PiGS: The Channel Master DVR+ EP Guide Server Replacement - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #61 of 97 Old 06-27-2020, 08:23 AM
For those that want to try out a Windows (or any OS that VirtualBox will run on for that matter)(just about any OS) solution without obtaining any additional hardware, I have created a set of instructions to create a Virtual Machine running Raspberry Pi Desktop OS. This is a pretty straight-forward solution. It has several steps. 95% or more just require clicking the Next or Continue button. Pay attention because those steps that require something different are important, too. I have been testing this and it seems promising. It has NOT been fully tested or vetted. Your results may vary. @timothee has put in a whole bunch of time in the PiGS solution and we should all be extremely grateful. I know I am. I bought a Pi 4B with 4 GB RAM just because I thought it was a sweet little project.
I then started playing around with options that didn't require additional hardware. The time that I put into this was minimal compared to what @timothee has done. Not even a "drop in the bucket", more like a "drop in the ocean." I just took an existing solution and applied it to @timothee 's solution. Virtual Machines were difficult for me to wrap my mind around initially, but once it clicked, it is now just fascinating. Most of it doesn't require any understanding of how it works. Just that it does work.
If you would like to experiment, here is a link to my Google Doc (everything referenced there is open-source and fully supported by other forums and resources on the Internet)(I "created" nothing but the Doc):
https://docs.google.com/document/d/1...it?usp=sharing
Out of respect, you will need to obtain the PiGS software from @timothee . My Doc just leads up to the very complete and informative spreadsheet @timothee has created.
This solution will allow you to boot it and leave it running 24/7 OR boot/shutdown whenever you want. There is likely a way to launch at Windows boot, but I haven't fully investigated.
Mark
pachinko, pilotart and timothee like this.
FitMark is offline
post #62 of 97 Old 06-27-2020, 12:54 PM
LenL's Avatar
Location: Randolph, NJ 925' elevation, 30 miles west of ESB
Quoted: 501 Post(s)
Liked: 353
FitMark,
You just confused me (It is easy to do).
So I have a computer now that has win10 on it. Are you saying to install virtual box in order for Raspberry Pi Desktop OS? Is this taking the place of installing Python for Windows 10? Eliminating the need?
LenL is offline
post #63 of 97 Old 06-27-2020, 12:55 PM
LenL's Avatar
Quoted: 501 Post(s)
Liked: 353
Originally Posted by 1badhombre View Post
LenL, AntiX is a good lightweight distro that does not implement systemd. You should be good to go. If anyone wanted to install a version of Linux that supports systemd you can still install dnsmasq. You just need to disable the systemd-resolved service. But it does take some tedious editing via the terminal.
The only problem is the only python that is supported seems to be 2.7.
LenL is offline
post #64 of 97 Old 06-28-2020, 05:58 AM
Originally Posted by LenL View Post
FitMark,
LenL,
Instead of trying to come up with a Windows specific solution (i.e. DNS Server and Python for Windows), you would be creating a Virtual Raspberry Pi instead of purchasing an actual (aka physical) Raspberry Pi computer. The only modification to Windows itself would be to install VirtualBox. From within VirtualBox, you create a "virtual machine" (aka VM) that functions the same as a physical computer. All of @timothee 's instructions would apply just the same as if you had a physical Raspberry Pi.
In addition, this same solution should work for a Mac, Linux or Solaris computers.
If you decide this solution is not for you, it is just a matter of deleting the VM and uninstalling VirtualBox.
Like I said previously, virtual machines are a mind boggling concept, but you really don't have to understand it all. Just accept the concept.
The attached photo is how the VM looks after it is "built" and running. It just runs in a window within Windows.
Hope this helps,
Mark
Name:	Annotation 2020-06-28 075321.png
pachinko and timothee like this.
FitMark is offline
post #65 of 97 Old 06-28-2020, 09:43 AM
1badhombre's Avatar
LenL,
If you go with the antiX Linux 19.2 Full version it comes with python 3.7.3. That said, I believe FitMark's suggestion of running Raspberry OS on Oracle's VirtualBox is the best solution for those who want to test PiGS without the need to buy additional hardware. Alternatively, you could install Raspberry Pi Desktop on your old laptop instead of antiX.
FitMark and timothee like this.
1badhombre is offline
post #66 of 97 Old 06-28-2020, 12:57 PM
Quoted: 20 Post(s)
Liked: 8
Originally Posted by flowersrj View Post
Another option...
Many routers are Linux based.
You might be able to add entries into its HOSTS file by using a program like puTTY.
This works on some routers, but I'm not sure it works on all.
I an running DD-WRT (Linux firmware) on my home router, and it has dnsmasq built in. All you need to do is tick the box to tell it to run dnsmasq (it doesn't run by default) and add the following line to the dnsmasq configuration: 'epg.channelmastertv.com/192.168.1.xx' where the 192....xx is the static IP of your guide server on your local network. That's it. No need for anything to run on the PC - the router does all the heavy lifting.
timothee likes this.
rudy.t is offline
post #67 of 97 Old 06-28-2020, 04:47 PM - Thread Starter
Quoted: 69 Post(s)
Liked: 106
I am running DD-WRT (Linux firmware) on my home router, and it has dnsmasq built in. All you need to do is tick the box to tell it to run dnsmasq (it doesn't run by default) and add the following line to the dnsmasq configuration: 'epg.channelmastertv.com/192.168.1.xx' where the 192....xx is the static IP of your guide server on your local network. That's it. No need for anything to run on the PC - the router does all the heavy lifting.
Yep, the router method with OpenWRT is the first thing I tried to redirect the dns. Once I figured out the Pi could do it, I abandoned the router idea since it seemed like extra hardware and I thought the Pi was required anyway. But now that PiGS runs without a Pi, its worth considering this method again, along with all the other methods that have been proposed.
DNS redirect probably deserves a whole tab on the spreadsheet because there are so many ways to do it.
I did just buy a Pi Zero off amazon for $17 and I'm going to try and configure that to do dnsmasq for a cheap DNS redirect method. I dont think the Pi Zero has enough HP run run the PiGS app (memory)
FitMark likes this.
timothee is online now
post #68 of 97 Old 06-28-2020, 05:42 PM
flowersrj's Avatar
Quoted: 20 Post(s)
With DD-WRT, you might not need DNSMASQ running. You can probably puTTY into the OS on DD-WRT and add "/ etc / hosts" entries to accomplish the same thing.
That's what I did with OpenWrt and I am not running DNSMASQ.
-flowersrj
flowersrj is offline
post #69 of 97 Old 06-28-2020, 07:18 PM
Quoted: 20 Post(s)
Liked: 8
Oh sure, I know that the etc hosts method works in DD-WRT, but running dnsmasq is as easy as ticking a box, and I can configure it from the management page.
Both are perfectly adequate solutions with no software to install. I just picked the easier one (for me).
rudy.t is offline
post #70 of 97 Old 06-28-2020, 09:33 PM
Quoted: 20 Post(s)
Liked: 8
I can't comment on PiGS memory footprint since I've never seen the code, but I've been running my own home grown guide server since the DVR+ guide started failing a few months ago, and the host has the same RAM as your Pi Zero -- 512MB.
512MB should be plenty to run PiGS if you switch to TinyCore Linux for the Pi since the memory footprint of your OS is huge compared to TinyCore.
My hardware is an Asus EEE-PC 700 laptop made in 2007 (900Mhz Celeron under-clocked to 630Mhz with 512 MB RAM). My disk drive is a tiny 128MB CF card in a USB reader booting x86 TinyCore Linux. Basically, all that's running is the Linux kernel, Python, my script, and sshd for remote access. Lean and mean, no X, no wireless, nothing not needed. Yes, my 512MB RAM is 4x larger than my disk drive ;-) Laptop has been on 24/7 for close to a decade - it's a tank!
rudy.t is offline
post #71 of 97 Old 06-29-2020, 05:51 AM
LenL's Avatar
Quoted: 501 Post(s)
Liked: 353
LenL,
I reloaded with AntiX 19.2 (I think the full version as the ISO was so large I put it on a DVD) and python 2.7 was the version installed. No to 3.7.3.
So right now I blew it away and installed Raspberry PI for the desktop. I am now dealing with the fact that Debian Linux does not recognize my Broadcom b43 card for wireless connection. That is probably why I went with other Linux versions that have no issue with older wireless cards. SO I am spending time trying to get around this issue. I have other ways to connect my laptop (Wired or Wireless USB) so I may give up trying to fix this issue for now and move to the next step in the PiGs installation. So far a very rocky journey for me and I am only at the very beginning.
LenL is offline
post #72 of 97 Old 06-29-2020, 07:44 AM
I just reconfigured my Virtual Pi to use 512 MB (instead of 1024 MB). It booted. I'll monitor.
Mark
kwg and timothee like this.
FitMark is offline
post #73 of 97 Old 06-29-2020, 07:49 AM
I just built another Virtual Machine with Tiny Core (I used 512 MB RAM and 1024 MB HDD). It's a bit more cumbersome than Raspberry Pi Desktop OS, but that is just because of my unfamiliarity. I'll have to do a little digging (aka Googling) to get dsnmasq, Python and PiGS installed and configured. Or..., should I just be able to use @timothee 's instructions? I'll keep you posted.
Mark
FitMark is offline
post #74 of 97 Old 06-29-2020, 09:24 AM
Quoted: 20 Post(s)
Liked: 8
Definitely more cumbersome to install because TinyCore's philosophy is completely different. It's a bare (really bare) bones system that you build on, adding only the components you need, rather than a fully functioning desktop distro. tce-ab is the app that searches for and installs extensions and all their dependencies. You'll need to install dnsmasq.tcz and python3.6.tcz (not python.tcz which is Python 2.x).
I build my systems with Core.iso and not TinyCore.iso because I don't need X - all y really need is two files, core.gz and vmlinuz, which are pre-configured for wired Ethernet.
FitMark likes this.
rudy.t is offline
post #75 of 97 Old 06-29-2020, 10:01 AM
LenL's Avatar
Quoted: 501 Post(s)
Liked: 353
LenL,
RaspBerry Pi Desktop Installed as the OS on my old Lenova laptop. I will now try to follow the rest of the instructions today and try to make some more progress.
Stuck at step 6 as leafpad command not recognized. Also ping of channelmastertv.com not returning results. WIFI is up and running. I can ping the router. lots of issues to fix.
LenL is offline
post #76 of 97 Old 06-29-2020, 12:04 PM
Quoted: 13 Post(s)
Liked: 4
Originally Posted by chazdole View Post
Thanks for the tips. Yeah, I think I'll keep my grubby mitts out of the NAS. As I recall, setting it up required several hours for the unit to format/prepare the hard drives. Then the OS and then the files. No thanks.
However, the wife's company has a "spare" DS 213 that I setup as their server in 2014. They have since grown into a multi-million $ company, and have outgrown my skill set as their IT guy. They use a windows computer as their server now. We'll see how reliable that is, as the Synology NAS was rock solid for 5 years. I'm glad they have someone else do their IT work.
Not sure if I will borrow their NAS to try PiGS. Would be fun, but I have too many remodeling projects to do on my 1928 house in my "spare" time. Will post if I lose my mind and try it.
I've been thinking right from the start of this about getting PiGS running on my Synology NAS. I know there have been various DVR and Plex solutions for the DiskStations, though mine is pretty old. I just looked to make sure and there is a Python development package available as well as a couple DNS options. I also have DD-WRT on my router so we'll see how I feel in a few weeks. I'm not a programmer and I know people have had problems with DiskStations where they still had to telnet into the box and use the default password to gain root access and all sorts of other fun stuff so, again, we'll see.
jeff275 is offline
post #77 of 97 Old 06-29-2020, 01:07 PM
frank70's Avatar
Quoted: 213 Post(s)
Liked: 174
Weird Ellen DeGeneres episodes text
Today’s Ellen Show had normal descriptive text, but for Tuesday onward the text has Ellen’s name replaced (in two places) by the string tWitch. Is this an SD error?
Never mind (see below)
frank70 is online now
post #78 of 97 Old 06-29-2020, 01:15 PM
frank70's Avatar
Quoted: 213 Post(s)
Liked: 174
Never mind... It seems that is actually a real person’s name and apparently substituting for Ellen.
rahanner and timothee like this.
post #79 of 97 Old 06-29-2020, 01:55 PM - Thread Starter
Quoted: 69 Post(s)
Liked: 106
I'm guessing that info does not appear on the CM guide!!
pachinko likes this.
post #80 of 97 Old 06-29-2020, 02:15 PM - Thread Starter
Quoted: 69 Post(s)
Liked: 106
Line 24 of instructions
Note about Text Editors... each Pi seems to have different editors, look in Raspberry Menu>accessories>Text editor
you will be editing some system files, which need to be run from the command line with the "sudo"
sudo leafpad <filename>
sudo nano <filename>
sudo apt install leafpad << cmd to install leafpad if the leafpad command does not work
someone also mentioned Mousepad or mousepad
post #81 of 97 Old 06-29-2020, 03:23 PM
frank70's Avatar
Quoted: 213 Post(s)
Liked: 174
Real programmers user vi (available on every linux/unix system for the past 30+ years).
Arenal04 and timothee like this.
post #82 of 97 Old 06-29-2020, 04:25 PM
Quoted: 20 Post(s)
Liked: 8
I proudly fly the vi flag here (actually vim these days). Vi rules!
Sadly a "good" vi is not part of many of the less-bloated Linux distros these days. Yes, they all have a vi command, and a vi-like editor, but it's usually the busybox version, which is frustratingly limited. Vi users can't live without the . command
rudy.t is offline
post #83 of 97 Old 06-30-2020, 05:36 AM
Arenal04's Avatar
Quoted: 165 Post(s)
Liked: 105
I'd have to add the command-line commands, i.e. the ":" command, and the "^" and "$" special characters (beginning of line and end of line, respectively). Okay, I'm dorking out.
Arenal04 is offline
post #84 of 97 Old 06-30-2020, 09:39 AM
frank70's Avatar
Quoted: 213 Post(s)
Liked: 174
vi is the visual extension of ex, which in turn is an extension of ed, which came out of Berkeley (along with Unix) in the early 70s. The ":" bounces you momentarily back to the underlying ex. I guess if there is no underlying ex, that might not work, but a vi clone for DOS/Windows called Elvis that's been around for eons supports ex commands as well as "^", "$", and ".", and just about everything else.
These are the "original" text editors for Unix - eventually along came emacs, but I could never get into all the key combinations.
Sorry for the disruption - back to your regularly scheduled PiGS programming.
post #85 of 97 Old 07-01-2020, 07:31 AM
LenL's Avatar
Quoted: 501 Post(s)
Liked: 353
In the NY metro area PBS WNET 13.1 (RF13) is moving to RF 12 on 7/2/2020 at 9 AM. Of course the current guide on the DVR+ will NOT show this change until the next update. (maybe if we are lucky?)
Curious as to how PIGS will handle this using Schedules Direct. However I am only working on step 7 of the instructions and stuck there at the moment. Don't think I will be up and running by 7/2.
LenL is offline
post #86 of 97 Old 07-01-2020, 07:52 AM - Thread Starter
Quoted: 69 Post(s)
Liked: 106
I don't know how SD will handle it. but RF is not really part of the guide process. you are indicating that the RF channel is changing, not the actual channel # 13.1. you will have to rescan with your DVR, but the channel number would remain the same and should not affect the guide. one thing that would be helpful is if you captured what your dvr looks like after the rescan. I heard sometimes the old channel gets bumped up to 100+ - I would like to see this. 1) take some pictures of your guide with the new channel showing and the old channel if it is there, and 2) when tuned to each channel (old and new if possible), pictures of the DVR Menu>Technical Information>Signals & Network. that shows the RF and also channel details that would help pigs remap stuff if needed.
I believe JHBrandt had a suggestion about this a long time ago... something about remapping. I could probably make a 'hidden' ChannelRemap[] list that would handle the actual channel number changing if there was a need. SD is pretty good about getting lineups changed when needed if you have an account and give the details about the rf remap.
post #87 of 97 Old 07-01-2020, 08:00 AM
LenL's Avatar
Quoted: 501 Post(s)
Liked: 353
You are probably right it will remain 13 in the guide as they are keeping channel as 13.1. So a non issue?
LenL is offline
post #88 of 97 Old 07-01-2020, 08:05 AM - Thread Starter
Quoted: 69 Post(s)
Liked: 106
see what dvr does, take some pics and we will know soon!
post #89 of 97 Old 07-01-2020, 08:42 AM
Quoted: 20 Post(s)
Liked: 8
This won't happen with a complete rescan because the old channel is gone. The DVR+ won't remember the old channel was there.
If you do a manual scan of just the affected channel, then yes, the new frequency will appear at 100+ and the old dead frequency will still be there where it's always been.
That being said, if you happen to hit rescan and both the old and new transmitters are on, you will get a channel at 100+, but that'll only happen if the TV station screws up
Lots of stations moving this week - July 3rd is the expiry date for current (last) wave or repacks. My WVNY-22 is going from RF14 (hi-VHF) to RF7 (mid-VHF) so I'm going to lose it completely. My antenna is UHF, but catches RF14 because it's the highest VHF station and closest to UHF.
rudy.t is offline
post #90 of 97 Old 07-01-2020, 01:36 PM
frank70's Avatar
Quoted: 213 Post(s)
Liked: 174
RF14 is UHF (470-476 MHz), not HI-VHF. The highest frequency VHF channel is 13 (210-216 MHz).
rahanner likes this.
Reply HDTV Recorders
