Washington, DC / Baltimore, MD - HDTV - Page 510 - AVS Forum | Home Theater Discussions And Reviews
 320Likes
post #15271 of 15340 Old 05-19-2020, 11:21 PM
joblo's Avatar
Quoted: 146 Post(s)
Liked: 170
Originally Posted by scpivo21 View Post
I'd be surprised if WHTJ is interfering with WBFF given the Rabbit Ears signal results below
Agree.
Nothing much you can do about it if that's the case, correct?
INcorrect. IF that were your problem, the interfering signal is nearly 180 degrees off-axis, so there are definitely things you could do, but I agree that's UNlikely to be your issue, so let's not go there.
My (very uneducated) guess is that WBFF isn't operating at full power given the issues the area has faced with the repack
I doubt it. My rf25 and rf26 look just as they should on my TiVos, given that 26 is approximately 2.5 dB weaker.
This is my rabbitears report, which you can see is very similar to yours:
https://www.rabbitears.info/searchma...study_id=92405
How is your reception on WNUV, what antenna are you using, and where/how is it installed?
Originally Posted by KyL416 View Post
WBFF shouldn't be affected by the ongoing repack related work for WMAR, WBAL and WJZ, it's on a seperate tower.
Agree.
joblo is online now
post #15272 of 15340 Old 05-20-2020, 06:54 AM
Quoted: 17 Post(s)
Liked: 7
Is the WBFF reception worse during windy weather as we've had this week? If so, then probably multipath interference from trees blowing around.
I'm only 12 miles from the transmitter (compared to OP's 50) but WBFF has oddly seemed more prone to multipath at my house than WNUV even before the repack change. As I type on this windy morning I see WBFF's signal fluctuating between 80 and 100% while WNUV is a steady 100%.
Re the low power theory, in the Live Bandscan section of rabbitears.info WBFF looks marginally stronger from the Leesburg monitor and slightly worse from Alexandria since the mid-March repack. I see no weakness 12 miles out.
fri1038 is offline
post #15273 of 15340 Old 05-20-2020, 02:50 PM
keeper's Avatar
Quoted: 658 Post(s)
Liked: 277
Have they started work on these towers?
keeper is online now
post #15274 of 15340 Old 05-20-2020, 03:01 PM
KyL416's Avatar
Quoted: 320 Post(s)
Liked: 199
According to WJZ's progress report that they filed last week, they didn't begin tower work yet.
WBAL's progress report from May 4th says they'll transition to an auxiliary antenna at reduced power and won't complete their final facility until after July when their contractor can schedule a helicopter crew:
https://enterpriseefiling.fcc.gov/da...71e00e0ed9025f
KyL416 is offline
post #15275 of 15340 Old 05-20-2020, 04:27 PM
keeper's Avatar
Quoted: 658 Post(s)
Liked: 277
Thanks for the info.
post #15276 of 15340 Old 05-20-2020, 08:57 PM
Liked: 0
Thanks for the feedback. My reception on WNUV is non-existent, similar to WBFF (from what I remember, I was picking WNUV up a few months ago, but nothing recently). I have a ClearStream 2Max, which is set up outside next to our deck door. It's about 13 feet off the ground and faces Northeast. I promised the Mrs. I won't put the antenna on the roof, so that's not an option.
scpivo21 is offline
post #15277 of 15340 Old 05-21-2020, 01:29 PM
Digital Rules's Avatar
Quoted: 118 Post(s)
Liked: 26
Yep, no 45 or 54 here either. They are both a tad weaker than channel 2 which is a bit too weak to decode as well. 54 used to be good here when on RF 40. OTOH MPT 22 is decode-able since the re-pack, even with the antenna pointed towards Baltimore.
Digital Rules is offline
post #15278 of 15340 Old 05-21-2020, 03:29 PM
Liked: 0
I have a Terk MTVGLS that is picking up Baltimore stations and WMPT in Annapolis, but not DC ones. I might be able to setup a small outdoor antenna in my balcony. What antenna do you recommend I try?
My Rabbit Ears study ID is 93103.
Casey
Casey Hartman is offline
post #15279 of 15340 Old 05-22-2020, 05:05 AM
Quoted: 17 Post(s)
Liked: 7
Do you get *any* DC stations? Is there anything especially challenging about your location - e.g., basement apartment? That is an amplified antenna. Can you try without the amplifier? You could be overloading your tv tuner, being so close to DC. A simple rabbit ears and loop, like this, should get you the DC stations, in theory.
https://www.walmart.com/ip/GE-Easy-A...3694/194842437
Casey
fri1038 is offline
post #15280 of 15340 Old 05-22-2020, 12:42 PM
Liked: 0
I am in a 15th floor unit and the compass app on my phone claims it is has an elevation of 140 feet. The unit faces away from the DC broadcast towers. I was mistaken, the Terk MTVGLS is able to pick up channels 50 and 66 with the amplifier plugged in. Today I am getting 14 as well. I have scanned for channels with it being unplugged and it was not able to pick up 4, 5, 7, 9 , 20, or 32. I might get some RG6 coax to be able to try the antenna on my balcony.
[quote=fri1038;59689202]Do you get *any* DC stations? Is there anything especially challenging about your location - e.g., basement apartment? That is an amplified antenna. Can you try without the amplifier? You could be overloading your tv tuner, being so close to DC. A simple rabbit ears and loop, like this, should get you the DC stations, in theory.
post #15281 of 15340 Old 05-23-2020, 07:24 PM
Liked: 0
I'm having the exact same experience as you. It used to be that I could pick up WBFF-45 without any problem, and MPT-22 was hit or miss. Now, I can't pick up 45 at all, and I pick up MPT-22 more often than WHUT-32.
scpivo21 is offline
post #15282 of 15340 Old 05-24-2020, 09:10 AM
Quoted: 118 Post(s)
Liked: 26
Too bad the re-pack has reduced power to areas that used to get a decent signal. Not sure why the FCC is so overly protective of TV signals and then seem to not protect the FM band with HD & LPFM stations?
Look at the coverage map for WWEG below. WJFK's HD signal wipes out a good chunk of the southeastern half of WWEG's listening area. I would think WWEG would not be too happy about this? How does this happen?
https://radio-locator.com/cgi-bin/pa...WEG&service=FM
post #15283 of 15340 Old 05-24-2020, 04:28 PM
Trip in VA's Avatar
Quoted: 1899 Post(s)
Liked: 887
Not quite clear what this means. Each station was replicated to a power that matched its pre-repack contour on the new channel. For WBFF, that 655 kW on channel 46 becamne 440 kW on channel 26. For some reason, they opted to build at only 420 kW, which is about 0.2 dB less--I can't imagine anyone would notice. For WNUV, the 845 kW on channel 40 became 620 kW on channel 25, but WNUV voluntarily increased power to 750 kW when they built it.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #15284 of 15340 Old 05-25-2020, 07:13 PM
Quoted: 118 Post(s)
Liked: 26
- Trip
Thanks Trip, I wasn't aware they were trying to replicate the previous coverage areas. For whatever reason I'm not getting any Baltimore channels now. There can be a lot of other factors that come into play as well. I am already on the edge of Baltimore's coverage anyway and the leaves on the trees aren't helping either.
post #15285 of 15340 Old 05-27-2020, 08:03 AM
Liked: 0
[quote=Casey Hartman;59691680]I am in a 15th floor unit and the compass app on my phone claims it is has an elevation of 140 feet. The unit faces away from the DC broadcast towers. I was mistaken, the Terk MTVGLS is able to pick up channels 50 and 66 with the amplifier plugged in. Today I am getting 14 as well. I have scanned for channels with it being unplugged and it was not able to pick up 4, 5, 7, 9 , 20, or 32. I might get some RG6 coax to be able to try the antenna on my balcony.
A neighbor in a different building bought a Clearstream 2Max antenna and picks up 55 channels. I bought one since the dipoles and 2 round UHF portions could be an improvement over the flat amplified Terk antenna. Surprisingly the 2Max performed better as it was placed further away from the balcony. I have the antenna in the HVAC closet, where the in-wall coax cables originates, facing around 330 degrees and it is receiving 50 channels. The only major network I missing NBC. WRC NBC 4 broadcasts in the UHF band so I am surprised it doesn't come in and WBAL 11 broadcasts on VHF that doesn't reach Alexandria/Fairfax County. I'll have to share my findings with my Montebello Condo neighbors.
post #15286 of 15340 Old 05-27-2020, 09:25 AM
Trip in VA's Avatar
Liked: 887
Ah! I could just about throw a rock and hit you. This is a live list of what I receive off my roof antenna, which needs work:
https://m.rabbitears.info/index.php?...1062ADBE&tno=1
If you're on the wrong side of the building, you might be out of luck.
- Trip
TheKrell likes this.
N4MJC
RabbitEars
post #15287 of 15340 Old 05-27-2020, 01:35 PM
Liked: 0
- Trip
Howdy neighbor! I moved the antenna to the walk-in closet by the front door, which is slightly further north east portion of my unit. Now I can pick up NBC 4 and a few other stations. I may trim the coax cable I ran from the antenna to the in-wall coax origination since the big box retailer substituted a 100 ft roll for a 50 ft one. It looks a mess and the excess cable may allow signal degradation. My TV's signal meter shows some of the channels in the 40% range, lower than it the antenna connected directly to it.
post #15288 of 15340 Old 06-01-2020, 04:05 PM
KyL416's Avatar
Quoted: 320 Post(s)
Liked: 199
WBAL, WMAR and WJZ posted their rescan dates, 7/2 at 9am:
https://www.wbaltv.com/article/wbal-tv-rescan/32582927
https://baltimore.cbslocal.com/2020/...els-on-july-2/
https://www.wmar2news.com/rescan
Ion's outdated rescan website still says 5/1 for WWPX, but since they have to coordinate with all those other swaps stretching from DC to NYC, they'll be doing it at the same time.
KyL416 is offline
post #15289 of 15340 Old 06-02-2020, 12:31 AM
keeper's Avatar
Quoted: 658 Post(s)
Liked: 277
WBAL, WMAR and WBZ posted their rescan dates, 7/2 at 9am:
Thanks for the update. I hope these changes improve their signals.
post #15290 of 15340 Old 06-02-2020, 04:43 AM
Quoted: 17 Post(s)
Liked: 7
WBAL and WJZ reception may get worse before they get better as it sounds like they will need to run off backup hardware initially, as per baltomedia.net on May 28, due to lack of helicopter crews and needing to use cranes for the replacement antenna work.
fri1038 is offline
post #15291 of 15340 Old 06-02-2020, 10:55 AM
StevenJB's Avatar
Quoted: 23 Post(s)
WBAL, WMAR and WBZ posted their rescan dates, 7/2 at 9am.
Thanks for this useful information but actually WBZ was part of Phase 4 and not Phase 10. It's also located in Boston, MA. Just having a little fun with you!
StevenJB is offline
post #15292 of 15340 Old 06-02-2020, 10:58 AM
KyL416's Avatar
Quoted: 320 Post(s)
Liked: 199
Yeah, I meant WJZ, lol
KyL416 is offline
post #15293 of 15340 Old 06-04-2020, 02:58 PM
mkfs's Avatar
Quoted: 35 Post(s)
Titan-TV:
Even since Zap2It updegraded itself, I've been using TitanTV for schedules.
But starting several months ago, it's been wrong re: WETA's programming. Mostly on WETA-UK but sometimes 26.1/3 is also wrong.
Just compare WETA's schedule page with TTV.
So I wrote to TTV and finally got an answer, in April!
They told me they were asking their supplier but that was the last I heard.
Where do they buy their schedule data, the Dollar Store?
qonder likes this.
mkfs is offline
post #15294 of 15340 Old 06-04-2020, 03:08 PM
ericlhyman's Avatar
Quoted: 22 Post(s)
Question
Is there any information on when the DC area stations will broadcast in ATSC 3.0 since some new tv models are including these tuners now?
ericlhyman
ericlhyman is offline
post #15295 of 15340 Old 06-04-2020, 03:18 PM
KyL416's Avatar
Quoted: 320 Post(s)
Liked: 199
TitanTV uses FYI Television for their data, which is perhaps the worst of the 3 major guide data providers.
KyL416 is offline
post #15296 of 15340 Old 06-05-2020, 08:33 AM
mkfs's Avatar
Quoted: 35 Post(s)
So I was right! Too bad it's got the most rational and readable UI.
mkfs is offline
post #15297 of 15340 Old 06-05-2020, 09:13 AM
mkfs's Avatar
Quoted: 35 Post(s)
How will this work? Will the ATSC 3.0 be in the same RF space as the existing? Or will there be another musical chairs game of temporary sites, etc?
And when will our existing sets and tuners be as useful as CECB's?
mkfs is offline
post #15298 of 15340 Old 06-05-2020, 11:16 AM
Quoted: 17 Post(s)
Liked: 7
From what I've read so far, two or more broadcasters will work together. One or more existing transmitter will carry all or most channels from all in ATSC 1.0. Another existing transmitter will carry them in ATSC 3.0.
EDIT: This is how Las Vegas is doing it now. Four stations working together. Three transmitters in ATSC 1.0, one in 3.0.
https://www.avsforum.com/forum/45-lo...l#post59708644
There is a general ATSC 3.0 thread to browse through for more info. Might be some DC rumors hiding in there.
https://www.avsforum.com/forum/25-hd...tsc-3-0-a.html
fri1038 is offline
post #15299 of 15340 Old 06-08-2020, 02:07 PM
joblo's Avatar
Quoted: 146 Post(s)
Liked: 170
So far, the main movers and shakers for 3.0 are Sinclair, the Pearl Consortium, of which Sinclair is a member, Univision, and Entravision, which operates a number of Univision stations under JSAs. No ABC/CBS/FOX/NBC O&Os, ION, or PBS stations have participated outside of the Phoenix model market. All the 3.0 transmissions so far are on UHF.
Full power virtual channels around here are as follows, more or less in order of likely participation based on the record so far:
Sinclair: DC 7, Baltimore 24, 45, 54
Other Pearl: DC 9, 50, Baltimore 2, 11, Hagerstown 25
Univision/Entravision: DC 14, 68
PBS: DC 26, 32, Maryland MPT
Major network O&Os: DC 4, 5, 20, 44, Baltimore 13
ION: DC 66, Martinsburg 60
Complete speculation based on the record so far:
Baltimore will go before DC because of Sinclair's presence there, flip Sinclair's RF 25 or 26 to 3.0, and divvy up its 1.0 contents among the other Sinclair and Pearl RFs.
In DC, Sinclair, Pearl, and Univision/Entravision will get together and flip RF 15.
When this will happen, if at all, I have no idea, except that covid will probably make it later than it otherwise would have been.
If/when these changes occur, MVPD subscribers will be unaffected, but OTA viewers will need to rescan. Basically, it will be like another repack, meaning more compression and PQ degradation for most viewers.
3.0 will be invisible except to OTA viewers with 3.0-cappable receivers, which are still few and far between.
joblo is online now
post #15300 of 15340 Old 06-08-2020, 03:46 PM
Trip in VA's Avatar
Liked: 887
Agreed on Baltimore.
In DC, the smart thing to do would be to make WHUT the host station. 32-1 could go on WJLA's transmitter, while 32-2 could probably fit on WUSA's. That assumes WHUT decides to get involved, of course.
- Trip
N4MJC
RabbitEars
