Springfield / Joplin, MO - HDTV - Page 197 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #5881 of 5907 Old 01-21-2020, 11:27 AM
justpushplay's Avatar
Quoted: 25 Post(s)
Originally Posted by mrradiohead55 View Post
That is correct, they are not. I heard from the KY3 engineer today via email. He told me the tower crew still had a little tower work left for KOZK before they could turn the transmitter to full power. The weather threw off their work a couple days. Then KYTV has a tower crew on site to start work on facilities for KSPR-LD and KYCW-LD, but that work won't prevent KOZK from going to full power. KOZK will try to get to full power by midweek this coming week.
Jim - Springfield, Missouri
Ah, that's good to hear. I have been struggling with KOZK, with heavy pixellation, whereas everyone else on the Fordland towers have been stable with the exception of wind and storms.
Both the Tivo and the HDHomerun Quattro tuners get really flustered at times with the heavy multipath and low signal strength. Trying to play back a recording of PBS Newshour via the HDHomerun/Emby server combo has caused the Roku to crash and reboot a few times. Good times!:-)
justpushplay is offline
post #5882 of 5907 Old 01-21-2020, 02:33 PM
dbsstephen's Avatar
Quoted: 47 Post(s)
Liked: 0
I get KYCW-LD, which is on rf 25, just fine. See attached pic. But then I live just outside Springfield, on the NW side. They are presently at 3.9 kW @ 222'.
BTW, the engineer for KYTV also told me that the Gray Television stations (KYTV, KYCW-LD, KSPR-LD) are going to add three channels within the next two months - Circle TV, Justice and Quest. But they don't know which of the three stations are going to get which channel.
BUT first they have to complete their repack transition of KYCW-LD and KSPR-LD.
They have the equipment/transmitters delivered already, but engineers have to do the tower work. KYCW-LD is moving from 25 to 24, KSPR-LD is moving from 15 to 34. The KYCW-LD antenna will go from 222' to 1676' eventually, while the KSPR-LD antenna will go from 256' to 1676' eventually. By mid March, they will probably start running messages on KYTV 3 and KSPR 33 about the changes.
They even working to get their atsc 3.0 channels up and running
Sent from my SM-G973F using Tapatalk
dbsstephen is online now
post #5883 of 5907 Old 01-22-2020, 01:17 PM
21hawk's Avatar
Quoted: 25 Post(s)
As stated some time back NextGen TV, as it's being marketed now, has been a part of the process since day one. Where applicable, the new equipment installed is compatible with NextGen, they have wisely and cost effectively used the repack to facilitate NextGen deployment.
Of note, the antenna that KSPR/KYCW will share supports 3 stations according to their 399 filing. It would seem they may be prepared to host simulcasts there? As it stands, I believe Gray hse or plans to have 9 channels total, they should have plenty of room to incorporate NextGen into the mix.
Not much NextGen news out of CES, maybe by NAB show in the spring there will be something more definitive, but for the time being, if they do get the shared antenna online by mid Feb, I'd say they are not too far behind, maybe even ahead of the curve..
21hawk is offline
post #5884 of 5907 Old 01-22-2020, 06:07 PM
dbsstephen's Avatar
Quoted: 47 Post(s)
Liked: 0
Turn out all the Springfield locals that are the high-powered stations will all be going next gen TV which will be good though I don't know how nexstar is going to do there's though what they'll do with their channels
post #5885 of 5907 Old 01-31-2020, 04:42 PM
Quoted: 25 Post(s)
The GM at KY3 told me in an email Circle TV will be 03-5. He said the 33-5 is wrong for Circle TV and believes that is someone's speculation. Target date is mid February, when there will be channel realignments over three stations.
I installed a Channel Master CM-3418 8-way active splitter yesterday to replace the passive 8-way. Whilst screwing around with the Tivo Roamio OTA signal strength meter today, I saw a KYTV 3.3 subchannel lit up at full strength. Looks like they're playing with their new toys:-)
post #5886 of 5907 Old 02-01-2020, 04:16 PM
21hawk's Avatar
Quoted: 25 Post(s)
It looks like a couple of DTV America stations liscensed in Joplin, KFKY and KCNH, have been granted amended CPs and interference waivers, and will be building on the tower at KOLR's Division St studios, allowing them to cover about half the area that a full power signal would. At RF25 and RF26, they will add to a very crowded slice of spectrum from 19-28, we'll see how that works out?
If a deal were in place, this might allow some flexibility for Nexstar if there were a need to offload subchannels to accommodate a simulcast on one of the Fordland transmitters.
As far as any other programming these LPs might carry, who knows
dbsstephen likes this.
21hawk is offline
post #5887 of 5907 Old 02-13-2020, 03:51 PM
21hawk's Avatar
Quoted: 25 Post(s)
RF19 right now
Name:	Screenshot_20200213-165045_Hdhomerun Signal Meter_1581634279138.jpg
ID:	2684602Click image for larger version
Name:	Screenshot_20200213-165029_Hdhomerun Signal Meter_1581634290822.jpg
ID:	2684604Click image for larger version
21hawk is offline
post #5888 of 5907 Old 02-13-2020, 04:37 PM
gar1r's Avatar
please post again sir when they light all the channels on rf19 I am curious what the bit rate of nbc and abc will be football was already bit starved this winter
gar1r is offline
post #5889 of 5907 Old 02-14-2020, 10:29 AM
Quoted: 32 Post(s)
Liked: 9
Yes, barring no weather problems, the tower crew will be on the tower on Sunday installing the antenna for KFKY and KCNH. And in a few weeks, the engineer will be installing the transmitter etc. Regarding programming, still undecided. I guess they are still waiting on a contract with a provider.
Antennas - Antennacraft MXU59 UHF antenna & home-brew version of Antennacraft VHF Y-10-7-13 antenna @ 25'. Both antennas fed through a Channel Master 7777 30dB pre-amp.
Tuners - Zenith DTT901 converter box; AirSpy HF+ sdr; Silicon Dust HDHomerun Dual ATSC tuner, using Rabbitears autologger support.
mrradiohead55 is offline
post #5890 of 5907 Old 02-14-2020, 10:34 AM
Quoted: 32 Post(s)
Liked: 9
RF 19 might just be an interim solution to getting their three channels lit up - Circle, Justice, and Quest. KYCW-LD and KSPR-LD still have to move to their repack channels, but not sure when that will happen. Its possible they will do some channel juggling once those stations are complete. I know *from good authority* those two stations have had their new equipment delivered already.
post #5891 of 5907 Old 02-14-2020, 12:43 PM
Trip in VA's Avatar
Quoted: 1721 Post(s)
Liked: 737
Don't look for Justice or Quest, at least, to go anywhere.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #5892 of 5907 Old 02-14-2020, 03:12 PM
MGOMRJSURF's Avatar
Quoted: 37 Post(s)
Theirs others in Springfield area without channels to. Springfield doesn't have yet H and I,Start TV,Decades,Getv,Stadium and so on yet.
MGOMRJSURF is offline
post #5893 of 5907 Old 02-14-2020, 05:27 PM
dbsstephen's Avatar
Quoted: 47 Post(s)
Liked: 0
Why is there a channel 19.8 showing up in my guide
post #5894 of 5907 Old 02-14-2020, 05:28 PM
dbsstephen's Avatar
Quoted: 47 Post(s)
Liked: 0
So I don't know why that's there but it's in the
post #5895 of 5907 Old 02-14-2020, 05:40 PM
dbsstephen's Avatar
Quoted: 47 Post(s)
Liked: 0
What are those stations anyway
post #5896 of 5907 Old 02-14-2020, 06:06 PM
Quoted: 32 Post(s)
Liked: 9
They are low power digital stations, owned by HC2/DTV America. The Springfield stations aren't on this list yet but if you go to the linked page, you will see the type of programming they carry...
https://hc2broadcasting.com/subchannel-listing/
post #5897 of 5907 Old 02-14-2020, 06:10 PM
Quoted: 32 Post(s)
Liked: 9
They evidently don't have everything set up yet, because on my HDHomerun it shows up as 8 but not like a channel 8, like its part of the KYTV channel lineup. I'm certain its got something to do with the stream that will be Quest, which will be 3-6 when they get everything straightened out. I was hoping it would have been completed today but now probably not until next week.
post #5898 of 5907 Old 02-16-2020, 08:18 AM
21hawk's Avatar
Quoted: 25 Post(s)
I just noticed KNWA signal is full strength after a few months of very poor signal. I know they have had some issues with repack, but this signal is solid!
21hawk is offline
post #5899 of 5907 Old 02-16-2020, 10:07 AM
Liked: 0
Channel 3.4 (Circle), 3.5 (Justice) and unknown 19.1 are showing up on my TVs. All show full strength and s/n of about 35.5db. But nothing on 'em yet. I'm in Greenfield.
Underclocked is offline
post #5900 of 5907 Old 02-16-2020, 01:29 PM
Quoted: 25 Post(s)
You always beat me to it!:-) Just noticed myself, and yes, it seems very solid. I can't rescan the HD Homerun Quattro because Emby is recording the Daytona 500, but I'll check signal quality tonight. Now, if I can suss out why I still have problems with KOZK, while the rest of the Fordland tower stations are doing great.
post #5901 of 5907 Old 02-16-2020, 01:43 PM
21hawk's Avatar
Quoted: 25 Post(s)
I spoke too soon,
Name:	Screenshot_20200216-144305_Hdhomerun Signal Meter_1581885815241.jpg
21hawk is offline
post #5902 of 5907 Old 02-16-2020, 03:28 PM
dbsstephen's Avatar
Quoted: 47 Post(s)
Liked: 0
I have the same issues with Ozark public television it doesn't come in Strong enough all the time
post #5903 of 5907 Old 02-16-2020, 03:31 PM
Quoted: 25 Post(s)
I spoke too soon,
Hmmmm. The Tivo Roamio is giving KNWA a 54, while KRBK comes in with a 49. And KNWA is hitting the back of my Channel Master 4228. I'm sure they're playing with settings today. I'm also seeing KYTV 3.4 Circle and 3.5 Justice being active today, and a strange 19.8 with no PSIP, none of which have programming.
post #5904 of 5907 Old 02-16-2020, 06:15 PM
dbsstephen's Avatar
Quoted: 47 Post(s)
Liked: 0
19.8 is quest TV
post #5905 of 5907 Old 02-18-2020, 07:16 AM
Quoted: 32 Post(s)
Liked: 9
KYTV has lit up Circle, Justice and Quest now.
post #5906 of 5907 Old 02-18-2020, 04:15 PM
21hawk's Avatar
Quoted: 25 Post(s)
Name:	Screenshot_20200218-171020_Hdhomerun Signal Meter_1582067621642.jpg
ID:	2686850Click image for larger version
Name:	Screenshot_20200218-171008_Hdhomerun Signal Meter_1582067633852.jpg
ID:	2686852Click image for larger version
Name:	Screenshot_20200218-170955_Hdhomerun Signal Meter_1582067680688.jpg
ID:	2686854Click image for larger version
Name:	Screenshot_20200218-170941_Hdhomerun Signal Meter_1582067689337.jpg
21hawk is offline
post #5907 of 5907 Old 02-18-2020, 05:09 PM
gar1r's Avatar
so kspr gets the less bits I have a 65 oled and all channels look good but very soft still it is what it is
gar1r is offline
