Omaha / Lincoln, NE - HDTV - Page 268 - AVS Forum | Home Theater Discussions And Reviews
 100Likes
post #8011 of 9951 Old 04-05-2010, 03:09 PM
rmalbers's Avatar
Liked: 24
Originally Posted by OmahaTVAddict View Post
I see the HD and standard version of Epix on my TV.
Did you see that movie they had on there last night, topless, full sex, etc. I have a feeling that channel won't be on in Omaha for long.
rmalbers is offline
post #8012 of 9951 Old 04-06-2010, 10:01 AM
JoelWNelson's Avatar
Noticed a couple days ago that KMTV has now started doing the weather segment of their newscast in full widescreen, instead of putting up the blue sidebars during weather. Their graphics aren't "SD-safe" -- they utilize the full 16x9 picture -- so I don't know if SD cable systems letterbox it or if people with 4x3 screens will actually just miss part of the graphics.
example: http://www.joelwnelson.com/tvscreeng...KMTV+-+188.jpg
JoelWNelson is offline
post #8013 of 9951 Old 04-06-2010, 10:37 AM
HuskerMike's Avatar
I'd argue they are "HD-enhanced" rather than not "SD-safe". On Qwest and I believe DirecTV, it just truncates the extra real estate, but the information on the sides is repeated elsewhere during the weathercast in the main section of the screen. (Usually, it's a 3 day snapshot of the weather, plus a wider scan of the radar.)
CBS does something similiar with their NFL ticker. In the area to the right that's cut off in SD, they show down, distance, and field position for other games.
HuskerMike is offline
post #8014 of 9951 Old 04-06-2010, 06:36 PM
OmahaTVAddict's Avatar
I saw it and I liked it! That channel fits in just nicely. No different then what's on HBO or Cinemax.
OmahaTVAddict is offline
post #8015 of 9951 Old 04-06-2010, 08:12 PM
HDNewbie1028's Avatar
Admittedly I hadn't been up to watch any movies within the Cox On Demand service for a couple months. Question - when did they remove HD on Demand with the premium channels? I have Starz and you used to be able to watch some On Demand movies in HD - can't find a listing for it anymore. Same holds true for HBO because I checked.
Did they stop doing that or move it to a different part of the guide? I pretty much checked everywhere and didn't see it. Thanks.
HDNewbie1028 is offline
post #8016 of 9951 Old 04-07-2010, 07:24 AM
BPHusker's Avatar
I was reading on another thread that people in other Cox markets are now able to get the DCX3400 DVR with a 500GB drive. Is this available in Omaha yet?
BPHusker is offline
post #8017 of 9951 Old 04-07-2010, 07:41 AM
PAULSTORM's Avatar
It was announced on NTV News that KTVG Ch 17 in GI went dark Mon nite @ midnite. OTA viewers told to watch Fox on 13.2 in Central Nebr.
PAULSTORM is offline
post #8018 of 9951 Old 04-07-2010, 07:46 AM
Not really a huge surprise. 13.2 is HD (as far as I know -- planning to go out that way later this year and will check in on markets such as Scottsbluff and North Platte as well) and has a bigger signal than 17 did. It's more cost-effective for NTV etc. to just use the existing signal than continue to run a duplicate signal on 17.
Maybe the money saved can be used to get HD on channel 51 in Lincoln and boost the signal to reach areas like York, Seward, Beatrice, etc.
post #8019 of 9951 Old 04-07-2010, 08:02 AM
PAULSTORM's Avatar
Yes, 13.2 is in HD
post #8020 of 9951 Old 04-07-2010, 01:41 PM
Cox has just added the CBS Masters 3D feed on channel 703.
post #8021 of 9951 Old 04-08-2010, 05:08 PM
ajwees41's Avatar
Quoted: 21 Post(s)
HBOHD was never on demand on any cable system
ajwees41 is offline
post #8022 of 9951 Old 04-09-2010, 06:13 AM
BPHusker's Avatar
Anyone know if Cox Omaha has the DCX3400 DVR available yet?
BPHusker is offline
post #8023 of 9951 Old 04-09-2010, 08:15 AM
Okay. I don't have HBO. I just looked at their on-demand section.
I know though that for a while there when I would go to the OnDemand section and look at Starz movies they had a section that said "StarzHD". I watched a few movies that way.
So, was there some fluke with my HD box, or do you think Cox had a fluke on their end, realized the mistake, and removed the HD content? Just curious.
post #8024 of 9951 Old 04-09-2010, 08:46 AM
ajwees41's Avatar
Quoted: 21 Post(s)
starzhd is on 1758
it even shows on 1758 on a non hd box
ajwees41 is offline
post #8025 of 9951 Old 04-09-2010, 09:29 AM
ajwees41's Avatar
Quoted: 21 Post(s)
aleast Epixis part of the movie tier not a seprate charge like HBO
ajwees41 is offline
post #8026 of 9951 Old 04-11-2010, 08:15 PM
ScottChez's Avatar
Quoted: 17 Post(s)
I see KETV channel 7.2 (not sure what it is on Cox) now plays a full Movie every Saturday night with commercials.
Wonder if there there weather channels is not making any money as it was.
If they would combine NEWS and WEATHER and Sports kind of like News on 4, I bet more would watch.
ScottChez is offline
post #8027 of 9951 Old 04-12-2010, 10:58 AM
starzhd is on 1758
Thanks - and for some reason it is now showing up again on the On Demand Guide. Weird. But yes it is there. Thanks for your help!
post #8028 of 9951 Old 04-12-2010, 02:27 PM
440forpower's Avatar
Quoted: 34 Post(s)
Hello anyone in the Seward area? Is there even a chance of picking up the omaha stations from here? Also where is the nearest FOX tower? Omaha too? Thanks in advance
440forpower is offline
post #8029 of 9951 Old 04-12-2010, 02:40 PM
From Omaha... you should get KPTM Fox 42 (actual channel 43) and KXVO CW 15 (actual channel 38). Any of the others are a stretch. Nearest Fox tower to you is KFXL 51 located near 30th and Superior Street in north Lincoln. However, it operates at low power, so you might actually get better reception from the Omaha station. Otherwise, ABC 8 and CBS 10 are your only true local full-power signals. Lincoln's PBS 12 is over 20 miles northeast of Lincoln and probably won't reach Seward well without a dedicated VHF antenna.
Try www.tvfool.com where you can put in your address and get a report of what's receivable at your location. My guess is your only sure channels are 8 and 10 but with a decent antenna you'll get a few more.
*Edit:
I checked TVFool myself, centered on downtown Seward, and it looks like with an indoor antenna you could get Lincoln's ABC and CBS stations and Omaha's Fox and CW stations. If the indoor antenna has a good VHF component you ought to be able to get Lincoln's PBS station as well. With a UHF attic/rooftop antenna you could add Lincoln's Fox station and the PBS station near Aurora (in opposite directions), probably Omaha's ABC and NBC stations, and maybe even Omaha's CBS station and the Hastings NBC affiliate which is actually the designated NBC station for the Lincoln/Seward market as well.
post #8030 of 9951 Old 04-14-2010, 12:52 PM
Quoted: 34 Post(s)
Thanks Joel
post #8031 of 9951 Old 04-20-2010, 08:22 AM
swiftaw's Avatar
Did EPIX HD disappear from Cox in Omaha?
swiftaw is offline
post #8032 of 9951 Old 04-20-2010, 09:45 AM
rmalbers's Avatar
Liked: 24
FWIW: I picked up a HD cable box from COX Omaha the other day and asked about more HD channels. The guy said right away, the next HD adds will be a HD pay tier with things like HDNet in it.
rmalbers is offline
post #8033 of 9951 Old 04-20-2010, 10:58 AM
ajwees41's Avatar
Quoted: 21 Post(s)
any dates'?
ajwees41 is offline
post #8034 of 9951 Old 04-20-2010, 02:55 PM
Nope still on 760.
post #8035 of 9951 Old 04-22-2010, 10:12 AM
rmalbers's Avatar
Liked: 24
Nope still on 760.
Looks like they are blacking it out when there is good stuff/soft porn on that channel during prime time. I predict that channel moves to the pay HD tier when they add that tier. I wondered what would happen when I first saw the movies they were showing (see a few posts back).
rmalbers is offline
post #8036 of 9951 Old 04-22-2010, 10:14 AM
rmalbers's Avatar
Liked: 24
any dates'?
He said with a couple of months but I don't know if I believe that part of the story, I doubt he would know that level of detail. I do believe the HD tier part though, he said it quickly and without even thinking about it.
rmalbers is offline
post #8037 of 9951 Old 04-22-2010, 10:52 AM
ajwees41's Avatar
Quoted: 21 Post(s)
in the cox hdforum on here someone said that HDNET's were coming to Omaha and they would be free.
ajwees41 is offline
post #8038 of 9951 Old 04-22-2010, 10:55 AM
ajwees41's Avatar
Quoted: 21 Post(s)
you need to call you should be getting it
ajwees41 is offline
post #8039 of 9951 Old 04-23-2010, 09:47 AM
billiefan2000's Avatar
Quoted: 13 Post(s)
cox channel 123 and it is friday and not saturday night. this isnt a surprise.
the weather channel on cable has been doing news shows and movies for some time.
they btw should put news on 4 as a wowt sub-channel aka channel 6.3
billiefan2000 is offline
post #8040 of 9951 Old 04-23-2010, 10:06 AM
Quoted: 13 Post(s)
I read that Classic Arts Showcase is going to be a sub-channel for pbs station in oklahoma
wouldnt that be great sub channel for pbs in nebraska
since only cox cable of omaha carries Classic Arts Showcase in nebraska
help a n00b , multiple source , newbie , ota antenna to existing satellite wiring
