New JVC DVHS Decks ( HM-DH5U and HM-DT100 ) Discussion - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 785 Old 08-17-2004, 04:52 PM
alk3997's Avatar
Liked: 94
Stereo Advantage claims to have the HM-DH5U available. I don't know if it is true or not. Amazon still has the "coming soon" stamp.
http://www.stereoadvantage.com/homevideo.htm
alk3997 is offline
post #32 of 785 Old 08-20-2004, 10:43 AM
Troy LaMont's Avatar
Quoted: 282 Post(s)
Liked: 261
JVC now has the HMDH5U on their website. MSRP $799.
Troy
Onkyo TX-NR807
Polk LSi15, Polk LSiC, Polk LSiF/X, Velodyne HGS12
Optoma HD80 on 106" Elite Aeon Cine grey, Samsung Q6FN (2018)
Xbox One X, Samsung UH750 Quantum Dot 28" UHD monitor
Troy LaMont is offline
post #33 of 785 Old 08-20-2004, 05:39 PM
Frank D's Avatar
Quoted: 417 Post(s)
Liked: 101
Re: HMDH5U
The description on the JVC website does not say anything about DTS for this model it only indicates Dolby Digital. Does that mean that this unit can not output DTS?
Regards
Frank
Frank D is offline
post #34 of 785 Old 08-20-2004, 10:58 PM
HDTVFanAtic's Avatar
Originally posted by Frank D
Re: HMDH5U
Regards
Frank
The stereo advantage website sure mentions it in the description:
Built-in MPEG2 Decoder for Direct Connection to HDTV via Y/Pb/Pr or HDMI (High Definition Multimedia Interface)
Digital Set-top box ready with Digital-to-Digital connection via i.Link (IEEE 1394) terminal
MPEG-2 CODEC encoding/decoding for digital recording of NTSC sources
HDTV Digital Broadcast Bitstream Recording/ Playback
D-Theater compliant with the advanced D-VHS security system
Can Record Any Type of Broadcast including HD, SD or Analog
HS mode (28.2 Mbps) for up to 3.5 hours* HDTV recording STD Mode (14.1 Mbps) for up to 7 hours* SD recording LS3 Mode (4.7 Mbps) for up to 21 hours* long-time recording * and LS5 mode for up to 35 hours* long-time recording *per DF-420 cassette
Frame Synchronizer for pristine analog-to-digital dubs
D-VHS (HS, STD, LS3) S-VHS (SP, EP) S-VHS ET (SP, EP) HiFi VHS (SP, EP) VHS (SP, EP)
Full Spec HDTV Compatible (with all 18 ATSC broadcasting formats)
DigiPure Technology for high resolution analog recording and playback
5.1 Dolby Digital Output (optical)
2 channel Linear PCM Audio Output capability
1080i, 720P, 480P and 480i
2 Sets of AV inputs
S-Video inputs
2 Sets of AV outputs
2 S-Video Outputs
1 Component Video Output (Y, Pb, Pr)
1 x Optical Digital Output
2 x I.Link Terminal (IEEE 1394), DV input only for camcorders
Front Inputs ( AV, S-Video, i.Link)
Video Navigation- Tape Number, Record date and Category sorting
MTS Decoder for SAP programs
VCR Plus+ with provided cable box controller
Express Programming
Plug and Play for automatic tuner and clock set-up
1-year / 24-event programmable timer
Av Compu Link
Multi-Brand TV/Cable/DBS compatible Glow Key Remote Control
1 Year Parts, 90 Days Labor
Weight: 13.5 lbs.(6.1kg)
Width: 17.1?(435mm)
Height: 3.8?(97mm)
Depth: 13.7?(348mm)
Availability: Usually ships the next business day.
JVC-HMDH5UManufacturer's List Price: $799.95Sale Price: $599.90
HDTVFanAtic is offline
post #35 of 785 Old 08-21-2004, 08:10 AM
Emaych's Avatar
Quoted: 523 Post(s)
Liked: 256
Still unclear -- does the unit include the hi-def tuner?
Emaych is online now
post #36 of 785 Old 08-21-2004, 08:57 AM
DaveFi's Avatar
Quoted: 727 Post(s)
Liked: 233
The DH5U doesn't have the tuner- That model costs twice as much (don't ask me why).
Why does the 40K have a higher MSRP?
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #37 of 785 Old 08-21-2004, 10:32 AM
Chris Gerhard's Avatar
Because prices have come down and it is an older model, the same reason the 30K has a higher MSRP than the 40K. This is of course the same reason my 12 year old 486 computer had a higher MSRP than a current Pentium 4. Manufacturers usually don't reduce the MSRP on discontinued products when new products are released. The 40K can be found for a much lower price than the 5U despite the higher MSRP.
Chris
Chris Gerhard is offline
post #38 of 785 Old 08-21-2004, 01:55 PM
rabident's Avatar
Quoted: 416 Post(s)
Liked: 142
HDTVFanAtic,
I don't see any mention of DTS in what you quotes either. Are you implying that since it's "D-Theater compliant" it also works with DTS? The 30k was D-Theater compliant, but it couldn't output DTS. They specifically list Dolby 5.1 below, but not DTS.
Maybe that will be another differentiator between the 2 models? I hope not. I also hope they're not dropping DTS. Anyone have any info?
Built-in MPEG2 Decoder for Direct Connection to HDTV via Y/Pb/Pr or HDMI™ (High Definition Multimedia Interface)
2 Sets of AV inputs
S-Video inputs
2 S-Video Outputs
Express Programming
Av Compu Link
Width: 17.1?(435mm)
Height: 3.8?(97mm)
Depth: 13.7?(348mm)
rabident is offline
post #39 of 785 Old 08-21-2004, 02:56 PM
fcsmith's Avatar
Quoted: 26 Post(s)
I don't think they list DTS for the 40K either, but I think it supports it. Maybe it's an "undocumented feature".
fcsmith is offline
post #40 of 785 Old 08-21-2004, 05:20 PM
Sorry - second time I've screwed up DTS an D-Theater - guess I need to read slower
post #41 of 785 Old 08-21-2004, 06:28 PM
This site indicates the HM-DH5U has DTS capability. I don't know if it is right or not but I can't imagine that JVC would drop DTS from the current models.
http://www.dotcities.com/dotcities_p...sinSearch.html
Chris
post #42 of 785 Old 08-23-2004, 08:38 AM
alk3997's Avatar
Liked: 94
Check the 5u photo on either the JVC or the above referenced web site. The second logo to the left on the bottom right of the 5U appears to be the DTS logo.
alk3997 is offline
post #43 of 785 Old 08-23-2004, 10:48 AM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
alk3997, I just noticed the same thing. Also, the Viktor HM-DHX2, the Japanese equivalent to the HM-DH5U has the DTS logo prominently displayed in the same spot.
I might be getting one of these in the next week or two so I can verify by then.
bferr1 is offline
post #44 of 785 Old 08-23-2004, 10:24 PM
I seem to be going back and forth on ordering one of these.....i probably would have done it from etronics this past weekend who claim they are in stock for $549 if i hadn't read some bad reviews on them saying things were in stock that werent.
I think I have $150 worth of amazon certificates somewhere as well. Might take the plunge if I could find it there at a reasonable price.
Anyone KNOW of anyone that REALLY has the deck at a decent price?
post #45 of 785 Old 08-24-2004, 02:56 AM
W.Mayer's Avatar
Quoted: 239 Post(s)
Liked: 305
seams no one have it truly on stock.
reason is may that jvc not have released the units till today.
W.Mayer is offline
post #46 of 785 Old 08-24-2004, 10:35 AM
johnovox's Avatar
Quoted: 27 Post(s)
I am hoping the new model has an improved MPEG decoder and improved component out quality. Has anyone heard anything in this regard?
johnovox is offline
post #47 of 785 Old 08-24-2004, 05:12 PM
works4me's Avatar
Well Folks,
I am looking at the mauals front page and it shows the DTS insignia saying Digital Out
the specs page lists the Optical connector passing both the Dolby Digital Out stream and the DTS digital output stream.
Lastly the glossary specifies that there is no digital decoder just that it will be glad to pass it along to your decoder.
Stereo Advantage has them in stock..
HM-DH5U that is
Kevin
works4me is offline
post #48 of 785 Old 08-24-2004, 06:49 PM
well Kevin, as you don't list a location, I can't exactly tell where Stereo Advantage is located. Where are they and what are they charging for the unit. Did you purchase one?
post #49 of 785 Old 08-24-2004, 07:13 PM
works4me's Avatar
I am new to this forum.
I do computers for living and assume everyone can read my mind.
I actually figured everyone on this forum would know much more than me and would get it.
I got it from one of the subscribers on the forum.
Took about a week.
Not enout posts yet to place a URL PM me
But the address is in this thread.
Kevin
Take Care
works4me is offline
post #50 of 785 Old 08-25-2004, 06:58 AM
ktoolsie's Avatar
Quoted: 34 Post(s)
I placed an order with Stereo Advantage for a JVC HM-DH5U last week Thursday.
My unit was shipped today, scheduled delivery is on the 27th of this month.
Kurt
ktoolsie is offline
post #51 of 785 Old 08-25-2004, 07:25 AM
Brajesh's Avatar
Quoted: 559 Post(s)
Liked: 285
Kurt, we'll be eagerly awaiting your impressions of the HM-DH5U.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #52 of 785 Old 08-25-2004, 10:07 AM
Matt_Stevens's Avatar
Liked: 48
Big time. I am very curious about the new deck.
Vimeo is the home of the Super8 Shooter...
http://vimeo.com/super8shooter
Matt_Stevens is offline
post #53 of 785 Old 08-25-2004, 10:37 AM
Me too and in a couple of years we will know if it is any better than the earlier models.
Chris
post #54 of 785 Old 08-25-2004, 12:03 PM
ktoolsie's Avatar
Quoted: 34 Post(s)
So what the consensus on the best blank tape to use?
I've got some old high quality S-VHS tapes lying around which I can (maybe) use until my order of JVC D-VHS tapes is delivered.
Kurt
ktoolsie is offline
post #55 of 785 Old 08-25-2004, 12:26 PM
Liked: 48
Fuji S-VHS tapes rock. I have a failure rate of maybe 0.05% tops.
I like JVC's D-VHS tapes as well. I use them for the more important recordings.
post #56 of 785 Old 08-25-2004, 12:43 PM
Any D-VHS tape works great and any high grade SVHS tape I have tried works great. Fuji H471S tests out best on my equipment. Standard grade SVHS has been hit or miss for me so I quit using it. H471S is often more expensive new than D-VHS tape but I use it whenever I can find it in great shape used at a great price.
Standard grade Fuji has been the worst for me, much worse than Matt's .05% if he is talking about standard. Based on my experience with SVHS, I would expect JVC standard grade SVHS to be bad also but I have never tried it for D-VHS.
Chris
post #57 of 785 Old 08-25-2004, 12:51 PM
Liked: 48
That is odd, Chris. I and a good friend of mine use them all the time. We have recorded hundreds, if not thousands of times onto these tapes and have almost no problems. I think I have had 2 bad tapes all year.
post #58 of 785 Old 08-25-2004, 01:13 PM
Brajesh's Avatar
Quoted: 559 Post(s)
Liked: 285
I've had great success w/Fuji SVHS tapes as well. This was when I had my Panny HD1000 deck & now w/the JVC 30K.
Brajesh is offline
post #59 of 785 Old 08-26-2004, 10:46 AM
trendscape's Avatar
Kurt:
Did your Stereo Advantage order ship? I want to place an order myself.
trendscape is offline
post #60 of 785 Old 08-26-2004, 11:28 AM
If I recall, I had about 3 or 4 bad D-VHS recordings out of 10 using Fuji standard grade SVHS. I reused the same SVHS tape for SVHS recording and it worked fine and I have never used it again for D-VHS. I have never had a bad Fuji H471S. I tested the standard grade Fuji using my Hitachi D-VHS VCR which has a tape quality reading that has proven reliable for testing D-VHS tape suitability and the tape failed to get an acceptable reading so it won't be used by me. Since I have several different D-VHS VCRs, I know that some are more SVHS tape friendly. I would expect my Mitsubishi D-VHS VCR would work fine with standard grade SVHS while some of the others will not. Just to simplify, I use tape that works well with all of the VCRs.
Chris
Reply HDTV Recorders
