Boston, MA - OTA - Page 396 - AVS Forum | Home Theater Discussions And Reviews
 497Likes
post #11851 of 12541 Old 03-23-2019, 04:46 PM
Quoted: 12 Post(s)
Liked: 0
Originally Posted by Channel99 View Post
Short term it netted them significant dollars - a one time windfall, however. Those that switched to VHF low have boxed themselves into a corner permanently at a competitive disadvantage. Cord cutting and streaming is still increasing. With ATSC 3.0 coming, those stations will still have a second-rate signal.
For WGBH it is not too significant. They will still have the UHF WGBX signal on which to carry the most important channels.
Well not in corner yet on the low band vhf, low power of 600 so fcc is dishing out big money involved with the low power vhf stations.?
Hdb91xg is offline
post #11852 of 12541 Old 03-23-2019, 05:28 PM
Quoted: 12 Post(s)
Liked: 0
Originally Posted by ejb1980 View Post
WGBH and WGBX (2-1 and 44-1) were already in the list of stations in the database from day 1, so they weren't added today. You should already see them in your guide if you use a Boston zip in your AM21. If you see 2-2, you should see 2-1. If you erase all the old zips in your system, it should work. That can be a pain - sometimes you have to reset the AM21, then reset your receiver, then disconnect the AM21 and reset the receiver again, then reconnect the AM21 but disconnect your antenna cable, re-run it without the antenna so it finds nothing and wipes out what it tried to retain, and then finally connect it all properly and then say a little prayer... As long as you have the Miami zip in there, it will not work. In the past, the AM21 needed to match the RF AND PSIP to display, but it doesn't need that anymore - it just needs to see the PSIP of 2-1 to find it. Maybe that could be a reason you had trouble before. I know that WGBH and WGBX are funky with their RF and subchannel displays.
I did the same thing a while ago, my MeTV 5-3 (Burlington VT DMA) isn't in the database so I added a Texas zip to get their MeTV in my guide. A long time ago, I put a Boston zip in my AM21 just to see what it would show. My Bounce channel is on 44-3 and not in the database, but WGBX 44-3 shows up. When they update the Burlington database, I will be in your boat and have to deal with the cumbersome process to make it right to get those pesky old zips out of there and let the new ones show.
Apparently, sometimes when a station is channel sharing, they label it as that instead of a station that Directv doesn't carry - like they don't carry WFXZ but it is channel sharing with WGBH, so they label it WGBHDT5 or whatever instead of what it should be. Dumb. They've done this with other markets, too.
A few months ago, they also re-enabled the displaying of all channels it scans in, so you'll see everything your antenna picks up now. Like before, it must be in the database for it to show guide data. When they started doing that, I got the few Montreal stations I get OTA on my guide, without guide data. One of those channels is SRC CBFT 2-1 and that channel shows up for me as 2-1 WGBHDT because of that lingering Boston zip so that channel is in there for you to find!
I use a "moved" address because the VT locals are lacking and Boston has a nearly complete set of locals. In southern VT, you get both. Perfect. The AM21 adds in the subchannels and PBS that isn't carried by "moving" my service address. The AM21 is a pain in the @$$ but it's better than nothing. They are making a new OTA integration device for Directv, but it works the same as the AM21.
Yes that's why I'm waiting TOO what happens with the low power vh f stations.
Hdb91xg is offline
post #11853 of 12541 Old 03-25-2019, 04:44 PM
Brian in CT's Avatar
Quoted: 104 Post(s)
Originally Posted by Hdb91xg View Post
Yes only a 100 but the fcc is dishing out big money involved with the
Low power vhf stations and I bet the power will go up after all said and done.
Power is not the problem with VHF-Lo. It's RF interference from all your appliances that could make the signal drop out. TV stations like WGBH are counting on cable or satellite penetration remaining high to get their signals out.
Brian in CT is offline
post #11854 of 12541 Old 03-25-2019, 06:52 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
The noise has gotten much worse in the 10 years the low channels have been mostly unused. LED light bulbs, digital controls, switching power supplies, etc., have increased in numbers massively - and few have had reason to complain. Now these channels will suddenly be in use again. Impulse noise is a big problem also, and was in the old analog days - but that type of noise was annoying but relatively easy to ignore as dashed lines in an analog picture - however the same noise will cause a digital signal to lose lock and go black. To override that local noise is nearly impossible even with many times the power. Good reception might be possible with a very directional roof antenna.
Some stations just don't care, they would rather the cash. WGBH will still have the full power UHF WGBX for their most-watched channels, though.
Channel99 is offline
post #11855 of 12541 Old 03-27-2019, 06:33 AM
Quoted: 12 Post(s)
Liked: 0
We'll I never had that problem with an outdoor tv antenna
only with RABBIT ears!!
Hdb91xg is offline
post #11856 of 12541 Old 04-03-2019, 05:48 PM
bac522's Avatar
Quoted: 245 Post(s)
Liked: 137
Just did a scan on my HDHomerun...anyone know what VF 22 is going to be? Seems only 22.1 is broadcasting some religious stuff right now, the other VF channels just have color bars. WFEO comes up as a Florida station, that's one hell of an atmospheric skip!
bac522 is offline
post #11857 of 12541 Old 04-03-2019, 05:53 PM
bac522's Avatar
Quoted: 245 Post(s)
Liked: 137
Actually 22.4 is showing a nice Linux Login sreen, LOL...strange
bac522 is offline
post #11858 of 12541 Old 04-03-2019, 06:06 PM
Trip in VA's Avatar
Quoted: 1693 Post(s)
Liked: 714
I think it's WLEK-LD.
https://www.rabbitears.info/contour....2&site=1&map=Y
- Trip
bac522 likes this.
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #11859 of 12541 Old 04-05-2019, 09:25 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
The login prompt shows makocommunications. Mako Communications is part of HC2 Holdings, which owns the station.
post #11860 of 12541 Old 04-06-2019, 03:39 AM
bac522's Avatar
Quoted: 245 Post(s)
Liked: 137
http://www.makocommunications.com/
Wonder what stations they will be broadcasting? Based on the website doesn't look like anything promising though. Could care less about SBN that is currently broadcasting. Would be great to see something that is similar to ION, but with 4 VF channels, not going to have great quality .
bac522 is offline
post #11861 of 12541 Old 04-06-2019, 05:53 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
Probably nothing to write home about. Looking up a few of their stations on RabbitEars.info:
WKOB-LD New York SBN, Daystar, Shop LC
W25DW-D Chicago LATV, HSN, HSN2, QVC2, Shop LC, Almavision, BeautyiQ
WDUM-LD Philadelphia HSN, HSN2, QVC2, BeautyiQ
KUVM-CD Houston LATV, HSN2, HOT TV
WYGA-DC Atlanta SHOP LC, SBN, HOT TV, HSN, HSN2
bac522 likes this.
post #11862 of 12541 Old 04-07-2019, 12:32 AM
wizwor's Avatar
Quoted: 471 Post(s)
Liked: 275
...with 4 VF channels, not going to have great quality .
Suggest you tune in WENH. 2x720p plus 3x480i look great.
wizwor is offline
post #11863 of 12541 Old 04-24-2019, 09:42 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
The FCC yesterday approved WLEK's application to move the transmitter to Peabody MA, operating with 15 KW from 540 feet on ch 31 with a pattern pointing south, covering much of the Boston area:
https://www.rabbitears.info/contour....50b5b2e&site=1
If WLEK does carry SBN, it will fit in perfectly with SBN on WWDP, Norwell, which has a lot of coverage gaps toward the north. Perhaps they should work together and try to add a couple of the larger diginets missing from the Boston and Providence markets.
Hdb91xg likes this.
post #11864 of 12541 Old 04-25-2019, 07:09 AM
Patsfan123's Avatar
Quoted: 529 Post(s)
Liked: 343
I can't really see SBN being a popular channel in the Boston area considering the demographics. Wish that we were provided with some new non-religious material OTA.
Hdb91xg likes this.
LG 65C6P FW: 05.30.80 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is online now
post #11865 of 12541 Old 04-25-2019, 07:32 AM
ejb1980's Avatar
Quoted: 131 Post(s)
Liked: 33
I agree. I miss Cozi TV on WMFP.
ejb1980 is offline
post #11866 of 12541 Old 04-25-2019, 07:48 AM
Trip in VA's Avatar
Liked: 714
COZI is, of course, found on WYCN 15-2.
- Trip
Hdb91xg likes this.
N4MJC
RabbitEars
post #11867 of 12541 Old 04-25-2019, 09:49 PM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
SBN must be collecting enough in donations and sales of religious items in the market to be able to offer WMFP (via WWDP) more than other diginets do. They get must-carry on cable and satellite also.
The two largest diginets not carried in either the Boston or Providence markets, though they once were, are AntennaTV and Movies! There are other popular ones, such as RetroTV, LightTV, etc. Apparently those diginets would prefer to be unseen in either market than come to an agreement with any station in the area.
post #11868 of 12541 Old 04-26-2019, 11:45 AM
Quoted: 12 Post(s)
Liked: 0
- Trip
Thanks again Rabbit ears for your time and consideration when
It comes down to the BROADCASTING channel's and so on 73.
Hdb91xg is offline
post #11869 of 12541 Old 05-27-2019, 07:52 AM
rm00k's Avatar
Quoted: 24 Post(s)
In last few days noticing ch25 Fox and CBS ch4 are a very weak signal. Pixel break up and sound loss and sometimes the signal is gone altogether. Haven't seen this since they had the transmission tower issues in Boston a couple of years ago. ch7 and ch5 (WCBV) and ch15 (NBC) the signal is strong so its not my equipment/TV's. Maybe it is a tower issue and these 2 ch are on the same tower. Anyone seen this or know anything about it?
Bob
rm00k is offline
post #11870 of 12541 Old 05-27-2019, 08:32 AM
DocSmith's Avatar
Quoted: 40 Post(s)
I just re-scanned my channels and I see slightly lower signal strength for 4.1 and 25.1 than I saw on my previous scan which was back in the winter. However, spring is here and my trees just got all leafy. I usually lose some signal strength in the leaf-covered months. It is strange that I see more loss on 4 and 25 than I do through the rest of my line-up.
DocSmith is offline
post #11871 of 12541 Old 05-27-2019, 06:36 PM
tveli's Avatar
Quoted: 100 Post(s)
Liked: 57
Ditto here in Nashua. Still tuning attic antenna but 25 is entirely absent, 7 is questionable. Forget NBC/60/bruins, way weak.
4 and 5 dropping plenty of frames.
Summer is always the worst season for OTA ATSC but has other advantages . Will ATSC 3 improve summer reception or must NH fringe people maintain a subscription to limited basic tv as well as the limited basic summer available here?
tveli is online now
post #11872 of 12541 Old 05-27-2019, 07:00 PM
wizwor's Avatar
Quoted: 471 Post(s)
Liked: 275
In Danville, I am watching the Bruins as I type this (which looks pretty good via my Recast). Earlier watched According to Jim on LAFF (25 sub). I just checked in on This which is a 7 sub. All good. (Devil's Brigade is a great movie, BTW.)
I live on a hill, but my house is surrounded by white pines, red pines, oaks, and maples.
wizwor is offline
post #11873 of 12541 Old 05-28-2019, 08:00 AM
rm00k's Avatar
Quoted: 24 Post(s)
You should be able to pick up NBC from WYCN Nashua ch 15-1 (real 36). WHDH-7 is still strong for me. 25 still weak to non-existent. WBZ-4 is back to good strength (which according to TVFOOL is noramally my strongest Boston ch). I was thinking there could be some new interference between Nashua and Boston but other Boston ch on the same direction are still good so that can't be it. I'm guessing tower issues with 25 so I might check out their website and inquire there.
rm00k is offline
post #11874 of 12541 Old 05-29-2019, 01:28 AM
Channel99's Avatar
Quoted: 162 Post(s)
Liked: 88
WFXT had moved earlier this year from the Candelabra tower to a temporary antenna on the CBS tower so that the top of the Candelabra tower could be safely rebuilt with a new master antenna. WFXT was the only remaining station there. When the new master is ready, WGBH, WGBX, WBZ, WCVB, and WSBK will move from the CBS tower to the Candelabra tower, along with WFXT. That will allow the master antenna at the top of the CBS tower to be replaced. Once that is completed, WGBX, WBZ, WCVB, and WSBK will move back to the CBS tower. They will be joined there by WNEU (NBCBoston) moving from NH, and WUTF moving from Boylston, MA. WGBH will remain on the Candelabra tower where they will be broadcasting on real ch. 5. Though not yet approved by the FCC, WUNI will probably move from Hudson, MA to the Candelabra tower.
It is possible that some work has begun on the CBS tower, affecting the signals of WBZ, WFXT, etc.
post #11875 of 12541 Old 05-29-2019, 03:48 AM
DocSmith's Avatar
Quoted: 40 Post(s)
Thanks for all the info Channel99. I don't have a VHF antenna any more. Bye bye WGBH!
As I recall, channel 7 which used to be NBC tried to return to VHF after the great initial ATSC upgrade and failed. Nobody wanted them on VHF and they pretty quickly returned to UHF42. What makes WGBH think this is a good idea now, 10+ years after most of us have taken down our VHF antennas?
DocSmith is offline
post #11876 of 12541 Old 05-29-2019, 03:55 AM
wizwor's Avatar
Quoted: 471 Post(s)
Liked: 275
Likely WGBX will carry all the PBS subs. No need for two Boston affiliates when you have subs. PBS cashed in, will still be carried on cable, and can still fund raise as WGBH and WGBX. WENH is the best PBS affiliate in the nation and you should invest in an antenna that will pull that in if you are a PBS fan.
The nice thing about WMUR and WENH being VHF-high stations is that we can point a VHF-high antenna that way and a UHF antenna at Boston to pull in all stations without rotating the antenna. Awesome in this era of multiple TVs and unattended recording.
Tschmidt likes this.
wizwor is offline
post #11877 of 12541 Old 05-29-2019, 03:59 AM
Trip in VA's Avatar
Liked: 714
WGBH had 161,723,929 reasons.
- Trip
wizwor, Tschmidt and Brian in CT like this.
N4MJC
RabbitEars
post #11878 of 12541 Old 05-29-2019, 04:10 AM
DocSmith's Avatar
Quoted: 40 Post(s)
Thanks for the antenna tips wizwor. If I ever want to add another antenna I will try to follow your excellent example. But I must disagree with you on WENH being the best. They ceased being a great independent PBS channel in September 2012, when they became a surrogate, re-broadcaster of WGBX. Their content is now 99% the same as WGBH/WGBX and much of the local flavor is gone, IMHO.
DocSmith is offline
post #11879 of 12541 Old 05-29-2019, 04:26 AM
wizwor's Avatar
Quoted: 471 Post(s)
Liked: 275
but they carry all the subs. most PBS affiliates carry some subset. create, world, discover, and kids plus WGBX is better than WGBX plus Kids and Create, right?
wizwor is offline
post #11880 of 12541 Old 05-29-2019, 04:31 AM
wizwor's Avatar
Quoted: 471 Post(s)
Liked: 275
BTW, I am using a Stellar Labs 30-2476 plus the front of a second 30-2476 to pull in WENH and WMUR right now. The extended antenna is better than a Y10-7-13 (which is an awesome antenna).
wizwor is offline
Displays
