Wilmington, NC - HDTV - Page 84 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #2491 of 2633 Old 09-29-2019, 07:05 AM
tbritt2112's Avatar
Quoted: 13 Post(s)
Originally Posted by finallygreen View Post
In case this is of any use to anyone else (because I'm learning things move a lot, and different sites list different locations for different channels), here's what I'm able to get in the Monkey Junction area as of today with just a cheap $9 flat antenna:
3.1 ABC
3.2 CBS
3.3 CW
6.1 NBC
6.2 Bounce
6.3 Escape
6.4 Laff
24.1 CW
24.2 MeTV
24.3 Heroes & Icons
26.1 FOX
26.2 this
26.3 GRIT
26.4 ion
39.1 PBS
39.2 PBS Kids
39.3 PBS
39.4 PBS
49.1 WQDH-LD
49.2 WQDH-LD
49.3 WQHD-LD
49.4 WQHD-LD
So....I guess I still have my original questions....1. can anyone confirm they can still get Antenna TV in this area (and if so, what channel?), and 2. what else might I get here if I jumped from a cheap antenna on the downstairs wall to a higher end antenna in the attic?
I live in Wilmington also and you have the same channel lineup as me. Yes, I get Antenna TV. Antenna TV is in the 29 block of channels. If you're not getting it on your inside antenna, you're gonna need an outdoor antenna. I have a Clearstream Max 2 and it does a pretty good job. I get same as you plus channels, 10.1 thru 10.3, 29.1 thru 29.4. I also get 35.1 thru 35.6 when that station is on the air. I don't know whats up with that station as its on sometimes then its not. Can anyone comment on this? I can get 12.1 thru 12.4 sometimes. That station is in New Bern. I may install a second outdoor antenna and aim it toward New Bern to get them channels. Anyway, some smart people here that can help you out as they know a lot about this stuff.
And if you do put up an outdoor antenna, definitely try it in different positions. I have found that if I turn mine just a few inches it can make a difference. I have it now where I can get everything (except them New Bern stations) with pretty good reception. It took many times turning it and rescanning to find the sweet spot.
tbritt2112 is offline
post #2492 of 2633 Old 09-30-2019, 05:04 AM
finallygreen's Avatar
Thanks, I appreciate the info!
finallygreen is offline
post #2493 of 2633 Old 10-01-2019, 04:08 AM
tbritt2112's Avatar
Quoted: 13 Post(s)
Looks like Court TV Mystery will replace Escape channel. That's 6.3 for those in Wilmington. Its on the air now. I searched for a schedule of shows but didn't find one. My program guide still has Escape listed. I hope they show Forensic Files. That's one of my favs.
post #2494 of 2633 Old 10-01-2019, 04:32 AM
idiotcontrol's Avatar
CourtTV Mystery is the Escape channel. Escape just rebranded. I haven't seen anything explicit about programming changes. I think most of it will remain the same. https://www.broadcastingcable.com/ne...urt-tv-mystery
idiotcontrol is online now
post #2495 of 2633 Old 10-01-2019, 04:33 AM
KyL416's Avatar
Quoted: 280 Post(s)
Liked: 166
Escape was renamed Court TV Mystery yesterday nationwide, the schedule is still mostly the same as Escape's:
https://www.courttv.com/mystery/
KyL416 is offline
post #2496 of 2633 Old 10-05-2019, 11:28 AM
tbritt2112's Avatar
Quoted: 13 Post(s)
I live in Wilmington and channels 29.1 thru 29.4 have vanished. Anyone else notice this? Ive rescanned several times. Also, WWAY TV 3 doesn't and never has since I switched to OTA TV, come in as good as WECT TV 6. This happen to others on here? Ive been OTA for about a year now.
post #2497 of 2633 Old 10-05-2019, 12:11 PM
jspENC's Avatar
Quoted: 288 Post(s)
Liked: 59
WWAY used to be close to the strongest signal I received years back, but now, it is weaker than WSFX. I think they have issues for sure, since they are using Christmas lights to keep their transmitter on.
jspENC is offline
post #2498 of 2633 Old 10-11-2019, 03:56 PM
tbritt2112's Avatar
Quoted: 13 Post(s)
Well Wilmington channels 29.1 thru 29.4 are back. They were gone for a few days but yesterdays rescan shows they are back on the air.
post #2499 of 2633 Old 10-14-2019, 01:01 PM
drt2k3's Avatar
Quoted: 14 Post(s)
What networks do they affilate with now? WILM tooks heroes and icons
drt2k3 is offline
post #2500 of 2633 Old 10-22-2019, 02:27 PM
tbritt2112's Avatar
Quoted: 13 Post(s)
WWAY must have got their act together. Full signal strength since I switched to OTA. That's been about a year.
post #2501 of 2633 Old 10-23-2019, 06:17 AM
jspENC's Avatar
Quoted: 288 Post(s)
Liked: 59
All the channels seem to be stronger from the main tower in Winnabow. Maybe they got the combiner ironed out?
For anyone looking for more channels from the New Bern area, you might try the STIRR app. You can stream the channels there, and they look better than OTA. There are about 25 or 30 channels.
jspENC is offline
post #2502 of 2633 Old 10-26-2019, 06:50 AM
tbritt2112's Avatar
Quoted: 13 Post(s)
I did a rescan yesterday and WILM has added channel 15.3 in the Wilmington area. They were showing Heros and Icons. Anyone else see this?
post #2503 of 2633 Old 10-28-2019, 04:59 PM
drt2k3's Avatar
Quoted: 14 Post(s)
Yeah i saw that. Whats wtmv showing now that Heroes and Icons is on wilm
drt2k3 is offline
post #2504 of 2633 Old 11-11-2019, 05:53 AM
jr3us's Avatar
Quoted: 14 Post(s)
Liked: 2
Speaking of wilm channel 10, on real 15, I am in Ocean Isle Beach, and their signal is just getting clobbered for the past few weeks and is very dependent on the weather.
I understand that there are a couple of channels up near Raleigh that use 15 / used 15 that are the culprits for my problem, and with the orientation for those Raleigh channels related to where I am, The direction from my house to the broadcast antenna to raleigh 15, and local 15 are practically the same.
I can't get WILT as it is too far away/signal not oriented correctly.
Any others have any ideas how I can improve, or how WILM can improve it?
I do like the H and I channel, but don't care much for the 2 Me TV channels that wilm does.
Regards!
Jay
jr3us is offline
post #2505 of 2633 Old 11-11-2019, 07:31 AM
unclehonkey's Avatar
Quoted: 630 Post(s)
Liked: 178
Regards!
Jay
WRAZ in Raleigh is also on RF15. Capitol Broadcasting (owner of both WILM and WRAZ/WRAL) told the FCC that they would accept the interference with both stations on RF15. The issue is WILM only broadcasts at 15,000 watts whereas WRAZ is at 700,000 watts (with a construction permit to go up to 805,000 watts). WILM cant go any higher power as they are classified as a low powered station (so 15,000 watts max).
I'm not near there so I cant suggest how to improve your reception since we're dealing with co-channel ionterference. Hopefully someone local can help out.
Can you post your rabbitears plot? (more up to date version than tvfool)
https://www.rabbitears.info/searchmap.php
jr3us likes this.
unclehonkey is offline
post #2506 of 2633 Old 11-11-2019, 07:48 AM
jr3us's Avatar
Quoted: 14 Post(s)
Liked: 2
Here is the link for the tvfool equivalent: ( I am sure glad someone took over the reigns for this. I didn't realize that rabbitears had this available! )
https://www.rabbitears.info/searchma...study_id=26897
I don't think capitol broadcasting cares so much for WILM anymore since they lost cbs down here. Also, their 10.1 channel that now does mostly Me TV in 'HD' except for their news, and a few new shows a day...
It would be better in my opinion if they moved the H and I station to their 720 10.1 channel.
Thanks for the info.
jr3us is offline
post #2507 of 2633 Old 11-11-2019, 08:01 AM
jspENC's Avatar
Quoted: 288 Post(s)
Liked: 59
There is a construction permit on an LP 15 down in Georgetown also. Columbia SC has a 15, but I doubt that is an issue. For people in the areas in and around Bladen County, or even southern Sampson, I cannot imagine they can watch either FOX 50 or MeTV from either station. They would likely need WSFX or WITN, or WFXB
jspENC is offline
post #2508 of 2633 Old 12-01-2019, 08:19 AM
tbritt2112's Avatar
Quoted: 13 Post(s)
This TV has pulled the plug in Wilmington. Anyone know whats going on?
post #2509 of 2633 Old 12-01-2019, 10:01 AM
Trip in VA's Avatar
Quoted: 1843 Post(s)
Liked: 849
Is it just blank or did something replace it like a slide?
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #2510 of 2633 Old 12-01-2019, 10:37 AM
jspENC's Avatar
Quoted: 288 Post(s)
Liked: 59
- Trip
Yesterday, (when I wanted to watch that channel) they had a slide up. It said something like "This TV has ceased airing in Wilmington, Visit http://thistv.com for answers."
WSFX DT2 Wilmington NC
I went to the site, but I saw nothing that provided any information.
jspENC is offline
post #2511 of 2633 Old 12-01-2019, 12:37 PM
jr3us's Avatar
Quoted: 14 Post(s)
Liked: 2
I wonder if this tv (26.2) on cable tv is also messed up?
thistv.com as well as wsfx website show nothing unusual.
jr3us is offline
post #2512 of 2633 Old 12-19-2019, 10:34 AM
jspENC's Avatar
Quoted: 288 Post(s)
Liked: 59
WPXU - ION 35 seems to have increased power going by my maxed out TV meters. The real frequency is 16. Some of you may want to attempt to tune it in again for ION HD and several other channels such as ION plus and the shopping channels. The new tower is closer to Wilmington just north of Surf City.
jspENC is offline
post #2513 of 2633 Old 12-19-2019, 10:44 AM
jr3us's Avatar
Quoted: 14 Post(s)
Liked: 2
I am not able to receive WPXU here on Ocean Isle Beach. Sometimes when the tropospheric effects are in my favor, I can get it pretty good, but won't last more than a couple of hours.
Did they recently do an additional antenna like WILM did?
Regards.
jr3us is offline
post #2514 of 2633 Old 12-19-2019, 12:15 PM
jspENC's Avatar
Quoted: 288 Post(s)
Liked: 59
Regards.
No, they just changed towers, to the WRMR FM 98.7 location, which is a bit higher than the original location. I think the old location had 92.3 and 105.5 FM sharing the tower too.
jspENC is offline
post #2515 of 2633 Old 12-28-2019, 07:39 AM
timhk63's Avatar
Quoted: 24 Post(s)
Any word on THIS TV or if they plan to replace it with another services. Movies would be nice
timhk63 is offline
post #2516 of 2633 Old 12-28-2019, 07:41 AM
timhk63's Avatar
Quoted: 24 Post(s)
Are the Wilmington stations going to be ready for the revised rescan date of Jasn 14th ?
timhk63 is offline
post #2517 of 2633 Old 12-31-2019, 05:39 PM
jspENC's Avatar
Quoted: 288 Post(s)
Liked: 59
WECT has activated a 5th channel. I assume it is due to Circle about to come on the air. Between 5 channels here, and 6 channels on WITN to the north, NBC will not look as good as we are used to I am afraid.
jspENC is offline
post #2518 of 2633 Old 01-03-2020, 07:26 AM
ILMRay's Avatar
We also installed a new encoder that does a great job of encoding without artifacts. The technology has advanced a great deal in the last few years.
Ray
CE
WECT-WSFX
jspENC, Retspin and idiotcontrol like this.
The comments expressed are mine, and mine only. I in no way speak for my employer.
ILMRay is offline
post #2519 of 2633 Old 01-03-2020, 04:07 PM
jspENC's Avatar
Quoted: 288 Post(s)
Liked: 59
ILM Ray,
Do you know of any plans for another channel on 26 to take the place of ThisTV?
jspENC is offline
post #2520 of 2633 Old 01-08-2020, 07:09 AM
tbritt2112's Avatar
Quoted: 13 Post(s)
ILM Ray,
WQDH has 3 channels on the air. In the Wilmington area that's channels 49.1, 49.2 and 49.3. One is a Spanish channel and the other 2 have just been showing infomercials. Anyone know if infomercials will be their only programming? I was excited when I rescanned and saw new channels, but not so much now. Looks as if there will be a 4th channel also. 49.4 is on, but just color bars for now.
