New York, NY - OTA - Page 672 - AVS Forum | Home Theater Discussions And Reviews
 537Likes
post #20131 of 20542 Old 07-20-2019, 12:07 PM
nyctveng's Avatar
Quoted: 171 Post(s)
Liked: 78
Originally Posted by CopRock View Post
Thanks for the info, was wondering why it vanished [zip 10003, 2nd floor above ground facing south with an antenna on the window]
Silly move by FOX since Aug 1st is almost 2 weeks away, wonder is ESB might have been a better choice ??
Do you think stations like FOX make "silly moves" if they didn't have to? Trust me, all the major stations in the city have the engineers that know what they are doing.
nyctveng is offline
post #20132 of 20542 Old 07-21-2019, 06:15 AM
LenL's Avatar
Location: Randolph, NJ, 725' above sea level, 30 miles west of ESB
Quoted: 448 Post(s)
Liked: 318
I really don't think the station engineers are calling the shots. They are not high up on the decision making line from what I see in terms of actual results. If they are then heaven help us!
CopRock likes this.
LenL is offline
post #20133 of 20542 Old 07-22-2019, 07:41 AM
CopRock's Avatar
Quoted: 16 Post(s)
If they knew what they were doing I and many others would be able to tune to 5.1 and see video as we did prior to two weeks ago
CopRock is offline
post #20134 of 20542 Old 07-22-2019, 12:04 PM
nyctveng's Avatar
Quoted: 171 Post(s)
Liked: 78
Just because you and others lost signal for a short period of time does not mean stations don't know what they're doing. Short term pain for long term gain. You will likely get FOX back after the repack, if not then no later than the start of the Fall TV season. Sorry but the work involved and the world does not revolve around just you. There are factors outside of the stations' control like those summarized nicely by SnellKrell.
Brian in CT likes this.
nyctveng is offline
post #20135 of 20542 Old 07-22-2019, 12:39 PM
trailblazer's Avatar
Quoted: 139 Post(s)
Liked: 43
Since the repack testing began I have nothing but problems with WNBC/Telemundo channels 4 and 47 whereby I can't get a stable signal to lock in. Hopefully once they move to the new frequency this issue will go away
CopRock likes this.
trailblazer is offline
post #20136 of 20542 Old 07-22-2019, 12:39 PM
Quoted: 41 Post(s)
Liked: 4
I think there is fox5 app so you don`t need to miss out on your favorite shows, I can wait till 2nd of August, what I like to see is wliw on freedom tower which is being delayed till they built out, which should be sometime this year.
Useeme1234 is online now
post #20137 of 20542 Old 07-22-2019, 12:41 PM
Quoted: 41 Post(s)
Liked: 4
Last night nbc signal was lost, I did rescan I got wvit ch30 from Ct instead
post #20138 of 20542 Old 07-22-2019, 05:34 PM
Quoted: 28 Post(s)
Liked: 4
WLIW is already doing tests at 1WTC. You can see the two spikes in RF 32 when WLIW is being broadcasted from 1WTC here: https://www.rabbitears.info/tvdx/ren...32/-14days/now
WLIW will switch to RF 32 (at 1WTC) on Aug 1st. I'm not aware of any delays.
darkegg is offline
post #20139 of 20542 Old 07-22-2019, 05:40 PM
SnellKrell's Avatar
Quoted: 217 Post(s)
Liked: 72
From what I've been able to glean, WLIW's move to 1WTC is still scheduled
for 1 p.m. on August 1st.
The only things that have changed are -
Durst being unable to fulfill its original placement of WLIW main transmission
location on PEP40, the Upper UHF Antenna. Main transmission will emanate from
PEP96, the Lower UHF Antenna and the Upper will be used for Auxiliary transmission.
The next Durst screw up is that a Combiner will have to retuned, not in time for the
magic Phase 4 date of August 2nd. Therefore, WLIW will have to operate from its brand,
spankin' new facility at reduced power.
Durst, you've done it again!
SnellKrell is offline
post #20140 of 20542 Old 07-22-2019, 06:18 PM
foxycat's Avatar
Originally Posted by NYC View Post
Try using code 2303. Also, you did not mention batteries, but I assume you replaced them.
I have a Digital Stream converter box from Radio Shack and I am able to control the box with these remotes and codes:
Universal Zenith 3 in 1, ZEN350B, use code 358, [email protected]
Universal Replacement 3 by Philips, use code 0765, support phone 919-573-7854
If those don't work or can't find them, try to look for a code search feature on your remote, where various codes are attempted. You will need to keep pressing a button to indicate the current code did nothing and to move on to the next code. Also, try to use codes listed under cable or satellite, that is what worked for me, after all, it is a converter box. Hope that helps.
Yes, they're new batteries, and the TV turns on and off just fine.
There's no button for a converter box among the devices on the remote. (makes sense to me, we have probably the only 2 boxes in the US) Tried the cable button, but the Power key doesn't stay on. It blinks 4x and turns off. Maybe this remote is too new. It's an RCA, BTW.
My PBS station, the only station, quit over the weekend. One thing about having no TV is that I go to bed earlier and get up earlier.
Update--just bought a copy of the original remote from Ebay.
foxycat is offline
post #20141 of 20542 Old 07-23-2019, 01:00 AM
Quoted: 41 Post(s)
Liked: 4
Thanks for the update on wliw, I saw that cptv has renamed their bridgeport station wedw to Stamford
post #20142 of 20542 Old 07-23-2019, 08:39 AM
Quoted: 145 Post(s)
What they did was they changed their city of license from Bridgeport to Stamford. The purpose of doing this was so they could get their DTS application approved. Once the DTS goes live later this year they will have coverage throughout Fairfield County, Westchester, NYC, and northern NJ. Obviously this greatly expands the current coverage area of WEDW.
ansky212 is offline
post #20143 of 20542 Old 07-23-2019, 06:58 PM
speedlaw's Avatar
Quoted: 76 Post(s)
Liked: 56
after checking the contours...
Originally Posted by KyL416 View Post
Check Rabbitears they have contours for all the construction permits and STA applications
WPXN:
Construction Permit contour:
https://www.rabbitears.info/contour....4&site=1&map=Y
Reduced Power STA Contour:
WCBS:
https://www.rabbitears.info/contour....3&site=1&map=Y
Reduced Power STA contour:
https://www.rabbitears.info/contour....5&site=1&map=Y
WLIW:
https://www.rabbitears.info/contour....7&site=1&map=Y
WNJU/WNBC hasn't filed for anything yet, while WNYW had to file to change their final construction permit because of the Durst mess.
Amazing. It's almost like they don't really care about the OTA viewer. I find myself on a hill, and it remains green pretty much in all the models...Yet, channel 5 has gone missing here 40 miles up the Hudson. I'm not a Fox viewer, so don't care (save The Orville) but previously it was one of the strongest signals from the NYC area.
Hope I get WLIW-Motorweek isn't carried on 13, and 50.1 NJN is hit or miss.
In Vienna we sit, in late night cafe. Straight Connection, on T.E.E.
speedlaw is offline
post #20144 of 20542 Old 07-23-2019, 07:55 PM
KyL416's Avatar
Quoted: 162 Post(s)
Liked: 90
Here's the contour for WWOR/WRNN's STA that they filed for yesterday:
Licensed contour:
https://www.rabbitears.info/contour....0&site=1&map=Y
https://www.rabbitears.info/contour....6&site=1&map=Y
Nothing filed for WNJU/WNBC yet, although it's possible they could temporarily relocate to their Aux facility at 4 Times Square:
4 Times Square Contour:
https://www.rabbitears.info/contour....d&site=1&map=Y
KyL416 is offline
post #20145 of 20542 Old 07-25-2019, 06:43 AM
Quoted: 145 Post(s)
I ran a channel scan this morning and I'm picking up a new channel on 6-1 which has the ID of WNWT-WX. They appear to be running the same weather programming as WJLP 33-10. Anybody know what WNWT is? I don't see them listed on RabbitEars.
ansky212 is offline
post #20146 of 20542 Old 07-25-2019, 07:17 AM
SnellKrell's Avatar
Quoted: 217 Post(s)
Liked: 72
After seeing this, I did a scan - and there is was.
Although not listed as Display 6.1, it's a "Guest" channel hosted by WJLP. Here's the listing on Rabbitears -
51 3 (G) WNWT-LD NEW YORK NY On the air IND
Display
Channel Physical
Channel Video Audio Call Sign Network/Programming Nickname Notes Print
51-1 3.1 480i (w) DD2.0 BuenaTV NewsNet (Soon)
51-2 3.2 480i (w) DD2.0 LATV LATV
51-3 3.3 480i DD2.0 CTVN Cornerstone
51-4 3.4 480i (w) DD2.0 WBQM-4 Spanish Independent "Teleuniverso"
post #20147 of 20542 Old 07-25-2019, 08:00 AM
Trip in VA's Avatar
Quoted: 1647 Post(s)
Liked: 692
I've updated the WNWT-LD listing to mirror WJLP for the time being. I'll update it more later.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #20148 of 20542 Old 07-25-2019, 08:58 AM
Quoted: 145 Post(s)
Does anyone know if WLNY completed their move yesterday? They were supposed to move to their new channel assignment at 1pm on 7/24. I'm not picking anything up on RF27 or RF29, but my signal from WLNY is not always very reliable so I can't tell for sure.
ansky212 is offline
post #20149 of 20542 Old 07-25-2019, 09:50 AM
SnellKrell's Avatar
Quoted: 217 Post(s)
Liked: 72
My reception of WLNY on RF27 is not consistent. Currently, I'm not receiving the station.
It's new frequency, Channel 29 is still being occupied by WNYN-LD.
Just went to WLNY's website, and strangely, the only rescan mentioned was the last one -
June 2018!
So much for the communications expertise of CBS.
Are you sure you saw today's date for WLNY's changeover?
Everyone else (with the exception of WNET) has set 1 p.m. on August 1st as the time
and date.
post #20150 of 20542 Old 07-25-2019, 09:57 AM
Quoted: 145 Post(s)
and date.
I was watching WLNY about a week ago and they had a crawl at the bottom of the screen that said July 24th at 1pm for the changeover. I don't watch WLNY that much so I don't know if that has since changed.
ansky212 is offline
post #20151 of 20542 Old 07-25-2019, 06:24 PM
Brian in CT's Avatar
Quoted: 85 Post(s)
WLNY has switched to RF channel 29. Unfortunately, when WPXU-LD switches to RF 29, everybody from NYC to the west can say goodbye to WLNY. Sorry ansky212.
Brian in CT is offline
post #20152 of 20542 Old 07-26-2019, 10:46 AM
Quoted: 145 Post(s)
No biggie. The only thing I ever watched on WLNY was the occasional 9pm newscast. I have not been able to pick up anything on RF29 last night or today. Perhaps the new frequency is underperforming compared to their old one.
ansky212 is offline
post #20153 of 20542 Old 07-26-2019, 11:15 AM
SnellKrell's Avatar
Quoted: 217 Post(s)
Liked: 72
Beyond other stations transmitting on Channel 29, difficulty for some trying view WLNY might
very well be due to the station using its AUX antenna as it does work on its Main.
The AUX antenna only transmits an ERP of 139 kW, while the Main is authorized at 1000 kW.
There may he hope for viewers trying to view WLNY who live farther east from New York City.
Here is the station's May 2019 filing with the FCC concerning the above. Don't know how much
is still applicable.
"The antenna will operate with a maximum horizontally‐polarized effective radiated power (ERP) of 139 kW
and a vertically polarized ERP of 59.6 kW. The antenna will be required briefly on August 2, 2019 to permit
reconfiguration of the primary antenna system as part of the DTV repack."
post #20154 of 20542 Old 07-26-2019, 11:15 AM
NYC
NYC's Avatar
Quoted: 24 Post(s)
I now have that channel, however I am getting it as 18.1.
I also noticed another new channel, 2.3 DABL. It appears that CBS is launching a lifestyle channel on September 9. Odd that they did not carry Decades (soon to appear on a Fox station in NYC, from what I read), but will add DABL.
Also noticed that Arirang on 48.3 has been off for a while, and there is an SD version of whatever airs on 48.1 on 48.3.
NYC is offline
post #20155 of 20542 Old 07-26-2019, 11:39 AM
Quoted: 24 Post(s)
Liked: 1
I live in Suffolk County so normally I have no problem at all getting WLNY. Last night I rescanned and didn’t pick up any signal from WLNY on channels 27 or 29.
LIantenna585 is offline
post #20156 of 20542 Old 07-26-2019, 11:57 AM
KyL416's Avatar
Quoted: 162 Post(s)
Liked: 90
WCBS did carry Decades on 2-2, but like all the other CBS owned stations, they replaced it with StartTV last year.
KyL416 is offline
post #20157 of 20542 Old 07-29-2019, 12:28 PM
falltime's Avatar
Pix11
Sorry if this has been asked/answered but cant find anything recent. What is story with WPIX. I barely get a signal anymore (Central Brooklyn) - used to be reasonably strong but now weak to the point of useless. Is this me or has something changed
falltime is offline
post #20158 of 20542 Old 07-29-2019, 12:40 PM
SnellKrell's Avatar
Quoted: 217 Post(s)
Liked: 72
Just checked things out and nothing appears to have changed concerning
WPIX's transmission. The Richmond Hill, Live Bandscan shows a strong,
consistent signal for the past week.
post #20159 of 20542 Old 07-29-2019, 01:02 PM
falltime's Avatar
Probably a stupid question but it looks like it comes from WTC - why would all other stations from WTC (for ex. WCBS, WWOR) come in strong and WPIX is weak to non-existent.
falltime is offline
post #20160 of 20542 Old 07-29-2019, 01:06 PM
KyL416's Avatar
Quoted: 162 Post(s)
Liked: 90
WPIX is from Empire. It's also a VHF station, so you might want to check if any of your VHF elements were damaged in one of the recent storms.
KyL416 is offline
