Los Angeles, CA - OTA - Page 354 - AVS Forum | Home Theater Discussions And Reviews
 482Likes
post #10591 of 11001 Old 01-26-2019, 04:20 PM
gadgetfreaky's Avatar
Quoted: 218 Post(s)
Liked: 36
Originally Posted by fshagan View Post
You'll have to play with both the amplifier and the position of the antenna to see if you can bring in both Fox (channel 11) and ABC (channel 7). Both of those are high-VHF and a lot of the little antennas sold now have problems with VHF signals.
If it has to be indoors, maybe something like a Clearstream 2v could work in a window. It's a pretty good antenna.
which amplifier should I get? I already have the outdoor antenna, the
winegard elite. I thought it was already the best. mounted on my roof.
gadgetfreaky is offline
post #10592 of 11001 Old 01-30-2019, 06:12 PM
shivaji's Avatar
Quoted: 1314 Post(s)
Liked: 1343
For some reason I lost 5-1, have 5- 2,3 and 4 though. Anyone else. Did a rescan, still the same.
shivaji is online now
post #10593 of 11001 Old 01-30-2019, 07:19 PM
Sitcomics's Avatar
Quoted: 12 Post(s)
So is retro tv gone from 63-3 for everyone else? It’s now LA-1 en espanol. Is retro moving or gone forever?
Sitcomics is offline
post #10594 of 11001 Old 01-30-2019, 07:44 PM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 72
Still getting 5-1 here fine in So. LA. ...
Sent from my LM-V405 using Tapatalk
shivaji likes this.
HoTatII is offline
post #10595 of 11001 Old 01-30-2019, 08:09 PM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 72
Yep, obviously a change in format with KBEH going all Spanish now with this new channel and dropping Retro TV.
And with RTV's old location on KFLA 8-3 forever down (just color bars for months now). I guess that spells the end of RTV in this market for the time being anyhow.
HoTatII is offline
post #10596 of 11001 Old 01-31-2019, 10:18 AM
shivaji's Avatar
Liked: 1343
So, what may account for the fact that I pick up the the rest of the channel 5-2 through 4#'s with an 85 signal strength,
but not 5-1? They have to be broadcasted from the same tower, yes?
post #10597 of 11001 Old 02-01-2019, 05:45 AM
jmonier's Avatar
Quoted: 222 Post(s)
Liked: 123
KDOC is up on physical 12 with a test pattern so it looks like they're advancing toward their move. I have no idea how it'll be until the actual move, however. It still might be quite a while.
jmonier is offline
post #10598 of 11001 Old 02-01-2019, 05:55 AM
Trip in VA's Avatar
Quoted: 1783 Post(s)
Liked: 784
KVCR and the San Diego stations are apparently planning to move on March 14. That's according to an FCC filing from KPBS yesterday.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #10599 of 11001 Old 02-01-2019, 09:30 AM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 72
Good catch ...
Just reads as "12-1" with no further PSIP info. on my TV's ATSC tuner after a rescan.
After re-scanning my TiVo, assigned it to former KTBV-LD's primary channel which I have checked off my guide list. So didn't see it at first.
HoTatII is offline
post #10600 of 11001 Old 02-01-2019, 09:39 AM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 72
- Trip
Trip, KTBV-LD 12-1 thru -4 appears to be off the air here now, which is obviously why KDOC can begin testing there with color bars on 12-1 virtual and physical. So guess you can update rabbitears accordingly .. .
HoTatII is offline
post #10601 of 11001 Old 02-01-2019, 09:41 AM
Trip in VA's Avatar
Liked: 784
There's no guarantee that KTBV-LD is off the air yet; KDOC could just be swamping it.
- Trip
N4MJC
RabbitEars
post #10602 of 11001 Old 02-01-2019, 09:50 AM
ADTech's Avatar
Quoted: 178 Post(s)
Liked: 90
Check to see if your "favorites" list (or whatever your set calls it) has been edited to disable the display of virtual channel 5-1.
Tech support for Antennas Direct
ADTech is offline
post #10603 of 11001 Old 02-01-2019, 10:14 AM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 72
- Trip
Ok, that's possible;
But unless I just couldn't receive KTBV-LD here in So. LA to begin with, it's been missing from my lists of received channels on my TV, OTA TiVo, and DIRECTV DVR (via a connected AM21 tuner module accessory). All of which have been rescaned many times over the past months long before KDOC's test signal went up.
HoTatII is offline
post #10604 of 11001 Old 02-01-2019, 07:10 PM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 2428 Post(s)
Liked: 3939
Being physical channel 11 and 13 are occupied in L.A. how can this work. I always thought the rule was adjacent channels weren't allowed ?
"Espresso is like tequila, when in doubt apply more shots."
tenthplanet is online now
post #10605 of 11001 Old 02-01-2019, 07:37 PM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 72
For analog TV yes, but for technical reasons not necessary for digital TV signals which may be spaced adjacently without mutual interference.
HoTatII is offline
post #10606 of 11001 Old 02-01-2019, 09:01 PM
Liked: 3939
Thanks that makes sense.
post #10607 of 11001 Old 02-02-2019, 05:33 AM
jmonier's Avatar
Quoted: 222 Post(s)
Liked: 123
Although this is mostly true, there are apparently a few cases where there can still be trouble with adjacent channels. For instance, the upcoming moves of KTLA from 31 to 35 followed by KCBS from 43 to 31 is a case in point. I've wondered why not simply move KCBS to 35? The best answer that I could find was that KCBS couldn't be adjacent to KNBC (36), but KTLA could. There was no further information that I could find. Maybe Trip knows more?
jmonier is offline
post #10608 of 11001 Old 02-02-2019, 06:04 AM
Trip in VA's Avatar
Liked: 784
Adjacency is permitted as long as the stations are reasonably co-located and have similar antenna patterns. Basically, a receiver can handle adjacent-channel signals just fine as long as they're within about 30 dB of each other in strength. If there's a significant area where two stations differ by more than 30 dB, then it can create a problem for viewers.
The TVStudy software that I work on for the FCC is used to determine whether stations can co-exist or not. In the case of KCBS/KTLA, the issue was that KCBS (placed on 35) could not be adjacent to KNBC (on 36), while KTLA (if moved from 31 to 35) could and KCBS could fit on 31. I don't know the specific location that made it unacceptable, but that calculated interference would have been the cause.
- Trip
rdvegas, phildaant and HoTatII like this.
N4MJC
RabbitEars
post #10609 of 11001 Old 02-03-2019, 02:54 AM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 72
Crap ....
Was enjoying the "Mod Squad" on the DECADES's ch. weekly weekend marathon on KAZA 54-2. And as it frequently does, the station's OTA signal goes out. Been down for hours now.
Sign ... I hate KAZA/KHTV ...
Note: I know it's the OTA signal because DIRECTV via microwave or fiber I assume, is still broadcasting 54-1 just fine on their local satellite feeds to the LA market.
HoTatII is offline
post #10610 of 11001 Old 02-03-2019, 03:32 AM
Liked: 1
I suspect that it will be this way for a long time to come. They have both just spent the money to do the repack and it's unclear (to me at least) that they would save enough (or indeed any) money by packing both on a separate channel (if such a channel is even available).
When they originally announced the merger, they said that they would be keeping the 28 and 50 channels separate with their separate identities, but that they would share some programs to provide more viewing opportunites. Of course, there's no guarantee that they won't change their minds in the future. But that was their stated intent for the indefinite future.
DXR27 is offline
post #10611 of 11001 Old 02-03-2019, 03:51 AM
Liked: 1
Originally Posted by Sammy2 View Post
7.1 is borderline low VHF so susceptible to interference.
Sent from my SM-G960U1 using Tapatalk
Actually, 7 is the bottom end of VHF high and is not close to VHF low:
VHF low = channels 2-6 = 54 to 88 Mhz
VHF high = channels 7-13 = 174 to 216 Mhz
So there is a gap of 86 Mhz between VHF low and VHF high, which is not really borderline.
DXR27 is offline
post #10612 of 11001 Old 02-03-2019, 08:46 AM
HarrisonS's Avatar
Quoted: 40 Post(s)
Liked: 32
Exactly. And it should be noted that this large gap includes the entire FM broadcast band (88 - 108 MHz) and an important aviation band as well.
HarrisonS is offline
post #10613 of 11001 Old 02-19-2019, 06:09 AM
Super Moderator
DrDon's Avatar
Quoted: 2445 Post(s)
Liked: 4783
Anybody catch the rescan crawl on KCBS, this weekend? I saw part of it, but missed any date they might have mentioned.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #10614 of 11001 Old 02-19-2019, 06:47 AM
LATV's Avatar
Quoted: 55 Post(s)
Liked: 57
KTLA is running spots saying to re-scan on March 18 at Noon.
LATV is offline
post #10615 of 11001 Old 02-19-2019, 06:51 AM
Super Moderator
DrDon's Avatar
Liked: 4783
Thanks. Since they have to move first, I imagine the CBS2 date is pretty close to that.
DrDon is online now
post #10616 of 11001 Old 02-19-2019, 08:12 AM
Teeps's Avatar
Quoted: 31 Post(s)
Yes I think is said Apr 12.
DrDon likes this.
Cheers, Tp
"No lawsuit ever fixed a moron."
Teeps is offline
post #10617 of 11001 Old 02-20-2019, 04:59 PM
euskadi71's Avatar
Quoted: 27 Post(s)
Liked: 29
Yes, I think it was last week I first saw that. It gave a website to visit...
http://tvanswers.org/
Change is coming to antenna TV.
Americans depend on their local broadcast stations for the most trusted news, weather and emergency information – not to mention the best entertainment on TV.
By law, many TV stations are moving to new frequencies between now and 2020. If you watch TV for free, using an antenna, you must take action to keep your channels. Any time after a station moves, rescan your TV or converter box to continue to receive your local TV stations. Rescanning is when your TV finds all of the available channels in your area. Because stations must move at different times, you may need to rescan your TV more than once.
No new devices, equipment or services are needed to rescan.
Broadcasters are committed to serving their local communities and making these changes as easy as possible for viewers. Use the tool to the right to find out which stations are moving frequencies and when, and what you need to do to keep watching the local TV you rely upon.
euskadi71 is offline
post #10618 of 11001 Old 02-20-2019, 06:59 PM
Super Moderator
DrDon's Avatar
Liked: 4783
Confirmed. 4/12 at 10am. Thanks.
DrDon is online now
post #10619 of 11001 Old 02-21-2019, 07:13 PM
Falcon_77's Avatar
Quoted: 54 Post(s)
And what a birthday present for me.
I haven't been on here a while and a lot of posts!
RF12 is baffling me still. KDOC ID's on it now and then but then vanishes to nothing decodable. Still testing, I presume.
I will be most curious about KVCR RF 5 when they move. I'm sure it will do better over the mountains for me than 26 does now. But I'm still scratching my head on them building a new tower on Box Springs Mtn. vs. co-locating to Mt. Wilson/Mt. Harvard, especially since we will have another Lo-V there (on 4). I'm not keen on non-co-located antennas on the same band, but it's a common problem in this country. And many markets are much worse about it than LA.
Falcon_77 is offline
post #10620 of 11001 Old 02-22-2019, 04:37 AM
LATV's Avatar
Quoted: 55 Post(s)
Liked: 57
KDOC-TV is still testing.
LATV is offline
ch 2.1 , ch 43.1 , grand wega , kcbs , Ota , pasadena ca
