Charlotte, NC - OTA - Page 357 - AVS Forum | Home Theater Discussions And Reviews
 550Likes
post #10681 of 12955 Old 01-28-2017, 05:59 PM
ybsane's Avatar
Quoted: 183 Post(s)
Liked: 62
Originally Posted by tylerSC View Post
This may not be apparent closer to Charlotte, but WCNC appears to be at reduced power recently in fringe areas. And today I am experiencing dropouts at my location in Greenville, SC. WBTV, WJZY, and WMYT are normal. Perhaps local interference, but hopefully it will return. Right now no signal here.
Weak here for me right now with a 24-SNR which is usually around 35. I saw it drop out to zero a couple of times today also.
All Comments made are my own and not of my employer.
ybsane is offline
post #10682 of 12955 Old 01-28-2017, 06:19 PM
Zaxcom's Avatar
Quoted: 147 Post(s)
Liked: 71
Started to lose WCNC last night in uptown.
Zaxcom is offline
post #10683 of 12955 Old 01-28-2017, 06:26 PM
ybsane's Avatar
Quoted: 183 Post(s)
Liked: 62
OTA or through Charter/TWC..?
ybsane is offline
post #10684 of 12955 Old 01-28-2017, 06:27 PM
Zaxcom's Avatar
Quoted: 147 Post(s)
Liked: 71
ota or through charter/twc..?
ota
Zaxcom is offline
post #10685 of 12955 Old 01-29-2017, 02:17 AM
jmccurrytech's Avatar
Quoted: 100 Post(s)
Most definitely reduced power, I was able to pull in WYFF better than WCNC. Ended up watching that for NBC.
jmccurrytech is offline
post #10686 of 12955 Old 01-29-2017, 04:44 AM
bdfox18doe's Avatar
Quoted: 378 Post(s)
Liked: 239
Maybe you all need a preamp..Zaxcom needs at the least to raise his antenna ...
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is online now
post #10687 of 12955 Old 01-29-2017, 05:51 AM
ybsane's Avatar
Quoted: 183 Post(s)
Liked: 62
You are right, I need to add two more antennas and at least that many pre-amps and I might get WCCB good enough for 4.2.2 quality.
ybsane is offline
post #10688 of 12955 Old 01-29-2017, 06:38 AM
bdfox18doe's Avatar
Quoted: 378 Post(s)
Liked: 239
... and I might get WCCB good enough for 4.2.2 quality.
Are you trying to get it in MPEG2 4:2:2, H264 4:2:2, or H265 4:2:2 ? You need to be specific..
Bob
post #10689 of 12955 Old 01-29-2017, 06:39 AM
Zaxcom's Avatar
Quoted: 147 Post(s)
Liked: 71
Yeah 216 HAAT is just not enough.
W4DXL likes this.
Zaxcom is offline
post #10690 of 12955 Old 01-29-2017, 07:30 AM
tylerSC's Avatar
Quoted: 1336 Post(s)
Liked: 247
They must be having technical issues because since yesterday I get no signal at all. SNR says 11.70db. And the past week or so they seemed to be at reduced power on the signal meter. Hopefully they will get it corrected.
tylerSC is offline
post #10691 of 12955 Old 01-29-2017, 07:52 AM
ybsane's Avatar
Quoted: 183 Post(s)
Liked: 62
Trying to MPEG-2 4.2.2, If I increase the voltage on the pre-amp to 18vdc will that improve the ATSC M/H Parade..?
ybsane is offline
post #10692 of 12955 Old 01-29-2017, 08:16 AM
tylerSC's Avatar
Liked: 247
I called WCNC newsroom and the lady answered the phone said they have technical problem and are working to repair. Hopefully by the end of the day and they will be back to full power.
tylerSC is offline
post #10693 of 12955 Old 01-29-2017, 08:21 AM
KramerTC's Avatar
Quoted: 105 Post(s)
Liked: 73
Thank you. That information is very helpful. The technical problem was already happening Friday evening. I could hardly get a signal to watch my favorite signal, Grimm
Trying to watch Meet the Press now and the issue persists.
KramerTC is offline
post #10694 of 12955 Old 01-29-2017, 09:24 AM
difuse's Avatar
Quoted: 125 Post(s)
Liked: 26
I also am not receiving WCNC well, north of Charlotte. Normally there is no issue at all, signal solid.
difuse is offline
post #10695 of 12955 Old 01-29-2017, 10:47 AM
ybsane's Avatar
Quoted: 183 Post(s)
Liked: 62
The signal is there Tyler it just has to many errors to be effective at any great distance.
ybsane is offline
post #10696 of 12955 Old 01-29-2017, 02:21 PM
speedy22's Avatar
they got it working just in time for the NHL all-star game. 100%quality. 58%strength 30 miles north of Charlotte.
speedy22 is offline
post #10697 of 12955 Old 01-29-2017, 07:23 PM
tylerSC's Avatar
Liked: 247
No they are still not back to normal. No signal here in the fringe Greenville, SC. SNR is still around 11.70db. But good it improved a bit in your area. Probably because WCNC has side mounted directional antenna towards Charlotte, so the signal my be a bit stronger to the northeast rather than the southwest. WBTV is top mount omnidirectional, as seen on the FCC coverage maps. But I am watching Tom Brokaw special on WYFF-4, so no problem for NBC.
tylerSC is offline
post #10698 of 12955 Old 01-29-2017, 09:42 PM
KramerTC's Avatar
Quoted: 105 Post(s)
Liked: 73
Still no no signal for me in Huntersville.
KramerTC is offline
post #10699 of 12955 Old 01-29-2017, 11:59 PM
tylerSC's Avatar
Liked: 247
WCNC website says major transmitter failure. They hoped to have it repaired Sunday but look like it may be Monday. Unless they have to order a part or something. Also out on Dish Network but not Time Warner or DirecTV. Not sure about original Charter Spectrum systems which may get OTA. I guess Direct and Time Warner have fiber feed or some other than OTA.
tylerSC is offline
post #10700 of 12955 Old 01-30-2017, 08:14 AM
eacalhoun's Avatar
Quoted: 99 Post(s)
Liked: 27
Just found this gem of a photo on a Charlotte history FB page. I guess this was the WCCB transmitting tower seen in this shot - as opposed to a tower for an STL or other station use. This tower no longer exists. So, Bob or others, what's the history of this tower?
Eric
Name:	Old Coliseum - WCCB Pic.jpg
Eric Calhoun
"If it was simple, anyone could do it" - Roy Clark from Hee Haw
eacalhoun is offline
post #10701 of 12955 Old 01-30-2017, 04:03 PM
tylerSC's Avatar
Liked: 247
Update: Spoke to WCNC. They are hoping to repair transmitter to full power by Wednesday afternoon. Had to replace 60 feet of transmission line.
tylerSC is offline
post #10702 of 12955 Old 01-30-2017, 04:06 PM
Quoted: 37 Post(s)
Liked: 9
Interesting. I've had no trouble at all in Huntersville.
blackcat7 is offline
post #10703 of 12955 Old 01-30-2017, 08:00 PM
KramerTC's Avatar
Quoted: 105 Post(s)
Liked: 73
I'd say! May I ask what type of antenna do you have? Mine is a simple indoor amplified antenna I have on an upstairs window. I've haven't had any issues with WCNC until this weekend.
KramerTC is offline
post #10704 of 12955 Old 01-31-2017, 04:14 PM
difuse's Avatar
Quoted: 125 Post(s)
Liked: 26
I'm as far north of Charlotte as Tyler is south, and there is signal, but very little this far away. The ERP is way lower than normal. None of my receivers can decode anything but small segments of the signal.. I miss Dick Cavett.
difuse is offline
post #10705 of 12955 Old 01-31-2017, 08:09 PM
tylerSC's Avatar
Liked: 247
You see some signal from WCNC because their side mounted antenna is optimized your direction. They have a null to the southwest, unlike WBTV which is more omnidirectional. WJZY is also side mounted, but they do not have as much of a null. Hopefully WCNC will be repaired by Wednesday evening as projected. But I have a strong local signal from WYFF-4 for NBC, so no problem there.
tylerSC is offline
post #10706 of 12955 Old 02-01-2017, 10:31 AM
Quoted: 36 Post(s)
I've got no signal from WCNC here south of Waxhaw at noon today. It was working ok last night.
Working again now at 5:30 pm.
davebmck is offline
post #10707 of 12955 Old 02-01-2017, 06:10 PM
Liked: 0
Thanks for the info provided about this issue!
I recently noticed that my NextPVR OTA recordings of WCNC began failing due to no signal beginning on 1/28. I live about two miles from center city Charlotte and normally WCNC is one of my strongest and most reliable OTA signals, with typical SNR in the green around 24-26 with an indoor directional antenna.
This afternoon I could not acquire a signal.
However, this evening the signal is there, but weak, so I was able to record the evening news, with SNR in the yellow zone, below 20. Some dropouts, but the recording completed normally.
The good news is that the Super Bowl is being broadcast on WJZY, which is still coming in loud and clear, so no hurry ... :-)
zzzoom is offline
post #10708 of 12955 Old 02-01-2017, 08:03 PM
tylerSC's Avatar
Liked: 247
WCNC signal has now been restored. Not sure if they are full power yet, but at least they are back. Will check more tomorrow.
Because I am in the null side of their side mounted antenna, sometimes their signal is 8 bars on a Samsung TV; other times it is 4 or 5. Hard to tell with them as they are more subject to atmospheric conditions. WBTV and WJZY have more omnidirectional contours, as seen on the FCC coverage map. WBTV is always 10 bars and 33db SNR. Not sure why WCNC chose a directional antenna for 22, when their analog 36 was omnidirectional. I suppose it was to boost the signal more towards the east side of Charlotte which is more of their designated market area. Or perhaps to avoid adjacent channel interference with WHNS on 21.
But glad to see WCNC is finally back.
tylerSC is offline
post #10709 of 12955 Old 02-02-2017, 08:53 AM
Liked: 0
I checked again this morning. WCNC is back to full strength where I am located, about 22 miles from the transmitter. Glad they are back, too!
zzzoom is offline
post #10710 of 12955 Old 02-02-2017, 10:47 PM
W4DXL's Avatar
Quoted: 63 Post(s)
Eric
That must have been a very long time ago. A confessed tower spotter I never remember seeing a tower like that at WCCB. WTVI had one at their building across the street, I remember that one. The last time I saw it they had cut it down somewhat but used it for the studio transmitter link I believe.
W4DXL is offline
