Philadelphia, PA - OTA - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 94Likes
post #121 of 4589 Old 04-22-2006, 07:29 PM
braveranger's Avatar
Originally Posted by georget View Post
Is anyone getting channel 10.1 or 10.2 tonight?
Not for me, it's been out the whole day. is the weather a factor?
braveranger is offline
post #122 of 4589 Old 04-23-2006, 12:26 AM
smgill75's Avatar
I have a 10.1 and 10.2 problem too. I don't think it is a weather problem. The odd thing is, I show a signal strength of 92 on channel 67 using my HD-Tivo, but no station identifier shows up.
Steve
smgill75 is offline
post #123 of 4589 Old 04-23-2006, 01:39 AM - Thread Starter
newsman's Avatar
It seems that the problem may be at the transmitter end of things, since both 10.1 and 10.2 are down. If that's the case, it may be till Monday when things get fixed.
newsman is offline
post #124 of 4589 Old 04-23-2006, 05:35 AM
newsposter's Avatar
it's definitely on their end..good signal but no pic here and all other stations are fine so it's not my antenna
57 inch Hitachi 57F710S
Tivo Premiere w/DB8 antenna which gets in VHF 6
Sony T60 2-160 drives unsubbed
Panasonic E80 Dvd recorder
newsposter is offline
post #125 of 4589 Old 04-23-2006, 08:57 AM
austen0316's Avatar
the hd feed of nbc 10 is down, i guess no nhl in hd for us today
austen0316 is offline
post #126 of 4589 Old 04-23-2006, 02:26 PM - Thread Starter
newsman's Avatar
It will get addressed on Monday, from what I hear.
newsman is offline
post #127 of 4589 Old 04-23-2006, 04:38 PM
rdsandy's Avatar
I called ch 10 and spoke with Tom an engineer there. He said the are down and waiting for a part that hopefully will arrive tomorrow.
rdsandy is offline
post #128 of 4589 Old 04-24-2006, 05:46 AM
newsposter's Avatar
I wonder if it was their analog feed if it would have been "today" or if they would have just not cared everyone is watching I can't imagine not having a spare set of parts on hand if something is that crucial. Oh wait, sorry, i'm an idealist...nix that.
post #129 of 4589 Old 04-24-2006, 02:29 PM - Thread Starter
newsman's Avatar
I spoke to someone there today. Their DT signal may be up by tonight.
newsman is offline
post #130 of 4589 Old 04-24-2006, 06:14 PM
eatenhogg's Avatar
Thanks you guys.
I thought it was just me. Turned on SNL(don't ask why) on Sat. and got a blank screen. My meter keeps jumping on 10.1 and 10.2. Thought it might be my tuner at first but all other channels are fine. I'm glad I finally found a current board here and not one dated 2003.
eatenhogg is offline
post #131 of 4589 Old 04-24-2006, 06:34 PM
eatenhogg's Avatar
WOW, I guess FM is still a valid science. No sooner had I posted and re-scanned my channels did WCAU re-appear. Now if I could block the glare form Howie Mandel's bald head, I would be fine.
post #132 of 4589 Old 04-25-2006, 06:08 AM
newsposter's Avatar
i see it was on at 8 per your post
just saw it this AM..would love to know what part they needed
post #133 of 4589 Old 04-30-2006, 09:15 PM
eatenhogg's Avatar
Not sure what part they needed but since they obviously didn't have one on hand, it most likely was an expensive one. Damn those accountants
post #134 of 4589 Old 05-01-2006, 06:47 AM
newsposter's Avatar
i hope the advertisers got refunds on the ads i didn't skip thru on my tivo
post #135 of 4589 Old 05-01-2006, 06:43 PM
moseymosey's Avatar
Just moved into a house near Trenton with a gigantic antenna on the roof (three-story house -- don't know how old the antenna is, but it looks pretty old). Hooking up a regular TV to it, and I get pretty good reception on the usual Philadelphia stations (3,6,10,12) (the antenna is pointed right at Philly, AFAICT).
Anyway, I then hooked up my Samsung SIR-T451 and get... nothing. It shows 'No signal' all across the board. I don't have another antenna to use at the moment, but I am certain the Samsung is fully operational.
Does this make any sense at all? What may be the problem here?
moseymosey is offline
post #136 of 4589 Old 05-01-2006, 08:35 PM
BrentHD's Avatar
I think you need a good UHF antenna. If that doesn't work on all stations you'll need to add a preamp.
"Sweet Cracker Sandwich!"--Satchel Pooch
BrentHD is offline
post #137 of 4589 Old 05-02-2006, 06:17 AM
moseymosey's Avatar
Yes, that sounds like the next step. Would you have any particular antenna to recommend? I'm about 25mi east-northeast of Phila and 54mi southwest of NYC.
Thanks again.
post #138 of 4589 Old 05-02-2006, 09:08 AM
BrentHD's Avatar
I have had a lot of success with the Winegard PR-8800. You would need a rotator to try for both cities. Or, you could use a smaller PR-4400 toward Philly and an 8800 toward NYC. You may have to add a UHF pre-amp if you still find weak signal strength. I got my antenna and pre-amp from Stark Electronic. They were cheap and fast. My antenna and pre-amp are in the attic, and I am 40 miles from the transmitter, but I still get 10 DTV stations.
BrentHD is offline
post #139 of 4589 Old 05-02-2006, 11:41 AM
lman12's Avatar
I hope someone can provide the needed information on this matter. I live in Somerset, Somerset County, New Jersey. I want to receive the OTA stations from NYC and Philadelphia. I need advice, opinions, experience, etc. on the best outdoor antenna to get the best reception. I understand the hardest OTA stations to receive from Philly are WHYY and FOX 29.
I am considering the CM 4228 or DB8 antennas. Am I on the right track or are there better antennas to use?
Thanks for the help!
lman12
lman12 is offline
post #140 of 4589 Old 05-02-2006, 12:00 PM
newsposter's Avatar
I can tell you that the db8 is better than the winegard unit that is similar in design(dont know model number sorry). I already had bought a db8 and paid an installer to put it up. It wasn't working that well but then when he put up his winegard, it outperformed that measurably.
I had a very difficult install as i was shooting thru a 'tunnel' between my neighbors house and some unknown object.
So I can say the DB8 works great for me except whyy (only at night). But if you want to save money, many people have had luck with the 4228.
also you have to keep in mind (well, not really), that 6 is going back to 6 in 2009 and i dont think the db8 will pick that up. Not sure what others will though.
post #141 of 4589 Old 05-02-2006, 05:27 PM - Thread Starter
newsman's Avatar
And channel 10 wants to go back to channel 10. We'll see if the FCC allows that.
newsman is offline
post #142 of 4589 Old 05-02-2006, 07:46 PM
BrentHD's Avatar
I was thinking that I may have to add a VHF antenna to my UHF antenna, but I can get analog 6 and 10 fairly well with my current setup. I am hoping that I may be able to get away with just the UHF antenna after all. Check back on this forum in 2009.
BrentHD is offline
post #143 of 4589 Old 05-05-2006, 07:53 PM
newsposter's Avatar
you mean even after 34 or 35 or whatever agreed to vacate the channel? ( I linked on here somewhere about it)
post #144 of 4589 Old 05-06-2006, 12:14 PM
whsbuss's Avatar
I see NBC10 digital is once again off the air. Guess I'll have to watch the NY affiliate on DTV to get the HD Devils vs. Hurricanes.
whsbuss is offline
post #145 of 4589 Old 05-06-2006, 01:44 PM
newsposter's Avatar
it's on now...hockey is on..and a fight
post #146 of 4589 Old 05-07-2006, 07:56 PM - Thread Starter
newsman's Avatar
Yes. We'll see what happens over time.
newsman is offline
post #147 of 4589 Old 05-10-2006, 05:05 PM
whsbuss's Avatar
Can someone confirm a drop in signal in NBC10's digital signal? I went up to my attic today to try and re-caputre their signal with no success. My HR10-250 shows 0 signal on ch.67 yet all others (KYW, WPVI, WHYY, WPHL, WPSG) all have strong signals.
whsbuss is offline
post #148 of 4589 Old 05-11-2006, 05:37 AM
HarleyJoel's Avatar
I'm getting a 70 where I usually get close to 100 so it does look like they may be on reduced power this morning.
HarleyJoel is offline
post #149 of 4589 Old 05-11-2006, 07:16 AM
whsbuss's Avatar
Aah, that makes me feel better. I usually get 78-82 signal for their digital transmission. I hope when 2009 comes around the locals get their act together.
whsbuss is offline
post #150 of 4589 Old 05-11-2006, 08:32 AM
newsposter's Avatar
someone a while ago ( i think this thread) said that 35 was down. I now have a good 80s signal so I guess it's back
