Philadelphia, PA - OTA - Page 142 - AVS Forum | Home Theater Discussions And Reviews
 110Likes
post #4231 of 4702 Old 12-21-2018, 05:26 AM
Ken.F's Avatar
Quoted: 2392 Post(s)
Liked: 2789
Originally Posted by frank70 View Post
I'm curious why WCAU was off-air for several hours this evening. Just came back up at 9:30PM.
They said on twitter:
"The issues were due to a power outage. In addition to CoziTV, viewers can also watch the Timeless finale and other primetime shows On Demand and on the NBC10 and Telemundo apps once the shows are posted."
And
"Broadcast programs on NBC10, Telemundo62, CoziTV and Telexitos were disrupted over the air and across several cable & satellite providers. Service has been restored and NBC10’s Timeless will re-air tomorrow from 8 p.m. to 10 p.m. ET on CoziTV."
That was posted last night so Timeless will re-air tonight (Friday) on CoziTV.
Ken.F is online now
post #4232 of 4702 Old 12-21-2018, 07:43 AM
trailblazer's Avatar
Quoted: 152 Post(s)
Liked: 56
And
I noticed that WCAU went out around 7:10 pm but I was still receiving a signal till later on in the evening when there was no signal. While I was receiving a signal I was getting scrambled signal displayed on my TV till the signal was shut off. Timeless on CoziTV will probably be 480i and look horrible like everything else on Cozi!
trailblazer is offline
post #4233 of 4702 Old 12-21-2018, 07:45 AM
Quoted: 152 Post(s)
Liked: 56
I was recording Timeless and only captured the last 31 minutes of the program.
post #4234 of 4702 Old 12-21-2018, 01:03 PM
wilbur_the_goose's Avatar
Quoted: 624 Post(s)
Liked: 372
Seriously? They don't have a backup generator?!
Oh yeah, WCAU is a Comcast station. Figures that they'd do OTA as poorly as they do cable TV.
wilbur_the_goose is offline
post #4235 of 4702 Old 12-21-2018, 05:20 PM
LastButNotLeast's Avatar
Quoted: 3057 Post(s)
Liked: 2878
Backup generator? They probably don't have a surge protector.
wilbur_the_goose likes this.
LastButNotLeast is offline
post #4236 of 4702 Old 12-21-2018, 05:33 PM
Ken.F's Avatar
Liked: 2789
I'm watching it now. It is definitely standard definition but it's 16:9 and looks pretty clean. Much better than the typical CoziTV stuff.
Ken.F is online now
post #4237 of 4702 Old 12-22-2018, 11:21 AM
modifish's Avatar
Liked: 1
Anyone else notice WTXF broadcasting on channel 25 today? I had trouble with it up here in Wind Gap PA and looked at in my tuner and while there is a weak signal on 42, I cannot lock on it. Then I found it on 25! What's up with that? Thought they were going to 31 when all the post auction moves are done....
modifish is offline
post #4238 of 4702 Old 12-22-2018, 01:15 PM
unclehonkey's Avatar
Quoted: 638 Post(s)
Liked: 185
25 is the translator in Allentown. Same tower in Bauer Rock as WNEP's translator and the frequency for PBS 39, the religious channel and WMFZ
https://www.rabbitears.info/contour....7&site=2&map=Y
unclehonkey is offline
post #4239 of 4702 Old 12-22-2018, 01:35 PM
Super Moderator
DrDon's Avatar
Quoted: 2569 Post(s)
Liked: 5031
25 is the Allentown translator for WTXF. https://www.rabbitears.info/contour....ea70277&site=2
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #4240 of 4702 Old 12-22-2018, 07:11 PM
ravi132's Avatar
Originally Posted by TranzPhat View Post
Last,
Back to 2.1 & 6.1, I am about the same distance from the 2.1 tower as you, but in a 2edge zone (not a LOS site as you). Using a dedicated low-VHF antenna in my attic, I receive both 2.1 and 6.1 very well (6.1 with a 30 dB SNR and 2.1 with a 26 dB SNR) - no amp, no filters needed.
Hi, which is a good dedicated low-VHF antenna? Would it only receive low VHF or be good for the other VHF and UHF stations?
ravi132 is offline
post #4241 of 4702 Old 12-22-2018, 08:35 PM
modifish's Avatar
Liked: 1
Ok guys, thanks. I thought they were using 38 on the Allentown translator. I see now it's 25. Allentown was weak for me in the past and I used to need to delete the translator to avoid duplicating WTXF in my channel lineup. Thanks for the info!
modifish is offline
post #4242 of 4702 Old 12-23-2018, 02:56 PM
frank70's Avatar
Quoted: 226 Post(s)
Liked: 185
Well, depends on where you are located, but a simple folded dipole made out of twinlead (only really suitable for an indoor/attic installation) and oriented at a right angle to your direction to Roxborough might do the trick. For channel 6, it should be 66" long (tapped at the center), and for channel 2, 100" long. You might try a 100" for both since 2 has the lower power. I'm using a 66" and you don't even want to know what crazy getup I'm using for 2
This would only be good for low VHF and you'd need a VHF/UHF combiner to mix it with your main (high VHF/UHF) antenna. Obviously, you can buy commercial low VHF yagi-style antennas or single-channel antennas too.
frank70 is offline
post #4243 of 4702 Old 12-23-2018, 06:43 PM
Liked: 3
I use a custom folded dipole using 1/2" copper pipe with a reflector, located in my attic. The antenna is tuned to around ch 3.8 to give me a solution that would have an optimum SWR at both frequencies It works very well.
I used the info from Holl_ands, at -> https://www.avsforum.com/forum/25-hd...els-2-6-a.html. And then used the calculator from John Drew (VK5DJ) to build the antenna.
TranzPhat is online now
post #4244 of 4702 Old 01-17-2019, 12:53 PM
blueeyedbanditt's Avatar
Wpvi6
Have there been any solutions for 6ABC specifically for indoor antennas?
It seems like some of the "Leaf-style" antennas cover all the way down to 40 hz or so, has anyone had success with those for picking up 6ABC?
Any other relatively easy solutions?
blueeyedbanditt is offline
post #4245 of 4702 Old 01-17-2019, 01:21 PM
Ratman's Avatar
Quoted: 2888 Post(s)
Liked: 2967
I use one similar to this in my attic. Get 2, 6 and 12.
https://www.ebay.com/i/202389017707?chn=ps
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #4246 of 4702 Old 01-17-2019, 01:38 PM
Thanks - are you connecting to an existing antenna in the attic and how? I was looking for a solution to connect to a Leaf-style near TV, is there like a coupler that will merge the two signals?
post #4247 of 4702 Old 01-17-2019, 01:47 PM
frank70's Avatar
Quoted: 226 Post(s)
Liked: 185
Originally Posted by blueeyedbanditt View Post
...is there like a coupler that will merge the two signals?
There are many combiners offered on the internet. Here is one like the one I use: https://store.antennasdirect.com/antenna-combiner.html
Also note that 12 (VHF) will be moving to 13 (VHF) during the repack (spring 2020). And moving down to VHF, WFMZ 69, currently on 45 (UHF) out of Roxborough will be moving to 7 (VHF) during the repack.
frank70 is offline
post #4248 of 4702 Old 01-17-2019, 01:58 PM
Ratman's Avatar
Liked: 2967
I just connected the rabbit ears to my Channel Master 4228 antenna. Just connected to existing connectors. No extra gadgets.
I worked for me, may not for you. IMO, inexpensive test if you have stuff in your basement in a box.
post #4249 of 4702 Old 01-17-2019, 05:20 PM
Brian in CT's Avatar
Quoted: 172 Post(s)
Liked: 36
Also note that 12 (VHF) will be moving to 13 (UHF) during the repack (spring 2020).
When WHYY switches to RF channel 13 it will still be on the VHF band. I'm sure that was just a typo.
Brian in CT is offline
post #4250 of 4702 Old 01-17-2019, 05:59 PM
frank70's Avatar
Quoted: 226 Post(s)
Liked: 185
That was indeed my error - corrected in original post.
frank70 is offline
post #4251 of 4702 Old 01-18-2019, 01:09 PM
Liked: 3
Speaking of AntennasDirect, here is a VHF antenna with a built-in combiner: https://store.antennasdirect.com/VHF-Antenna-Kit.html
I have used this to receive 6.x, 9.x and 12.x - works very well - it is not very good with 2.x though.
post #4252 of 4702 Old 02-25-2019, 01:57 PM
MattFromPhilly's Avatar
Quoted: 16 Post(s)
Liked: 26
I actually added an FM antenna from an old stereo to my setup and channel 6 is usually pretty good. If you have one laying around it's worth a try. For some reason it seems to work better hung vertically rather than horizontally.
MattFromPhilly is offline
post #4253 of 4702 Old 02-25-2019, 03:29 PM
frank70's Avatar
Quoted: 226 Post(s)
Liked: 185
Which just shows to go you that receiving antenna technology, in spite of all the documented scientific theory, is mostly black art.
frank70 is offline
post #4254 of 4702 Old 02-26-2019, 07:56 PM
KEVINL71's Avatar
Quoted: 170 Post(s)
Is the FM antenna the kind with the two rods or as a dipole shaped kinda like a "T"? I used to use a dipole on an AM/FM/TV cassette radio back in 1987-88. It was so-so on the TV side. The VHF did seem a little better. (Hartford/New Haven had channel 3 in Hartford and channel 8 in New Haven for analog TV.)
KEVINL71 is offline
post #4255 of 4702 Old 02-27-2019, 08:20 AM
Quoted: 16 Post(s)
Liked: 26
It's a T-shaped dipole wire. Like this one:
https://www.staples.com/Axis-FM-Dipo...EaAiTEEALw_wcB
I have a homemade UHF antenna so just attached the two leads to the screws where the antennae connects to the impedance matching balun.
post #4256 of 4702 Old 03-08-2019, 08:21 AM
edfiero's Avatar
WPHL 17.2 Antenna TV Picture QUALITY
What is up with picture quality on 17.2? I got that its not HD, but still, it looks horrible. I love some of the old shows from the 80's like Growing Pains, but the quality so poor that it is just unwatchable OTA. (Not sure if its any different on cable or not)
I'm not referring to signal STRENGTH, but quality. 17.1 looks fine. It's like they compress the heck out of 17.2 and its all pixelated and/or fuzzy.
I tried e-mailing WPHL, but I got no response.
Do you think they will ever reduce the compression or whatever on 17.2 to improve the picture quality?
edfiero is offline
post #4257 of 4702 Old 03-08-2019, 08:32 AM
Trip in VA's Avatar
Quoted: 1899 Post(s)
Liked: 890
The channel 17 signal is carrying 2 HD streams and 5 SD streams. Something has to give along the way; priority goes to 17-1 and 65-1 in HD. The SD channels get squeezed.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #4258 of 4702 Old 03-08-2019, 09:40 AM
Quoted: 152 Post(s)
Liked: 56
Even the HD channels on 17-1 and 65-1 look like crap. The picture is soft and dull. The sub-channels are totally unwatchable. Why bother with broadcasting these channels when they are unwatchable!
post #4259 of 4702 Old 03-08-2019, 09:47 AM
edfiero's Avatar
Exactly my point! Sounds like they need to drop 1 or more of those side channels to free up space.
edfiero is offline
post #4260 of 4702 Old 03-08-2019, 03:23 PM
Liked: 1
My understanding is that RF9 in Allentown is constructing a new transmitter at 120kw as opposed to their current 80kw signal. They carry WFMZ, WPPT, WLVT, and WBPH. Unfortunately their signal does not reach into South Jersey as it did prior to the repack when these stations were on individual UHF channels.
Can anyone in the Delaware valley get RF9 currently and can anyone confirm when the more powerful signal is supposed to be active?
tavistock is online now
