New York, NY - OTA - Page 688 - AVS Forum | Home Theater Discussions And Reviews
 546Likes
post #20611 of 20661 Old 01-12-2020, 08:58 AM
MeatChicken's Avatar
Quoted: 329 Post(s)
Liked: 271
Originally Posted by dstoffa View Post
The only "hype" I would believe would be a claim by a reputable antenna maker that their "new" antenna has been redesigned for the re-packed UHF TV Band.
Most UHF antennas on the market have been designed for an upper limit of RF69. I doubt many were re-tuned for an upper frequency of RF51, and certainly none have been made / designed for an upper limit of RF36.
I'd bet many sold are still tuned for Upper limit of RF83!
MeatChicken is offline
post #20612 of 20661 Old 01-12-2020, 09:18 AM
Quoted: 44 Post(s)
Liked: 5
You can make a 4 bay antenna cut for new uhf band, 10" on each side, gets you vhf channels to boot.
Useeme1234 is offline
post #20613 of 20661 Old 01-17-2020, 10:37 AM
NYC
NYC's Avatar
Quoted: 27 Post(s)
On or around February 17, WABC will drop LiveWell and launch Localish on 7.2
NYC is offline
post #20614 of 20661 Old 01-17-2020, 10:40 AM
Quoted: 149 Post(s)
Sounds similar to the "LX" network that NBC is launching.
ansky212 is offline
post #20615 of 20661 Old 01-22-2020, 08:53 AM
jrampoldi's Avatar
Liked: 0
MHz Worldview (14.1 & 46.1) will cease broadcasting March 1, 2020
mhznetworks.com
jrampoldi is online now
post #20616 of 20661 Old 01-23-2020, 05:56 AM
LenL's Avatar
Location: Randolph, NJ, 725' above sea level, 30 miles west of ESB
Quoted: 467 Post(s)
Liked: 336
mhznetworks.com
Say it ain't so! This is one of the best OTA stations with some really fantastic foreign detective shows! One of my most watched channels along with PBS!
Hopefully someone else will pick them up.
LenL is offline
post #20617 of 20661 Old 01-23-2020, 08:05 AM
Quoted: 35 Post(s)
Liked: 9
No one will pick them up because they are ending their OTA service...
https://mhznetworks.com/mhz-worldvie...tal-streaming/
My guess is they are ending their C-band OTA service to the 26 public television stations that were their affiliates, which most likely is due to $$$ of having a C-band feed.
All is not lost, as they explain they will still be available, but only over the internet and you will now have to pay $ to watch them. A seven day trial and then pay up.
Jim - Springfield, Missouri
Antennas - Antennacraft MXU59 UHF antenna & home-brew version of Antennacraft VHF Y-10-7-13 antenna @ 25'. Both antennas fed through a Channel Master 7777 30dB pre-amp.
Tuners - Zenith DTT901 converter box; AirSpy HF+ sdr; Silicon Dust HDHomerun Dual ATSC tuner, using Rabbitears autologger support.
mrradiohead55 is online now
post #20618 of 20661 Old 01-23-2020, 09:59 AM
KyL416's Avatar
Quoted: 190 Post(s)
Liked: 107
They ended their C-Band service a few years ago, since then they've been delivered to affiliates and sat providers via IP.
KyL416 is offline
post #20619 of 20661 Old 01-23-2020, 10:14 AM
Quoted: 35 Post(s)
Liked: 9
Thanks for the info KyL416. I wondered if they were doing IP after I posted that. I have been a C band/Ku band user for 15 years and am noticing a lot of the longtime C-band services leaving that broadcast medium for IP/fiber. Those that still do satellite TV as a hobby are seeing it shrink away.
Jim
post #20620 of 20661 Old 01-23-2020, 01:05 PM
Quoted: 149 Post(s)
WEDW just filed their tolling request to extend their CP. In it they provide more detail, specifically that you can blame WJLP's owners for filing yet another bogus objection causing the delay in getting the Empire State Building DTS facility on the air.
https://enterpriseefiling.fcc.gov/da...6f1f14e51000ba
Has there been any recent update on the status of WEDW?
ansky212 is offline
post #20621 of 20661 Old 01-23-2020, 01:24 PM
KyL416's Avatar
Quoted: 190 Post(s)
Liked: 107
Nothing new has been filed outside of a recently granted extension of their current RF 21 STA until July.
KyL416 is offline
post #20622 of 20661 Old 01-24-2020, 07:24 AM
LenL's Avatar
Quoted: 467 Post(s)
Liked: 336
MHZnetworks left the air before only to return when their business plan did not work out. They may or may not stay off the air this time too. They may just be playing a game to see if they can find a more lucrative offer than what PBS was giving them....... which was probable peanuts.
It is a niche product they are selling.
LenL is offline
post #20623 of 20661 Old 01-24-2020, 08:12 PM
Liked: 0
I have a question that goes back to analog. How did they have WNBC on channel 4 and WNYW on channel 5 without interference?
Joe Iannucci is offline
post #20624 of 20661 Old 01-24-2020, 08:52 PM
KyL416's Avatar
Quoted: 190 Post(s)
Liked: 107
There's a 4 MHz gap between RF 4 and RF 5:
RF 4: 66-72
RF 5: 76-82
KyL416 is offline
post #20625 of 20661 Old 01-24-2020, 09:11 PM
Liked: 0
RF 4: 66-72
RF 5: 76-82
I see. So, even on more sensitive tuners it wasn't an issue?
post #20626 of 20661 Old 01-25-2020, 09:17 AM
Quoted: 329 Post(s)
Liked: 271
Yes, Channel numbers "essentially" are not the relevant information, it's the actual frequencies that matter ....
For example, there's the 4Mhz gap mentioned above, between 4 and 5 ...
But, between 5 & 6, there's essentially No Gap ( 76-82, and 82-88) That's why historically they wouldn't allow chs 5 & 6 in the same market, but 4 & 5 were fine ....
There's a Whopping 86 MHz gap between Chs 6 and 7 .....
post #20627 of 20661 Old 01-25-2020, 08:18 PM
Brian in CT's Avatar
Quoted: 114 Post(s)
Liked: 29
To be precise, full power TV stations on adjacent channels (except 4/5, 6/7, and 13/14) had to be at least 35 miles away from each other in the analog era. Full power co-channels had to be at least 160 miles apart. Some VHF stations (back before UHF became profitable in the early 1980's) were "short spaced" to as little as 140 miles, but TV station owners needed to jump through hoops with the FCC to get those approved. In contrast, the FCC is allowing full power co-channels in ATSC to be packed in as little as 90 miles apart.
Brian in CT is offline
post #20628 of 20661 Old 01-26-2020, 05:29 AM
mets18's Avatar
Interesting stuff. I wonder why back in the day NYC was allocated channel 5 instead of channel 6. It seems the latter would have offered more space on both sides.
mets18 is offline
post #20629 of 20661 Old 01-26-2020, 10:15 AM
Quoted: 44 Post(s)
Liked: 5
Philly has channel 6. Wpvi abc affiliate, what im sutprised, how come analog signal travel much further than digital.
post #20630 of 20661 Old 01-26-2020, 12:37 PM
KEVINL71's Avatar
Quoted: 156 Post(s)
There was also VHF channel 6 in Schenectady, NY (WRGB-TV) and New Bedford, MA (WLNE-TV).
KEVINL71 is offline
post #20631 of 20661 Old 01-26-2020, 01:54 PM
mets18's Avatar
Yes, but channel 5 first signed on in 1945, 2 years before channel 6 in Philadelphia, 9 years before WRGB moved to channel 6, and 18 years before WLNE signed on.
mets18 is offline
post #20632 of 20661 Old 01-27-2020, 11:23 PM
Liked: 0
I never really though about the frequencies. I thought maybe there was some kind of "filter" or something at the transmitter site to prevent interference. I literally had no idea on that one. I live in the Philadelphia market south of Trenton, NJ. As far as NYC tv, the only channel I actually picked up from there is WABC post digital transition. I have more luck with WLNY and WLIW during tropo months. During the analog days, there was a time I picked up most NYC stations as well NBC 30 in up in CT.
post #20633 of 20661 Old 01-28-2020, 07:37 AM
KEVINL71's Avatar
Quoted: 156 Post(s)
They may have moved, but some time back, WVIT-TV (NBC) channel 30 of New Britain was on channel 35. Then and now, their site is Rattlesnake Mountain in Farmington, CT. CW 20, PBS 24, ION 26 and FOX 61 all transmit from there, too. (Channel 20 is now on channel 33, where CBS 3 of Hartford had been.)
KEVINL71 is offline
post #20634 of 20661 Old 01-28-2020, 06:48 PM
speedlaw's Avatar
Quoted: 84 Post(s)
Liked: 61
AKA the FM broadcast band, which is why you could get the channel 6 audio carrier back in the day with your FM radio tuned to 87.9
In Vienna we sit, in late night cafe. Straight Connection, on T.E.E.
speedlaw is offline
post #20635 of 20661 Old 01-28-2020, 08:17 PM
KyL416's Avatar
Quoted: 190 Post(s)
Liked: 107
87.7 and in the 5 boroughs of NYC you still can do so because of WNYZ-LP which is operating as a franken-FM station:
https://enterpriseefiling.fcc.gov/da...84cf6212b6c0ea
KyL416 is offline
post #20636 of 20661 Old 01-30-2020, 04:22 PM
NYC
NYC's Avatar
Quoted: 27 Post(s)
I used to enjoy the silent movies that were shown on channel 6 WNYZ-LP, with Charlie Chaplin and Buster Keaton, but I am no longer able to tune in that station. I recall that the FCC did not approve as the video and audio were totally unrelated. What video are they airing now? How are they able to stay on the air? Won't they be forced to switch to digital only at some point?
NYC is offline
post #20637 of 20661 Old 01-31-2020, 04:42 PM
Quoted: 27 Post(s)
Liked: 1
Thanks for the interesting post.
According to the Wikipedia article on the station: "On June 29, 2011, the FCC canceled the license of WNYZ-LP and deleted its call sign". So, no more video signal. It looks as if the station had planned to switch to digital on physical channel 49, but the construction permit from the FCC expired. It also look as if the station operated as an analog FM audio/digital video hybrid for just over one year, presumably on physical channel 6, with 1.1 as the video virtual channel number.
logger-a is offline
post #20638 of 20661 Old 01-31-2020, 04:53 PM
KyL416's Avatar
Quoted: 190 Post(s)
Liked: 107
That license cancellation was a clerical mistake on the FCC's part, which is why that section of the article is titled "Accidental license cancelation". It was quickly reversed and they have since been granted another digital flash cut construction permit which doesn't expire until 2023.
The FCC is still deciding on the final fate of the Franken-FM stations after 2021 and is considering letting them continue to broadcast an analog audio signal as an ancillary service.
KyL416 is offline
post #20639 of 20661 Old 02-08-2020, 09:45 AM
Liked: 0
Angry WABC OTA 7-1 compression quality
Hello, new here, if there's a better forum for this please let me know:
Just wondering if anyone else with WABC OTA ch 7-1 has noticed how poor their picture quality is compared to other OTA networks. It's practically internet video. They are compressing significantly more than necessary.
The website below suggests in the technical details for WABC that their bitrate is quite low, as low as 5 Mbps (less than DVD and Netflix), vs other networks using >10 Mbps, which would explain it. I'm not sure how they determined that but would be curious to know.
rabbitears.info/market.php?mktid=1
Just wondering who / what dept I would contact at WABC or ABC to do something about this. It's lame watching big events at this quality and is a perplexing choice for a flagship network in their own city. I'm looking forward to the Academy Awards but watching with "classic RealPlayer quality" is going to bug me. : \
upislouder is offline
post #20640 of 20661 Old 02-10-2020, 01:20 PM
Quoted: 26 Post(s)
Liked: 3
Part of the issue is that ABC uses 720p - I know this is a circular debate but for non-sports content, I think 1080i has a much better quality for news and drama content. But there's definitely something else going on - they must be using an ancient encoder, because there is a ton of visible MPEG compression to the point where it almost looks like I'm watching a moving JPEG.
marlowja is offline
