Hartford, CT - OTA - Page 258 - AVS Forum | Home Theater Discussions And Reviews
 40Likes
post #7711 of 7747 Old 06-12-2019, 04:46 PM
Brian in CT's Avatar
Quoted: 62 Post(s)
Originally Posted by ansky212 View Post
Nice. Any word on how long it takes to get this turned on? I'm hoping they put a usable signal into northeastern NJ.
I assume this will happen when WEDW/WZME repack to RF channel 21 sometime during phase four. They should have a tower crew ready from when they planned on moving their transmitter to Stamford.
Brian in CT is offline
post #7712 of 7747 Old 06-12-2019, 04:59 PM
Quoted: 104 Post(s)
Liked: 7
That would make sense. I guess we'll find out over the next 2 months. Is it known if they will be using the main mast on top of ESB or installing a new side mount?
ansky212 is online now
post #7713 of 7747 Old 06-12-2019, 06:16 PM
100/40's Avatar
Quoted: 26 Post(s)
Z, how about an update on WEDW?
100/40 is offline
post #7714 of 7747 Old 06-12-2019, 06:37 PM
KEVINL71's Avatar
Quoted: 124 Post(s)
Bring me up to speed: WEDW-TV (PBS) channel 49 will move to Stamford for its city of license? Does their transmitter move, too?
KEVINL71 is offline
post #7715 of 7747 Old 06-12-2019, 07:15 PM
Quoted: 104 Post(s)
Liked: 7
Their DTS application was approved today. That means they will be running 2 transmitters - the existing one from Trumbull and the new transmitter from Empire in NYC.
post #7716 of 7747 Old 06-12-2019, 07:18 PM
KEVINL71's Avatar
Quoted: 124 Post(s)
Forgive my ignorance...but how can a TV station run two different transmitters?
KEVINL71 is offline
post #7717 of 7747 Old 06-12-2019, 07:24 PM
Quoted: 104 Post(s)
Liked: 7
WMBC in NJ currently does it. They have one transmitter in Montclair, NJ and another atop ESB in NYC.
I'm sure Trip could provide more insight into the technical aspects of it.
post #7718 of 7747 Old 06-13-2019, 02:42 AM
Trip in VA's Avatar
Quoted: 1407 Post(s)
Liked: 514
Send a message via AIM to Trip in VA
This should help, though the "individual broadcasters" section is very outdated. https://en.wikipedia.org/wiki/Distri...mission_system
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #7719 of 7747 Old 06-13-2019, 03:00 PM
Quoted: 24 Post(s)
Liked: 1
That assumes that they had planned to actual transmit from Stamford, as opposed to proposing to transmit from Stamford as a ruse to change their community of license to Stamford and then use Stamford as the reference point for the DTS application.
I suspect that their top priority is to transmit on RF 21 from Trumbull using a temporary antenna. After that is done by the deadline August 2, 2019, they can start work on replacing the temporary antenna at Trumbull with a permanent one (and remove the current RF 49 antenna).
A suitable antenna may already be available on the Empire State Building.
logger-a is offline
post #7720 of 7747 Old 06-13-2019, 10:21 PM
Quoted: 23 Post(s)
Liked: 1
Wedw needs to drop wzme and broadcast pbs programming in 1080 like years before, or nobody is gonna tunein to 480 regardless what is being shown imho
Useeme1234 is offline
post #7721 of 7747 Old 06-20-2019, 01:45 PM
Quoted: 24 Post(s)
Liked: 1
What should happen in the near future is that WTXX will transmit its own over-the-air signal instead of being a temporary channel sharing guest of WEDW. For more information see https://enterpriseefiling.fcc.gov/da...65b470742a0b07
logger-a is offline
post #7722 of 7747 Old 06-25-2019, 08:50 AM
pauldow's Avatar
Quoted: 17 Post(s)
WGBY says they will be changing frequency on July 19.
I believe they're moving from UHF channel 22 to VHF channel 13.
https://wgby.org/tvrescan
Paul
pauldow is offline
post #7723 of 7747 Old 06-25-2019, 05:01 PM
ctdish's Avatar
Quoted: 97 Post(s)
Liked: 44
How can they be on the same channel as WPRI in Providence? Are they going to switch on the same day? They have a large overlap in coverage area.
John
ctdish is offline
post #7724 of 7747 Old 06-26-2019, 05:47 AM
KEVINL71's Avatar
Quoted: 124 Post(s)
Never once did I get a hint of channel 57 in the south end of New Britain. I did get WGGB-TV (ABC) channel 40 in. One lone time. I never received a blip from WWLP-TV (NBC) channel 22 whatsoever. The only Rhode Island digital signal I ever received was WPXQ-TV (ION) channel 69 of Block Island/Providence. That was likely due to their transmitter being in Exeter, RI, close to the Connecticut border.
KEVINL71 is offline
post #7725 of 7747 Old 06-26-2019, 09:35 AM
terminal_man's Avatar
John
WPRI's rescan date for their change to channel 7 isn't until Aug 2.
https://www.wpri.com/news/local-news...ansmitter/amp/
terminal_man is offline
post #7726 of 7747 Old 07-01-2019, 10:11 AM
There was a crawl on WFSB 3 this morning announcing their rescan date as August 1
post #7727 of 7747 Old 07-02-2019, 05:08 AM
100/40's Avatar
Quoted: 26 Post(s)
Understanding I have tree problems, yesterday I lost WFSB 3 completely. Unusual for me. Anyone else have problem?
100/40 is offline
post #7728 of 7747 Old 07-02-2019, 05:10 AM
KEVINL71's Avatar
Quoted: 124 Post(s)
Unless I'm reading something wrong, I'm seeing WFSB-TV channel 3 listed as using channel 36. Is that going to be their new repack channel number? I thought they've been on channel 33?
KEVINL71 is offline
post #7729 of 7747 Old 07-02-2019, 05:17 AM
Trip in VA's Avatar
Liked: 514
https://www.rabbitears.info/tvdx/sig...3B/tuner0/WFSB
Looks like it dropped a lot yesterday. My guess is repack work. They have an STA for 20 kW side-mounted facility rather than their usual 1000 kW top-mount.
- Trip
N4MJC
RabbitEars
post #7730 of 7747 Old 07-02-2019, 08:29 AM
100/40's Avatar
Quoted: 26 Post(s)
- Trip
Thank you Trip!
100/40 is offline
post #7731 of 7747 Old 07-09-2019, 05:47 AM
KEVINL71's Avatar
Quoted: 124 Post(s)
Exclamation
The Frontier service is being removed from where I am on the Berlin/Newington town line. I got caught off guard, only have an old Radio Shack indoor VHF/FM antenna with two rods. Normally, Rattlesnake Mountain would be fine from here (I'm near the tri-point where Berlin, Newington and Rocky Hill all meet, actually). All I could get was channel 30 and its "channel 19" subchannels. Channels 20 and 24 (and "WEDY") popped in. No channel 3,18, 8/59 or 61. I have no other old antenna lying around here. Damn!
KEVINL71 is offline
post #7732 of 7747 Old 07-09-2019, 06:39 AM
Quoted: 104 Post(s)
Liked: 7
You can go to Best Buy on the Berlin Tpke. They should have some antennas to choose from. If not, there is always Amazon.
post #7733 of 7747 Old 07-09-2019, 03:43 PM
BiggAW's Avatar
Quoted: 797 Post(s)
Liked: 207
Frontier is removing their plant? Huh? You could go to Comcast if you want pay TV.
BiggAW is offline
post #7734 of 7747 Old 07-09-2019, 05:01 PM
Quoted: 62 Post(s)
Being removed? Do you live in a condo/apartment complex? Frontier paid big $$$ to AT&T for its Connecticut infrastructure. They can't be discontinuing service in your whole neighborhood, can they?
post #7735 of 7747 Old 07-10-2019, 10:53 AM
KEVINL71's Avatar
Quoted: 124 Post(s)
The relative I'm staying with has to leave their apartment at month's end. A different relative had the Frontier services cut on Monday (TV, phone and internet). That's all. Nothing to do with Frontier or Comcast's relationship with the complex we're in. It's the Berlin side of the town line...barely. The occasional mail offer in the mail box comes from Comcast, not Cox (which is Newington and Rocky Hill).
I had a couple of other indoor antennas at my old place in New Britain's south end. They would've been better for UHF reception. Again, the antenna I'm using now is an ancient Radio Shack VHF/FM antenna with two telescoping rods. I see no elements on it for UHF whatsoever. With the rods folded in, the UHF got a tiny bit better. At first, channel 20 showed up, but only as a blank screen, with the TV displaying 20-4 to 20-6. At last check, I'm getting channel 20 and its subchannels, along with channel 30 and it's "channel 19" subchannels of Telemundo and Telexitos.
It was the first time I even had my relative's TV on, in any fashion, since late March. Since I have to leave within three weeks, there's no point to get another antenna now. Nearly all I've watched since has been with my laptop. I don't stream any TV shows. Just the occasional youtube clip and checking forums like this and the Radio Discussions site.
I assume the other reason I couldn't see channel 24 (PBS) or 61 (FOX) is due to the tower work and the channel repacking mess. Normally (and especially in New Britain), the Rattlesnake Mountain stations were always rock solid.
KEVINL71 is offline
post #7736 of 7747 Old 07-10-2019, 03:03 PM
BiggAW's Avatar
Quoted: 797 Post(s)
Liked: 207
Why are they cutting services? That makes no sense, even for Frontier. Here in Wethersfield, I have been fighting with them for 4 months to wire my building for POTS service as is required by law (which will also bring 70mbps or faster VDSL in since the VRAD is right down the street). Frontier doesn't want to follow the law that says they have to wire it if anyone wants POTS, PURA doesn't feel like doing their job and forcing them to do it, so nothing gets done. They just keep playing hot potato with it, while Frontier is like "HUH?" "WHAT?" "DURRRRR". It's sad because the front-line techs at Frontier are very talented and knowledgeable, but the management is completely incompetent. I swear if they just fired the whole management and let the CWA guys run the show the company would make way more money and the service would be way better.
Brian in CT likes this.
BiggAW is offline
post #7737 of 7747 Old 07-10-2019, 04:47 PM
Quoted: 62 Post(s)
Geez. Your relative couldn't wait to cut service until you vacated the property? If it were me, this person would be out of the will.
post #7738 of 7747 Old 07-10-2019, 04:50 PM
Quoted: 104 Post(s)
Liked: 7
WLNY is running a scroll this evening indicating that they will be changing to their new RF assignment on July 24th at 1pm.
post #7739 of 7747 Old 07-11-2019, 05:31 PM
BiggAW's Avatar
Quoted: 797 Post(s)
Liked: 207
Oh, I re-read that, I guess it was the relative. It sounded like Frontier cut the service off the first time I read it.
BiggAW is offline
post #7740 of 7747 Old 07-15-2019, 12:27 PM
KEVINL71's Avatar
Quoted: 124 Post(s)
Yes, the Frontier service was cut to the apartment. The two TVs the place had are now gone, leaving only the s----y VHF/FM indoor antenna behind (won't work for most UHF anyways). With the rods folded in, I picked up a little of channel 20 and 30. It REALLY sucks with no internet now! (My cell phone browser won't work either, on top of the phone not having a working number since March of 2018.)
Meanwhile, while in his work place's break room, my brother said channel 3 had their crawl running across the top of the screen. It was their reminder about the rescan on either July 31st or August 1st.
KEVINL71 is offline
