Chicago, IL - OTA - Page 433 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
post #12961 of 12988 Old 07-30-2019, 10:52 AM
Liked: 0
WEDE-CD Channel 34.2
I live in Park Ridge with a large Winegard antenna up 30 feet with a rotor plus a pre-amplifier and I have serious difficulty receiving channel 34. Does any one have any information about this station regarding their broadcast pattern from Willis Tower going straight south? They are licensed to Arlington Heights.
pnchaple is offline
post #12962 of 12988 Old 07-30-2019, 11:47 AM
snowdog 88's Avatar
Quoted: 1691 Post(s)
Liked: 238
WEDE-CD coverage map (RF 34)
WEDE-CD pattern (RF 34)
Very odd pattern here. Not even a full kW being sent in your direction. Make sure you have your antenna aimed precisely at their transmitter. Also make sure all your coaxial cable is RG6 and not the cheap RG59, double check all your connections and if possible, remove any splitters between your TV and antenna as all of these may weaken the signal.
Newer is not always better.
snowdog 88 is online now
post #12963 of 12988 Old 07-30-2019, 02:29 PM
Liked: 0
Thanks for the suggestions. I appreciate your quick response.
pnchaple is offline
post #12964 of 12988 Old 08-13-2019, 10:32 AM
dishrich's Avatar
Quoted: 186 Post(s)
Liked: 90
This is a sorta related OTA post..but DirecTV pulled down WYIN's .2 subchannel from their sat delivered locals...but upgraded WYIN's main ch from SD to HD
dishrich is offline
post #12965 of 12988 Old 08-14-2019, 10:12 AM
malapane's Avatar
Hello. Below is my TVFool link.
http://www.tvfool.com/?option=com_wr...903843cc02b96e
I ditched cable and DirecTV almost 2 years ago. This Bears season I need to get serious about an antenna. Going out for every game last year did not go well.
Can anyone recommend a first outdoor antenna for me to try at my location about 25 feet above the ground? I guess CBS will be the hardest for me to get in my location.
I was thinking GE 29884 maybe?
I really appreciate the tips and recommendations.
malapane is offline
post #12966 of 12988 Old 08-14-2019, 09:18 PM - Thread Starter
sebenste's Avatar
Quoted: 56 Post(s)
Liked: 37
Hello Malapane.
I would very highly recommend the ChannelMaster 4228 or the Xtreme Signal HDB8X. Both are 8-bay "bowtie" antennas that will do well from Chesterton, and will let you pick up channels 7-51.
If you want to pick up channel 6, and thus Me-TV radio, get the CM 3020. https://www.solidsignal.com/pview.asp?p=cm-3020 Any of these three should serve you well.
Gilbert
Gilbert
sebenste is offline
post #12967 of 12988 Old 08-15-2019, 11:05 AM
malapane's Avatar
Originally Posted by sebenste View Post
Hello Malapane.
Gilbert
Thank you Gilbert!
Placing an order today. Are there any tips to wiring to my TV, or just RG6 straight from the combiner on the antenna to the back of my television?
I really appreciate the help!
malapane is offline
post #12968 of 12988 Old 08-15-2019, 03:46 PM - Thread Starter
sebenste's Avatar
Quoted: 56 Post(s)
Liked: 37
Thank you Gilbert!
For now, I would say RG-6 from the combiner to TV. If reception is not as strong as you want it, a preamp can be added later. But with that antenna and one TV, that should be good.
Gilbert
sebenste is offline
post #12969 of 12988 Old 08-16-2019, 06:46 PM
zippyfrog's Avatar
Quoted: 28 Post(s)
Has a date been announced for when we will need to rescan our TV's to get the OTA channels that are changing frequencies in Phase 6? If not, do we know when that date will be announced?
zippyfrog is offline
post #12970 of 12988 Old 08-16-2019, 07:50 PM - Thread Starter
sebenste's Avatar
Quoted: 56 Post(s)
Liked: 37
No, and no...but since it will be fairly soon, I would expect engineers are coordinating a date.
Gilbert
sebenste is offline
post #12971 of 12988 Old 08-18-2019, 10:11 AM
ncsercs's Avatar
Quoted: 156 Post(s)
Liked: 92
These are the dates AFAIK.....
September 7, 2019 - October 18, 2019
Nick
Every day I beat my own previous record for the number of consecutive
days I've stayed alive. - George Carlin - 1996
ncsercs is offline
post #12972 of 12988 Old 08-18-2019, 02:51 PM
MrCoolDu4's Avatar
Interface between antenna and TV
I just hooked up a CM Omni+ and although I was a little skeptical at first it does a great job. My question is what are the best options for plugging the antenna into that have a channel guide with DVR? I'm using a HDHomerun Connect Quatro but it's a little bit clunky and if there is a better option I'd like to know while I can still return the HD to BB. Thanks
MrCoolDu4 is offline
post #12973 of 12988 Old 08-19-2019, 07:23 AM
andyross63's Avatar
Quoted: 322 Post(s)
Liked: 119
WLS AV Sync issues?
I don't have an antenna. I get my feed via Comcast. I have noticed that during WLS's local news, and ABC News, that the AV sync seems to be way off. When WLS goes to a remote report, the AV sync is even worse. But, watching "Good Morning America" seems fine. If it was a Comcast issue, I'd think it would happen all the time.
andyross63 is offline
post #12974 of 12988 Old 08-23-2019, 05:45 AM
Liked: 0
WCIU reception issues
I am in New Lenox, was getting good reception using antenna in the attic until last week.
Now can’t get any of the WCIU stations 26.1 -26.6 . Added an amplifier but still no go.
Anyone else having any issues ?
Shemp0203 is offline
post #12975 of 12988 Old 08-24-2019, 11:13 PM
dave73's Avatar
Quoted: 23 Post(s)
Sebenste has given you a couple good choices for UHF. From my own experience, any 8 bay antenna, as well as my old Winegard HD-1080 2 bay antenna, doesn't work as well with VHF. If you want a guarantee that you can get CBS out of Chicago, here's a VHF only antenna that can help. https://www.amazon.com/30-2476-Fring...%2C298&sr=8-31
When I went with separate VHF & UHF antennas, and this was 2010, I got the Antennacraft CS600 antenna for channels 2-13. I partially got it, because I wanted to get WOCK-CD on RF 4, which at the time had America One (now called Yu Too, not sure about spelling). WOCK-CD dropped that network. For UHF, I originally got the Winegard HD9032. It worked for the full market stations, but it had too narrow of a beam, that it didn't pick up the LPTV stations from Chicago. I then got a refurbished Americas Direct DB8, and it picked up the LPTV stations I wanted, including MeTV on 23.1 (even though it's simulcasted on WCIU 26.3) and the HD version of The U Too (will be just the U soon) on 48.1. As for the Winegard HD-1080 antenna I have, it's used solely for 56.1.
Since you live in an area that can also get South Bend stations, if you line up your UHF antenna properly, you might be able to pick up the South Bend stations from the back side, and can get CBS/Fox from WSBT-TV. I don't know what sports WSBT-TV carries, but you'll have additional choices from that station too. Lastly, this is a long shot from Chesterton, but if you can get WMEU-CD on RF 32 (soon to be RF 18), CBS Chicago is carried on 48.3.
dave73 is offline
post #12976 of 12988 Old 08-26-2019, 06:08 AM
malapane's Avatar
Thank you so much for the feedback. I installed the 8 bowtie antenna last week and get all channels with solid reception except CBS. I don't get anything at all for CBS.
I have a compass now and am going to try one last time to plumb and aim it more accurately. If that doesn't work, I may very well try what you have recommended. For only $50 it might be worth a shot for the one channel. I have another dish set up at my other corner that I can easily repurpose to give it a try. I will also check CBS South Bend to see if they will carry those 2 Bears games this season. Right now I have 13 of the 16 games covered. 2 are on CBS and the last one is ESPN.
malapane is offline
post #12977 of 12988 Old 08-30-2019, 08:31 AM
Take Two's Avatar
Liked: 27
What's going on with WTTW's OTA signal?
It has been out for over 24 hours here in the northern suburbs.
Just wondering if anyone here had any idea what is happening with WTTW's lack of OTA signal.
Edit: Nevermind, all of WTTW's channels came back on OTA sometime this afternoon.
Take Two is offline
post #12978 of 12988 Old 08-30-2019, 01:06 PM
DJ Lushious's Avatar
Quoted: 325 Post(s)
Liked: 116
I'm in Chesterton, too, and have the same experience with CBS. I have an Antennas Direct ClearStream 4 from about 10 years ago that has served me well; it's advertised as getting VHF frequencies, but now CBS has no picture (I don't watch much TV, so I don't know when the switch/issue happened). And this is all with an in-line amplifier!
I'll be curious to hear how you go about resolving the matter.
DJ Lushious is offline
post #12979 of 12988 Old 08-31-2019, 11:10 AM
mikemikeb's Avatar
Quoted: 17 Post(s)
The ESPN game should be carried on a local OTA Chicago station (not sure which one, though I assume WLS for its ABC ownership?).
I would guess that South Bend would carry Indianapolis Colts games, though I'm not sure.
mikemikeb is offline
post #12980 of 12988 Old 09-01-2019, 11:19 AM
zippyfrog's Avatar
Quoted: 28 Post(s)
Really random, but on CBS 2, I am now getting a channel 2-3 that says DABL as the on screen ID, but when I try and view the channel, my TV freezes and nothing is actually coming through. Just a black screen. Is there something else coming?
post #12981 of 12988 Old 09-01-2019, 12:59 PM
snowdog 88's Avatar
Liked: 238
TV make? I wouldn't expect it to freeze up on you.
Anyway, it sounds like they have the channel activated but there is no TS stream (encoding) on it yet. Most devices will simply say no signal or display a blank screen. Others like Samsung usually display a "mode not supported" message. I never heard of a channel freezing up the set unless its really misconfigured to the point that the TV doesn't agree with it.
post #12982 of 12988 Old 09-01-2019, 01:15 PM
PlnOTA's Avatar
Quoted: 43 Post(s)
It's a new diginet being launched by CBS on Sept 9th: https://tvnewscheck.com/article/2360...style-network/
PlnOTA is offline
post #12983 of 12988 Old 09-01-2019, 01:27 PM
zippyfrog's Avatar
Quoted: 28 Post(s)
Sorry - I should have been more clear. The TV is actually fine. I have a Samsung. It's actually the Dish Network receiver.
I re-scanned my Dish Network receiver for the OTA channels, and it picked up 2-3, but when I try and watch it, it causes the Dish Network receiver to lag and freeze until I move off of it. When I am watching through the Samsung OTA, it won't show it in my list of channels.
post #12984 of 12988 Old 09-01-2019, 01:45 PM
snowdog 88's Avatar
Liked: 238
Probably not agreeing with what I previously mentioned. Wait until they're broadcasting video and see if the receiver's symptoms clear up.
post #12985 of 12988 Old 09-07-2019, 06:25 PM
Mike99's Avatar
Quoted: 153 Post(s)
Liked: 66
This mentions the same dates. Since they give a range I presume not all stations are doing it at once, and it would be nice to know when each station is doing it.
https://www.fcc.gov/media/engineering/dtvmaps
Mike99 is offline
post #12986 of 12988 Old 09-09-2019, 08:36 PM
Rack's Avatar
https://www.dabl.com/ is up and running on WBBM-DT 2.3. I had to rescan both my old TV to get it to show up.
Rack is offline
post #12987 of 12988 Old 09-10-2019, 09:50 AM
andyross63's Avatar
Quoted: 322 Post(s)
Liked: 119
WCIU CW audio
I never really watched WCIU all that much before they switched to the CW. Watching "Pen & Teller Fool Us" and other shows, it seems as if there are some audio issues. The audio is 5.1, but the sound itself appears to only be front L-R. Nothing out of the surrounds or center channel. My receiver is set to just play 5.1 as-is with no extra processing.
post #12988 of 12988 Old 09-12-2019, 06:03 PM
Rack's Avatar
https://www.fox32chicago.com/news/re...ox-32-and-my50 Fox32 put out their rescan date and time, October 18th at 2am. Getting excited here!
Rack is offline
digital audio , wrjk
