Charlotte, NC - OTA - Page 395 - AVS Forum | Home Theater Discussions And Reviews
 328Likes
post #11821 of 11945 Old 04-17-2019, 09:04 PM
tylerSC's Avatar
Quoted: 1119 Post(s)
Liked: 215
WSOC is now the new official station of the Carolina Panthers. More promotional coverage and preseason games.
tylerSC is offline
post #11822 of 11945 Old 04-18-2019, 08:41 AM
foxeng's Avatar
Quoted: 204 Post(s)
Liked: 84
Originally Posted by Zaxcom View Post
WCNC reached out to Charter. Charter has confirmed they see the issue and have escalated the issue to their Video Ops team. Hopefully this will be a quick fix
I have turned off Dolby and using PCM only for now on my system because it recovers quicker when the hits occur.
They must be having an issue system wide. WGHP in High Point is also having an ongoing audio issue with Spectrum that they can't seem to fix.
All opinions expressed (unless otherwise noted) are the posters and NOT the posters employers. The poster in NO WAY is/will speak for his employers. "Arguing with an engineer is like mud wrestling with a pig. After a couple of hours, you realize the pig likes it"
foxeng is offline
post #11823 of 11945 Old 04-18-2019, 08:48 AM
Zaxcom's Avatar
Quoted: 118 Post(s)
Liked: 47
It does appear to be bigger than I originally thought. I now hear the same issue on WCCB. I have no clue why some stations are affected vs others, but I am yet to hear this problem on WBTV or WSOC, WJZY, WTVI or on any other non-local channels on Spectrum.
Maybe certain stations are sharing a bad QAM or some other piece of equipment in the signal path? I used to get a QAM Excel chart from someone who no longer works at TWC-Spectrum, but not in some time now.
Zaxcom is online now
post #11824 of 11945 Old 04-21-2019, 05:45 AM
Zaxcom's Avatar
Quoted: 118 Post(s)
Liked: 47
Thumbs down
Audio drops are getting worse. Now every couple of minutes. Spectrum turned the knob the wrong way.
post #11825 of 11945 Old 04-22-2019, 07:34 AM
Theo1080's Avatar
Quoted: 114 Post(s)
Liked: 53
Since the Charlotte broadcasters are preparing for the repack in September, are they also planning to upgrade to the ATSC 3.0 standard by 2020 as the article suggests? Looks like it would be more cost efficient to do it all at the same time.
ATSC 3.0 is not backward compatibility with ATSC 1.0. Tuner boxes/TV that receive ATSC 3.0 will not be out in force until Christmas 2020. It would be suicide for stations to go ATSC 3.0 now, nobody could view them. Transmitters sold and installed for FCC repack easily convert to ATSC 3.0. All the ATSC 3.0 "work" would be on the studio end.
evan237 and difuse like this.
Ted Hand, CPBE. 8VSB, DRB, AMD
Fellow - Society of Broadcast Engineers
I was there on July 23, 1996...First DTV broadcast in the US..WRAL-HD
Amateur Radio - W9SOC
Theo1080 is offline
post #11826 of 11945 Old 04-22-2019, 01:52 PM
bdfox18doe's Avatar
Quoted: 314 Post(s)
Liked: 168
Even then...Until a viable business plan is developed...Not to mention no one wants to accept that the lighthouse idea
is fundamentally flawed...no one has any idea what the mvpd’s will do with it..dare we mention the significant revenues generated by retrans consent?...plus I’m sure that WSOC’s highly rated news department will be more than willing to take the leap here at a risk of ratings... right Ted??..
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #11827 of 11945 Old 04-22-2019, 02:12 PM
tylerSC's Avatar
Liked: 215
Does WCCB want to reduce their Duke Power bill? Because FCC file says their repack power level has now been slightly reduced from the previously announced 1000kw for channel 18. Wish they would stay full power for those of us in the fringes. Right now I often pull in 27 in Spartanburg County with attic antenna, but sometimes it drop out during the day. Right on the edge but hope for better results when they move to 18.
And strange I can't pull in WSOC on 34 from the similar location, but need to tinker with the antenna in the attic. Right now I get WSOC on 30 but worry when they move to 12, although map look better. Maybe try a different preamp.
tylerSC is offline
post #11828 of 11945 Old 04-22-2019, 03:10 PM
ybsane's Avatar
Quoted: 136 Post(s)
Liked: 39
I am truly puzzled by your replies lately. There were indepth explanations to explain frequency,power output, and HAAT.
All Comments made are my own and not of my employer.
ybsane is offline
post #11829 of 11945 Old 04-22-2019, 03:14 PM
Theo1080's Avatar
Quoted: 114 Post(s)
Liked: 53
Wsoc / waxn
After the transition, WSOC will be on channel 19 at 1000Kw...WAXN will be on channel 32 at 200Kw, an increase from 150Kw, however, it will still be a directional pattern
Theo1080 is offline
post #11830 of 11945 Old 04-22-2019, 03:31 PM
tylerSC's Avatar
Liked: 215
Well WSOC and WCCB transmit from the same basic area and power level. So you would think you would get both about the same. But perhaps issues from the fringes or factors involving the antenna in the attic. But I do wonder why WCCB may slightly reduce repack power, as they had been previously approved for 1000kw if I recall correctly. But I guess just wait and see what happens in September and adjust the antennas as necessary at that time. Just would be nice to still get WCCB and one of the WSOC signals. Should still get all the Dallas signals.
tylerSC is offline
post #11831 of 11945 Old 04-22-2019, 03:43 PM
cpalmer2k's Avatar
Quoted: 376 Post(s)
Liked: 43
Charlotte, NC - OTA
Unless they’ve filed another amendment if you read closely you’ll see WCCB also has switched to a side mount in the latest filing. They will preserve their current coverage/viewer counts but the increase in area/viewers they were originally projected to have were basically erased by the change based on the estimates on rabbitears
cpalmer2k is offline
post #11832 of 11945 Old 04-22-2019, 04:53 PM
tylerSC's Avatar
Liked: 215
I was just wondering why they changed their plans. With a side mount they must want to maximize their signal in a specific area, and the power change must be to comply with FCC regulations. Perhaps someone knowledgeable could explain if they are allowed or choose to do so.
tylerSC is offline
post #11833 of 11945 Old 04-22-2019, 05:02 PM
ybsane's Avatar
Quoted: 136 Post(s)
Liked: 39
From Rabbit ears: I think people are splitting hairs with the data: Channel 27 Longley-Rice coverage map available. CHARLOTTE, NC
BLCDT-20020227AAZ (76fb8257933a422b8728cf6212b6c0ea) - App
1207' 1000 kW DA (H) Directional Pattern
(53.7 kW + 12.7 dB gain = 1000 kW ERP)
63.1 mile contour / 12512.2 sq. mi. area / Est. Pop. 3,607,658
1109' AGL; 1890' AMSL; (1037877)
0.5° Elec Beam Tilt; Full Service Filter
[H-Pat] Dielectric TFU-24DSC-R 3C130
NAD83: N 35° 16' 2", W 80° 44' 4" (35.267222, -80.734444) Rolling Acres (NC)
DTV-CP:
Granted Channel 18 Longley-Rice coverage map available. CHARLOTTE, NC
0000067979 (25076f9168a5f69c0168ce6a45163640) - App - (Exp. 09/06/2019)
1194' 963 kW DA (E) (Vertical ERP: Unknown) Directional Pattern
64.1 mile contour / 12897.3 sq. mi. area / Est. Pop. 3,681,324
1109' AGL; 1889' AMSL; (1037877)
[H-Pat] Dielectric TFU-24DSC/VP-R 3C130
ybsane is offline
post #11834 of 11945 Old 04-22-2019, 05:12 PM
Zaxcom's Avatar
Quoted: 118 Post(s)
Liked: 47
No no no. I want my 37 watts back!
post #11835 of 11945 Old 04-22-2019, 05:22 PM
ybsane's Avatar
Quoted: 136 Post(s)
Liked: 39
Yeah I can see where that 37 watts affects the power bill too, Bob is going green with that reduction. AOC will give him a thumbs up.
ybsane is offline
post #11836 of 11945 Old 04-22-2019, 05:33 PM
tylerSC's Avatar
Liked: 215
Watching Andy Griffith on 18.3 right now. Aunt Bee's famous pickles.
LMckin likes this.
tylerSC is offline
post #11837 of 11945 Old 04-22-2019, 06:00 PM
cpalmer2k's Avatar
Quoted: 376 Post(s)
Liked: 43
I never said it was a huge change, but when you are on the fringes like some of us that kind of change can actually make a difference. It isn’t as relevant now though since WSOC picked up the Panthers rights
post #11838 of 11945 Old 04-22-2019, 07:00 PM
tylerSC's Avatar
Liked: 215
New 18 height and power level are slightly lower than 27, but coverage area is actually about one mile wider. Must be due to new elliptical pattern or some other factor. Still curious why they didn't choose to top mount and stay full power, but perhaps economic or other technical factors. Perhaps cheaper to side mount and FCC policy requires slight power reduction.
tylerSC is offline
post #11839 of 11945 Old 04-23-2019, 02:45 AM
bdfox18doe's Avatar
Quoted: 314 Post(s)
Liked: 168
Aww..just get a preamp...
eacalhoun likes this.
Bob
post #11840 of 11945 Old 04-23-2019, 06:13 AM
Zaxcom's Avatar
Quoted: 118 Post(s)
Liked: 47
But I fell off the digital cliff, signal fell 1 block short without those watts.
post #11841 of 11945 Old 04-23-2019, 02:42 PM
bdfox18doe's Avatar
Quoted: 314 Post(s)
Liked: 168
We’ve Escalated to higher levels of TimeSpecCharWarner....keep us posted if you would Zaxcom...
Bob
post #11842 of 11945 Old 04-23-2019, 03:28 PM
Zaxcom's Avatar
Quoted: 118 Post(s)
Liked: 47
Have not heard any new updates since my last email exchange with Steve. Hopefully soon. I just go OTA now when watching anything I don’t want messed up.
post #11843 of 11945 Old 04-24-2019, 10:00 AM
A J
A J's Avatar
Quoted: 177 Post(s)
Liked: 55
I've seen the actual channel reassignments for the upcoming repack, but how about virtual channel changes? Will there be any?
My concern about virtual channels changes for OTA channels is the delay in getting program guide updates for my Roamio OTA. For example, CoziTV changed virtual channels from 40.1 to 22.1 back in March. TiVo still has the program guide for Cozi on 40.1 with no video, while the video is on 22.1 with no guide info.
A J is online now
post #11844 of 11945 Old 04-24-2019, 10:27 AM
bdfox18doe's Avatar
Quoted: 314 Post(s)
Liked: 168
Originally Posted by A J View Post
I've seen the actual channel reassignments for the upcoming repack, but how about virtual channel changes? Will there be any?.
No, will not change.. A stations legacy branding will remain. You have a very valid concern tho.
Bob
post #11845 of 11945 Old 04-24-2019, 11:20 PM
realoldman's Avatar
Quoted: 160 Post(s)
I hear Court TV will replace decades on WCNC.
realoldman is offline
post #11846 of 11945 Old 04-25-2019, 02:41 AM
ybsane's Avatar
Quoted: 136 Post(s)
Liked: 39
I hope they are just replacing it and not adding another +channel. The HD lite we watch is degrading daily.
ybsane is offline
post #11847 of 11945 Old 04-25-2019, 10:31 AM
W4DXL's Avatar
Quoted: 51 Post(s)
Nooooooo! Love Decades Court TV? Don't we have enough of that?
LMckin and evan237 like this.
W4DXL is offline
post #11848 of 11945 Old 04-25-2019, 10:46 AM
A J
A J's Avatar
Quoted: 177 Post(s)
Liked: 55
Would you share where you heard that? Certainly news to me, and bad news at that. Decades may not be a 24/7 watch but lots of oldies air there which are seldom available elsewhere. I would miss Decades and I would probably do the same to CourtTV whcih I do to the bible-thumper channels, click the hide option, and poof, gone.
A J is online now
post #11849 of 11945 Old 04-25-2019, 10:55 AM
Trip in VA's Avatar
Quoted: 1344 Post(s)
Liked: 459
Send a message via AIM to Trip in VA
From the Court TV website most likely; same place I heard it.
Decades seems like it's on the way out. The CBS O&Os dropped it to launch Start TV, and in places where Weigel has added networks, it has prioritized H&I and Start TV over Decades and Movies!
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #11850 of 11945 Old 04-25-2019, 05:10 PM
evan237's Avatar
Quoted: 103 Post(s)
Liked: 35
- Trip
Speaking of 'Movies!' - I hope WJZY doesn't have any plans on getting rid of their Movies! subchannel. However, they probably do need to trim down some of their other sub-channels.
evan237 is offline
