Charlotte, NC - OTA - Page 419 - AVS Forum | Home Theater Discussions And Reviews
 525Likes
post #12541 of 12876 Old 09-06-2019, 05:45 PM
Quoted: 22 Post(s)
Liked: 1
Originally Posted by cpalmer2k View Post
Something is clearly interfering with WSOC for those of us in SC. I'm about 46 miles away from the tower and have never had issues picking it up before. Tonight I'm getting nothing. It is so bad neither by HDHomeRun nor TiVo can even get a sniff of signal enough to recognize it exists. The rest of the repack seemed to be OK for me. WCNC is much improved, and WCCB is coming in loud and clear. WBTV has always been a "paperclip" channel here.
I'm in SC and WSOC is coming in great, WCCB is not coming in very good at all, and I'm only 31miles away. I've also lost WUNG and WTVI, I'm about 30-40 miles from there towers.
Matthew Hawkins is offline
post #12542 of 12876 Old 09-06-2019, 05:50 PM
realoldman's Avatar
Quoted: 171 Post(s)
There is a low power 19 on Tryon Peak Columbus that has not changed. UNC TV
realoldman is offline
post #12543 of 12876 Old 09-06-2019, 05:50 PM
netconcepts's Avatar
When is WAXN set to go full power. Cannot pull in 64 at all in Rock Hill
netconcepts is offline
post #12544 of 12876 Old 09-06-2019, 06:01 PM
Quoted: 22 Post(s)
Liked: 1
I think next week on 09/11/2019, that's when all the delayed channels should switch over.
post #12545 of 12876 Old 09-06-2019, 06:14 PM
cpalmer2k's Avatar
Quoted: 394 Post(s)
Liked: 46
You might be on to something with that one. With the right atmospheric conditions it might just be the cause of the problem where I am and Tyler the coverage pattern definitely looks close enough to be causing your issues.
cpalmer2k is online now
post #12546 of 12876 Old 09-06-2019, 07:08 PM
tylerSC's Avatar
Quoted: 1321 Post(s)
Liked: 245
What county in SC are you located?
tylerSC is offline
post #12547 of 12876 Old 09-06-2019, 07:13 PM
Quoted: 22 Post(s)
Liked: 1
York, and right by Gaston, NC.
post #12548 of 12876 Old 09-06-2019, 07:18 PM
tylerSC's Avatar
Liked: 245
Originally Posted by Trip in VA View Post
Are the various WSOC issues because various UNC translators on 19 are still operating? Is that what's going on?
- Trip
Perhaps that is the problem. Not a trace of signal in northwestern Spartanburg County. By contrast I am getting a strong signal from WCCB, and they are now reduced power. Now I now I am just beyond the fringe coverage contour for WSOC, but my Samsung and LG signal meters would always detect a signal from 34, even when it would not decode. It would often come in after 6pm and drop out around 10am. Now seeing nothing, and their new 19 signal theoretically should be stronger than before. So will UNC-TV be vacating the channel 19 on Wednesday? I still wonder if there is some sort of technical problem with WSOC and perhaps they are not yet fully operational until WAXN switch to full power on Wednesday. Or maybe that has nothing to do with it whatsoever, just speculating.
tylerSC is offline
post #12549 of 12876 Old 09-06-2019, 07:20 PM
tylerSC's Avatar
Liked: 245
Well you are much closer. Those of us in the western fringes are having difficulty with WSOC since they change to 19. We got 34 better before.
tylerSC is offline
post #12550 of 12876 Old 09-06-2019, 07:25 PM
tylerSC's Avatar
Liked: 245
Same problem I am having. And you are much closer. You should still get WSOC. I wonder if the new elliptical pattern is causing the problem or if it is UNC-TV interference? Because WCCB at the same basic location is much stronger and they are reduced power. WSOC is supposed to be full power, but something does not seem right. No trace of signal.
tylerSC is offline
post #12551 of 12876 Old 09-06-2019, 07:29 PM
tylerSC's Avatar
Liked: 245
WCNC seems improved to the west, but weaker to the east. I suspect they are on the temporary antenna although not confirmed. They have the STA permit for an extension on the top mount antenna. But much stronger signal in Spartanburg County with attic antenna. Nine or ten bars, but not as strong as WBTV when I checked my indoor Antop antenna. But still much improved.
tylerSC is offline
post #12552 of 12876 Old 09-06-2019, 07:31 PM
cpalmer2k's Avatar
Quoted: 394 Post(s)
Liked: 46
I'm hoping it is the UNC translator(s) and it will disappear next week. Technically parts of our county are in the Charlotte DMA and I'm in the eastern part closest to Charlotte, so it isn't like I'm on the fringes of the signal. If anything I should have benefited from the new pattern based on the contour maps. WCCB comes in stronger than before from the same location at RF18, so I'm betting interference is the culprit. Usually WSOC is stronger than WCCB at my location in the past.
post #12553 of 12876 Old 09-06-2019, 08:55 PM
tylerSC's Avatar
Liked: 245
The concern for WSOC may be Cleveland County and Shelby which is definitely part of the Charlotte DMA, and on the map it looks about the same distance as Cherokee County. So they would want to be sure their signal reaches Cleveland County. Although they will eventually replace the Crowder's Mtn. translator, it remains to be seen if the VHF signal on 12 will be as strong as the previous channel 30. I wish them good luck and hope for improvement as a concerned viewer.
tylerSC is offline
post #12554 of 12876 Old 09-06-2019, 09:13 PM
LMckin's Avatar
Quoted: 237 Post(s)
Liked: 35
I was able to get Wsoc 9.1 but on signal meter it was 1 bar tonight
But I was able get Wccb 18
LMckin is offline
post #12555 of 12876 Old 09-06-2019, 10:00 PM
tylerSC's Avatar
Liked: 245
Probably better because atmospheric conditions overnight. Should be stronger.
tylerSC is offline
post #12556 of 12876 Old 09-06-2019, 10:01 PM
wncbraves's Avatar
Quoted: 12 Post(s)
Update on WSOC at my location tonight, I was finally able to scan it in after not being able to this morning, but the signal is coming and going, it's not so much setting on the digital cliff but is having dramatic drops and rises in the signal, I first thought it was the wind but the wind is now calm and the issue persists. WCCB on the other hand is around the same signal strength but is holding steady. I was mistaken earlier when I was thinking pbs channel 17 from Linville may be causing my problems because I was thinking WSOC was now channel 18 instead of 19. Everything else seems improved so far.
wncbraves is offline
post #12557 of 12876 Old 09-06-2019, 11:46 PM
Quoted: 22 Post(s)
Liked: 1
So tonight on my WinTV scan I am getting WACH 57.1 FOX all the way from Colombia, over 75 miles away. It doesn't work on the Tivo but comes in great on the WinTV. Not sure how long that'll last.
post #12558 of 12876 Old 09-07-2019, 02:54 AM
Quoted: 132 Post(s)
Liked: 40
Originally Posted by wncbraves View Post
Same for me here in Spruce Pine as most others from the west of Charlotte have mentioned, WCNC is much improved for me with nearly a 20 percent increase in signal strength, but was disappointed to see that I no longer can receive WSOC or at least not this morning, it is trying to pull the signal in but it is just not quite strong enough. WSOC has always been one of my strongest channels and never went out in any season when it was on channel 34. I normally do not get WCCB at all from the main transmitter in the summer but it was trying to come in this morning, but that's not a big deal as I get the Smith Mountain translator very reliably ( except right now with whatever issues they're having at that site), unfortunately the WSOC translator from Smith Mountain is very hit or miss but has went from no signal before the channel move to being ably to receive it maybe 25 percent of the time. I know Charlotte is not my home market, but I hope things improve for me with the WSOC signal because I can not receive a single channel from the Asheville GSP market, but I have previously been able to receive every network from the Charlotte market as is the case with most people in this area. I'm wondering if co channel interference from Channel 17 PBS in Linville is causing the problem for me since WSOC moved to channel 18, due to the fact that I can see the PBS tower in Linville from my house and it comes in so strong I can pick it up with a paperclip stuck in the back of the tv, maybe once it moves to it's new channel things will improve.
I'm bummed too that I probably won't be able to get WSOC-Charlotte or WCCB-Charlotte in Morganton. I tried 4 different antennas- an 8 bay, 2 different corner reflectors, and a LPDA. I even tried turning my antenna sideways and nothing. The signal just isn't in the air-- so nothing to be done except build a 100 ft tower.
johnny antenna is offline
post #12559 of 12876 Old 09-07-2019, 06:17 AM
tylerSC's Avatar
Liked: 245
Finally WSOC come in this morning. Maybe they work on it, but probably atmospheric conditions, late summer, early morning. Not as strong as WCCB, but still decent 5 or 6 bars. WCCB 10 bars. We'll see how it last this afternoon. WBTV and WCNC 10 bars, WJZY 9 or 10.
tylerSC is offline
post #12560 of 12876 Old 09-07-2019, 06:54 AM
LMckin's Avatar
Quoted: 237 Post(s)
Liked: 35
I Just check WSOC This Morning as well and i was able get WSOC 9 and WAXN 64 also
and WCCB 18 Signal is Strong
bdfox18doe likes this.
LMckin is offline
post #12561 of 12876 Old 09-07-2019, 07:07 AM
Theo1080's Avatar
Quoted: 138 Post(s)
Liked: 62
WSOC / WAXN
WSOC is at full power. Everybody needs to just wait until Wednesday morning for every station in Phase 5 to cutover.
WAXN is at 15% power. It will go to full power at 3:00am Wednesday morning when WUNL goes off.
I know WSOC is getting out there. I received a call from West Jefferson, NC who can receive it and never has before since 9 analog was around.
WSOC is on channel 19. I don't know why some people are saying it is on 18. WCCB is on 18.
bdfox18doe, ybsane and eacalhoun like this.
Ted Hand, CPBE. 8VSB, DRB, AMD
Fellow - Society of Broadcast Engineers
I was there on July 23, 1996...First DTV broadcast in the US..WRAL-HD
Amateur Radio - W9SOC
Theo1080 is offline
post #12562 of 12876 Old 09-07-2019, 07:29 AM
bdfox18doe's Avatar
Quoted: 369 Post(s)
Liked: 225
Originally Posted by Theo1080 View Post
Everybody needs to just wait until Wednesday morning for every station in Phase 5 to cutover..
We at WCCB echo that sentiment. Be patient.There are a LOT of moving parts not easily evident to some of the hobbyist engineers here.
You can email us at hdtv AT wccbcharlotte DOT com We'd like to know your location and detailed reception reports now.. and.. after Wednesday.
But, due to too many projects and not enough staff, responses may be delayed. Thanks for bearing with all of this...
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #12563 of 12876 Old 09-07-2019, 08:03 AM
dscau14's Avatar
Was able to pick up wxii and wcwg
bill875 likes this.
dscau14 is offline
post #12564 of 12876 Old 09-07-2019, 10:23 AM
eacalhoun's Avatar
Quoted: 96 Post(s)
Liked: 26
EXCELLENT advice, Bob. I've the feeling many are making or seriously contemplating changes to their antenna system solely based on how things are NOW though much is in limbo until after we rescan again after 11:59pm Wednesday.
Eric Calhoun
"If it was simple, anyone could do it" - Roy Clark from Hee Haw
eacalhoun is offline
post #12565 of 12876 Old 09-07-2019, 11:04 AM
ybsane's Avatar
Quoted: 180 Post(s)
Liked: 60
Turn up and Test is suppose to be instant, your not allow to make any adjustments don't you know that..LOL
There is so much involved in getting everything working and the assumption is that you throw a switch...Testing and feed back is critical but I only see critics.
All Comments made are my own and not of my employer.
ybsane is offline
post #12566 of 12876 Old 09-07-2019, 12:07 PM
speedy22's Avatar
waxn 64. oh ok. I just got in a read the above. Wednesday it is then.
speedy22 is offline
post #12567 of 12876 Old 09-07-2019, 12:14 PM
realoldman's Avatar
Quoted: 171 Post(s)
WSOC / WAXN
Thanks for the info. What is channel 9.9 now? Will 64.9 be back?
post #12568 of 12876 Old 09-07-2019, 12:35 PM
Quoted: 22 Post(s)
Liked: 1
Looks like TiVo was on the ball, got all the changed over channels correct in the guide.
post #12569 of 12876 Old 09-07-2019, 01:07 PM
bdfox18doe's Avatar
Quoted: 369 Post(s)
Liked: 225
WCCB's 18-11 thru 18-17 via Smith Mtn W20DD-D on channel 20 is back up at half power per our STA until we migrate to CH-34 in the next few weeks.
eacalhoun and johnny antenna like this.
Bob
post #12570 of 12876 Old 09-07-2019, 02:57 PM
tylerSC's Avatar
Liked: 245
From Spartanburg County: Held on to WCCB all day, at 5 bars so good signal there. Was up to 10 last night. But lost WSOC after 10am so the weather conditions had played a role overnight. But I now see a trace of signal at 11 or 12db SNR, but just not enough to permanently decode. It drop in and out a few times. So when I am off Sunday and Monday I will try to make some adjustments in the attic with different antennas and positions and see if I can grab on to it. And wait till Wednesday and see if potential interference from UNC-TV go away.And perhaps i can switch to a better preamp that will pull in WSOC. Right now using Winegard LNA200. WCNC much improved maintaining full 10 bars, even if they use temporary antenna.
tylerSC is offline
