Boston, MA - OTA - Page 391 - AVS Forum | Home Theater Discussions And Reviews
 498Likes
post #11701 of 12549 Old 03-09-2018, 07:57 PM
jakejm79's Avatar
Quoted: 102 Post(s)
Liked: 95
Originally Posted by Channel99 View Post
Here's 3 of them - (I can't receive WNEU)
WBTS-LD
Bitrate: 24.000 Mbps Resolution: 1920 x 1080i
WYCN-LD
Bitrate: 17.613 Mbps Resolution: 1920 x 1080i
WMFP
Bitrate: 24.000 Mbps Resolution: 1280 x 720p
There isn't much visible difference really, switching back and forth on a 40" Samsung, but dark backgrounds on 60-5 seem slightly noisier. All 3 are better than the HDMI feed from Comcast cable ch. 810.
Also keep in mind 60.2 only has stereo sound, the others have DD5.1
jakejm79 is offline
post #11702 of 12549 Old 03-10-2018, 05:25 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
There may be limitations in the STL link from the NBC/Boston studios in Newton to the WNEU New Hampshire transmitter, or limitations in the current transmitter itself.
When they move the WNEU transmitting site to Needham at the repack, they will be using a new ch 29 transmitter, and new STL link from the NBC/Boston studios now under construction in Needham.
Channel99 is offline
post #11703 of 12549 Old 03-10-2018, 06:42 PM
pdicamillo's Avatar
What is indicating that 60.2 has only stereo sound? The program I use for recording shows this:
Stream contains 4 program(s).
Using program 2: 60-5 WBTS-LD:
0x41 MPEG-2 Video [PCR]
0x44 A52/AC-3 Audio, language = eng
0x45 A52/AC-3 Audio, language = spa [2nd audio]
Then when I open the saved .m2t file, the stream info shows:
Type: MPEG transport stream
Duration: 0:01:00
Data Size: 46.24 MB
Bit Rate: 6.45 Mbps
Video Tracks:
65 MPEG-2, 1280 × 720, 16:9, 59.94 fps, 24.00 Mbps, progressive
Audio Tracks:
68 AC3 3/2, 48 kHz, 384 kbps
Everything seems to indicate AC3 5.1. Is it that the surround channels never have content, even for shows where you know they should?
pdicamillo is offline
post #11704 of 12549 Old 03-10-2018, 09:51 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
Duration: 0:01:00
Data Size: 46.24 MB
Bit Rate: 6.45 Mbps
Video Tracks:
Audio Tracks:
60.5 is a subchannel of WMFP and transmits from Needham, and will be shutting down within the next month. 60.2 is a subchannel of WNEU, Merrimack, NH. They both carry WBTS programming. Per the previous poster, jakejm79, 60.2 is stereo only.
post #11705 of 12549 Old 03-12-2018, 04:56 AM
jtkohl's Avatar
Quoted: 12 Post(s)
OK, now I’ve lost track of the NBC Boston transition and final frequency/virtual channel plans.
In Arlington, I currently can tune it on virtual 8.1 (WBTS, low power, only tunable with antenna amp) and 15.1 (WYCN, good power) and 60.5 (WMFP sub-channel, good power but lesser quality as noted above). Sounds like WMFP is doomed. Will either 8.1 or 15.1 stay long term on the current frequency, or is it going to move again to yet another virtual/frequency channel?
jtkohl is offline
post #11706 of 12549 Old 03-12-2018, 05:15 AM
Trip in VA's Avatar
Quoted: 1696 Post(s)
Liked: 715
15.1 is the one that is not going anywhere for the foreseeable future.
- Trip
wizwor likes this.
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #11707 of 12549 Old 03-12-2018, 05:46 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 2008 Post(s)
Liked: 2482
- Trip
And that will remain on RF channel 43?
Hopefully all of these transitions will settle down in the near future. It's a PITA keeping the guide data mappings up to date so that recordings happen as scheduled and watching live TV actually works.
gsr is offline
post #11708 of 12549 Old 03-12-2018, 06:22 AM
bac522's Avatar
Quoted: 248 Post(s)
Liked: 138
Yup and also a disappointment to see stations disappearing while OTA is actually seeing strong growth!
bac522 is offline
post #11709 of 12549 Old 03-12-2018, 06:44 AM
Trip in VA's Avatar
Liked: 715
Until the repack hits and multiple stations change channels at once, yes. WGBX/WYCN-CD will, at that time, move from RF43 to RF32.
- Trip
N4MJC
RabbitEars
post #11710 of 12549 Old 03-12-2018, 06:47 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 2482
- Trip
Ugh, so we still have multiple changes to look forward to.
gsr is offline
post #11711 of 12549 Old 03-14-2018, 11:57 AM
pnkflyd51's Avatar
Quoted: 48 Post(s)
Liked: 34
Yeah, and we don't even know what ATSC 3.0 will bring or the timeframe!
Tschmidt likes this.
pnkflyd51 is offline
post #11712 of 12549 Old 03-25-2018, 09:50 PM
alg2468's Avatar
Quoted: 20 Post(s)
I checked the rabbitears.com site today and it appears that in addition to the changes that will be occurring to the Boston area TV stations as a result of the spectrum repack, the adjacent Providence TV stations will be affected, too. The Providence stations are available over a large area of the Boston area. These changes were granted by the FCC as of today:
WPRI - DTV ch 12, now RF13, moves to RF 7 at 27 Kw with a nondirectional antenna (could be a bit more difficult to receive as it moves to a lower channel).
WSBE - DTV ch 36, now RF21, moves to RF 2 at 10 Kwnondirectional (low VHF will be difficult to receive).
WJAR - DTV ch 10, RF 50, has an application pending to move to RF 25 at 1000 Kw and now nondirectional (making it easier to get over the Boston area).
WLNE - DTV ch 6, RF 49, moves to RF24, with a higher antenna, now nondirectional, and boosting power to 465 K (resulting in a powerful signal extending from Eastern CT to around Cape Ann on Boston's North Shore). That should make receiving the "snowy 6 signal" from the analog days a memory of the past.
WNAC - DTV ch 64, RF 12, has no changes.
alg2468 is offline
post #11713 of 12549 Old 03-26-2018, 05:14 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
WPRI will be more susceptible to RF noise problems on ch 7. Ch. 7 was the original final choice of WHDH back at the time of the analog shutdown, and they very soon requested returning to ch. 42 after many signal complaints.
WSBE's signal is quite spotty and seems to have gaps. I my location a couple of miles south of the Needham towers, I can receive all but WSBE perfectly, but I have never picked up WSBE, yet have received WLIW (also on real channel 21) on Long Island several times via skip. It will be interesting to see if the ch 2 signal does any better.
post #11714 of 12549 Old 03-31-2018, 10:50 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
NBC Boston (or WMFP) pulled the plug on ch 60-5 at 12:01 AM right in the middle of SaturdayNight live. They were not running a crawl, made no announcement, and have no slide directing viewers to rescan - just nothing. The virtual channel is there - with no video and or audio.
March 31 was to be their last day sharing with WMFP (scheduled to shut down later in April).
post #11715 of 12549 Old 04-01-2018, 05:45 AM
bac522's Avatar
Quoted: 248 Post(s)
Liked: 138
Yeah and I'm seeing the other 2 sub-channels off-air as well 62.3 and 62.4. Oh well we knew it was coming, just a bummer to lose stations. I liked some of the sci-fi movies they would show on Comet. I can use the streaming app, but no longer can I DVR which is pretty much the only way I watch TV now a days.
bac522 is offline
post #11716 of 12549 Old 04-01-2018, 08:25 AM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
The contracts probably all ran out on March 31. It appears the only remnant of WMFP that will end up sharing on WWDP is SonLife.
Comet is also carried by WJAR (ch 10-3), if you can receive that. (The real NBC 10....)
post #11717 of 12549 Old 04-02-2018, 04:31 AM
wizwor's Avatar
Quoted: 471 Post(s)
Liked: 275
15.1 is my new home for NBC (which I seldom watch) and it comes with 15.2 Cozi. Nothing on WMFP was as watched in my house as the sitcoms on Cozi are, so I am OK with the change -- a little goodness gained for a little more meh lost. I've removed both Boston PBS affiliates from my lineup. WENH is complete and more reliable. My dial is down to 31 reliable, watched channels. I only miss Antenna TV. Any more changes coming?
wizwor is offline
post #11718 of 12549 Old 04-02-2018, 05:33 AM
DocSmith's Avatar
Quoted: 40 Post(s)
They definitely did run a crawl during last Thursday's Will & Grace. They said 60.5 would be going off, said 15.1 is the new place for NBC, said OTA users would have to rescan. It is surprising that they didn't repeat that message on 60.5 as it was going down though. And then no slide for the information after going offline, sounds like someone was angry.
DocSmith is offline
post #11719 of 12549 Old 04-02-2018, 05:55 AM
bac522's Avatar
Quoted: 248 Post(s)
Liked: 138
Management probably doesn't care, isn't WMFP shutting down for good?
bac522 is offline
post #11720 of 12549 Old 04-02-2018, 07:55 AM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
WMFP would not care, because they are shutting down before the end of the month, and will be sharing on WWDP, presumably only 62-1, SonLife. They may have found it simplest to just pull all the subchannels at once.
However, NBC Boston only running a crawl during a few shows in advance is not enough. It should have been running all day Saturday at minimum, and if they cared to notify viewers adequately, they should have cut the programming before losing access to 60-5 on WMFP midnight and put up a slide with a notice to rescan.
post #11721 of 12549 Old 04-02-2018, 08:11 AM
bac522's Avatar
Quoted: 248 Post(s)
Liked: 138
One word "Sumcast" aka Comcast! Last thing they want to do is make life easy for OTA users!
bac522 is offline
post #11722 of 12549 Old 04-12-2018, 04:30 PM
ProjectSHO89's Avatar
Quoted: 336 Post(s)
Liked: 157
....Anyone up near Keene get any of the Boston stations?
ProjectSHO89 is offline
post #11723 of 12549 Old 04-13-2018, 06:02 AM
wizwor's Avatar
Quoted: 471 Post(s)
Liked: 275
no hope for you. enter your address into tvfool.com for the bleak picture.
wizwor is offline
post #11724 of 12549 Old 05-11-2018, 08:38 PM
mvcg66b3r's Avatar
Quoted: 128 Post(s)
WBTS (NBC Boston) moving to Providence(!?!?!?) after the repack
RabbitEars shows a repack listing for WBTS changing from channel 46 to 36, with Providence as its new COL.
https://rabbitears.info//market.php?...allsign=64996#
They still have WYCN-CD, piggybacked onto WGBX. That should be the main station.
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is offline
post #11725 of 12549 Old 05-12-2018, 12:45 AM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
They still will be moving WNEU from NH to Needham when the repack takes place in the Boston market, and that will most likely become the main station at that time. They won't need WGBX after that.
tveli likes this.
post #11726 of 12549 Old 07-11-2018, 07:09 AM
Liked: 0
Hope this is the right forum...
Hello, I need your help in determining what is the best antenna for my house. I have TVFOOL data here to help with the process.
http://www.tvfool.com/?option=com_wr...903839de2b8c66
I was looking at the HDB91x with possible LNA200 amp or channel master CM4228hd paired w CM7777 amp.
Please help in recommending an antenna and / or amp if needed.
Thanks for all your help as im open to your suggestions.
porky44 is offline
post #11727 of 12549 Old 07-11-2018, 07:08 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
It's mid July, and WMFP has filed with the FCC to extend their operation on ch 18 another 45 days. Why? Because the DirecTV uplink site is unable to receive the pitiful over-the-air signal of WWDP, with which WMFP will be sharing, and a fiber line ordered from Verizon is taking much longer than expected to install:
https://enterpriseefiling.fcc.gov/da...648a87ec4f4f8a
post #11728 of 12549 Old 07-12-2018, 03:34 AM
bac522's Avatar
Quoted: 248 Post(s)
Liked: 138
That setup should be more the adequate, although I don't think you need too preamp, but I suggest posting in this forum to get more idea's/suggestions. https://www.avsforum.com/forum/25-hdtv-technical/
bac522 is offline
post #11729 of 12549 Old 07-12-2018, 12:46 PM
holl_ands's Avatar
Quoted: 958 Post(s)
Liked: 531
CM4228HD has significantly MORE GAIN in UHF Band, esp. on lower UHF Channels than 91XG (after include Loss in it's Combiner):
https://photos.imageevent.com/holl_a...4%20-%20RG.jpg
Note that Ch22 is so strong, it is very likely to be received even with UHF Antenna pointed toward North-West to receive the remaining UHF Stations.
In order to receive Ch10, 12 and 13, you will ALSO need a Hi-VHF Antenna, such as:
https://www.amazon.com/30-2475-Fring.../dp/B014M0XXES
And a VHF/UHF Combiner, such as:
https://www.antennasdirect.com/store...rs.html?page=1
Note that it has DC PASS on the UHF Port, so that it can be located on the INPUT to amplify BOTH UHF and VHF signals or alternatively on the OUTPUT of a Preamp if you chose to amplify ONLY the UHF signals.
You should also post your FMFool Results [click on FM Channels (save image)]...where you will learn that there are two VERY Strong signals on 97.3 and 98.1 MHz. The second Harmonic of these falls on to of Ch10, so you MAY need to insert fol. FM Band Elimination Filter on Output of Hi-VHF Antenna....or Input of Preamp if it is configured to amplify VHF signals:
https://www.antennasdirect.com/store...on_filter.html
http://www.tinlee.com/PDF/CR7-%20FM%20bandstop-w.pdf
holl_ands is offline
post #11730 of 12549 Old 07-12-2018, 07:25 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
Nothing to worry about there. WLWC on ch 22 is only a memory now. The license moved early this year to channel share on WPXQ's transmitter, where it carries only ION Life.
It's too bad that TVFool is so out of date. It the owner needs help with it - there are probably a dozen people on this forum that would be happy to assist.
Displays
