Buffalo, NY - HDTV - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 117Likes
post #121 of 8100 Old 02-09-2003, 09:41 AM
dzt41j's Avatar
Quoted: 16 Post(s)
Forogot to ask, does anybody see audio sync problemns on wivb? Sometimes it seems worse than others.
dzt41j is offline
post #122 of 8100 Old 02-09-2003, 10:22 AM
sprocto4's Avatar
I have seen issues with audio sync, but none lately. Just occasional dropouts during 9:30 to 11:00 pm viewing. No problems with NBC.
sprocto4 is offline
post #123 of 8100 Old 02-10-2003, 01:47 PM
theedge's Avatar
Originally posted by dzt41j
What about the other Buffalo stations? Is "waiting for permit" mean they are closer to going live than the ones with a date?
Hey neighbor...
... PBS is looking at fall as far as I can remember
... WKBW is looking at spring
Other channels (29/49/etc are probably fall too... I imagine 23 can get it together soon since they are already multicast on 4-1/39-4
Dish Network XM Sirius? Talk about a no-win situation.
theedge is offline
post #124 of 8100 Old 02-12-2003, 04:24 AM
stjefrey's Avatar
I wrote to the local PBS Buffalo station and they said that they will be offering digital TV sometime in March. You can also look here for more info.
www.titantv.com
Steve
Sony XRB-930C
Sony Playstation 4
Mitsubishi 1100 DVHS
stjefrey is offline
post #125 of 8100 Old 02-13-2003, 05:15 AM
dzt41j's Avatar
Quoted: 16 Post(s)
Anyone else from Lockport here?
dzt41j is offline
post #126 of 8100 Old 02-18-2003, 09:13 AM
theedge's Avatar
Just me...
theedge is offline
post #127 of 8100 Old 02-25-2003, 10:47 AM
EK11's Avatar
Need Help
I cant seem to a get a signal from wivb-dt. I get wgrz-dt very well(usually 85-95%). I dont believe its a direction problem as the transmitters are only 12 degrees apart from my location. Is wivb's signal strength that much weaker? I'm using a radio shack amplified set top antenna(rs-1890)
Maybe its just a crappy antenna. I would prefer not go to the roof as I live on the first floor of a three story house(lots of cable to run). I cant imagine the houses across the street cause that much interference as I get wgrz so well.
Any help would be greatly appreciated.
EK
EK11 is offline
post #128 of 8100 Old 02-25-2003, 12:26 PM
midnite cowboy's Avatar
You do not say what channel you are trying to get wivb. I have the sammy 160 and I noticed about 5 weeks ago the hi-def signal went from 39-2 to
4-1. Have you tried either 39-2 or 4-1? I live on Grand Island and get both signals very well using an old (27 years) rotor antenna in attic...Joe
midnite cowboy is offline
post #129 of 8100 Old 02-25-2003, 12:28 PM
I would like to clarify my statement about receiving both signals well. I meant wgrz (2-1) and wivb (4-1). Sorry about that...Joe
post #130 of 8100 Old 02-25-2003, 01:03 PM
EK11's Avatar
Joe,
I get 2-1 & 33-1 both wgrz 85-95 signal strength
I cant get 4-1 or 39-1(2or3) wivb
When I do a channel search on my dtc-100 it recognize 2-1 &33-1 and all the analog signals but no 4-1 or 39-?
A freind a block over gets both well, but then again hes on 2nd floor w/ dish and wing antenna mounted on 10 foot pole on his deck, maybe I'm just to low to the ground.
I find it weird that I get one and not the other since they transmitt from relatively close areas in relation to my location. 156 vs. 142 degrees.
I may have to bite the bullet and get a roof top ant. but then I have to wait 'til it gets warmer out. Who knows when that will happen.
thanks,
Erinn
BTW ABC(WKBW) has pushed date back, now looking @ July
EK11 is offline
post #131 of 8100 Old 02-25-2003, 05:38 PM
EK11's Avatar
Just got done screwing around with different placements.
Moved the ant up 4', got my dtc-100 to recognize 39-1, 39-1, 39-1.(all @ 28%)
then only 39-1, 39-1wnlo-dt (didnt know they were up, maybe just testing)
Never able to get vid or aud from any, then all but 1 went away???
Still no cbs(wivb-dt). bummed out because they have the most shows broadcast in HD.
If theres anyone in the Elmwood/Bidwell(BuffaloNY)area with a solution, I would be most grateful.
At Wits End?????
EK
EK11 is offline
post #132 of 8100 Old 02-26-2003, 10:15 AM
theedge's Avatar
Yes, WNLO is up (as 39-4 on my E86 Hughes) but not HD...39-3 shows up as a weather radar and 39-2 (and 4-1) shows up as WIVB-4. No problems with a Silver Sensor Antenna on top of my TV in Lockport.
theedge is offline
post #133 of 8100 Old 02-27-2003, 07:35 AM
Erinn,
Is it possible you have a receiver problem and not a antenna problem?..Joe
post #134 of 8100 Old 02-27-2003, 07:45 AM
Erinn, I will be on the road for a few days so if you are looking for a response it won't be till Sunday or Monday..Joe
post #135 of 8100 Old 02-28-2003, 03:49 AM
jurassicjockey's Avatar
EK11
Just wanted to make sure that you're aware that 39-1 is only broadcasting during primetime, 8-11. If you're receiving 33, you sure should be receiving 39 since their signal is several times stronger.
Steve
If a man speaks in the forest, and there's no woman around to hear him, is he still wrong?
jurassicjockey is offline
post #136 of 8100 Old 05-02-2003, 06:24 AM
daredevil23's Avatar
Have any of the new stations gone live yet?
Has UPN started broadcasting on Ch. 32 or is it still being parasitical on 39-3?
Oh great, WPXJ-DT is on 53 which happens to conflict with City-TV-DT on 53 out of Toronto.
Married Men Live Longer Than Single Men, But Married Men Are More Willing To Die.
All Rights Reserved.
daredevil23 is offline
post #137 of 8100 Old 05-21-2003, 04:29 AM
Just recieved my Fusion II HDTV card yesterday and was pleasantly surprised the WNED-DT is already live before the May 31st projected date.
The assigned channel is 43 and it maps in as 17-1 showing the demo loop and 17-2 simulcasting the analog broadcast.
Now if only the other channels would get their HDTV up and running.
post #138 of 8100 Old 05-21-2003, 04:51 AM
Forum failed to bump date, bump again.
post #139 of 8100 Old 05-22-2003, 01:34 PM
theedge's Avatar
That is good news about PBS in Buffalo! Thanks for the heads-up!
theedge is offline
post #140 of 8100 Old 05-23-2003, 09:04 AM
theedge's Avatar
Tried it last night... 43-1, 43-2, 43-3 all remapped to 17-1, 17-2 and 17-3.
17-2 seems to be the normal WNED PBS feed...
17-1 had a lot of Scenic shows on like HDNets "Over America" etc...
17-3 had the WNED logo...
This was harder to get in than WIVB or WGRZ... those come in at 100% signal strength and WNED comes in at a max of 65! Time to get the antenna in the attic!
theedge is offline
post #141 of 8100 Old 05-23-2003, 09:33 AM
I see that Faux in Erie is showing as live on TitanTV, albeit at a whopping 1.2 kw. Anybody in the Buffalo or Erie area picking them up on channel 22.
post #142 of 8100 Old 05-23-2003, 09:47 AM
kb2tdu's Avatar
Got my HiDTV card running last night. The antenna is the biggest RS combo (VHF-FM-UHF) on a mast with a rotator, with a mast-mount preamp, about 20' above ground; my loc is relatively high, not in a valley IOW. This rig has pulled in clear UHF analog from Toronto and occasional tropo-ducting from Detroit, Toledo, Erie ... i.e. it has GAIN. (I live in Hamburg.)
Either the HiDTV card is picky or DTV is rather sensitive to multipath. Unless I rotate the antenna towards the xmitter, WIVB-DT breaks up or freezes fairly often. IOW, I can't just leave it pointed at Grand Island like I was hoping to. Ch 4's transmitter is maybe a dozen miles to the southeast of me.
With said ant pointed at Grand Island (if it's off even a little the multipath on ch 29 is terrible) I could not get a clean pic from Ch 17/43. A clean analog signal on 17, yes. The digital would either not lock, or would freeze and macroblock all over the place. Signal strength seemed to be in the 80s most of the time so I can't explain it. Anyone know if WNED-DT is at full strength?
Also, my subchannel list on 43 showed 17-0 analog, 17-1,2,3 digital. Too bad they plan SDx? instead of some real HD, but if it means they'll run some of the shows they ignore in favor of Britcoms and old movies then yay. If it means fund raising 24x7x365.25, well too bad they took away my national PBS feed from DirecTV.
I have the HiDTV plugged into a spare SVGA monitor (15" Sony trinitron). The picture is fabulous, better than I ever expected. Some day I will get a display big enough to make use of all the detail being transmitted.
That said, DTV will not succeed in the marketplace if people have to deal with rotating antennas. Most just don't care enough to bother. Until HD is on cable the market penetration will be small. If cable half-asses it by reducing data rate and upping compression, well there's always the satellite. Which we hope won't do the same.
People are starting to get used to DVD quality, once DVD-HD starts to hit the market more people will want the HD displays. The audio (at least on CSI) is fantastic too. Someday maybe TV station management will catch on that the quality of their signal *does* matter to many (*cough*Ch 7*cough*). OK not enough to make me watch "American Idol" but Fox doesn't care about digital quality anyway.
RF
kb2tdu is offline
post #143 of 8100 Old 05-25-2003, 08:22 AM
I like my rotating aerial antenna on it's 40 foot tower, it's a thing of beauty.
To find who is doing what check ou this link http://www.100000watts.com/tv/BUF.html
Signal strengths are fine at 85% or better here in Niagara Falls, Ontario.
Let's put some pressure on ABC to test some Stanley Cup Playoffs in HD. I sent them my email.
post #144 of 8100 Old 05-30-2003, 04:00 AM
stjefrey's Avatar
I was getting PBS yesterday 17-1 and now nothing? Are they still up and running?
Sony XRB-930C
Sony Playstation 4
stjefrey is offline
post #145 of 8100 Old 05-30-2003, 04:28 AM
kb2tdu's Avatar
17 ... on and off, not on all the time far as I can tell
RF
kb2tdu is offline
post #146 of 8100 Old 05-30-2003, 07:36 AM
I don't have PBS-HD on all the time but I just watch more demo just now and there was picture, and on previous days it would run until at least 0300 hours.
post #147 of 8100 Old 05-30-2003, 06:38 PM
stjefrey's Avatar
I did not know that were going on and off. I thought they were up 24/7!
Thanks for the replies. Hey guys, lets keep this thread alive and hope wkbw channel 7 starts testing!!
Sony XRB-930C
Sony Playstation 4
stjefrey is offline
post #148 of 8100 Old 06-02-2003, 01:35 PM
theedge's Avatar
Let's hope WKBW gets testing before the NFL season starts!
theedge is offline
post #149 of 8100 Old 06-02-2003, 07:16 PM
J in OP's Avatar
I've been looking for a source for HDTV info and feel like I just hit the jackpot!
I have a Sony 40" direct view TV, HDTV ready, and am considering a STB for OTA. (I have cable right now) I know ch 2, ch 4 and ch 17 are on the air, with ch 7 due in a month. I am considering the Samsung 165 STB, largely because of the multiple inputs and outputs (especially DVI, becease the Sony has a DVI input).
I would appreciate any insight anyone might have about what to expect, especially if you have info about the Orchard Park area. What type of antenna will I need (indoor/attic)? Will it have to be a directional and/or rotating antenna? Will I have to move the antenna every time I change the channel? Any problems with the local stations and the Samsung 165? Anything else that might be a push in the right direction?
Thanks in advance for the help. Part of me wants to jump in, while part of me says wait. One thing I do know - don't wait for Adelphia to come on board!
J in OP is offline
post #150 of 8100 Old 06-03-2003, 03:15 AM
Best place to start is with www.antennaweb.org and www.titantv.com which give you help in finding what's available signal wise and in which directions.
