Philadelphia / Harrisburg, PA - Blue Ridge - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 11-01-2017, 09:58 AM
pclement's Avatar
Quoted: 27 Post(s)
Has anyone else lost OTA channel 49-1 from Red Lion, PA? Is it broadcasting from a new location? I always got a strong signal until about 2 weeks ago. Now I get nothing. I see it on D*, but not OTA.
pclement is offline
post #32 of 35 Old 11-02-2017, 12:32 PM
pamajestic's Avatar
Quoted: 17 Post(s)
They are now channel sharing on the WHTM tower channel 10. If you can receive WHTM you may need to perform a rescan. It may be best to delete the old WGCB first.
WHTM also added GetTV and FAFF.
pamajestic is offline
post #33 of 35 Old 11-02-2017, 12:57 PM
pclement's Avatar
Quoted: 27 Post(s)
Thanks. I do not get WHTM (Channel 27and Channel 33 - PBS) very well for some reason. It comes and goes and I have to move the antenna 180 degrees from where I can get almost all of the other channels. 49-1 is COZI and I can get that from other stations. I can get ABC and PBS from Philadelphia, Baltimore and Washington (just not from Harrisburg, PA). 49-1 used to transmit from Red Lion, PA which I could easily get.
pclement is offline
post #34 of 35 Old 07-10-2019, 08:09 AM
pclement's Avatar
Quoted: 27 Post(s)
There are a lot of changes planned for this July. I suggest frequent rescans to check channel availability.
pclement is offline
post #35 of 35 Old 07-15-2019, 07:00 AM
Super Moderator
DrDon's Avatar
Quoted: 2295 Post(s)
Liked: 4340
Just a reminder, this thread is for subscribers to Blue Ridge Cable. The far-more active Philly OTA thread is here:
https://www.avsforum.com/forum/45-lo...l#post58268266
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
