Odessa / Midland, TX - HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-14-2008, 08:53 AM - Thread Starter
jrogers3's Avatar
I can get the following DTV Off-air channels in Midland/Odessa Tx:
ABC 2.1 KMID SD
CBS 7.1 KOSA HD
CBS 7.2 MYTV16 SD
Fox 24.1 KPEG HD
PBS 36.1 KPBT HD
PBS 36.2 KPBT SD
I cannot get 9.1 which is NBC HD. I can get 9, but the reception is aful. Any advice?
jrogers3 is offline
post #2 of 6 Old 09-14-2008, 09:08 AM
Trip in VA's Avatar
Quoted: 1567 Post(s)
Liked: 643
Send a message via AIM to Trip in VA
ABC 2.1 KMID SD
CBS 7.1 KOSA HD
CBS 7.2 MYTV16 SD
Fox 24.1 KPEG HD
PBS 36.1 KPBT HD
PBS 36.2 KPBT SD
What antenna are you using? All the stations you list have UHF digitals, while 9-1 is on VHF (channel 13). Maybe you should try some rabbit ears.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #3 of 6 Old 12-02-2008, 12:27 PM
mdamberger's Avatar
(VHF DX) For S.E. NM viewers; Live DTV test for Ch.8 & Ch.10 Dec. 3rd
This may be of interest for off air viewers near Midland-Odessa area and looking to see VHF DTV performance at a distance, DX.
For viewers in S.E. NM. KOBR and KBIM, will be conducting a coordinated engineering test of both stations transmission and antenna systems.
Starting sometime after midnight Dec. 3rd and finishing before 6am Dec.3rd. This test will use both stations post DTV transition RF channels, 8 & 10. During the test both stations low power DTV transmitters will be shut down, ch.38 (8) & ch.41 (10). A test pattern or SD programming will be passed; HD equipment is not yet in place for this DTV test.
Both stations will be conducting reception reports from cable companies within the viewing area of their VHF DTV signals. We would appreciate any reports from off air viewers who would be up at this time. Please pass this on if you know of anyone interested. Any performance reports of digital VHF reception is of great interest.
Marcus Damberger
KBIM
mdamberger is offline
post #4 of 6 Old 01-26-2009, 03:42 AM
loomdog32's Avatar
I just moved to Big Spring and was hoping to find more info on OTA in this area... I can only really get ch 9 NBC analog!! nothing digital!! antennaweb only shows odessa channels (less than 50 miles away) and no ch 9 nbc???
loomdog32 is offline
post #5 of 6 Old 12-31-2018, 11:19 AM
csworldwide1's Avatar
Quoted: 12 Post(s)
Major bump. KOSA-TV is shuffling its subchannels around.
The CW & Telemundo is moving from KWES to KOSA.
From KOSA's website.
7.1 - CBS
7.2 - The CW (from KWES 9.2)
7.3 - Telemundo (SD) (from KWES 9.3)
7.4 - Ion
7.5 - Telemundo (HD)
7.6 - MyNet (from KOSA 7.2)
7.7 - H&I (from KOSA 7.3)
Not sure if 7.5-7.7 comes from KOSA's signal or KTLE's digital signal on RF channel 20.
KWAB's signal will also change
4.1 - The CW
4.2 - Telemundo
4.3 - H&I
Not sure what KWES will replace on 9.2 & 9.3.
csworldwide1 is offline
post #6 of 6 Old 12-31-2018, 04:14 PM
unclehonkey's Avatar
Quoted: 584 Post(s)
Liked: 159
I would think 7-5 thru 7-7 will come off the low powered station KTLE-LP
Here in Minneapolis, Minnesota we have 3 examples of stations merging their PSIP's together off 2 RF stations.
unclehonkey is offline
