Los Angeles, CA - OTA - Page 368 - AVS Forum | Home Theater Discussions And Reviews
 489Likes
post #11011 of 11027 Old 05-15-2020, 01:49 PM
dschulz's Avatar
Quoted: 934 Post(s)
Liked: 675
Originally Posted by San Dimas View Post
Dear dschulz: Thank you for taking the time to suggest Clear Stream 2 Max. I noticed the antenna does not have the back grill and some Clear Stream Max 2 have the grill. The one you suggested does not have the back grill. Does it matter. Thank you again for suggesting the Clear Stream Max 2 and taking the time to provide your guidance.
Thanks again for your words of wisdom and thoughts and helping me choose a good antenna for my family...
Warm Regards,
San Dimas
For post number 11003
Since all the channels you want are on Mt. Wilson, I would get the version with the grill (or reflector, as Antennas Direct calls it). This gains a little efficiency in reception in the direction you have the antenna pointed, at the cost of signals coming from other directions. We're lucky to have all of the broadcasters co-located together at Mt. Wilston.
San Dimas likes this.
dschulz is online now
post #11012 of 11027 Old 05-16-2020, 12:36 PM
fshagan's Avatar
Quoted: 458 Post(s)
Liked: 215
Originally Posted by sted View Post
Are you picking up Santa Barbara/San Luis Obispo as well as Los Angeles?
I pick up KEYT, the ABC affiliate in Santa Barbara, off the back side of the CM 4228. Weather can affect it but we get good reception most of the time. Prior to the 4228 I had a ClearStream V (the larger one), and built an antenna for the frequency KEYT is on, and used a splitter in reverse to combine them.
fshagan is offline
post #11013 of 11027 Old 05-16-2020, 12:42 PM
fshagan's Avatar
Quoted: 458 Post(s)
Liked: 215
Originally Posted by dschulz View Post
I live in the San Fernando Valley, slightly further from Mt. Wilson than you, also with line of sight. I'm happy with my Antennas Director ClearStream.
Link.
This is a great choice too. I had the 4Max here in Ventura County, and while it wasn't as good as the larger antenna I have now, I have no doubt the ClearStream 2Max would do really well for you.
dschulz likes this.
fshagan is offline
post #11014 of 11027 Old 05-20-2020, 08:05 AM
Quoted: 158 Post(s)
Liked: 60
Do you think it would be possible to pick up Santa Barbara in Pasadena? If so, how? I have not picked up Santa Barbara here, but I have picked up San Diego.
sted is offline
post #11015 of 11027 Old 05-20-2020, 10:22 AM
KyL416's Avatar
Quoted: 285 Post(s)
Liked: 170
Not in Pasadena, KEYT's RF 27 is taken by KPOM-CD:
https://www.rabbitears.info/contour....d&site=1&map=Y
KyL416 is offline
post #11016 of 11027 Old 05-21-2020, 02:38 PM
LensClock's Avatar
Quoted: 43 Post(s)
Liked: 42
This is overkill - He's only 20 miles away, line of sight!
San Dimas, I'm not sure if you are still looking for an antenna, but if you are line-of-sight to Mt. Wilson, and only 20 miles away, you can almost get by with a coat hanger!
There is no need to go overboard, and if you have a window facing North, you might not even need an outdoor antenna.
Do what you wish, but if I were you, I'd go to CVS, find their "As seen on TV" aisle, and try one of those cheap indoor antennas that are always hawked on late-night TV.
You have nothing to lose - if it doesn't work, take it back!
Or, there's dozens of cheap antennas on Amazon - check out this review: https://www.tomsguide.com/news/best-cheap-tv-antennas
And check out this article on how many of your neighbors are getting by "...with antennas that can cost as little as a dollar"!:
https://www.latimes.com/archives/la-...c25-story.html
Do you really need to quote the entire post in your reply?
Channel Master DVR+, LG Plasma, Samsung UN60J6200 LED, Yamaha HTR-5860 & RX-V595 AV Receivers, SiriusXM, Infinity RS-9's, Klipsh 12" & Polk 10" SubWoofs, Sony STR-DE635, EPI 100's, Polk RTi8's
LensClock is offline
post #11017 of 11027 Old 05-24-2020, 07:55 PM
Sitcomics's Avatar
LX Tv
This coming to channel 4-3 apparently. Not sure the target audience loves ota.
https://www.lxtv.com/
Sitcomics is offline
post #11018 of 11027 Old 05-24-2020, 08:27 PM
Quoted: 158 Post(s)
Liked: 60
Tivo turned this channel on in the guide but I am seeing nothing.
sted is offline
post #11019 of 11027 Old 05-30-2020, 03:33 PM
Sitcomics's Avatar
It’s live now. 9-4 was just added but it’s just home shopping.
Any other good ota networks left that aren’t yet in LA? Retro TV?
post #11020 of 11027 Old 05-30-2020, 04:37 PM
Quoted: 158 Post(s)
Liked: 60
KBEH virtual 63-4 is Retro TV in LA
sted is offline
post #11021 of 11027 Old 05-31-2020, 02:54 AM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 76
Retro TV is currently on KBEH 63-3 ...
But since KBEH shares with KWHY 22 on low band RF ch. 4. You may not be able to receive it without a VHF-lo band capable antenna.
Sent from my LM-V600 using Tapatalk
rdvegas likes this.
HoTatII is offline
post #11022 of 11027 Old 05-31-2020, 09:22 AM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 76
It’s live now. 9-4 was just added but it’s just home shopping. ....
Yeah ....
Hey Tripp ...
You can update LX on Rabbitears as it's live now on KNBC 4-3 in widescreen SD (station ID Short_Name is simply "LX").
Also HSN on KCAL 9-4 is actually in widescreen SD. ...
Trip in VA likes this.
HoTatII is offline
post #11023 of 11027 Old 05-31-2020, 08:22 PM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 2568 Post(s)
Liked: 4290
In anything some of the digi-nets need to die. All these SD sub-channels are sucking picture quality from the main channels.
"Espresso is like tequila, when in doubt apply more shots."
tenthplanet is online now
post #11024 of 11027 Old 05-31-2020, 08:24 PM
Quoted: 158 Post(s)
Liked: 60
Are there any special steps being taken to protect OTA transmissions during civil unrest?
sted is offline
post #11025 of 11027 Old 06-01-2020, 06:37 AM
rdvegas's Avatar
Quoted: 421 Post(s)
Liked: 915
Station engineers are being armed with bigger grease pencils and slide rules. The copper thieves probably pose a bigger threat to stations and their towers.
Will the last subscriber leaving Dish Network please turn off the satellite.
rdvegas is offline
post #11026 of 11027 Old 06-01-2020, 07:32 AM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 76
I would assume (and hope) it's greatest protection is inherent in its remoteness.
So how likely are people going to be rioting and looting way atop Mt. Wilson/Mt. Harvard?
Sent from my LG-H932 using Tapatalk
HoTatII is offline
post #11027 of 11027 Old 06-01-2020, 11:38 AM
HoTatII's Avatar
Quoted: 205 Post(s)
Liked: 76
QVC channel now live on KCAL 9-5 I see ....
My as well update that one too Tripp. ...
Widescreen SD ....
HoTatII is offline
ch 2.1 , ch 43.1 , grand wega , kcbs , Ota , pasadena ca
