Whats Is 1.66:1 Aspect Ratio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-02-2004, 12:04 PM - Thread Starter
J.H.'s Avatar
I see this aspect ratio on the Night To Remember DVD.Whats is it?Is it an odd aspect ratio?Is it Anamorphic on this DVD?Thanks J.H.
J.H. is offline
post #2 of 8 Old 11-02-2004, 12:13 PM
Version's Avatar
1.66:1 means the horizontal is 1.66 times as long as the vertical.
It is a fairly common aspect ratio. Most Disney animated movies for example are made in 1.66:1 aspect ratio.
It can be anamorphic.
As far as DVDs go, anamorphic means that the encoded image is 1.78:1 or 16:9. For 1.85:1 films that requires a small black bar to be added to the top and bottom of the image, for 1.66:1 films it requires a small black bar to be added to the sides of the image. Not sure if the particular DVD you are asking about is anamorphic though. Sorry.
Version is offline
post #3 of 8 Old 11-02-2004, 01:49 PM
Art Sonneborn's Avatar
Quoted: 1179 Post(s)
Liked: 1611
This was also the aspect ratio used as the European wide screen at one time. The first three James Bond Films were 1.66:1 as was the Hitchcock film Frenzy for example.
Art
Art Sonneborn is offline
post #4 of 8 Old 11-02-2004, 03:36 PM
Shaded Dogfood's Avatar
Quoted: 118 Post(s)
Liked: 85
The Europeans use it a lot.
CW Hinkle
Shaded Dogfood is offline
post #5 of 8 Old 11-02-2004, 03:44 PM - Thread Starter
J.H.'s Avatar
Thanks for the informations it really helped.So the picture should not fill the whole screen with 1.66:1? J.H.
J.H. is offline
post #6 of 8 Old 11-02-2004, 06:06 PM
DblHelix's Avatar
It shouldn't although most disney DVDs that are 1.66:1 anamorphic crop it the same as what would be done in most US theaters and recompose to 1.85:1
DblHelix is offline
post #7 of 8 Old 11-02-2004, 06:29 PM
Hesitant's Avatar
The 40th Anniversary Special Edition Dr. Strangelove or: How I Learned to Stop Worrying and Love the Bomb dvd is 1:66 anamorphic 16:9.
http://www.dvdtalk.com/dvdsavant/s1407love.html
Hesitant is offline
post #8 of 8 Old 11-02-2004, 06:36 PM
Frode's Avatar
1.66:1 is the same as 15:9. While European widescreen sets are 16:9, due to overscan most proper 15:9 titles will look just like normal 16:9 titles - the black bars get eaten by the overscan border.
/frode
Frode is offline
Closed Thread Movies, Concerts, and Music Discussion
