: 277 Post(s)
Liked: 113
Yeah -- no 'standby' mode of some kind would be a setback (for me, at least). I know that in standby-mode the Franken-iView isn't really 'off' - but it is a low-power state that at least saves some wear and tear on the portable hard drive connected to it. Speaking of the hard drive - the possible power interruptions for running an external drive would be another show-stopper. Ever since I put the iView firmware on the Mediasonic to solve the double-clutch PSIP problem that erased scheduled timers - the small 320GB hard drive I have hooked up to the box has been rock-solid now for a year or so. With my wife's daily M-F programs, I haven't had a single failed recording or disappearing timer due to double-clutch PSIP problems or not-quick-enough write speed using the small portable drive and the iView firmware. The Mediasonic box still provides steady, dependable power to the drive. Perhaps it's due to the smaller capacity of the portable drive (I found that if you try to go 1TB or up - the delay in spinning up and reading the drive was noticeable and impacted recording start-times, while 200-300 GB drives gave near flash-drive speed responsiveness). Perhaps a smaller drive solves the Leelbox (and by extension, Cyberbox) problems - but it would be another step backwards for me besides having no standby mode to have power that was not dependable for the portable drive and have to go back to flash drives with the spin-of-the-roulette wheel luck needed to insure you have one with a fast-enough write speed.
eherberg is offline
post #64 of 91 Old 01-21-2020, 01:19 PM
Quoted: 21 Post(s)
Liked: 3
One of the amazon reviews (here) for the leelbox Q5 version mentions the failure to record when not turned on. But it is the only review out of 40+ that mentions this.
I've been looking around to see if any of the vendors of this exact box (in terms of the case and hardware, save for the remote) have issued any firmware updates during the history of the box.
All I've been able to find is updates (here) for the vmade v8 plus (which looks identical to the cyber box). While vmade makes a version of the v8 plus with an atsc tuner, the update listed is for the dvb version.
Chut Mingy is offline
post #65 of 91 Old 01-21-2020, 04:04 PM
JHBrandt's Avatar
Liked: 1475
  • PCM
  • SPDIF raw
  • HDMI raw
Found it (sorry for the delay). It's not where I remembered it.
Exit the DTV app or whatever app you're in, go to "apps," and select the "Droid settings" app. This brings up a "Droid Settings" menu. Select "Sound." Then select "Digital Sounds." This is where you can set SPDIF or HDMI to "RAW" to pass DD5.1 through.
I'm unsure what the other two options under the Sound submenu do.
JHBrandt is offline
post #66 of 91 Old 01-21-2020, 04:19 PM
JHBrandt's Avatar
Liked: 1475
Ironically, the Cyberbox seems to have a standby mode; it just doesn't work properly. Half the time when I turn it on from standby, it reboots; the other half of the time, it comes up fine without rebooting. BTW, it always boots to the factory-provided launcher, even if you install a different launcher and change the default launcher in settings.
Despite their clunky firmware, I have a lot of admiration for the mStar boxes. Their standby function works: everything is shut down except a timer, so they only use 1 watt or so in standby mode. But once a recording is about to start, they boot up in only 15-20 seconds, spin up the HDD, and (with the right firmware) start recording pretty reliably.
JHBrandt is offline
post #67 of 91 Old 01-21-2020, 04:52 PM
Quoted: 21 Post(s)
Liked: 3
There are at least two ways to play back a recording on the cyber box:
1. If the USB button is pressed, and, using the file browser, the file is selected after navigation to the appropriate folder. This, by default, will invoke the movie player app.
2. If the PVR button is pressed (but only while just on a live channel, and not within any other DTV app sub-menu), then a (rename-able) recordings list is presented. If a recording is selected for playback, it is played with what appears to be a modified version (slightly different menus) of the movie player app.
Method 2 shows a little camera icon ("REC") during playback. And I can't make it go away.
Method 1 shows closed captions (using a very small font). And I can't seem to disable them.
Does anyone have a solution?
post #68 of 91 Old 01-21-2020, 05:59 PM
jeajea's Avatar
Quoted: 18 Post(s)
5.1 audio works with Kodi
My normal setup is cyber box via HDMI to HDMI switch, HDMI switch to
TV HDMI input and TV optical out to AVR.
I found the droid settings menu and tried all three setting under digital
sound. None of the settings provide 5.1 audio for either live TV or
playback of recordings. 5.1 audio also failed with the cyber box directly
connected to the AVR.
I did very that closed caption works for playback via PVR.
However, 5.1 audio works using Kodi (running on the cyber box) to
play recordings.
I installed the Armv7a (32 bit) version of Kodi using the .apk. I tried the
64 bit version first but it complained of wrong version.
My audio settings for cyber box for Kodi
Quick settings
Surround
Either “Auto” or “Always” gives 5.1 audio (with Kodi). “Never” forces 2 channel audio.
The droid settings don't appear to matter to Kodi
My Kodi audio settings
System
Audio
Number of channels: 5.1
Audio passthrough: Allow Passthrough
However, it appears a Kodi addon is required for closed captions.
The jack on the back of the box labeled coaxial appears to be the same size as the
AV jack. I have never seen either an optical or coax audio cable that uses a plug that would fit.
FYI: The AV jack/cable is the same as used by the Roku express + and my 24 inch Vizio TV.
jeajea is offline
post #69 of 91 Old 01-21-2020, 06:27 PM
jeajea's Avatar
Quoted: 18 Post(s)
using Kodi for playback gets rid of both the camera and the captions
jeajea is offline
post #70 of 91 Old 01-23-2020, 04:44 PM
JHBrandt's Avatar
Liked: 1475
The jack on the back of the box labeled coaxial appears to be the same size as the AV jack. I have never seen either an optical or coax audio cable that uses a plug that would fit.
Yes; most iView devices use an RCA jack for coaxial audio, but for some reason the Cyberbox uses a 3.5mm jack instead. You need an adapter like this one: https://www.amazon.com/Monoprice-107.../dp/B0069MLDUO
The coaxial and A/V jacks are very close together. It's very difficult to plug a coaxial adapter and the A/V cable in at the same time. But they probably figured you'd only use one or the other.
JHBrandt is offline
post #71 of 91 Old 01-23-2020, 05:53 PM
JHBrandt's Avatar
Liked: 1475
The Gallery app will play videos without closed captions too. If you already have a default app you don't like, launch Settings; go to Apps; select the current default app (e.g., Movie Player); click "Open by default," and click Clear Defaults. Then you can change the default app for videos by selecting a video to play. Android will ask you which app to use. Select the app you want, then select "Always" to make it the new default. Then use method 1 to play videos.
JHBrandt is offline
post #72 of 91 Old 01-27-2020, 09:25 PM
JHBrandt's Avatar
Liked: 1475
Noodling around with a file explorer, I noticed several of the CyberBox apps (not the DTV app, but FileBrowser, MoviePlayer, the launcher, even "Droid Settings") were written by some outfit called DroidLogic. While searching for more info, I ran across another DroidLogic app that might be useful. It's called "Media Center" and you can download it here: https://android-apk.org/com.droidlog...c-mediacenter/ (You'll have to go to that page using Chrome or another browser you've installed on your CyberBox, such as Edge. There are two versions; make sure to get the older one. The newer one doesn't start. Or it might be easier to download on your PC, put the app on a thumb drive, plug that into your CyberBox, and install it from there.)
What it appears to do is add DLNA capability to your CyberBox, so you can play content from other DLNA devices on your network or vice versa.
JHBrandt is offline
post #73 of 91 Old 02-03-2020, 05:10 PM
JHBrandt's Avatar
Liked: 1475
I've been noticing the CPU in this thing seems to run rather hot (almost 70C). The ventilation holes are all on the bottom, too; none on the top, so without a fan you're not going to get any convection through it. So I'm thinking a small fan would be a wise investment. Any suggestions?
Originally Posted by dorismc View Post
I have the cyberbox and do not like it...the picture is way too big on the screen...
I had this problem but was able to fix it on the TV end. I'm using a small LG TV, which has a menu option to "label" the HDMI input according to what you plug into it:Blu-Ray, DVD, Set Top Box, etc. Turns out you must label the input "PC" or the TV will enlarge the image slightly, cutting off the edges. That doesn't make a lot of sense to me, but that's what my TV does.
My guess is that the box does not have L1 widevine, so the resolution is probably limited. Will check this and also if the box is rooted or not.
Probably no on Widevine. The box is rooted though. Just enable developer options by going to the full-screen settings app / About Media Box, scroll down to "Build Number" and click repeatedly until it says you're a "developer." Then Developer Options will appear above About Media Box. Click that, scroll down to Root access, and turn it on.
I'd prefer a safer and "stealthier" root, but this will do for the time being.
Also plan to check if the irfake module will run on this box, or if the remote control codes can otherwise be altered.
Files remote_key_config.xml and remote.conf in the /etc directory look promising....
JHBrandt is offline
post #74 of 91 Old 02-05-2020, 08:34 PM
JHBrandt's Avatar
Liked: 1475
By the way, if you have a spare GB or so on your PC, it's probably worth downloading a copy of the Cyberbox factory firmware from http://www.iviewus.com/download/firm...berBox-OTA.zip.
In case of disaster (or you just really screw things up), you can flash it to the Cyberbox with a special cable (USB A connectors on each end) that I think you can get on Amazon, and Amlogic's USB burning tool at https://sourceforge.net/projects/tvb...0.zip/download. Edit: Just looked at the file more closely and you don't flash it with the AmLogic USB Burning Tool. You put it on a USB drive and flash it with the CyberBox's "recovery." Details are a bit complicated so I won't go into them here. It's still worth having a copy on hand though.
ncsercs likes this.
JHBrandt is offline
post #75 of 91 Old 02-07-2020, 09:32 PM
JHBrandt's Avatar
Liked: 1475
By sheer coincidence, while trying to find a learning remote control sold at Wal-Mart, I came across this: https://www.walmart.com/ip/Wireless-...ndow/635814080
It's the Cyberbox remote! Some of the button labels are different, and I don't know if the IR commands match up, but it's supposed to be a learning remote, so maybe it can be taught to work. If not, you may have to transplant the remote.conf file from a box it does work with. Turns out remote.conf is useless on this box....
BTW, am I the only one amused to see the word "Wireless" used to describe a remote control? Duh - I sure hope so!
I'm trying out this fan: https://smile.amazon.com/gp/product/B0070ZHY6G
The fan's in the middle of a little table you sit your Cyberbox (or whatever device) on. Two of the legs are long and two are short, so it sits sloped a bit. For the Cyber box I oriented it so the front of the Cyberbox is sloped up (makes it easier to aim the remote when in IR mode. For a tablet you'd probably have the front sloped down for easier touchscreen use). The CPU is still quite hot but at least there's a bit of breathing room (it's around 60C now vs. 70C).
Forgot to mention: the fan is USB powered, so I needed a way to plug it, my flash drive, and my remote control dongle, all in at the same time. But the Cyberbox only has two USB ports. So I left the remote dongle in port 1 and plugged this hub into port 2: https://smile.amazon.com/gp/product/B002FFT8Z6. Then I plugged my flash drive and the fan into two of the hub ports. That seems to get the job done.
Now experimenting with Magisk (a contraction of Magic Mask). It allows you to grant root permissions on an app-by-app basis vs. being "all or nothing" as with the Cyberbox's stock root. You can also grant root access to an app for a limited time, so you don't have to remember to disable root after you've done whatever it is that required root in the first place. It also has a "Magisk Hide" function to mask (hence the name) the existence of root from particularly paranoid apps, such as Spotify.
The only problem I've noticed with Magisk so far is that the Cyberbox often freezes for a few seconds when an app requests root access. Often when this happens, I'll get an "app is not responding" dialog and have to tell Android to "wait." But so far Magisk hasn't seemed to interfere with normal apps.
I decided to install Spectrum TV. Their app installs and runs fine, but refuses to play anything: I get a curt message from Spectrum that "This app is not supported on this device. Please try another device."
The problem may be the lack of Widevine support that Chut Mingy mentioned.
Made a little progress on this.... Turns out the Cyberbox has Widevine L3 at least, so if you hide root from the Spectrum app with Magisk and turn off "USB debugging" in Developer Options, the Spectrum app runs! No nasty message. But it's still not usable on the Cyberbox ATM. I started it and it brought up the first channel (C-Span) and started playing. But then I was stuck. The only control that worked was closed captions. I couldn't change channels or watch anything but C-Span, I couldn't adjust the volume - I couldn't even exit! The only way out was with the Home button or one of the shortcut buttons that launch the web browser, GMail, etc.
Edit: Figured out a way to work with the Spectrum app. You have to move the mouse pointer to the left edge, click, and drag the mouse rightward. This "pulls out" the Spectrum menu. From there you can go to the Guide, My Library, On Demand, etc. Once you get off the live video screen, the exit key finally works.
So it's a bit awkward, but I can live with it, I guess....
JHBrandt is offline
post #76 of 91 Old 02-08-2020, 12:06 PM
dishdude1's Avatar
Quoted: 47 Post(s)
Liked: 42
They're $7 on eBay, just search for MX3 remote. No need to put wireless in
I just bought one to see if it'll work with my Android TV. Includes a USB dongle...for $7 what the heck!
JHBrandt likes this.
dishdude1 is offline
post #77 of 91 Old 02-08-2020, 03:02 PM
JHBrandt's Avatar
Liked: 1475
I gave up on the Cyberbox's built-in Movie Player, and installed MX Player from the Play Store to use as my go-to video player. Of course there are plenty of alternatives, including Kodi, but if you're just looking for an improved video player for your OTA recordings, MX Player is pretty good.
JHBrandt is offline
post #78 of 91 Old 02-10-2020, 08:33 PM
Quoted: 21 Post(s)
Liked: 3
As mentioned in a prior forum post (here), the circuit board of the cyber box has a space for a tf (micro sd) card socket.
I have installed the tf socket. The circuit board layout is configured for a tf card socket of the type like amazon B07KY7X33M or equivalent. I'm using a Samsung 128GB 100MB/s (U3) MicroSDXC EVO (MB-ME128GA/AM), also obtained from amazon (B06XWZWYVP).
Installation of the socket requires some delicate soldering. I also moved the wi-fi antenna slightly to make room for a slot for the card. See the photos below.
So far, the sd card works no worse than a usb flash drive.
ID:	2683578   Click image for larger version
ID:	2683580   Click image for larger version
ID:	2683584   Click image for larger version
ID:	2683586   Click image for larger version
arbegas likes this.
post #79 of 91 Old 02-11-2020, 01:56 AM
Quoted: 21 Post(s)
Liked: 3
In case of disaster (or you just really screw things up), you can flash [the firmware] to the Cyberbox with a special cable (USB A connectors on each end) that I think you can get on Amazon, and Amlogic's USB burning tool at https://sourceforge.net/projects/tvb...0.zip/download. Edit: Just looked at the file more closely and you don't flash it with the AmLogic USB Burning Tool. You put it on a USB drive and flash it with the CyberBox's "recovery." Details are a bit complicated so I won't go into them here. It's still worth having a copy on hand though.
What are the complicated details for disaster recovery to which you refer?
By 'disaster" I mean an unbootable box, perhaps one that will load no further than the bootloader but none of the OS.
Boxes like these often employ some type of micro switch that is accessed through a hole somewhere on the case and is used in the recovery process.
The cyber box has a switch (6SW2) behind the coaxial SPDIF jack (see first photo in the prior post here) which could be a "reset" switch. There is a space on the circuit board for a second micro switch (2SW1), which is not installed, near the front of the box.
Edit:
I installed the missing switch (2SW1). It does activate recovery mode. If "Apply update from EXT" is selected, both the sdcard and usb are listed. I believe that the zip firmware package as provided by iview can be installed using this method.
I also installed a connector for the uart connections and confirmed that uart mode works. The tx/rx connection points on the circuit board had a lot of sloppy solder and flux residue (as if done by hand) from the factory, so the uart is probably how the box is loaded with software in the first instance at the factory,
I couldn't get the other switch (6SW2, behind the spdif jack) to do anything.
ID:	2685546   Click image for larger version
ID:	2685548   Click image for larger version
ID:	2685550   Click image for larger version
post #80 of 91 Old 02-11-2020, 10:01 PM
JHBrandt's Avatar
Liked: 1475
I like what you did with the micro SD socket. Now if you can add that reset switch, your Cyberbox should be pretty brick-proof.
My understanding is, you can put a disk image file named recovery.img on a micro SD card, put it in the slot, and hold the reset switch while applying power, and the bootloader will boot the recovery.img. So, as long as the bootloader's OK, you could screw up pretty much everything else and still boot the box.
The importance of that makes me wonder why iView left both those parts off. I imagine it was to save money, but the 50 cents they save per box will probably be outweighed by bricked returns.
Lacking both the micro SD socket and switch, I decided to take a chance, and flashed a custom recovery directly onto my Cyberbox. The file I chose is at https://sourceforge.net/projects/tvb...y.img/download and luckily for me, it works. I use TWRP recovery on an old cell phone so I knew I'd be pretty comfortable with it if it worked.
But how do you flash over the default recovery in the first place? Luckily, the same Web page also has the AMLogic Recovery Flasher app: https://sourceforge.net/projects/tvb...T.apk/download. Download that and install it onto your Cyberbox, enable root access in developer options, and you can flash TWRP directly onto your Cyberbox.
I needed one more thing: an easy way to boot into recovery. I downloaded an app from the Play Store called ProBoot. But it's hard to find: search for "Wireless ADB" and look for the app by "Pzy64."
The very next thing I did, of course, was to boot into the TWRP recovery I'd just installed, and make a full backup of my Cyberbox onto my USB thumb drive. I did run into one bug right away: that version of TWRP won't work if you try to compress your backup files. I had to toggle that option off to make the backup. But now, as long as I can boot into recovery, I can restore that backup and be back in business.
JHBrandt is offline
post #81 of 91 Old 02-12-2020, 12:07 PM
Quoted: 21 Post(s)
Liked: 3
As for Chrome, I finally "solved" it by enabling developer options, enabling root access in developer options, moving the Chrome folder from /system/app to /sdcard (in case of disaster), rebooting so Android would realize Chrome was gone, then installing it as a brand-new user app. Now I'm finally on Chrome 79
During the past few weeks, you've added a lot of cool details to the post from which the above quote is taken.
Due to my years-long aversion to android, and my sticking with non-android media players (and windows phone) for so long, I have a sizable learning curve to hurdle in order to get up to speed on the basic workings of android and mobile android. Which seems odd since I've used linux for a decade.
I'd like to install Chrome 79 on the cyber box. Would it be too much trouble to make a numerated, all-inclusive list of steps that a five-year-old would understand?
post #82 of 91 Old 02-12-2020, 12:33 PM
Quoted: 21 Post(s)
Liked: 3
It doesn't matter that this recovery image is for 5X instead of 5D?
post #83 of 91 Old 02-12-2020, 02:39 PM
JHBrandt's Avatar
Liked: 1475
I feel your pain. Android is based on a Linux kernel, and it's open-source like Linux, so you'd think it would be easy to transition from Linux to Android. But it was also designed so manufacturers could "lock it down" to prevent users from messing up their devices (and not incidentally, to prevent them from removing Google's spyware easily). So it's been a pretty steep learning curve.
Apparently not. As far as I could tell the differences between these chips (S905X, S905D, and S912) don't require different recovery code. Biggest difference between the S905X and S905D seems to be the S905D's TS input, which (I assume) is what the tuner and demod are connected to. So the X is typically used in OTT-only boxes and the D is used in boxes with tuners. (Also the D supports gigabit Ethernet with some additional hardware. The Cyberbox doesn't include that, though.) And the S912 is basically just an 8-core version of the S905D (the D and X have 4-core processors). So the software is pretty compatible between these three chips.
JHBrandt is offline
post #84 of 91 Old 02-12-2020, 07:37 PM
JHBrandt's Avatar
Liked: 1475
How to remove Chrome 66 from the Cyberbox
First, make sure you have root access enabled. From the home screen, go to Apps, scroll down to Settings, and open it. In Settings, the next-to-last option should be Developer Options. If it isn't there, select the last option, About Media Box, then scroll down to the last item at the bottom, Build Number, and click it repeatedly until it says "You are now a developer." Then press Exit, and Developer Options should be visible. Now click on Developer Options, scroll down to Root Access (it's just above the "Debugging" heading). If it's off, click it to turn it on.
While you're in Settings, you also need to scroll to the Personal section, click on Security, scroll down to Device Administration, and make sure Unknown Sources is turned on, so you can "side-load" apps from sources other than the Play Store.
The next thing you need is a file manager that can access the filesystem's root. The CyberBox comes with FileBrowser, but that only accesses the Cyberbox's internal and external (USB) storage areas. So I used a file manager called MiX (short for Mix of eXplorers): https://forum.xda-developers.com/att...7&d=1580815875. You can browse to this AVSForum post with Chrome 66 (the same Chrome 66 you want to remove) and click on that link. It should download MiX and offer to install it. Go ahead and install and open it.
MiX is a bit counter-intuitive until you get used to it, and it's easiest to use with a mouse, so if your CyberBox remote isn't in mouse mode, click "TV" to switch to mouse mode. Now use the mouse to click the "hamburger" (three stacked horizontal lines) at the top left of the MiXplorer menu. Then click Root (it should be the third or fourth item in the menu that drops down).
Chrome is in the /system/app directory, so scroll down to the "system" folder. Don't click the icon; click the name. (If you accidentally click the icon it will select the folder; just press Exit to deselect it.) Then click on "app" too. Now you'll see subfolders for all your "system" (non-removable) apps, including Chrome. (There's also a "ChromeCustomizations," but I don't know what that is, so I just left it alone.) We're going to make a backup copy of the Chrome folder, then delete it.
Select the Chrome folder by either clicking its icon, or clicking the name but holding the OK button down for a few seconds. The icons at the top right will change. The second one, which looks like two overlapping windows, is the "copy" icon. Click it and MiX will respond "Added to the task list." Now press Exit on the remote until you get back to root; then press exit twice more. This should bring you back to Internal Storage.
If you wish, at this point you can click the "hamburger" again and select your USB drive, instead of Internal Storage, as the place to save your copy. But either way, click the Paste icon (it looks like a clipboard). MiX will ask for confirmation by saying Copy #1 not started. Click that and it will copy your folder. Now you can navigate back to Root / system / app, select Chrome again, and click the trash can to delete it, and confirm you really want to delete it. Note: You may find MiX cannot delete the Chrome folder. MiX should delete the contents, though, and that's all you need.
Finally, reboot the CyberBox by holding down the power button until the menu comes up and selecting Restart. Once it reboots, Chrome 66 should be gone, so you can install the latest version from the Play Store. (But if anything goes wrong, you can bail out by copying the Chrome folder back to /system/app.)
Q: Why didn't we just "cut" the Chrome folder, rather than copying it and then deleting it? A: The folders are in different partitions (like different drive letters on Windows) and MiX will only cut & paste within a single partition, so we had to do it the hard way.
Chut Mingy likes this.
JHBrandt is offline
post #85 of 91 Old 02-15-2020, 06:47 PM
JHBrandt's Avatar
Liked: 1475
I was playing with my Cyberbox today when suddenly, the air mouse went dead.
It appeared the box had locked up, so I pulled power for a minute and plugged it back in. It rebooted to the launcher, then started the DTV app as usual, but I couldn't control it.
That's when I noticed the red/green LED on the remote wasn't lighting up when I pressed buttons. I checked the batteries; sure enough, both were pretty much dead.
And these were brand-new Duracell alkaline batteries that came with the box! I've been using this for a little over a month. Apparently this remote eats batteries pretty fast, at least if you use the RF mode (which is necessary for the keyboard and air mouse). And when they go, there's no "low battery" warning: one minute it's fine, the next it's totally dead.
I'll try Energizer Ultimate Lithium batteries and see if I can get an extra week or two of use out of them.
JHBrandt is offline
post #86 of 91 Old 02-17-2020, 05:30 PM
JHBrandt's Avatar
Liked: 1475
Remote control issues
https://sourceforge.net/projects/tvb..._.apk/download lets you remap buttons on your remote.
Simple example: in RF mode "Repeat" launches Music Player and "Aspect" launches Gmail, but this app lets me change it to launch MX Player and BlackBerry Inbox, respectively. More complex example: these buttons function differently in IR mode than in RF mode. With this app, I can make a single click of the REPEAT button perform the default IR function, and a double click perform the default RF function (launching MX Player), regardless of the actual current mode.
Unfortunately there are some limitations. In IR mode, some buttons seem to emit codes that are only recognized by the DTV app and are not assigned to any of the 283 standard Android button codes or to custom codes. Therefore this app cannot remap them; nor can it perform these buttons' functions when pressing another button. Thus, this app can't make the DTV app fully functional in RF mode, as I'd hoped. Edit: See the edit in the next paragraph. There may be a way to do this after all. The buttons that are "limited" this way are: HDMI, TV/RADIO, USB, FAV, CC, ASPECT, and AUDIO.
Also, there doesn't seem to be a fix for the RETURN button acting like the EXIT button. In IR mode, these two buttons appear to send exactly the same code, so they cannot be distinguished. In RF mode they can, but the standard Android button code for "Previous Channel" doesn't work. Edit: I FOUND THE CODE FOR PREVIOUS CHANNEL! It's listed in /etc/remote_key_config.xml, which appears to define the key codes for the DTV app. It's 2032, which is way beyond anything Android uses - but it works! Now my "RETURN" button functions correctly, at least in RF mode (still can't do anything about IR mode though).
Hint: if you install this, click "More Options" and turn on "Alternate button handling" in the options menu. Otherwise the Cyberbox will perform the button's original function as well as its reassigned function!
Looks like irfake was written for a different chip. Might be possible to recompile from source targeting the S9xx family, but the irfake project is long gone from Google's site and the source was never archived.
I ran into an annoying problem of remote interference with my Cyberbox this week: turns out the Cyberbox responds to the remote control used by both the CM-7004 and DVR+. Even worse, it responds in an unhelpful way: for example, the "up" button moves the cursor down, while the "down" button acts like OK on the Cyberbox remote. So, having earlier determined that the remote_key_config.xml file is only used by the DTV app, I decided to investigate the remote.conf file to see if I could find a way around this. And I ended up spending Saturday learning all the intricacies of remote.conf, only to finally discover that the Cyberbox doesn't even use it! You can do anything you want to that file, even delete it entirely! It makes no difference. The Cyberbox always responds to its remote (and to the DVR+ remote) exactly the same way.
So I spent today trying to figure out why, and finally found the answer in this article: https://www.cnx-software.com/2017/03...st-quick-look/
Developers will also need to be aware the way to handle remote control codes has changed. The /system/etc/remote.conf is gone [except on the Cyberbox, where they apparently left it as a placebo], and instead Amlogic defines the codes in a specific DTSI (Device tree) file for remote code that includes definition for 3 remotes....
That led me down yet another rabbit hole, trying to figure out what the heck a "DTSI" file was and where it's stored on the Cyberbox. And it turns out, it's not stored on the Cyberbox at all; instead, it's compiled into a "DTB" (Device tree BLOB) and stored in the boot/kernel partition. So the only way to change remote codes now is to patch the kernel! Who the heck thought this was a good idea?
So after all that research, it turns out the only reasonable way around this remote interference problem is to block the IR receiver and use the remote exclusively in RF mode. Thanks to the Button Mapper app mentioned above, that's almost feasible. Unfortunately one function still requires IR mode: turning the box on! If it's in standby the power button will work in RF mode, but if it's totally powered off, you must use IR mode to turn it on I think that's because the RF dongle itself has no power if the box is off. Maybe I need to plug the dongle and my thumb drive into a powered hub?
JHBrandt is offline
post #87 of 91 Old 02-23-2020, 03:04 PM
JHBrandt's Avatar
Liked: 1475
The "rebooting" problem I mentioned above seems to have gone away after I installed the fan, so it may have been from the SoC getting too hot. Unfortunately, the problem with the DTV app not starting a scheduled recording if the Cyberbox is in standby remains, so standby isn't all that useful even though it now "works."
Edit: Rebooting problem may not be completely vanquished after all. Right after I wrote that, I turned on my Cyberbox and it promptly rebooted....
JHBrandt is offline
post #88 of 91 Old 02-26-2020, 09:30 PM
Quoted: 21 Post(s)
Liked: 3
Are you pretty sure that it's heat related? I've opened the cyber box several times, and have been surprised by how relatively cool the heat sink was, even right after playing high bitrate video.
On the other hand, the factory dc barrel power jack/connector on my unit was flaky. With a good jack, it should be possible to spin the plug in the jack without losing power. On my unit, I'd have to rotate the plug around to find a solid connection, and the power connection could easily be lost if the plug was rotated within the jack to certain positions. I changed the jack to one with a better bite on the plug, and that problem went away.
I've stopped using the cyber box and I'm instead using the U5PVR Slim. In my opinion, the U5PVR Slim is a better box all around. For instance, the time shifting feature can be set to be very long or unlimited.
post #89 of 91 Old 02-27-2020, 01:18 PM
JHBrandt's Avatar
Liked: 1475
Not sure if that last reboot was heat-related or not. I do know the CPU has a temperature sensor, and it reads quite hot, so I suspect some (most?) of the reboots I used to experience were heat-related.
But the fan has helped a lot. The sensor used to read close to 70 C, now it typically reads more like 55 to 60 C. That's still very hot but I suspect you won't feel that much heat at the top of the heat sink.
And I get a lot fewer reboots, but since I've done other (software-related) things too, I can't be sure that the reboots I used to get were heat-related.
JHBrandt is offline
post #90 of 91 Old 04-30-2020, 08:44 PM
JHBrandt's Avatar
Liked: 1475
Setting up WiFi on the CyberBox
I've always used an Ethernet connection with my CyberBox, but my Ethernet connection goes through a power-line adapter that drops the network connection way too often. So WiFi would probably work better for me, but I never could get WiFi to work.
Turns out the problem was the CyberBox "Settings" app. It's horribly buggy and simply does not work correctly for setting up WiFi. Sure, it will find your WiFi network and you can click on it. then it will prompt you for the password - so far, so good. But you'll notice a problem: there's nothing to click on the password prompt screen! So you enter the password, then what? Pressing OK or Enter does nothing! You're just stuck on the password screen.
Well, I don't know why it took me so long, but I finally figured out a simple workaround. Instead of using the "Settings" app, use "Droid Settings" instead, then click "More Settings." This brings up the standard Android settings screen, and you can set WiFi up from there just as you'd set up a smart phone.
Kicking myself for not figuring that out a long time ago!
Edit: One more thing. If you have an Ethernet connection, it takes priority over WiFi; so you'll have to physically disconnect the Ethernet cable to get the CyberBox to use its WiFi connection.
JHBrandt is offline
Reply HDTV Recorders
