Los Angeles, CA - OTA - Page 339 - AVS Forum | Home Theater Discussions And Reviews
 482Likes
post #10141 of 11001 Old 03-21-2018, 06:40 PM
holl_ands's Avatar
Quoted: 959 Post(s)
Liked: 531
When you connect two Hi-VHF Antennas to a 2-Way RF Combiner, each experiences an unwanted 3-4 dB Insertion Loss....and Multipath from One Antenna is injected into the Other Antenna, rather than being suppressed by the Front/Back Ratio. You didn't provide a link to your TVFool Results....but it is possible that Strong signals from One location will interfere with an Adjacent Channel on the Other. Ch7-11 are also allocated to BOTH S.D. and L.A. stations....so it may be difficult to receive whichever has the weaker signal. So in the absence of a TVFool Report, it is NOT usually Recommended....you should probably use TWO Coax Downleads and an RF Selector Switch.
You should post a link to your TVFool Results so we can do some actual calculation estimates....I took a quick look at your area using TVFool Map Function....it doesn't look very good for SD Ch8/10....and likely need to be on higher ground. Also need to know how High you plan to mount the Antennas, how many Drops and Coax Length(s) so I can calculate System Noise Figure with and w/o a Preamp.
The old Radio Shack 15-1217 IR Controlled A/B Coaxial Switch is the ONLY RF Switch I know with R/C, which is apparently still available, although "New" products are fairly rare. Insertion Loss Specs says "1.5 dB Max" with a healthy 80 dB Input Port-to-Port Isolation (less on UHF Freqs):
https://www.amazon.com/Radio-Shack-R.../dp/B000H50L9S
https://www.google.com/url?sa=t&rct=...eKIcq1SNe6Q13Z
I looked for Insertion Loss Spec for MANUAL A/B Coaxial Switches...about the ONLY Switchs I found that claimed actual Specs were Holland AB-4 and AB-90, with a Max Insertion Loss under 1.0 dB:
https://www.google.com/url?sa=t&rct=...g-xOiYre1-DBAX
As well as Max of 1.1 dB for the old "High-Isolation" CM-3210 Coaxial Switch (Co-branded Eagle-3210):
https://www.summitsource.com/Channel...10-P11536.aspx
https://www.summitsource.com/Eagle-3...10-P13752.aspx
I would guess that all of the Coaxial Switch mfrs have an Insertion Loss so low, they don't feel it's worth mentioning....so most anything you find at your local Home Depot should be "good enough".....
Falcon_77 and JHBrandt like this.
holl_ands is offline
post #10142 of 11001 Old 03-21-2018, 06:55 PM
Squirrel!'s Avatar
Quoted: 847 Post(s)
Liked: 534
Yeah... Everyone tells me it can't be done. For the past 11 years.
Main: Mitsubishi 73736|OTA|fireTV|Sony BDP-S1100|Denon AVR4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|1-1000watt & 1-500watt DIY 12" Subs|2 Bass Shaker|APC H15 Power Conditioner|Harmony Hub|Sennheiser RS 160|SMSL B1 BT Rx|Linksys SE2500
MBR: Vizio VF550M|OTA|fireTV3|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Dayton SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Harmony 550
Squirrel! is offline
post #10143 of 11001 Old 03-22-2018, 07:25 AM
Calaveras's Avatar
Quoted: 1798 Post(s)
Liked: 427
Most of the advice on here about combining two antennas like that is that it doesn't work most of the time. Sometimes people luck out. Looks like you're one. In this business there's almost always exceptions to any general rule. It doesn't make it good advice though. I try to give advice that I think has a high probability of working, especially when I'm spending someone else's money.
Calaveras is offline
post #10144 of 11001 Old 03-22-2018, 10:26 AM
Falcon_77's Avatar
Quoted: 54 Post(s)
Here are the TV Fool results:
http://www.tvfool.com/?option=com_wr...90381c7e758a81
But TV Fool hasn't been updated in years it seems? It shows old channels (such as 24 & 47, etc).
Here's my band-scan as well. Only the 5 element Hi-VHF Yagi is pointed to SD:
https://m.rabbitears.info/index.php?...tzone=ET&unit=
I can provide SDR pics too if you want to see them.
Falcon_77 is offline
post #10145 of 11001 Old 03-22-2018, 02:41 PM
holl_ands's Avatar
Quoted: 959 Post(s)
Liked: 531
Note that Ch8 from LA and SD (CBS) as well as Ch10 from LA and SD (NBC) are all within 2-3 dB of each other....this illustrates the Co-Channel Interference Problem, that I mentioned above can occur if using an RF Combiner to combine two Hi-VHF Antennas pointed in different directions. So for sure, you will need an A/B Coaxial Switch.
Antennacraft Spec for discontinued Y10-7-13 claimed 9.4 dBd = 11.6 dBi for Hi-VHF Band (only one number....probably MAX).
When I modeled Y10-7-13 (using my measurements), Gain was about 10-11 dBi.
StellarLabs Spec for 30-2426 claims 12 dBi [MAX and can't be dBd] for Hi-VHF Band.
Although I don't have measurements for 30-2426, I DID for the smaller 30-2425, finding Gain was about 1 dB lower than claimed.
Antennahacks did an OTA Comparison Test of Y10-7-13 to the StellarLabs 30-2426, finding that Gain was about the SAME, with about 1-2 dB LESS on Ch13:
http://www.antennahacks.com/Comparis...ar_30-2476.htm
So I'm going to presume that Gain of StellaLabs 30-2426 is between 10 and 11 dBi....and a bit lower on Ch13.
So for above Antenna Gain and a System Noise Figure of about 3-4 dB (With Typical Preamp+Coax on "San Diego" Antenna), the lowest TVFool calculated Pwr(dbm) would be -106+15-3+10 = -96 dBm....leaving only 4-7 dB Fade Margin...which is very minimal protection against Multipath Fading, Seasonal Variations and "Other Factors" such as Trees, et. al.
Determining your approx. location from your TVFool Report, I used TVFool's MAP Function to show the signal level in your neighborhood. Turns out that Ch8/10 from San Diego are about the SAME as Ch8/10 from LA....and you appear to be on the TOP of a Mesa [which helps] or just slightly off of it (depends on exactly WHERE you are located):
Falcon_77 likes this.
post #10146 of 11001 Old 03-22-2018, 10:02 PM
Squirrel!'s Avatar
Quoted: 847 Post(s)
Liked: 534
"Luck out"...LMAO...better stated 'I know what I'm doing'...
post #10147 of 11001 Old 03-22-2018, 11:00 PM
phildaant's Avatar
Quoted: 1073 Post(s)
Liked: 446
Question Did you get this red warning banner message during Station 19's pilot episode too?
Did anyone get this red warning banner message during Station 19's pilot episode on KABC's 7.1? Mine got interrupted by this red banner warning with its audio message: http://screenshot.cz/MF/MF7VU/s19redbanner.png ... At least closed captionings still showed the dialogs. This was in Los Angeles' KABC7 on Spectrum cable. It was recorded since I could rewind, pause, and fast forward it. I wonder if OTAers had that too.
Thank you in advance.
phildaant is offline
post #10148 of 11001 Old 03-23-2018, 06:55 AM
nathill's Avatar
Quoted: 278 Post(s)
Liked: 176
Vhf
Does VHF have fewer problems with multi-path?
If so, maybe the idea of two VHF antennas pointed in different directions might be a better idea than with UHF?
nathill is offline
post #10149 of 11001 Old 03-23-2018, 07:15 AM
Jerrymc777's Avatar
Quoted: 48 Post(s)
Looks like a weather warning for Ventura...
Large HD8200XL antenna with HDB91X and RCA preamp and a RCA VH226F rotor motor
,aimed at Mt. Wilson (Los Angeles) from Etiwanda area.
CM3410 Dist. amp in attic for a 5 room hookup.
Located in foothills behind Mt. Baldy, and experiencing signal loss and pixelation depending on time of day.
Jerrymc777 is offline
post #10150 of 11001 Old 03-24-2018, 01:52 PM
jasonvr's Avatar
Quoted: 42 Post(s)
Liked: 41
Has anything happened with KABC and KCAL recently? Over a month ago I put an antenna in my attic and I was able to pull in all the majors just fine. Now I've completely lost 7 and 9 on my TV and HDHomeRun. 2, 4, 5, 11, 13 are all fine
LG B6 65" OLED, Phillips UHD BluRay, Denon AVR-X4000, Chromecast Ultra, Roku Ultra, eD speakers and sub
jasonvr is offline
post #10151 of 11001 Old 03-24-2018, 02:44 PM
Jerrymc777's Avatar
Quoted: 48 Post(s)
I always have problems with both KABC and KCAL, especially in the early evenings.
Both are H-VHF and at close frequencies. 174Mhz~186Mhz
And both are only transmitting at 25~28Kw (pretty low power)
11 and 13 are still H-VHF on 198~216Mhz KTTV11 at 115kW and KCOP13 at 120kW.
Compare that to KNBCLA on UHF 602Mhz~608 Mhz at 665kW
and KCBSLA 644Mhz~650Mhz at 540kW!
Di$ney needs to inve$t in more power for their local stations! LOL
You'd be better off mounting your antenna to your roof.
post #10152 of 11001 Old 03-25-2018, 07:13 AM
Falcon_77's Avatar
Quoted: 54 Post(s)
Well, 8 &10 to San Diego turned out to be hopeless. The 30-2426 is a great Hi-VHF antenna, which is now pointed to LA. I get 8 from LA reliably, so the received power at my QTH seems better for LA and worse for SD than TV Fool predicted. No 10 from LA.
If 8 & 10 in San Diego are granted the power increases they are asking for, I will try again then.
Thanks again.
Mike
post #10153 of 11001 Old 03-25-2018, 07:28 AM
rdvegas's Avatar
Quoted: 413 Post(s)
Liked: 896
The lower the rf channel, the less power that is needed to cover a similar plot map. Add in the height of the transmitter tower, and the power levels are not that bad for your locals.
Will the last subscriber leaving Dish Network please turn off the satellite.
rdvegas is offline
post #10154 of 11001 Old 03-25-2018, 08:20 AM
Jerrymc777's Avatar
Quoted: 48 Post(s)
Is the fact that KABC and KCAL broadcast at 75% less power than KTTV and KCOP the reason so many people in the LA surrounding areas have drop outs with KABC and KCAL?
post #10155 of 11001 Old 03-25-2018, 10:52 AM
Super Moderator
DrDon's Avatar
Quoted: 2445 Post(s)
Liked: 4789
Since this has become a local reception thread, I'm going to combine it with the LA thread.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #10156 of 11001 Old 03-25-2018, 11:53 AM
rdvegas's Avatar
Quoted: 413 Post(s)
Liked: 896
Antennas are a leading factor in VHF reception pixelation and dropouts. You may need a different antenna to secure long term reception of rf VHF channels like KABC and KCAL.
rdvegas is offline
post #10157 of 11001 Old 03-26-2018, 09:48 PM
jasonvr's Avatar
Quoted: 42 Post(s)
Liked: 41
Well I figured out at least part of my problem - the F connector on my main feed from the antenna to the distribution partially fell apart. I don't know if it was natural (cheap compression from Amazon) or I messed it up when I was up there last weekend installing security cameras. I noticed that even my FM reception was messed up, so I knew something else must be up. Luckily I put the distribution amp directly in front of the attic access. When I pulled the power I notice no degradation which meant something wasn't connected properly. Started jiggling things and the input just fell apart.
Clipped it and recrimped. Seems better now, though not perfect. But I do have 7 and 9 back.
phildaant likes this.
jasonvr is offline
post #10158 of 11001 Old 03-27-2018, 07:18 AM
Jerrymc777's Avatar
Quoted: 48 Post(s)
Do you or your neighbors have solar panels?
post #10159 of 11001 Old 03-27-2018, 07:43 AM
HarrisonS's Avatar
Quoted: 40 Post(s)
Liked: 32
I have been seeing a dramatic improvement in my reception of KCET, ch. 28, over the past two or three days. This station has always been rather weak here because of poor coverage to the west from its particular location on Mt. Wilson. Previously it didn't even come in at all, most of the time on one UHF antenna which I am using with my main TV. Now it comes in almost perfectly on that antenna, with only occasional glitches. Ch. 28 has always been a problem station here, but now, with an antenna change, reception should be perfect all the time.
HarrisonS is offline
post #10160 of 11001 Old 03-27-2018, 05:38 PM
jasonvr's Avatar
Quoted: 42 Post(s)
Liked: 41
I do, but on the opposite side of the house from where the antenna is/is pointing. Some of my neighbors also do - why?
jasonvr is offline
post #10161 of 11001 Old 03-27-2018, 08:50 PM
Jerrymc777's Avatar
Quoted: 48 Post(s)
Some engineer from OC on TVFool.com suggested to me that solar panels's inverters create RF interference after the sun sets.
My KABC and KCAL breakup right after the sun sets.
My antennas point directly towards my neighbor's solar panels (path to Mt. Wilson).
It's a neighbor behind my next door neighbor.
My signals are all pretty weak here, so I have to use a pre-amp at the antenna, and a dist. amp in the attic to push the signal to 5 rooms. It only happens certain times of the year too, which makes it more frustrating.
I've been searching for a VHF-H RF filter pass-band thingy but have yet to find one...
I need something to filter out everything below 174Mhz.
post #10162 of 11001 Old 03-28-2018, 12:42 AM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 72
Huh???
With all due respect to that engineer, if anything if that is really the source of the RF interference then the reverse should be happening since the inverters of net-metering solar customers aren't being used after sundown when the solar panels obviously stop generating any DC electricity and customers are pulling AC power from the grid like everyone else.
Sent from my LG-H918 using Tapatalk
HoTatII is offline
post #10163 of 11001 Old 03-28-2018, 05:13 AM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 2432 Post(s)
Liked: 3959
It's been my experience UHF usually has more problems with multi-path then VHF.
"Espresso is like tequila, when in doubt apply more shots."
tenthplanet is offline
post #10164 of 11001 Old 03-28-2018, 05:30 AM
nathill's Avatar
Quoted: 278 Post(s)
Liked: 176
Thank you.
My limited experience in OTA reception tells me the same thing.
nathill is offline
post #10165 of 11001 Old 03-28-2018, 07:22 AM
Jerrymc777's Avatar
Quoted: 48 Post(s)
Originally Posted by HoTatII View Post
Huh???
I'm not really sure how solar panels work.
I thought the energy was stored to batteries, then converted to AC when needed...(after sunset)?
post #10166 of 11001 Old 03-28-2018, 11:48 AM
holl_ands's Avatar
Quoted: 959 Post(s)
Liked: 531
Some Solar Cell contain Active Electronics that are sometimes sources of EMI up high, where it is easy to leak into nearby TV Antennas....and other Solar Cells do NOT, with all of the EMI (if any) being radiated by the Active Electronics (incl. Inverter) in the Garage, where it can STILL be conducted up to the Solar Cells to be leaked into nearby TV Antennas. BTW: Just because it meets FCC Emission requirements does NOT mean it can't desensitize weak channel reception for nearly neighbors....and of course, SOME systems likely emit MORE than the single Test Sample used to obtain "Type" Approval.
FYI: My son's (and probably MOST) Solar Systems are used to lower their Monthly Electric Bill and do NOT have the Optional Battery Storage System. They break even after many, many years..at which time it would probably need to be replaced [unless prematurely damaged/destroyed by Severe Weather]. Only a portion of the Solar Cell Output is used during the Day and the rest is "sold" back to "The Grid". Under this scheme, you can STILL save $$$'s compared to Gasoline, by using JUST "The Grid" to recharge an Electric Car OVERNIGHT....using the "credits" you built up during the Day.
BTW: A "typical" home Solar System generates on the order of "thousands" of watts, MAX on a [Fixed Typo, was kWh per] "Good" Day of Sunshine...which varies a LOT from day-to-day and WHERE located....and only reaches PEAK for about 3-6 Hours per day. Fortunately, only a SMALL portion of a "typical" Solar System is needed to recharge MULTIPLE Electric Cars....although the ENTIRE Daily Solar Output for a SUNNY DAY may be needed for just ONE Insane or Ludicrous Mode Tesla owner....who should have no problem buying MUCH bigger Solar/Battery Systems for their MUCH bigger Roofs:
https://en.wikipedia.org/wiki/Electr...ttery_capacity
https://www.nrel.gov/docs/fy04osti/35297.pdf
Adding a Battery Pack obviously increases the Up-Front Cost (and even more if on a payment plan)....but presumably can pay for itself after many, many years of service....esp. if you have an Electric Car (my son does NOT). Tesla's POWERWALL Lithium-Ion Battery Pack installed cost is about $4K (more or less)....and some homes might need TWO....esp. if Off-The-Grid for Dual Redundancy:
http://instituteforenergyresearch.or...erwall-battery
https://www.energysage.com/solar/sol...l-home-battery
post #10167 of 11001 Old 03-28-2018, 06:36 PM
jasonvr's Avatar
Quoted: 42 Post(s)
Liked: 41
BTW: A "typical" home Solar System generates on the order of "thousands" of kWh per "Good" Day of Sunshine...which varies a LOT from day-to-day and WHERE located....and only reaches PEAK for about 3-6 Hours per day.
Your scale is off here. "Tens" of kWh is more correct, or "thousands" of Wh. I have a 6.27kW DC system and I will max out at about 40kWh in the peak of summer. I produced 37.2kWh yesterday which was 12.6kWh more than my house used for the day.
jasonvr is offline
post #10168 of 11001 Old 03-30-2018, 01:44 PM
holl_ands's Avatar
Quoted: 959 Post(s)
Liked: 531
Thanks....fixed the "typo".
My source was Figure on pg 7 of fol Solar Brochure...which shows a VERY wide variation:
post #10169 of 11001 Old 04-11-2018, 08:01 AM
Sammy2's Avatar
Quoted: 1060 Post(s)
Liked: 346
Question
Sick and tired of getting taken by Spectrum. I've already started using YoutubeTV to get a lot of Cable/Satellite Channels and get the family prepared for the transition. I currently use two Silicon Dust HDHR Prime CableCARD tuners and WMC with multiple Ceton Echo Extenders and an xBox 360 for a whole home solution. First I'm going to drop down to Spectrum Select or even just plain ole basic.. Then I'm getting a Silicon Dust HDHR Quatro and an antenna. I'm out east and to not go into exact specifics but west of March AFB. Here's my plot from FoolTV (strangely KCBS is missing but it shows up on AntennaWeb).
The rear of my house has 33x240w solar photo-voltaic system with 33x215w MicroInverters on it (glad to see those posts so recently to mine as I didn't even think of the effects of that). This whole portion of the roof faces almost due south and I have a gable roof. At any rate, I'm trying to figure on a decent antenna to get and was thinking of mounting it to the barge rafter at the peak of the gable roof as there's a pretty clear shot to Mt. Wilson from there but now I'm wondering about interference from the solar panels..
I'm currently considering the following but am open to suggestions:
Channel Master Altratenna 60
or
LAVA 8008 Omnidirectional
TIA
Sammy2 is offline
post #10170 of 11001 Old 04-11-2018, 08:18 AM
Teeps's Avatar
Quoted: 31 Post(s)
TIA
Who is your internet provlder?
Cheers, Tp
"No lawsuit ever fixed a moron."
Teeps is offline
ch 2.1 , ch 43.1 , grand wega , kcbs , Ota , pasadena ca
