Greenville, NC - HDTV - Page 337 - AVS Forum | Home Theater Discussions And Reviews
 61Likes
post #10081 of 10161 Old 11-15-2019, 05:15 AM
idiotcontrol's Avatar
WEPX 38 was coming in loud and strong last night for me. Since the repack, it's been about 2 bars at most on my signal meter. Thursday night, it was all 5 bars. Anybody else seeing better reception from them now? Or was it just an atmospheric fluke?
idiotcontrol is online now
post #10082 of 10161 Old 11-15-2019, 06:22 AM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
Yes. I just scanned to confirm, and 38 is coming in really good down here. Looks like they are ahead of schedule.
idiotcontrol likes this.
jspENC is offline
post #10083 of 10161 Old 11-15-2019, 08:56 AM
DeweyNC's Avatar
Quoted: 12 Post(s)
Liked: 3
I just scanned (10:50am) & didn't get 38 ION in Washington but did get 35 ION(36) with 4-5 bars out of 10.
Nvida Shield-purchased Dec2018
My normal tv channels 2s,7s,9s,12s,14s,19s,25s,38s, Often 5s,50s,51,(22?)
Rare 3s,4s,10s,11s,13s,17s,21s,26s,28s,30s,35s,36s,49s
Outside yaga style antenna. 28-30ft off the ground. Pointed west. Preamp RCA-TVRAMP1Z/No balun, 60ft R6 cable
DeweyNC is online now
post #10084 of 10161 Old 11-15-2019, 12:43 PM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
Not sure why it would be saying 35.1, but 38 is on channel 36, WPXU Ion 35 is on channel 16
jspENC is offline
post #10085 of 10161 Old 11-15-2019, 01:16 PM
DeweyNC's Avatar
Quoted: 12 Post(s)
Liked: 3
Yeah, I couldn't find any info on the combination 35/36 what little bit I searched.
I added a picture to my post later showing it.
I checked my other tv at that time & it showed the same.
I just checked my tv & 35 is gone & 38 is now showing, I didn't do anything.
post #10086 of 10161 Old 11-15-2019, 03:45 PM
DeweyNC's Avatar
Quoted: 12 Post(s)
Liked: 3
Anyone else having any issues with 38 ION, it's dropping out right much from 4 bars (out of 10). May be the current weather but I didnt have these issues before.
post #10087 of 10161 Old 11-15-2019, 05:01 PM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
They moved their transmitter to the WIKS KISS 102 FM tower in Craven county. The old location was just north of the WITN tower, so if you are aimed at the old location, you may need to make some adjustments.
DeweyNC likes this.
jspENC is offline
post #10088 of 10161 Old 11-15-2019, 05:29 PM
DeweyNC's Avatar
Quoted: 12 Post(s)
Liked: 3
Thanks. I checked that tower & I see now
I added a FCC.gov image of the difference.
Im aimed at the WLFL-22 tower (furthest away towards the west) & the location change for 38 is now LESS South but 1 mile further away. (EDIT)
The feed has gotten a little better since 545pm but its still occasionally dropping but not annoying.
EDITED
post #10089 of 10161 Old 11-16-2019, 09:52 AM
timhk63's Avatar
Quoted: 23 Post(s)
Re-scanned and got 38 strong with antenna pointed NW. Now if WNCN and the TUTT stations would get back up.
timhk63 is offline
post #10090 of 10161 Old 11-16-2019, 02:29 PM - Thread Starter
jamieh1's Avatar
Quoted: 37 Post(s)
38 off and on in Washington, signal not good enough to watch, 14 off and on also
Directv HD
Samsung UN50H6350 50" LED Smart TV
Channel Master 4228 antenna
Greenville NC, Ral-Durham NC ota market
jamieh1 is offline
post #10091 of 10161 Old 11-19-2019, 05:08 PM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
Anyone else seen that "Circle" is up on 7.6 ? The picture is blank however.
jspENC is offline
post #10092 of 10161 Old 11-19-2019, 05:10 PM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
Both of these signals are directional toward the west mainly, and that means you will have to be very precise in your setup to get stable reception.
jspENC is offline
post #10093 of 10161 Old 11-19-2019, 06:25 PM - Thread Starter
jamieh1's Avatar
Quoted: 37 Post(s)
Yea Circle supposed to launch in early 2020
https://youtu.be/4zi_AAPsL2c
Directv HD
jamieh1 is offline
post #10094 of 10161 Old 11-27-2019, 06:54 AM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
Anyone know the plans for WYDO? All I've heard is to re-scan on December 6 at 10 AM.
I assume that they will lower the power to do some work, and also that WUNM 19 will have work done at the same time. WUNM will be significantly stronger once the new frequency goes on the air. WYDO will be a little stronger, but nothing like WUNM.
jspENC is offline
post #10095 of 10161 Old 12-03-2019, 07:35 PM
DeweyNC's Avatar
Quoted: 12 Post(s)
Liked: 3
Noticed something strange with the aiming of my old yaga end of my antenna.
I had normally tried to aim at 276deg to get AntennaTv-22 as its a weak station for me & I didnt have any issues getting ION-38.
Since the repack of ION my signal has been subpar so tonight I had my wife to watch the signal on ION-38 while I adjusted the antenna. What's strange is as I adjusted more South towards the ION tower direction (242deg EDIT-INCORRECT LOCATION) the worse the signal got.
So I turned it right much back towards the North & then started back towards the South when the signal maxed out on ION-38 at 300deg so I locked it down.
I still pulled 2s,5s,7s,9s,12s,14s,19s,25s,36s,38s,50s & 54. I checked the direction with a standard compass.
I haven't checked the strength on all the channels but the amount of channels increased from earlier.
Still no 22s lol
post #10096 of 10161 Old 12-04-2019, 08:05 AM
Still no 22s lol.
Still no 22, 28 for me in Winterville either. I am able to pull in 17 sort of reliably in the evenings though it comes and goes sometimes. I don't think you will see 22 or 28 again until the new year when they are moved higher up the tower on their permanent antennas.
post #10097 of 10161 Old 12-04-2019, 08:29 AM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
Since the repack of ION my signal has been subpar so tonight I had my wife to watch the signal on ION-38 while I adjusted the antenna. What's strange is as I adjusted more South towards the ION tower direction (242deg) the worse the signal got.
Still no 22s lol
The signal must be bouncing off of something... due to multi path. If you are in Beaufort Co, the tower should be south south west in northern Craven Co.
DeweyNC likes this.
jspENC is offline
post #10098 of 10161 Old 12-04-2019, 12:58 PM
DeweyNC's Avatar
Quoted: 12 Post(s)
Liked: 3
Edited
post #10099 of 10161 Old 12-04-2019, 01:35 PM
DeweyNC's Avatar
Quoted: 12 Post(s)
Liked: 3
Also on ***fcc.gov*** points to WEPX ION tower is on E Hanrahan rd between Ayden & Grifton, near hwy 11.
The field behind addresses 494 & 530 E Hanrahan Rd, Grifton, NC 28530
Craven County, what am I missing here? thats pretty much straight South of me.
post #10100 of 10161 Old 12-04-2019, 02:21 PM
KyL416's Avatar
Quoted: 175 Post(s)
Liked: 99
WEPX now comes from a tower on Van Moreadith Rd in Jasper, check the maps at RabbitEars instead:
https://www.rabbitears.info/contour....d&site=1&map=Y
https://www.rabbitears.info/tower.ph...e&asrn=1007564
The E Hanrahan Rd tower is their pre-repack location. Many Ion stations, including WEPX, switched towers during the repack because of a dispute with American Tower, so the maps at fcc.gov and other antenna pointing sites/apps might not be up to date.
DeweyNC likes this.
KyL416 is offline
post #10101 of 10161 Old 12-04-2019, 03:28 PM
DeweyNC's Avatar
Quoted: 12 Post(s)
Liked: 3
Ok. I wouldnt had thought the FCC info would be incorrect in which caused me confusion in what was being presented to me obviously.
Im adding 2 pictures
1st shows the location of the water tower & my antenna
2nd shows the ION tower location South of my antenna & the horizontal line to Clayton is a rough estimate of the towers that broadcast 5s/22s/50s etc
Im maybe 3 miles from the water tower.
ID:	2649410   Click image for larger version
post #10102 of 10161 Old 12-04-2019, 03:59 PM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
You won't pick up UHF stations beyond 75 miles with any consistency. It just isn't possible unless you put up a tower that is 100ft high. VHF can go further with a good VHF high setup and probably a preamp.
The Raleigh stations are way behind schedule, so all you can do is wait until they get their antennas finalized.
The old ION tower location was in Ayden/Grifton. If you've ever seen it, it was the oddest looking broadcast tower for UHF. It was so short it was ridiculous.
DeweyNC likes this.
jspENC is offline
post #10103 of 10161 Old 12-04-2019, 04:16 PM
DeweyNC's Avatar
Quoted: 12 Post(s)
Liked: 3
Im holding a constant 2 bars out 10 on channel 5 right now.
My antenna is roughly 30ft off the ground.
Can I be getting them off the water tower?
I dont always pull the 5s,50s & 54 though.
Edit, I do have a amp.
Added picture at 3bars
post #10104 of 10161 Old 12-04-2019, 05:13 PM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
That's quite impressive, and yes you could be getting a signal reflected off the tower. I tried to get Raleigh here just now, and I cannot. I do get WILM LD 10 (15) however, which I am way outside of it's coverage contour.
I do not have very good luck with signals from the west here.
DeweyNC likes this.
jspENC is offline
post #10105 of 10161 Old 12-04-2019, 05:51 PM
DeweyNC's Avatar
Quoted: 12 Post(s)
Liked: 3
Cool.
Im not sure of your location but I just rescanned my tv just in case, I dont recall ever getting a channel 10 from Wilmington before.
Maybe a year ago or so I did pull a channel 10 WAVY (NBC) from Norfolk Va area back when I was first playing with rotating the antenna around to get a feel of what stations were available but I dont really play with it anymore because of having to get on top of my roof (metal at that & dew sets fast on it).
jspENC likes this.
post #10106 of 10161 Old 12-05-2019, 06:53 AM
foxeng's Avatar
Quoted: 264 Post(s)
Liked: 144
The internal FCC data is correct. There is a time lag for when that data is publicly available. TripinVA could possible give a better explanation on why.
DeweyNC likes this.
All opinions expressed (unless otherwise noted) are the posters and NOT the posters employers. The poster in NO WAY is/will speak for his employers. "Arguing with an engineer is like mud wrestling with a pig. After a couple of hours, you realize the pig likes it"
foxeng is offline
post #10107 of 10161 Old 12-07-2019, 04:17 AM
Trip in VA's Avatar
Quoted: 1693 Post(s)
Liked: 714
I'm not involved with ongoing operation of that tool and cannot say how recently it was updated.
- Trip
DeweyNC likes this.
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #10108 of 10161 Old 12-07-2019, 06:38 AM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
WYDO scan day is now the 11th.
jspENC is offline
post #10109 of 10161 Old 12-07-2019, 09:11 AM
foxeng's Avatar
Quoted: 264 Post(s)
Liked: 144
I have my receive station at Atlantic Beach back up. Not receiving WYDO very at all. Very low signal.
Trip in VA likes this.
foxeng is offline
post #10110 of 10161 Old 12-07-2019, 01:56 PM
jspENC's Avatar
Quoted: 264 Post(s)
Liked: 54
I receive it no matter which way I turn, but until I get right on the tower, the signal is low. Once I aim just right, I get it about 90-95% on the meter.
jspENC is offline
