New York, NY - OTA - Page 645 - AVS Forum | Home Theater Discussions And Reviews
 494Likes
post #19321 of 20113 Old 07-02-2018, 03:02 PM
Quoted: 398 Post(s)
Liked: 354
Originally Posted by Trip in VA View Post
I'm hearing that WLNY has made its move from channel 47 to channel 27. Can anyone confirm?
- Trip
Yes they are. Still broadcasting from both frequencies. Is the 27 frequency from long island? Or NYC?
Sony A1E OLED 4K Ultra H
FS Gen2 Nvidia shield TV 2017 version
EF9500 is offline
post #19322 of 20113 Old 07-02-2018, 03:06 PM
SnellKrell's Avatar
Quoted: 181 Post(s)
Liked: 63
From the tower in Middle Island.
SnellKrell is offline
post #19323 of 20113 Old 07-02-2018, 05:27 PM
Brian in CT's Avatar
Quoted: 62 Post(s)
@FrankH3rd : Even in the analog era, it was very hard to get VHF signals inside a concrete or cinderblock building. I assume that is still true with digital signals. I also assume that is why SnellKrell had to put his rabbit ears antenna very close to the window to get WNET-13. As for metal buildings, I have never been able to try, but it's probably a similar situation.
The cable boom in the USA didn't hit until the 1980's. In fact, cable didn't achieve 50% household penetration until 1987. That's when rooftop antennas were disappearing at a brisk rate. In the 2010's, they have slowly popped back up here and there. Unfortunately, people in urban centers will have trouble with their TV reception until ATSC 3.0 rolls out.
Brian in CT is offline
post #19324 of 20113 Old 07-02-2018, 05:32 PM
SnellKrell's Avatar
Quoted: 181 Post(s)
Liked: 63
Without beating a dead horse, my reception problems didn't begin until stations moved to 1WTC.
Same high-rise apartment, same construction, same everything except for 1WTC.
post #19325 of 20113 Old 07-02-2018, 05:41 PM
Quoted: 53 Post(s)
New York, NY - OTA
And yesterday 27 was broadcasting CBS. Stinks that they stopped that because cbs is hard for me to pick up from NYC
Jay Stone is offline
post #19326 of 20113 Old 07-02-2018, 05:46 PM
Quoted: 62 Post(s)
@SnellKrell : My bad. I guess I assumed too much. Being on the Upper East Side, can I assume that window you use for your antennas points southwest toward both the ESB and 1WTC? If it does, my only guess is that the TV signals have to pass through more buildings.
post #19327 of 20113 Old 07-02-2018, 05:52 PM
SnellKrell's Avatar
Quoted: 181 Post(s)
Liked: 63
The window faces south.
The problem is not necessarily that the signal has to pass through more buildings.
The problem is that the transmission antennas are much higher and the signals have
trouble reaching locations that are relatively close to 1WTC.
If that weren't had enough, WNET is now running at approximately half the Effective
Radiated Power that it had been when it was transmitting from ESB.
The perfect storm!
post #19328 of 20113 Old 07-02-2018, 06:00 PM
Quoted: 62 Post(s)
@SnellKrell : Like you said, ATSC 3.0 hopefully will solve many of the problems associated with ATSC 1.0. Until then, maybe they can put translators on top of the ESB again.
post #19329 of 20113 Old 07-02-2018, 06:09 PM
SnellKrell's Avatar
Quoted: 181 Post(s)
Liked: 63
Glad you used a smiley face.
Stations couldn't care less about OTA.
Station sharing and adding more and more subchannels are great for a station's
bottom line, but only degrades the quality of the main signal.
Thank you, WNET!
ATSC 3.0 is their last hope that stations have when it comes to OTA.
They will then have the ability to compete in the marketplace selling data packages,
and delivering signals to smartphones.
reddice likes this.
post #19330 of 20113 Old 07-03-2018, 07:49 AM
dstoffa's Avatar
Quoted: 94 Post(s)
Liked: 32
Aluminum siding effectively block all television signals.. should your home still have it.
dstoffa is offline
post #19331 of 20113 Old 07-03-2018, 09:31 AM
d3193's Avatar
Quoted: 76 Post(s)
Liked: 57
Originally Posted by FrankH3rd View Post
Question- Was OTA TV reception using an indoor antenna EVER good and consistently reliable for viewers living in steel and concrete buildings in Manhattan and Brooklyn, regardless of the transmitting antenna location, ESB or original WTC ? Even in the old analog days? I seem to recall that almost from the beginning of TV in the 1950's and 1960's, building owners would connect their apartments to antennas located on building roofs, because reception with indoor antennas was problematic at best. Then cable services replaced the rooftop antennas starting in the (1970's?). (Wasn't the original purpose of cable systems, before there were "cable channels", to get broadcast stations to hard to reach rural and urban locations?).
OTA reception in Manhattan has always been a problem. There are inevitably multiple reflections from the many tall buildings. In the old analog days the image was clouded with ghosts to the extent that it was usually unwatchable. To watch local broadcasts, a cable feed was pretty much essential for most people. The arrival of digital broadcasting made OTA reception more of a possibility. The strongest signal might well be a reflection from another building, and multiple signals at once (ghosts in analog) can still cause problems, but if you do succeed in getting something it will look pretty good.
Unfortunately, few people are able to place an antenna on their roof, so some sort of interior device is the only option. I'm in mid Manhattan and can get some, but definitely not all, the OTA channels.
d3193 is offline
post #19332 of 20113 Old 07-03-2018, 12:06 PM
scorpiony's Avatar
Quoted: 34 Post(s)
Liked: 29
New York, NY - OTA
Oddly enough, a typical indoor antenna tucked to my 2nd floor window sill facing Broadway on UWS in the 80’s, gets all channels now.... go figure.
The Elevation in my area is 120 ft
HoundBaby likes this.
The Home Tech Scholar
AV Consultation / Calibration
New York, NY
(212) 362-8133
[email protected]
scorpiony is offline
post #19333 of 20113 Old 07-09-2018, 07:29 AM
LenL's Avatar
Location: Randolph, NJ, 725' above sea level, 30 miles west of ESB
Quoted: 442 Post(s)
Liked: 316
How is everyone's reception these days? Anything new to report? I'm still w/o 7.1 and 11.1. Everything else seems to be ok.
LenL is offline
post #19334 of 20113 Old 07-09-2018, 08:47 AM
reddice's Avatar
Quoted: 645 Post(s)
Liked: 128
Where I am channel 13 is much stronger on the 1WTC. No surprise as my TV and radio reception (WKCR, WPAT, WKTU) use to be excellent when they were on the original twin towers WTC.
Watching a Capital Fourth on WNET then switching to WNBC-WNJU when it ended so I watched the fireworks without ads it did not break up once. Last year was a disaster when it was on the ESB. So for me 1WTC I can now get WPXN channel 31 which I could not get a blimp on the ESB. WNBC-WNJU comes in stronger too. I wish WPIX would move as on the ESB its terrible when there is bad weather just as bad as WNET was.
Charter Spectrum.
My Router: Netgear R7000 - Advanced Tomato
3.5-140 K26ARM USB VPN-64K.
My Primary Streaming Device: Apple TV 4K (2017).
Cats are the best pets.
reddice is offline
post #19335 of 20113 Old 07-09-2018, 08:54 AM
Aero 1's Avatar
Quoted: 380 Post(s)
Liked: 185
my antennas (3 of them, 1 uhf, 1 hi-vhf and 1 lo-vhf) have not moved in 10 years facing ESB when I installed and i have had zero problems with reception during the repacks and moves. I haven't lost any channels because of it.
Cord Cutter | OTA - NYC DMA - 10 HDHomerun Tuners - 5 Apple TV's with Channels DVR | Plex Pass | Netflix | Amazon Prime Video | ESPN+ | hulu | Fios Gigabit with Ubiquiti Unifi Enterprise Network/Wifi/Surveillance System
Aero 1 is offline
post #19336 of 20113 Old 07-09-2018, 09:54 AM
LenL's Avatar
Quoted: 442 Post(s)
Liked: 316
You are in a great location. You can't be much more than 15 miles from the ESB and 1WTC. Plus you are above sea level and your antennas are directed east south east. All of which means you probably did not need to re-aim them and reception did not take a hit.
I forget was it you that mentioned you still get NJN now transmitting from Basking Ridge?
LenL is offline
post #19337 of 20113 Old 07-09-2018, 10:32 AM
Aero 1's Avatar
Quoted: 380 Post(s)
Liked: 185
no, i dont get it. its too far and in a totally different location. the montclair antenna is 2 miles away from me dead center in the path of esb though.
Aero 1 is offline
post #19338 of 20113 Old 07-09-2018, 10:55 AM
LenL's Avatar
Quoted: 442 Post(s)
Liked: 316
Too bad the Montclair antenna is not used anymore. NJ PBS lost a ton of viewers with the change and they are so stupid thinking that the people in North Jersey can receive NJN without changing their antennas and subsequently losing the all the other stations they get coming out of NY.
They look and see how much coverage their broadcast get coming north from Basking Ridge and don't understand antenna pointing.
LenL is offline
post #19339 of 20113 Old 07-09-2018, 12:54 PM
nyctveng's Avatar
Quoted: 169 Post(s)
Liked: 76
They are not stupid. They knew they would lose viewers. But they got $200 million in the process. Money to keep them afloat and money they would never got from the OTA viewers they lost.
Aero 1 likes this.
nyctveng is offline
post #19340 of 20113 Old 07-09-2018, 05:19 PM
SnellKrell's Avatar
Quoted: 181 Post(s)
Liked: 63
I'm fairly certain that the $194 million that the state of New Jersey received for selling
WNJN, Montclair's frequency, went into Trenton's general account, with no amount specifically
earmarked for broadcasting.
In fact, the New Jersey Public Broadcasting Authority, had asked the state that a portion of
the money generated by the sales be directed to the Authority - there was no expectation
to receive all the proceeds.
i don't know the outcome. But with the state's financial problems, it's doubtful if any has
gone to Public Broadcasting.
Also, it's interesting that Authority spokespeople, in trying to justify the sales, stated -
"We want to make sure this money goes back to communities and make sure they get
the information and media they want to see."
It was also claimed that there would be no disruption in services!
Who are you going to believe, Trenton or your own eyes???
post #19341 of 20113 Old 07-09-2018, 07:05 PM
HoundBaby's Avatar
Quoted: 71 Post(s)
Liked: 35
I’m still able to receive VHF ch 58.1. Plus 7.1 , 13.1. WPIX 11.1 at times sometimes in the AM. For the most part it looks like it doesn’t exist. I’m thinks of raising the antenna another 5 feet and see if it helps. Any updates on if and went WNYW 5.1 planed move to the WTC will take place.
HoundBaby is offline
post #19342 of 20113 Old 07-10-2018, 03:47 AM
LenL's Avatar
Quoted: 442 Post(s)
Liked: 316
They are stupid. I give money to public broadcasting just about every year and guess what happened when I can no longer get NJN? Probably more people are like me and so those funds are gone for ever!
LenL is offline
post #19343 of 20113 Old 07-10-2018, 05:21 AM
SnellKrell's Avatar
Quoted: 181 Post(s)
Liked: 63
Bingo!
post #19344 of 20113 Old 07-14-2018, 12:34 PM
Aero 1's Avatar
Quoted: 380 Post(s)
Liked: 185
WJLP 33.7 new? Just noticed it, it has color bars and the channel name is called "future".
Aero 1 is offline
post #19345 of 20113 Old 07-15-2018, 01:46 PM
Riverside_Guy's Avatar
Quoted: 46 Post(s)
Weren't some having issues with 5.1 (fox)? Just watched the World Cup Final, no glitches at all, reception fine (UWS, flat antenna).
Internet Connection/Roku Streaming Stick+
Riverside_Guy is offline
post #19346 of 20113 Old 07-16-2018, 07:07 AM
NYC
NYC's Avatar
Quoted: 18 Post(s)
The description states for future programming. Some audio was playing for a short while. Seems like they are testing Heartland, a country music network. The color bars have been up for weeks now.
NYC is offline
post #19347 of 20113 Old 07-22-2018, 07:20 PM
Giacomo Siffredi's Avatar
Quoted: 107 Post(s)
Liked: 40
Or DECADES, as we prepare to say so-long to that diginet's WCBS-TV New York (and other CBS O&Os) affiliations
https://tvnewscheck.com/article/2191...emale-diginet/
Giacomo Siffredi is offline
post #19348 of 20113 Old 07-23-2018, 10:48 AM
unclehonkey's Avatar
Quoted: 570 Post(s)
Liked: 143
Why couldnt they put it on WLNY?
unclehonkey is offline
post #19349 of 20113 Old 07-23-2018, 01:50 PM
Quoted: 107 Post(s)
Liked: 40
Hey Unclehonkey,
CBS could create a subchannel on WLNY-TV Riverhead, though they have not done so to date, and there is ongoing speculation as to whether they will do just that on one of their Los Angeles, CA. TV properties. However, that option begs the question as to why CBS wouldn't just add a -3 subchannel to WCBS-TV New York and move DECADES there. The WLNY-TV signal contour, at present, is fringe throughout most of New York City proper and non-existent in New Jersey, thus such a move, while it would technically keep DECADES on the air in the New York market, would effectively cull its available audience by a significant population quantity.
post #19350 of 20113 Old 07-23-2018, 03:59 PM
Quoted: 570 Post(s)
Liked: 143
I'm not in NY so I'm just speculating. The one press release said that in LA it will move stations. Whether that is CBS's KCAL or Weigel's KAZA is not known. Chicago it will move to a Weigel owned station. I'm sure the reason for the change is due to instant cable coverage of the new diginet.
I wish CBS would create a -3 for Decades. I'm in Minneapolis which is losing Decades too (WCCO-DT2) and unlike most of the CBS O&O markets, Minneapolis has no sister station for it to go to. But it took forever for CBS to add a subchannel to their O&O stations (when they added Decades) so they may be hesitant to add a 2nd subchannel.
