Jacksonville, FL - HDTV - Page 152 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #4531 of 4585 Old 11-17-2017, 10:13 AM
Super Moderator
DrDon's Avatar
Quoted: 2383 Post(s)
Liked: 4568
Originally Posted by Darkfire124 View Post
Hi all, I'm new to OTA and was looking for suggestions for getting an antenna.
Here is my TVFool Link.
tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d60ed844775364 a
Inside? Outside? Attic? Number of televisions? Stations that are/aren't important? Apartment? Condo? Which floor? Budget?
Otherwise, I'd recommend a small UHF-VHF-Hi combo (example) on the roof or high up on the side of the house nearest the transmitters. From the looks of things, you might be able to get away with less, but if you want to do it once and be done with it, that'd work.
Start cheap and keep receipts. At your distance, depending on your dwelling info, something as simple as rabbit ears might work. I think I speak for most of us when I recommend you avoid gimmick antennas. You're paying for the gimmick when something far cheaper would work just as well.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #4532 of 4585 Old 11-17-2017, 10:18 AM
chadsmith013's Avatar
Quoted: 2448 Post(s)
Liked: 2497
Dr. Don...are you in the Tampa area?
if so we are putting together a small GTG off of the Palm Coast area..i know thats a little far..but just putting it out there.
Receiver : Pioneer Elite SC-95
Front Speakers: 3 DIYSG 1099's
Surround Speakers:2 DIYSG Volt 10's Atmos: 2 DIYSG Volt 6's
Subwoofers: Dual LaVoce SAN214.50 21's in Cyclops enclosures w/Inuke 6000 DSP Channel A
Nearfield: 4 B-52 SP-1804 18s w/Inuke 6000DSP Channel B
chadsmith013 is offline
post #4533 of 4585 Old 11-17-2017, 10:25 AM
Super Moderator
DrDon's Avatar
Liked: 4568
Yeah, I'm in Tampa pending a new gig. PM me dates, etc. Though you're correct. At the moment, it's a bit far. I have one parrot recovering from an issue. He requires 2X daily meds which rules out anything requiring an overnight stay, for the moment. We're about to TRY a couple, though. He's about to that point.
If you ever hit Disney on a weekday, let me know. We make that trip rather frequently since we can't do much else.
And THANKS.
DrDon is offline
post #4534 of 4585 Old 11-17-2017, 01:16 PM
Liked: 2497
And THANKS.
cool..sent you a PM.
sorry to hear about the parrot..
this would only be a half day sort of thing,.
post #4535 of 4585 Old 11-17-2017, 01:20 PM
Liked: 2497
And THANKS.
post #4536 of 4585 Old 11-17-2017, 07:20 PM
Liked: 0
Otherwise, I'd recommend a small UHF-VHF-Hi combo channelmaster.com/Digital_HDTV_Outdoor_TV_Antenna_p/cm-2020.htm on the roof or high up on the side of the house nearest the transmitters. From the looks of things, you might be able to get away with less, but if you want to do it once and be done with it, that'd work.
Inside?Outside?Attic? It's a block wall house and it's a single floor and I have an old chimney that isn't used so I figure that would be a good mounting point. So I planned on outside.
Number of televisions? 3 planned, 4 max.
Stations that are/aren't important? As many as possible is what I'd be shooting for. Only really planned on the stuff coming out of Jacksonville.
Budget? I figured this would be a permanent thing so I wouldn't mind up to 150 if it lasted.
I believe we currently have 2 RCA ANT1052F and a few channels come in okay with spots of lag. We can't get WCWJ-DT at all and would like to get most of the major broadcast channels.
Any other information I can provide please let me know so I can be more of a help.
Darkfire124 is offline
post #4537 of 4585 Old 11-18-2017, 08:48 AM
Super Moderator
DrDon's Avatar
Liked: 4568
You have 2 must-have VHFs, so this or this on your chimney pointed NNW would probably work. If you still have VHF problems, you may need to step up to this.
A preamp might also be nice to have since you'll be feeding up to 4 sets.
DrDon is offline
post #4538 of 4585 Old 11-19-2017, 06:44 PM
Liked: 0
If I wanted to do overkill would the first link you sent, the channelmaster.com/Digital_HDTV_Outdoor_TV_Antenna_p/cm-2020.htm ,just to do it once and be done with it, work? Or would that hurt the signal more than it would help?
post #4539 of 4585 Old 11-19-2017, 10:40 PM
Super Moderator
DrDon's Avatar
Liked: 4568
If you just want to do it once, go with the third link. Or something similar. Some may argue, but, unless you live 3 miles from the transmitters, it's hard to overload without some kind of amplifier. The biggest issue is VHF multipath. The more you can do to minimize that, the better.
Gator99 likes this.
DrDon is offline
post #4540 of 4585 Old 11-20-2017, 05:54 PM
Liked: 0
Thank you very much for your time and help =)
post #4541 of 4585 Old 11-25-2017, 09:36 PM
Quoted: 20 Post(s)
Liked: 2
Hey is there any other Jacksonville owners thread? Just curious. I was considering using Behrens for some home theater upgrades and wanted to know if anyone had experience with them and their recommendations etc.
Phouglas is offline
post #4542 of 4585 Old 11-28-2017, 02:48 AM
Quoted: 20 Post(s)
Liked: 2
Anyone? Bueller?
Phouglas is offline
post #4543 of 4585 Old 01-30-2018, 12:33 PM
reds75's Avatar
Quoted: 231 Post(s)
Liked: 226
It looks like we will be getting Quest tv on one of the sub-channels.
reds75 is offline
post #4544 of 4585 Old 04-18-2018, 12:15 PM
reds75's Avatar
Quoted: 231 Post(s)
Liked: 226
If you want a differnt approach to the way news is delivered watch Bethany Anderson on WTLV 12-1 on Sunday mornings at 7:00 AM. She is very entertaining with a style all her own.
reds75 is offline
post #4545 of 4585 Old 06-13-2018, 01:41 PM
reds75's Avatar
Quoted: 231 Post(s)
Liked: 226
Casey Black Desantis leaves First Coast Living. I wonder who will be her replacement.
reds75 is offline
post #4546 of 4585 Old 07-01-2018, 08:37 AM
reds75's Avatar
Quoted: 231 Post(s)
Liked: 226
I now cant get WJXT with my antenna. This is a first in 15 years. Normally its 25-1 I cant get.
reds75 is offline
post #4547 of 4585 Old 07-01-2018, 08:59 AM
mesaboy's Avatar
Quoted: 22 Post(s)
Liked: 35
I’m not having any trouble with WJXT OTA this morning. Its signal has been garbage though on DirecTV, other locals are coming in fine.
mesaboy is offline
post #4548 of 4585 Old 07-03-2018, 01:41 PM
reds75's Avatar
Quoted: 231 Post(s)
Liked: 226
Now I am getting 4-1 and 25-1. Maybe it has to do with atmospheric conditions. Mesaboy,nice to see someone else on the Jacksonville forum.
reds75 is offline
post #4549 of 4585 Old 08-09-2018, 06:11 AM
reds75's Avatar
Quoted: 231 Post(s)
Liked: 226
If you live a distance away from WJXT and WTLV transmitters,it might be hard to get them lately. I talked to an engineer from the station who said that issues have developed on the towers they hope to have them fixed shortly.
reds75 is offline
post #4550 of 4585 Old 08-13-2018, 06:42 PM
mesaboy's Avatar
Quoted: 22 Post(s)
Liked: 35
Caught this earlier today, explains why it’s been bad on DirecTV lately:
https://www.news4jax.com/entertainme...njoy-wjxt-wjcw
Good to know it’s not just me.
mesaboy is offline
post #4551 of 4585 Old 11-26-2018, 08:38 AM
reds75's Avatar
Quoted: 231 Post(s)
Liked: 226
I wonder how long it will be before Jacksonville stations convert to 3.0 transmissions?
reds75 is offline
post #4552 of 4585 Old 11-26-2018, 08:48 AM
Gator99's Avatar
Quoted: 90 Post(s)
Do you mean the FCC TV spectrum repack? - the dates for that are on antennaweb.org
Jeff
Gator99 is offline
post #4553 of 4585 Old 11-26-2018, 12:52 PM
reds75's Avatar
Quoted: 231 Post(s)
Liked: 226
Thanks for the info. I wanted to know also when they might broadcast in 4k.
reds75 is offline
post #4554 of 4585 Old 11-26-2018, 12:59 PM
Gator99's Avatar
Quoted: 90 Post(s)
Gotcha - 4k broadcast is not even on my radar (yet)
Jeff
Gator99 is offline
post #4555 of 4585 Old 02-22-2019, 05:46 PM
reds75's Avatar
Quoted: 231 Post(s)
Liked: 226
Maybe someday ABC 25-1 will get a strong enough signal to reach St. Augustine all the time. The other Jacksonville stations dont seem too have problems reaching here on a daily basis. This has gone on for at least 15 years.
reds75 is offline
post #4556 of 4585 Old 03-05-2019, 12:40 PM
reds75's Avatar
Quoted: 231 Post(s)
Liked: 226
CBS and FOX local affiliates sold. I wonder if there will be any changes to the news department?
Gator99 likes this.
reds75 is offline
post #4557 of 4585 Old 03-10-2019, 10:39 AM
Liked: 0
WJXT 4 has added StartTv on 4-3. WCWJ 17 has added Movies! on 17.3. I wish I could get channel 35. I'd love to watch Cozi TV and Escape.
fcagaki is offline
post #4558 of 4585 Old 03-10-2019, 04:10 PM
Gator99's Avatar
Quoted: 90 Post(s)
I have recently lost my signal to PBS(WJCT). Picked up 17.3 and added 4.3 but 4.3 has no signal 4.2, 4.1 are fine
Sent from my Pixel 2 XL using Tapatalk
Jeff
Gator99 is offline
post #4559 of 4585 Old 03-10-2019, 05:28 PM
Liked: 0
I still get WJCT 7 but I live about 5 miles from the antenna farm near Southside Bvld.
fcagaki is offline
post #4560 of 4585 Old 03-10-2019, 05:37 PM
Gator99's Avatar
Quoted: 90 Post(s)
I was at 100% WJCT, guess I need to check my antenna.
Jeff
Gator99 is offline
