LaCrosse / Wausau, WI - HDTV - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1441 of 1634 Old 06-19-2010, 12:43 PM
bonse's Avatar
So the past few months, my local over the air HD channels are telling me signal strength not strong enough anymore. So I am not able to get any HD channels from any of my Samsung 22" flat panels. Don't use roof top antenna, just the built in attenna on the tv. I do have Charter cable but a Charter cable box is not plugged into these tv's. Any ideas? I used to get all the channels just fine (in the upper 100's).
bonse is offline
post #1442 of 1634 Old 06-28-2010, 08:23 AM
hunmanik's Avatar
I'd be watching Wimbledon on W50DR right now, except that W50DR is down. There's plenty of signal strength, but no data on that signal.
UPDATE so I thought to rescan. What that did was lose my 10.1 and 10.2 mappings. Instead, I can manually punch in 50 or 50.1 or 50.2, they all revert to "50" with plenty of signal strength, but no data.
hunmanik is offline
post #1443 of 1634 Old 06-28-2010, 09:07 AM
adler187's Avatar
I don't know of any new tvs with a built in antenna. Do you mean that you use the built in QAM digital cable tuner to get the local over the air channels from Clear QAM? If so, check out this post. You should just have to rescan your tvs to get the latest QAM lineup.
If you actually are using an antenna to get them over the air, you most likely need to get a better antenna set up. Without more details it would be difficult to know what to suggest.
adler187 is offline
post #1444 of 1634 Old 06-28-2010, 10:35 AM
hunmanik's Avatar
W50DR came back online at 12:33 pm.
hunmanik is offline
post #1445 of 1634 Old 07-05-2010, 07:09 AM
bonse's Avatar
My bad, that is what I meant. I have re-scanned several times but I'll try again and check out the link. Thx.
bonse is offline
post #1446 of 1634 Old 07-05-2010, 09:49 AM
bonse's Avatar
So I re-scanned my tv (Samsung 460 LCD), upgraded the firmware on the tv, tried the new channels (70 range), but it still says scrambled or weak signal. Bummer. I live on the northside of Onalaska. It sucks because I used to be get all the local channels previously in HD when they were were in the 100+ range.
bonse is offline
post #1447 of 1634 Old 07-05-2010, 09:13 PM
bubbaspeed's Avatar
Charter has recently reassigned the QAM locations for local HD channels in La Crosse (and I suspect that they may be shuffled again JUL 28 when they make some minor tweaks to the line-up).
La Crosse area HD channels as I've picked them up...
79-1 WKBT CBS
79-3 WXOW ABC
81.1 WHLA PBS
81.4 WLAX Fox
82.1 WEAU NBC
highlights of SD digital QAM channels...
79.5 this
80.5-80.50 Music Choice
81.2 Wisconsin Channel
81.3 Create
82.2 24/7 Weather
85.4 ion network feed (not KQEG)
86.11 TV Guide Channel
95.1- 95.14 community access channels
bubbaspeed is offline
post #1448 of 1634 Old 07-08-2010, 09:24 PM
DA1745's Avatar
Sometime today (Thursday July 8th, 2010) Charter in Eau Claire changed, remapped, or possibly just encrypted/"scrambled" their Clear QAM HD channels. - Everything was working fine in E.C. yesterday.
I noticed something was wrong when Windows Media Center wasn't correctly recording the Clear QAM HD channels I had programed at 7;00PM namely Fox 25/48 and Weau on another system. According to Windows Media Center the channels were now scrambled. I went to my HDTV to double check what was going on and only the Clear QAM Standard Definition (80's) were coming in. No more 600's or Community channels were coming in and no music channels either (again this is over Clear QAM only - the Analog channels are still working fine AND they (of course) still come in just fine in you have a rental box from charter digital cable STB I tested that too.
I am giving them until tomorrow, then I'm calling to find out what they are doing?
What's stranger is that my HDTV deleted the channels after a few seconds, I believe this is a response (to as Windows reported it ) the channels encryption has been turned on, normally if my HDTV doesn't find the channel it doesn't do an automatic disable like this. It only does that for encrypted / locked channels. Whether this is an accident, or because they are ONCE AGAIN REMAPPING THE CHANNEL Line up I don't know but it's FRUSTRATING and i'm there was no warning of this.
DA1745 is offline
post #1449 of 1634 Old 07-10-2010, 10:36 AM
bonse's Avatar
79-1 WKBT CBS
79-3 WXOW ABC
81.1 WHLA PBS
81.4 WLAX Fox
82.1 WEAU NBC
79.5 this
81.3 Create
82.2 24/7 Weather
Thank you! These work great!
bonse is offline
post #1450 of 1634 Old 07-15-2010, 05:53 PM
DA1745's Avatar
The channels were in deed re-mapped the Clear QAM line up (AGAIN) all except the music channels and KMSP ch 9 out of the Twin cities which remain the same; as was the case in LAX - except the line up is of course different. We now have the network [THIS] and we have lost [ION] at this time. However, it took a few days before they were (done) and not all the channels are posting all the time - the 24/7 weather and NBC TV 13 HD channel seem to be the most cantankerous.
I can't really understand WHY? they did this remapping. I mean the Clear QAM Main ch lineup no longer mirrors what the STB gives ? Are they planning to remap the HD Network channels down into the 80-90 channels? on the STB
Why other than to Frack around with the Clear QAM users was this re-mapping necessary or done I wonder? --> I am aware they are adding or changing some channels in a few weeks so why change Clear QAM now & not the STB?
EAU CLAIRE, WI Charter Clear QAM lineup to the best of what I have so far.
19.3 FOX KMSP CH 9 (SD/HD) TwinCities (MN)
78.6 Lifetime (SD) * This is NEW to our Clear QAM lineup
79.1 CBS WKBT CH 8 (HD) LaCrosse, WI
79.3 ABC WQOW CH 18 (HD)
79.5 THIS Lacrosse EC ?? * This is NEW to our Clear QAM Lineup
81.1 NBC WEAU CH 13 (HD) [Having Issues]?
81.2 NBC 24/7 Weather - [Having issues]?
81.4 PBS - WHWC - WIS
81.5 PBS - WHWC - CREATE
82.1 FOX WEUX TV 48 (HD)
83.1 PBS - WHWC - WPT - CH 28 (HD) Menomonie, WI
83.8 PBS - KTCA - TPT CH 2 (Twin Cities, MN)
83.9 My Network TV
83.12 CW - WQOW CH 15(cable) * New to our Clear QAM lineup
86.1 C-Span (1)
86.4 C-Span (2)
86.6 WGN - Chicago CH 22 (Cable) - This was added last time along with ION
86.9 C-Span (3)
86.10 WISC EYE - Statewide public / Govt. Channel
86.11 TV Guide (Not like the Old TV guide Ch. they show movies and TV too)
98.13 Chippewa Valley Ch 96 Public Access (SD)
98.14 Chippewa Valley Ch 97 Public Access (SD)
No ION ( so far anyway) * Unless maybe i'm having some interference or other issue since they switched channels... could be I'm just not able to receive it but, to have found all the others, I think not. Anyone in E.C. find it ?
Public Access stations outside of the E.C. Area
98.7 Winona, MN Public Access
98.8 Onalaska, WI Public Access
98.9 UW-La Crosse Channel
98.10 Stockton, MN Public Access
98.11 Stanley, WI Public Access
98.12 Rice Lake, WI Public Access
These are the Standard Def. Digitals of the networks
81.3 PBS - WHWC - WPT Ch 28 (SD) Menomonie, WI
83.2 Fox WEUX TV 48 (SD)
83.4 ABC WQOW TV 18 (SD)
83.6 NBC WEAU TV 13 (SD)
83.7 CBS WKBT TV 8 (SD)
Digital Music
80.05 - 80.50 Digital Music Clear QAM 64
Infomercials
78.12 Charter Main Street Advertisement (SD)
77.12 Infomercial
84.12 Infomercial
86.2 Shop NBC Infomercial
86.5 HSN
86.8 QVC
86.12 Infomercial
98.14 - Color bars ??? 24/7 ???
Religious
18.3 (Religious - Network - the one with the Crest in the lower right corner) - Also on Ch 107.3
86.3 EWTN - Religious
107.7 Dayst*r
DA1745 is offline
post #1451 of 1634 Old 09-18-2010, 09:39 PM
Tobias Ziegler's Avatar
This message is to keep this thread alive.
Tobias Ziegler is offline
post #1452 of 1634 Old 10-19-2010, 01:39 PM
roadfever2's Avatar
I'll second that. Keeping it alive.
roadfever2 is offline
post #1453 of 1634 Old 11-07-2010, 05:31 PM
tjdub's Avatar
I panicked a bit when I couldn't get Sunday Night Football. Channel 10 is now really channel 10 instead of channel 50 from WXOW's tower.
tjdub is offline
post #1454 of 1634 Old 11-07-2010, 05:35 PM
mattdp's Avatar
Quoted: 90 Post(s)
Liked: 25
It shows up on RF Channel 10 or is it that the remap shows up as 10.1?
I wouldn't think that they would retransmit on RF Ch 10 via a translator, so if you are picking up RF 10, I would think you are actually getting it from Grand Meadow.
mattdp is offline
post #1455 of 1634 Old 11-08-2010, 10:39 AM
eziemann's Avatar
I love to be the bearer of bad news but for those of you on Charter, expect another $1.01 charge plus tax on your bill for "BROADCAST TV SURCHARGE"
"The Broadcast TV Surcharge is a pass through reflecting charges assessed to Charter by the owners of local broadcast, or local network-affiliated, TV stations. While broadcast stations distribute their signals over the air using free spectrum granted to them by the federal government, they charge Charter significant amounts to carry their TV signals. These signals were historically made available to Charter at no cost, or low cost. However, the prices now demanded by broadcast stations have necessitated that we pass these costs on to customers."
If only they could cut down on all the junk email they send to me about Charter phone, they could skip the price increases.
eziemann is offline
post #1456 of 1634 Old 11-08-2010, 05:41 PM
tjdub's Avatar
Wow, you're right. I just checked again and it is 10 from Grand Meadow I'm getting. My antenna is still pointing due north at La Crosse, and Grand Meadow is 50 miles away due west. Up until this week I was getting channel 50 just fine, but now it won't lock. I left it tuned to 50 for a few minutes and I do see a blip of signal every now and then, so I guess it is still there. Very strange.
tjdub is offline
post #1457 of 1634 Old 11-24-2010, 06:39 PM
roadfever2's Avatar
11/24/2010 @ 8:00 p.m. - Are WFSX and WTPX down or could it just be issues on my end. Just checking.
post #1458 of 1634 Old 11-24-2010, 07:34 PM
lovebohn's Avatar
Fox 55 is down for my OTA too.
lovebohn is offline
post #1459 of 1634 Old 11-24-2010, 08:53 PM
roadfever2's Avatar
It's back. I just picked up a Winegard sensar and had set it up on the railing of my deck to see how it worked and lost wfxs soon after - had me worried (the one I have on my camper worked quite well so I thought I'd give it a shot at the house). The good news is that I picked up WTPX (ION Network) with the new set up. Haven't been able to pick that one up since the DVT transition.
post #1460 of 1634 Old 11-25-2010, 07:58 AM
roadfever2's Avatar
Does anyone normally pick Ch 46 - wtpx near Wausau? After loosing it with Fox 55 last night (which is back now) it never came back. Doesn't show up when I rescan yet if i enter 46.1 manually it shows the same signal strength as it had before loosing it yesterday - just no picture. Wondering if anyone is having similar issues.
post #1461 of 1634 Old 01-29-2011, 06:23 AM
CPR to this thread
post #1462 of 1634 Old 03-17-2011, 10:00 PM
doughboy1013's Avatar
Visiting my parents in northern Wisconsin today, and a commercial came on WAOW noting that the newscasts were switching to HD "soon".
Link to article: http://www.waow.com/Global/story.asp?S=14244167
Impressive for such a small DMA, eh?
doughboy1013 is offline
post #1463 of 1634 Old 03-23-2011, 12:34 AM
mgburg's Avatar
Stay tuned for updates...WEAU DT-13 (NBC) lost its 1,998 foot tower Tuesday evening due to the severe icing and weather that's hit the area.
Station staff was notified by the County Sheriff's Office after one of their own patrol vehicles came upon the tower resting across the county road.
Station staff will be able to determine fully the extent of the damages once the weather clears, daylight is fully available and that it's safe to operate in the immediate vicinity.
In the meantime, other local broadcasters are offering assistance to WEAU where possible and available.
Hopefully, there will be an OTA signal available for NBC-viewing before this weekend.
Respectfully,
Mark
mgburg is offline
post #1464 of 1634 Old 03-23-2011, 01:43 PM
Jim920's Avatar
According to WEAU, their signal is back up on WQOW-18.3. The signal has also been restored to cable and satellite. WEAU is also on 50.1 in La Crosse displacing KTTC-Rochester, thanks to WXOW.
Jim920 is offline
post #1465 of 1634 Old 03-24-2011, 12:33 PM
wi-cj5's Avatar
Signal is currently 480i
wi-cj5 is offline
post #1466 of 1634 Old 03-24-2011, 12:34 PM
mattdp's Avatar
Quoted: 90 Post(s)
Liked: 25
This would make sense, as it's a subchannel on 18.3 and 50.1 is most likely jut retransmitting 18.3.
mattdp is offline
post #1467 of 1634 Old 03-24-2011, 06:52 PM
maybeway36's Avatar
WEAU.com says it's on 25.2 (WLAX) in La Crosse. The Leader-Telegram, however, confirms the 50.1 placement. Is it on both?
maybeway36 is offline
post #1468 of 1634 Old 03-24-2011, 07:10 PM
Trip in VA's Avatar
Quoted: 1424 Post(s)
Liked: 533
Send a message via AIM to Trip in VA
WEAU's website says it will be on 25-2 starting tomorrow.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #1469 of 1634 Old 03-24-2011, 09:35 PM
tjdub's Avatar
Good! I hope they leave it there. 25-2 has always been just a duplicate of 25-1 in lower definition anyway. It would be great to just run WEAU on it indefinitely for those of us around La Crosse who haven't been able to pick up channel 13 since they went digital.
tjdub is offline
post #1470 of 1634 Old 03-24-2011, 09:35 PM
erobert1's Avatar
Sorry for asking such a basic question...
I have been happily watching KTTC from Onalaska (just north of La Crosse) on my Windows 7 media PC for a while now. Yesterday I stopped receiving KTTC. I checked my Sony DVR and I am still getting KTTC on that. When I check the signal strength on my PC it is still reporting a strong signal for 10.1 (KTTC). It has 2 sources listed; 10.1 and 50.1. One of them is called Low Power and the other is called KTTC-DT.
Does anyone have any idea why I can get it on my Sony DVR, but my Windows 7 PC lost it? Any ideas on how to fix it?
erobert1 is offline
