Rochester, MN - HDTV - Page 118 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #3511 of 3523 Old 11-04-2018, 10:42 AM
mattdp's Avatar
Quoted: 80 Post(s)
Can anyone verify that KXLT moved to 26?
Any changes in signal level?
mattdp is offline
post #3512 of 3523 Old 11-04-2018, 11:49 AM
plasmanut's Avatar
Yes, I can verify it has moved. I was out of town last week but when I returned yesterday it was on 26. Signal improved to a consistent 100% from 80% with my attic antenna/HD homerun setup in Rochester.
mattdp likes this.
plasmanut is online now
post #3513 of 3523 Old 11-08-2018, 03:27 PM
Liked: 0
I haven’t been able to pick up KXLT since the lightning strike. I’ve rescanned several times and raised my antenna height 2ft. Using ClearStream 2Max with the reflector. My Tablo shows 5 full bars on all channels in the DMA, besides Fox not showing up at all.
Peabody91 is offline
post #3514 of 3523 Old 11-08-2018, 03:30 PM
mattdp's Avatar
Quoted: 80 Post(s)
Just for kicks, have you tried the tuner built into your TV?
mattdp is offline
post #3515 of 3523 Old 11-08-2018, 04:27 PM
Liked: 0
Great idea, unfortunately still missing KXLT on my built in tuner. Strange that I can get 100% strength on KSMQ but nothing on KXLT. I’m itching to see the values when TV Fool updates their site. I’m LOS with -74 power pre repack. I’m guessing they dropped the transmitter height a few feet.
post #3516 of 3523 Old 11-08-2018, 04:54 PM
Liked: 0
I’m in Mason City btw. If I get up to 5 posts I’ll link the TV Fool report. I’m about ready to go purchase and install a tripod mount before it gets too cold/snowy, if I lose 1ft of height current setup, KXLT goes from LOS to 1 edge.
post #3517 of 3523 Old 11-08-2018, 04:57 PM
mattdp's Avatar
Quoted: 80 Post(s)
Just looked up Mason City on TVFool. You're 30-45 mi from the transmitters. I'd try an RCA TVPRAMP1R on the antenna as it is now.
I would strongly recommend going with a better antenna setup and a preamp if you're going to go to all the trouble of putting up a tripod install - would give you way more "gain" than just mounting that anemic antenna a few feet higher. Might be a step overkill, but I'd do a Newark.com 30-2370 on UHF pointed right at 45° and a 30-2475 on VHF pointed at 53° into separate inputs of an RCA TVPRAMP1R.
Peabody91 likes this.
mattdp is offline
post #3518 of 3523 Old 11-08-2018, 05:15 PM
plasmanut's Avatar
I agree with Matt on the stronger antenna. KXLT’s coverage in Mason City is now very marginal according to the map on rabbitears. I think it was much better previously but I’m not sure how to retrieve the contour before the move.
https://www.rabbitears.info/contour....=&cir=&circen=
post #3519 of 3523 Old 11-08-2018, 06:16 PM
Trip in VA's Avatar
Quoted: 1327 Post(s)
Liked: 451
Send a message via AIM to Trip in VA
Here's the before: https://www.rabbitears.info/contour....a&site=1&map=Y
- Trip
plasmanut likes this.
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #3520 of 3523 Old 12-30-2018, 03:30 PM
mattdp's Avatar
Quoted: 80 Post(s)
I was down in Rochester over the Holidays. At two different locations (both within 10 mi and LOS to the tower), K25NK-D was nowhere to be found. Anyone know when they went off the air? I haven't seen anything filed with the FCC.
Took SNR levels at one location with an LOS to all R/A/Mc towers. The difference between old/new KIMT and KXLT channel allocations is within 1dB (both are sitting at about 31-33dB - by comparison, KYIN was at 28dB).
mattdp is offline
post #3521 of 3523 Old 12-31-2018, 07:44 AM
AMF8270's Avatar
I was down in Rochester over the Holidays. At two different locations (both within 10 mi and LOS to the tower), K25NK-D was nowhere to be found. Anyone know when they went off the air? I haven't seen anything filed with the FCC...
Mid to late October.
It was about the time that KIMT and KXLT switched frequencies.
I assumed many such low power stations would be leaving the air.
AMF8270 is offline
post #3522 of 3523 Old 03-31-2019, 07:11 PM
brendanjered's Avatar
Liked: 0
Has anyone else had reception problems for the past half of a week or so? As of Thursday morning, all channels were coming in perfectly. Starting Thursday night, the only channel we could receive was KTTC. I've tried rescanning channels and ensured the rooftop mounted antenna is still pointed in the correct direction, so this one has me a little baffled right now. Hopefully the problem is not on our end and everything will be back to normal soon.
brendanjered is offline
post #3523 of 3523 Old 03-31-2019, 07:26 PM
plasmanut's Avatar
Yes, while I still have reception for all, I’ve noticed some dropouts over the weekend with my dual attic antenna setup. The Rochester locals were previously pegged at 100% on my hd homeruns but now they are very choppy strength (except kttc which is still pegged). Very abrupt change after months of being very stable for me. Click image for larger version
