Master List of currently available 4k HDR titles, will be updated often. - Page 888 - AVS Forum | Home Theater Discussions And Reviews
 31018Likes
post #26611 of 27855 Old 07-02-2019, 06:42 PM
puddy77's Avatar
Quoted: 1084 Post(s)
Liked: 2072
Amazon has released the movie Peterloo in 4k HDR: https://smile.amazon.com/gp/video/detail/B07QCWS2VJ/
galonzo, mdsjedi44 and mrtickleuk like this.
puddy77 is offline
post #26612 of 27855 Old 07-02-2019, 06:52 PM
helvetica bold's Avatar
Quoted: 1719 Post(s)
Liked: 1078
While streaming Netflix from my Apple TV I noticed the Dolby Vision layer shuts off momentarily from time to time. Anyone experience this? This happened while I was rewatching Sabrina on my C9.
LG65C9, XBOX ONE X, PS4PRO, APPLE 4K, SONY STRDN1070, TAKE CLASSIC 5.1
helvetica bold is online now
post #26613 of 27855 Old 07-02-2019, 09:20 PM
Ph8te's Avatar
Quoted: 6518 Post(s)
Liked: 6231
I have never experienced that with my ATV4K or internal app on my B7. You may want to try in the C9/AppleTV thread.
Ph8te is online now
post #26614 of 27855 Old 07-03-2019, 06:35 AM
Oppo Beta Group
RichB's Avatar
Quoted: 1964 Post(s)
Liked: 1431
Originally Posted by aaronwt View Post
Would anyone even see a difference? Other than the lower compression and higher bitrate from Disc.
Here are some images I took a while back of Jumanji streamed from iTunes by the ATV4K and the disk played.
I doubt many would notices the difference in color depth. It is hard to see but there was more detail in the DV disk.
The streamed audio seemed a bit more aggressive in the surrounds and center channel.
- Rich
Name:	Jumanji Apple 2.jpg
ID:	2587044   Click image for larger version
Name:	Jumanji Oppo UHD.jpg
aron7awol likes this.
Oppo UPD-205 x 2 | UPD-203 | Sonica DAC | Emotiva XMC-1 (v3) | Revel Salon2s, Voice2, Studio2s | Benchmark AHB2 x 4 | ATI AT522NC | Velodyne HGS-15 | LG 77C9 | Lumagen 2020 | HDFury Vertex x 2
RichB is online now
post #26615 of 27855 Old 07-03-2019, 10:21 AM
Quoted: 2799 Post(s)
Liked: 11948
- Rich
Thanks for posting those images. In my experience, I agree that the difference between the stream and disc is actually pretty hard to see most of the time, but it's there and can be seen in certain scenes and of course it's easier to see with bigger screens.
As far as the audio side, I haven't tested the Jumanji DD+ Atmos track specifically, but so far in (Edit: almost) every example that I have tested, I've found a lossless Atmos track from a disc to be essentially identical to its streaming DD+ Atmos track. Please note, I am referring to the actual mix (the effects and their levels), and I'm not trying to say there isn't a sound quality difference between lossy and lossless
This makes sense to me. If I had already mixed an Atmos track for the disc and I needed to create a lossy Atmos track, I'd keep my existing work and just encode it to lossy.
galonzo likes this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #26616 of 27855 Old 07-03-2019, 02:19 PM
cmdrdredd's Avatar
Quoted: 4254 Post(s)
Liked: 4545
Originally Posted by DisplayCalNoob View Post
DV streaming has better color, disc has everything else.
Sent from my LGMP450 using Tapatalk
Your TV is a 10bit panel and cannot display the extra color information so...I don't think your statement is truly accurate. Besides you would have it backwards. Streaming is 10bit only, disc is 12bit. Again, your TV can only display in 10bit.
As far as the audio side, I haven't tested the Jumanji DD+ Atmos track specifically, but so far in every example that I have tested, I've found a lossless Atmos track from a disc to be essentially identical to its streaming DD+ Atmos track. Please note, I am referring to the actual mix (the effects and their levels), and I'm not trying to say there isn't a sound quality difference between lossy and lossless
I have found that streaming DD+ Atmos has weaker bass than the lossless track on the disc. That's the most notable difference for me. I have to increase the master volume by 5dB to get the same effect from the LFE.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #26617 of 27855 Old 07-03-2019, 02:30 PM
morphinapg's Avatar
Quoted: 2312 Post(s)
Liked: 1869
Better color can be found in the way things are tonemapping, so if we're talking DV streaming vs HDR10 disc, there is benefit to be found.
Plus, very, very few people would be able to see any difference between 10bit and 12bit. It definitely wouldn't be anything obvious.
That being said, a higher bit depth source will be better in the sense that it will lose less through any processing, and if the bit distribution of the display is different than the content (as it almost certainly would be even from tonemapping alone), then there is benefit to be found there too. However, I still have no idea what bits mean in terms of the panel. The electricity driven to the pixels will be analog, not digital.
Sent from my OnePlus One using Tapatalk
Living Room: Sony XBR65X930D, Sony HTCT780, Base PS4, Philips BDP7501
Bedroom: LG OLED55C6P, Denon AVR-X1300W (5.1.2), PS4 Pro, Sony UBP-X700, Atomos Ninja Inferno
Check out my video game movie edits
morphinapg is online now
post #26618 of 27855 Old 07-03-2019, 03:19 PM
Quoted: 1852 Post(s)
Liked: 1116
Not in that manner, streaming through Vudu, doesn't use YCbCr as a color space. It uses IPT or ICtCp(Dolby) color space. ICtCp is a constant luminance color space designed specifically for HDR.
YCbCr has crosstalk issues, as it is a non constant luminance color space. In high brightness situations red can drift to orange or magenta. Also posterization pops up.
Netflix supports ICtCp as well.
mrtickleuk likes this.
DisplayCalNoob is offline
post #26619 of 27855 Old 07-03-2019, 05:36 PM
Liked: 11948
Based on what I've seen analyzing multiple cases, you may want to consider the possibility that the difference in bass level you think you experienced was placebo, at least in some cases. Again, I'm not saying there's no quality difference, but there doesn't appear to be any difference at all in effects, bass level, or filtering, in most cases.
I just remembered the two that I tested and there was a difference, and that was Aquaman and Captain Marvel. I think every other one I've tested has been essentially identical. Was Aquaman or Captain Marvel possibly ones you're thinking of? Edit to add: I want to make sure to clarify that I'm not saying you are wrong, just that while you may have experienced it in some cases, it isn't always the case, so be careful assuming it always is, that's all.
Here are a couple of recent examples that I've compared...
Shazam!
The Wolf's Call
RichB, morphinapg, galonzo and 1 others like this.
post #26620 of 27855 Old 07-04-2019, 06:07 AM
cmdrdredd's Avatar
Liked: 4545
Shazam!
The Wolf's Call
No, I noticed it right away with Ready Player One too. What streaming service are you measuring? I was watching through Vudu on a Apple TV 4K. I have not tried the app through my Nvidia Shield to compare. Maybe the app or device matters?
post #26621 of 27855 Old 07-04-2019, 08:01 PM
puddy77's Avatar
Liked: 2072
It’s probably common knowledge, and I assume today’s festivities have gotten in the way like they did for me, but just in case... Stranger Things season 3 came out today on Netflix in 4K HDR.
puddy77 is offline
post #26622 of 27855 Old 07-05-2019, 01:43 AM
Quoted: 64 Post(s)
Liked: 65
Well, I think I've said this before in other thread but I think you are overlooking the important benefit of 'oversampling'.
12-bit HDR encode of a 10-bit HDR source has less banding than a 10-bit encode of a 10-bit source just like a 4K supersampled image has less aliasing than a 2K image on 2K display.
ShePearl is offline
post #26623 of 27855 Old 07-05-2019, 02:01 AM
lujan's Avatar
Quoted: 4589 Post(s)
Liked: 2663
Last night I saw "13 Hours" in 4k Dolby Vision and all I can say is:
aaronwt, galonzo and ma1746 like this.
lujan
561 Ultra HD
721 HD
4 SD
lujan is online now
post #26624 of 27855 Old 07-05-2019, 04:00 AM
roland6465's Avatar
Quoted: 416 Post(s)
Liked: 412
We watched it all yesterday. Some great eye candy. Would have been better with Atmos.
Chuck666, aaronwt, galonzo and 1 others like this.
roland6465 is offline
post #26625 of 27855 Old 07-05-2019, 02:03 PM
UHD Addict
aaronwt's Avatar
Quoted: 9302 Post(s)
Liked: 5986
Yes. But at least I didn't need to use my ATV 4K since it didn't have Atmos. I'm partway through episode six. Since it had DV and no Atmos I used the Netflix app on my FireTV 4K stick, my TCL TV, and my Philips UHD BD player to watch Season 3 so far. I'll probably just finish the rest of it using the FireTV 4K stick.
galonzo likes this.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #26626 of 27855 Old 07-05-2019, 03:23 PM
drewTT's Avatar
Quoted: 2093 Post(s)
Liked: 2239
The mall scenes in Stranger Things are really nice. Only two episodes in for me but looking really good!
aaronwt and galonzo like this.
LG OLED65E8 | Plinius Hiato | Dynaudio Contour 20 | Dynaudio Stand 6 | REL S/510 | PS Audio DirectStream Junior | Furman IT-Reference 15i | Sony PS4 Pro | Synology DS916+ | Apple TV 4K | BDI Mirage | NEEO | Focal Shape 40 | iFi Pro iDSD | iFi Pro iRack | roon
drewTT is offline
post #26627 of 27855 Old 07-05-2019, 04:52 PM
Liked: 1078
Indeed, Dolby Vision and wide color gamut really make 80s fashion pop.
Plus the sounds track is awesome as well.
post #26628 of 27855 Old 07-05-2019, 06:57 PM
Ph8te's Avatar
Liked: 6231
Just finished STs3 and have to say the use of Dolby Vision was very nice. This is especially the case for the final episode.
aaronwt, mrtickleuk and DrTim like this.
Ph8te is online now
post #26629 of 27855 Old 07-06-2019, 02:53 AM
mrtickleuk's Avatar
Quoted: 4858 Post(s)
Liked: 7150
Why the rush?! I can't understand where you guys get so much free time from sometimes! It would take me weeks to get to it, there's so much good stuff on TV as it is.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #26630 of 27855 Old 07-06-2019, 03:04 AM
lujan's Avatar
Liked: 2663
Me too, I'm only watching one episode per night and alternating between Stranger Things and Jessica Jones so it will take me about 3 weeks to watch all of the two series.
longhorn23 likes this.
lujan
561 Ultra HD
721 HD
4 SD
lujan is online now
post #26631 of 27855 Old 07-06-2019, 03:34 AM
mrtickleuk's Avatar
Liked: 7150
I've worked out that my backlog is well over 1,000 hours. I would have to give up work to catch up. Which unfortunately I cannot afford to do. Hence my shock at how other people manage it!
aaronwt, Musician and longhorn23 like this.
_______________
post #26632 of 27855 Old 07-06-2019, 07:11 AM
cmdrdredd's Avatar
Liked: 4545
I think with the Fourth of July being a full day off for most in the US and many having a 4 day weekend out of it and possibly no plans, they just sit down and spend the day watching it. Same for any show. I did it for Punisher.
post #26633 of 27855 Old 07-06-2019, 07:13 AM
Liked: 1078
I’m switching between The Society and Stranger Things. Didn’t expect to like the former as much but I’m hooked.
DrTim likes this.
post #26634 of 27855 Old 07-06-2019, 09:39 AM
mrtickleuk's Avatar
Liked: 7150
Good point! Thanks
ps a late Happy "Original Brexit" day to you folks
galonzo and RagtopFE like this.
_______________
post #26635 of 27855 Old 07-06-2019, 11:09 AM
roland6465's Avatar
Quoted: 416 Post(s)
Liked: 412
Yep. My wife and I were both off on the 4th, don't like to travel on holidays, and all nearby family was doing other things, so we planned to spend the entire day in our pj's and taking out ST3. Took breaks to let the dog out and play, finished ep. 6, grilled burgers and baked beans, then took back to the theater to finish it off. We were in bed by 9.
post #26636 of 27855 Old 07-06-2019, 11:45 AM
jconjason's Avatar
Quoted: 1275 Post(s)
Liked: 2117
Those of us that are single and don't work weekends can easily bang out a season in a Saturday. I finished season 3 of Designated Survivor in a single sitting.
aaronwt, galonzo and Gillietalls like this.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
jconjason is offline
post #26637 of 27855 Old 07-06-2019, 11:50 AM
UHD Addict
aaronwt's Avatar
Liked: 5986
For me, certain shows get pushed to the top of the list when they are released. Stranger Things is one of them. Jessica Jones was too. So I typically watch a new season within a couple of days to a week. I finished Stranger Things Season 3 on the second day. I hope it comes back for a fourth season.
Ph8te, galonzo and Salty01 like this.
post #26638 of 27855 Old 07-06-2019, 12:42 PM
lujan's Avatar
Liked: 2663
Those two were pushed to the top of the list for me as well but I still can only sit through one episode per day. I think I just get too impatient and need to get up after a while and do something else.
lujan
561 Ultra HD
721 HD
4 SD
lujan is online now
post #26639 of 27855 Old 07-06-2019, 02:25 PM
Ph8te's Avatar
Liked: 6231
I had the day off and I’m on call so I stayed home, so plenty of time to watch. I could have done it in one day, but split it over two. I’ve also cut what I watch way down so right now when it’s fairly “slow” I can watch Netflix more easily. While there is a bunch of good shows, I rarely watch network TV and there are other shows that have been put on back burner status until I feel like starting them up. If I didn’t stay home because I was on call I wouldn’t have been able to finish in two days, but would have this weekend. As others have said, there are shows that will move to the top once released (ST is one of them). I can binge it then be done with it and go back to normal programming.
aaronwt and mrtickleuk like this.
Ph8te is online now
post #26640 of 27855 Old 07-06-2019, 03:53 PM
p5browne's Avatar
Quoted: 4000 Post(s)
Liked: 3175
Stay detached - whole season.
Right into it - a few episodes, then time out to calm down.
Lost in Space - one episode at a time was all I could handle! Tensions just got too high!
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
Reply High Dynamic Range (HDR) & Wide Color Gamut (WCG)
dolby vision , hdr10 , JS8500 , KS9800 , ultra hd blu-ray
