Greenville, NC - HDTV - Page 335 - AVS Forum | Home Theater Discussions And Reviews
 60Likes
post #10021 of 10160 Old 09-18-2019, 05:53 AM
idiotcontrol's Avatar
Originally Posted by Trip in VA View Post
My understanding is that WRAL is running the show at the shared tower. WRAL, WNCN, WLFL, WRDC, and WRAZ are all being done by the same crew at the same time.
- Trip
That's great to know, thanks Trip! Hopefully, one rescan will be all it takes once the work is done. *fingers crossed*
idiotcontrol is online now
post #10022 of 10160 Old 09-18-2019, 06:31 PM
Retspin's Avatar
Quoted: 53 Post(s)
Is there anyone here using a DirecTv OTA tuner? After the repack last week I retained almost all the channels I had before, with the exception of WITN. The WITN signal is fine on all the TV set tuners in the house, but it’s a no show on the Directv tuner. Is anyone else having this issue? I’m thinking Directv goofed on the database.
Retspin is offline
post #10023 of 10160 Old 09-18-2019, 07:08 PM
KyL416's Avatar
Quoted: 175 Post(s)
Liked: 98
The AM21 doesn't need the RF numebers to match anymore, a firmware update from a few years ago changed it so it can just use the virtual major-minor for matching.
Try resetting antenna settings, reboot your receiver twice to clear out any old pre-repack channels it might have retained, and then rerun initial antenna setup.
KyL416 is offline
post #10024 of 10160 Old 09-18-2019, 07:29 PM
Retspin's Avatar
Quoted: 53 Post(s)
Thanks I’ll try that.
Retspin is offline
post #10025 of 10160 Old 09-19-2019, 09:01 AM
Retspin's Avatar
Quoted: 53 Post(s)
That fixed it and thanks for your help! It still doesn’t have 7-4 and 7-5 but I can live with it.
KyL416 likes this.
Retspin is offline
post #10026 of 10160 Old 09-20-2019, 06:48 PM
timhk63's Avatar
Quoted: 23 Post(s)
Db4 back instock at ollies
Was in the Jacksonville Ollie's tonight and they had 5 or 6 of the Antennas Direct original model DB4 back in stock. I don;t know the rules on mentioning pricing here,but I say the were under 50
timhk63 is offline
post #10027 of 10160 Old 09-21-2019, 07:46 AM - Thread Starter
jamieh1's Avatar
Quoted: 37 Post(s)
I have a genie HR54 with a AM21 it does pick up over the air channels that are not in the directv over the air data base. It shows 7.4 and 7.5. But not program info just to be announced.
Retspin likes this.
Directv HD
Samsung UN50H6350 50" LED Smart TV
Channel Master 4228 antenna
Greenville NC, Ral-Durham NC ota market
jamieh1 is offline
post #10028 of 10160 Old 09-22-2019, 01:41 PM
jspENC's Avatar
Quoted: 263 Post(s)
Liked: 54
Nice. I bought a new antenna recently at Lowes. They had Winegard combo VHF hi/UHF for under $30, original over $70. I couldn't resist. It's built like a tank and you can even add elements for VHF low if necessary, (comes with the antenna as a bonus). I am going to test it soon and see what it does.
jspENC is online now
post #10029 of 10160 Old 09-22-2019, 04:05 PM - Thread Starter
jamieh1's Avatar
Quoted: 37 Post(s)
I use to use a channel master 4228 I recently changed to a antennas direct clear stream Max 4. Great antenna and picks up long range.
Also Directv/AT&T channel dispute deadline with WCTI 12 coming up 9/27.
jspENC likes this.
Directv HD
jamieh1 is offline
post #10030 of 10160 Old 09-23-2019, 04:17 PM
timhk63's Avatar
Quoted: 23 Post(s)
What model was it? Get it online or in Jville Lowes
timhk63 is offline
post #10031 of 10160 Old 09-23-2019, 07:09 PM
jspENC's Avatar
Quoted: 263 Post(s)
Liked: 54
It is an RCA ANT3037Z which is really a Winegard Prostar 1000. I don't think they have anymore at Lowes. I got the last one on the shelf... You can check the website and see. This was the Western Blvd location.
post #10032 of 10160 Old 09-26-2019, 04:27 PM
timhk63's Avatar
Quoted: 23 Post(s)
Has anyone every tried this beast? The ClearStream 5® VHF Attic/Outdoor HDTV Antenna
timhk63 is offline
post #10033 of 10160 Old 09-26-2019, 07:52 PM
jspENC's Avatar
Quoted: 263 Post(s)
Liked: 54
No, but I've researched and read that it isn't as good as a yagi VHF high band. I also think it is an eyesore (just my opinion).
post #10034 of 10160 Old 09-27-2019, 09:00 PM
timhk63's Avatar
Quoted: 23 Post(s)
definitely a backside of the house antenna
timhk63 is offline
post #10035 of 10160 Old 09-28-2019, 07:11 PM
timhk63's Avatar
Quoted: 23 Post(s)
So has anyone been able to get anymore info on the ION station (38) or the Tutt stations? I was able to get 21 briefly,but it was only 21.1 and obviously WINT is on the 34 frequency ,so that explains 35 not tuning
timhk63 is offline
post #10036 of 10160 Old 09-28-2019, 07:16 PM
KyL416's Avatar
Quoted: 175 Post(s)
Liked: 98
Ion's website says November 25 for WEPX's full power rescan:
https://iontelevision.com/rescan
KyL416 is offline
post #10037 of 10160 Old 09-28-2019, 10:29 PM
timhk63's Avatar
Quoted: 23 Post(s)
thanks for the info
timhk63 is offline
post #10038 of 10160 Old 09-29-2019, 06:44 AM
jspENC's Avatar
Quoted: 263 Post(s)
Liked: 54
WPXU 35 ION is on channel 16 real. WITN is on 34 real, WPXU's old channel. WTMQ is supposed to move to channel 32 WITN's old spot. Last I checked, it is off the air still.
post #10039 of 10160 Old 10-01-2019, 08:03 AM
AndThenScottSays's Avatar
Quoted: 95 Post(s)
2020 market rankings just came out and we are #100 . Not sure but I think this is the first time we moved into the top 100.
AndThenScottSays is offline
post #10040 of 10160 Old 10-05-2019, 02:57 PM
timhk63's Avatar
Quoted: 23 Post(s)
RDU Transmitters Towers OffLine
Could not get any of the RDU stations early this morning, so I used FB to message WRAL and they told me they had it down working on it. Haven't noticed any difference in signal since they powered back up,so not sure what they were doing or which channel they were working on.
timhk63 is offline
post #10041 of 10160 Old 10-06-2019, 11:01 AM - Thread Starter
jamieh1's Avatar
Quoted: 37 Post(s)
WNCT 9.4 is now carrying Court TV Mystery. Rebranded Escape channel.
Directv HD
jamieh1 is offline
post #10042 of 10160 Old 10-14-2019, 02:56 PM
jspENC's Avatar
Quoted: 263 Post(s)
Liked: 54
WEPX is on a very low power, and has been since the end of last month. Apparently they had an issue getting power to the transmitter. It will not be turned up until the new stuff goes on the air. No telling when that will happen...
WTMQ is still off the air. It hasn't been on for several weeks.
post #10043 of 10160 Old 10-14-2019, 05:49 PM - Thread Starter
jamieh1's Avatar
Quoted: 37 Post(s)
https://iontelevision.com/rescan full power date in late Nov.
DeweyNC likes this.
Directv HD
jamieh1 is offline
post #10044 of 10160 Old 10-22-2019, 10:42 AM
WITN adding Gray's country lifestyle network, Circle, to 7.6 soon, according to Rabbit Ears. Gray's press release says it launches in early 2020. Guess ITN may go ahead and carve out the bandwith for it. WCTI debuting Dabl November 1 on 12.3. No word on where or if Movies! is going anywhere. WTMH 21.3 is still a simulcast of 21.2, Antenna. Wonder if they'll pick it up or place something new there since it doesn't look like Decades is coming back?
post #10045 of 10160 Old 10-22-2019, 03:12 PM - Thread Starter
jamieh1's Avatar
Quoted: 37 Post(s)
I wish WCTI and WYDO would get sub channels picture ratio right. It looks terrible, WITN and WNCT has its channels full screen. WCTI and WYDO pictures cropped.
Hoping maybe some one adds Court TV. Wife watches on Apple TV pretty good programming.
Directv HD
jamieh1 is offline
post #10046 of 10160 Old 10-22-2019, 03:48 PM
Retspin's Avatar
Quoted: 53 Post(s)
Must be something local, the Sinclair stations in Raleigh display those same channels properly.
Retspin is offline
post #10047 of 10160 Old 10-22-2019, 04:49 PM
jspENC's Avatar
Quoted: 263 Post(s)
Liked: 54
I agree. I often stream Comet on Roku because of the shrunken image. You might try the Stirr app too. It has some good channels.
post #10048 of 10160 Old 10-23-2019, 05:26 AM
It's definitely a local preference/issue. In the aftermath of the hurricane last year, when Sinclair managed to get both stations (CTI/YDO) back on the air, the aspect ratio for the subs was presented correctly. Bounce, especially, before that, was awful. Once things settled down and control was returned locally, the subs were pillar boxed again. They're definitely not watchable as they are except for Movies! and Bounce. Like others mentioned, I'll either watch OTT or the RDU stations (once they're available OTA again).
post #10049 of 10160 Old 10-26-2019, 09:57 AM
timhk63's Avatar
Quoted: 23 Post(s)
Okay just going to throw out a few random transition questions here.
Any word on when the Tutt Stations will transition? As it is now I can only manged to get 21.1 and 21.2 and that is part time. I had no problems with them before this phase
Any news on the RDU stations getting back to full power. I still barely get 11 and 17
Also I'm seeing a WQDH in my guide I think its Wilmington any know anything about this station?
timhk63 is offline
post #10050 of 10160 Old 10-27-2019, 01:37 PM
jspENC's Avatar
Quoted: 263 Post(s)
Liked: 54
I think WQDH is coming from Wilmington, on 49 virtual? Does it have color bars? I've seen it several times, but it doesn't come in often.
