Pittsburgh, PA - OTA - Page 159 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #4741 of 4809 Old 12-15-2018, 02:40 AM
mshaver76's Avatar
You're right, an on screen ticker would be helpful. I'm glad everything got sorted out in the end though.
mshaver76 is offline
post #4742 of 4809 Old 02-01-2019, 12:01 PM
Liked: 0
re: WOSC channel 61 OTA-
Ok, since my last report when they changed frequencies, I need to report that their broadcasts (on all subchannels 1 thru 5) are a complete incompetent mess.
And it has NOTHING to do with signal strength. That is fine.
Every day, at MANY various and random times, either a black blank signal is being broadcast, or the signal is freezing in an odd way (looks like mpeg encoder issues, and certainly NOT signal strength issues), or occasionally no signal is detected. Occasionally things will be fine for several hours. But never for any LONG CONTINUOUS period of time.
Tested on various tvs, tuners, and with different antennas.
Tried contacting them after the frequency change, but I get the impression no one there gives two-shakes about the OTA broadcasts.
So if anyone reads this at WOSC and has smidgeon of competency, get your act together and fix these problems. A month of incompetence is enough. Get it done.
bosschops is offline
post #4743 of 4809 Old 02-08-2019, 10:03 AM
mclellan83's Avatar
Quoted: 24 Post(s)
Liked: 29
Guess I should go home and check my bedroom TV
Budget 9.2 setup Samsung 65" Plasma, Denon AVR-X4300H, KEF KHT3005BL 7.1, KEF Q-300, BIC America Formula F-12
mclellan83 is offline
post #4744 of 4809 Old 02-19-2019, 08:50 AM
mshaver76's Avatar
I hear you about WOSC being a mess. I also noticed WIIC having problems. Ever since 31.1 went 1080i a couple weeks ago, my TV can't properly decode the signal. It's just a purple mess. Other tuners are having better luck with it (it's not purple), but it's still not perfect. Also 31.3 has been blank for long stretches of time. Anyway, I hope both of these stations get everything worked out.
post #4745 of 4809 Old 04-22-2019, 06:09 PM
Liked: 0
FYI -- those clowns at WOSC channel 61 are off-the-air again, broadcasting a black screen on all 5 channels.
Yesterday, 61.1 was the only channel broadcasting black. Today, all 5 are.
Wow those people are incompetent. Makes you wonder how the FCC granted them a license. Surely there is some basic competence requirement.
post #4746 of 4809 Old 04-29-2019, 08:45 AM
Liked: 0
WPCB (rf 50) will ad COURT TV as a sub-channel on May 8th.
tort2017 is offline
post #4747 of 4809 Old 05-08-2019, 01:56 PM
mshaver76's Avatar
WPCB-40 has added a couple channels today. The before mentioned Court TV was added on 40-2. They also added Bounce on 40-3. Both channels at 720p. They also moved their Pittsburgh Faith & Family Channel from 40-2 to 40-6.
post #4748 of 4809 Old 05-13-2019, 08:11 AM
Liked: 0
WPCB is also supposed to add QUEST to it's line-up. Can anyone confirm? Channel is out of range for me.
tort2017 is offline
post #4749 of 4809 Old 05-13-2019, 08:57 AM
mshaver76's Avatar
I read on RabbitEars that Quest was coming soon, but as of now, there's nothing yet. As WPCB moved its PFFC channel to 40-6, it does suggest there's a 40-4 and 40-5 coming. If they do though, I would think that something has to give regarding resolution. Right now they're running 4 channels and 3 of them are HD (1 1080i and 2 720p).
post #4750 of 4809 Old 05-22-2019, 03:56 AM
mshaver76's Avatar
As expected, WPCB just added Quest on 40-4. It's 480i, but not widescreen.
post #4751 of 4809 Old 05-24-2019, 07:43 PM
Liked: 0
FYI -- another WOSC report -- tonight 61.3 has distorted audio. Appears to be another WOSC technical issue, because the commercials are also affected, not just the shows.
post #4752 of 4809 Old 05-27-2019, 05:43 AM
mshaver76's Avatar
It's kind of sad, but also frustrating that WOSC continues to have problems. Although, to be honest, I don't watch much Buzzr (61-3) anymore ever since WOSC messed up the aspect ratio by stretching it wide and letterboxing it at the same time.
post #4753 of 4809 Old 06-11-2019, 07:10 PM
mshaver76's Avatar
We're about to deal with the channel repack soon and I saw WQED's notice tonight about it. They're going to cease transmitting on their old frequency (RF 13) on June 27th and start on their new frequency (RF 4) on or about July 1st. They also noted that cable viewers will be unaffected during the outage.
post #4754 of 4809 Old 06-12-2019, 12:40 AM
firemantom26's Avatar
Quoted: 30 Post(s)
Repack is coming soon. The test of stations in Pittsburgh will happen sometime in August.
Tom
firemantom26 is online now
post #4755 of 4809 Old 06-12-2019, 05:05 PM
Liked: 0
Does anyone know when there are going to change KDKA and WJAC?
otay2go is offline
post #4756 of 4809 Old 06-12-2019, 07:23 PM
mshaver76's Avatar
Well, we're in Phase 4 of the repack which runs from June 22nd through August 2nd. I don't get WJAC so I don't know when it would move, but I know it is moving. As for the full power Pittsburgh stations, KDKA and WPCW aren't moving during the repack. WTAE moved early and changed their frequency last year, so that just leaves the rest of them. For where everything is moving and for low power stations, RabbitEars.info has all of the new channel assignments.
post #4757 of 4809 Old 06-12-2019, 07:44 PM
PA_MainyYak's Avatar
Quoted: 51 Post(s)
Liked: 24
WJAC is in August as well. 34 to 35
"One of the few good things about modern times: If you die horribly on television, you will not have died in vain. You will have entertained us."
- Kurt Vonnegut
-0-
PA_MainyYak is offline
post #4758 of 4809 Old 06-12-2019, 07:52 PM
Liked: 0
I know WTAE moved to 27 last year, but are they going to change WTAE atop the WQED Tower utilizing 22 now?
otay2go is offline
post #4759 of 4809 Old 06-12-2019, 08:02 PM
mshaver76's Avatar
According to RabbitEars, WTAE is keeping their repeater on RF 22.
post #4760 of 4809 Old 06-13-2019, 01:45 PM
Quoted: 30 Post(s)
Any word on the need the big networks making the move soon.
Tom
post #4761 of 4809 Old 06-20-2019, 08:15 AM
Liked: 0
KDKA will add the sub-channel DABL-TV, in September.
tort2017 is offline
post #4762 of 4809 Old 06-25-2019, 09:05 AM
Trip in VA's Avatar
Quoted: 1411 Post(s)
Liked: 517
Send a message via AIM to Trip in VA
Look for WQED and WINP to transition within the next week. WINP just filed an STA to turn on channel 16 at 475 kW (versus the CP value of 775 kW, and current power of 500 kW) and said the plan remains to transition on June 29.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #4763 of 4809 Old 06-25-2019, 09:17 AM
Quoted: 30 Post(s)
- Trip
Thanks for the update.
Tom
post #4764 of 4809 Old 06-25-2019, 05:05 PM
mshaver76's Avatar
Yep, thank you @Trip in VA and @tort2017 for the updates.
post #4765 of 4809 Old 06-27-2019, 06:08 PM
Liked: 1
Hi everyone, im new to the forums but have been following this topic for a while.
Thanks for the info!
I used to be able to recieve WQED until this week. Has the move been completed? Can anyone else receive it?
blackbears7079 is offline
post #4766 of 4809 Old 06-27-2019, 06:19 PM
mshaver76's Avatar
Hi. Welcome to the forums. As for WQED, no, it's not completed. They shut off their transmitter this morning and plan to start transmitting on their new frequency on Monday.
post #4767 of 4809 Old 06-28-2019, 07:34 PM
Liked: 0
tonight, WOSC off the air AGAIN, all 5 channels broadcasting black screen.
These people really need to win some kind of incompetence award.
post #4768 of 4809 Old 06-29-2019, 09:24 AM
Quoted: 51 Post(s)
Liked: 24
Since it transmits from WQED’s tower, the WQED transition to its new frequency may have required all broadcasts from that tower to cease while the work is going on over the weekend. Just a guess.
- Kurt Vonnegut
-0-
post #4769 of 4809 Old 06-29-2019, 06:46 PM
mshaver76's Avatar
WINP completed their transition and is now on RF 16.
Trip in VA and firemantom26 like this.
post #4770 of 4809 Old 06-30-2019, 04:58 AM
Trip in VA's Avatar
Liked: 517
Anyone seeing WQED on the air this morning? A post from a viewer on Facebook claims it's up this morning.
- Trip
N4MJC
RabbitEars
