AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   HDTV Recorders (https://www.avsforum.com/forum/42-hdtv-recorders/)
-   -   Channel Master Stream+ Incorrect Aspect Ratio (https://www.avsforum.com/forum/42-hdtv-recorders/3113776-channel-master-stream-incorrect-aspect-ratio.html)
Patrick McGuire 01-03-2020 05:09 PM
Over the past couple of months certain recorded 16:9 widescreen shows are displaying in what appears to be 4:3 aspect ratio. Everything is squeezed into being tall and skinny. It actually appears to be narrower than 4:3. I contacted CM and the guy emailed me back saying "Google changed the way recorded 480i widescreen displays". He said "theres a fix though, just grab your tv remote and change the aspect ratio". Yeh, every time I want to watch a recording of a 480i widescreen show, I have use another remote, and switch it back afterwards. That's bad enough, but the tv's format function doesn't fully widen the image without stretching it.
CM says contact Google. I say, they should contact Google and get this corrected. Anyone else seeing this problem. H&I Network and Quest are two that do this. They look fine live, but recordings are squeezed.
arbegas 01-03-2020 07:07 PM
cm fixes its all about contact google.
if its ota via live channels its not too much that you can do i guess.
Kelson 01-03-2020 07:50 PM
Unfortunately, the CM Stream+ is only an Android hardware box that runs Android-TV as the OS. The functioning of the applications that provide all the functionality are the province of the app developers -- not CM. As long as the hardware runs as advertised, CM is in the clear. I suspect that is exactly the way CM wants it.
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
