Netflix and Amazon HDR dark on Samsung 4k TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-29-2018, 09:22 AM - Thread Starter
richard58's Avatar
Have a Samsung ku6300 series 4k TV. It's HDR capable even though it doesn't have wide color gamut. Problem is, whenever I stream HDR content from Netflix or Amazon it looks dark; broad daylight looks like early morning for example. I'm afraid to buy a 4k BD player because I worry HDR discs will look the same way. Is there a fix? Thanks.
richard58 is offline
post #2 of 3 Old 01-29-2018, 11:45 AM
Elisha's Avatar
Quoted: 628 Post(s)
Liked: 590
What is your Backlight for regular viewing?
HDR won't look great since it is a 400 Nit TV. But if you can watch regular tv at low Backlight like 6/20, you'll notice that HDR will be an improvement when it ramps up to 20/20.
Sent from my PH-1 using Tapatalk
Elisha is offline
post #3 of 3 Old 01-29-2018, 11:31 PM
ray0414's Avatar
Quoted: 12763 Post(s)
Liked: 12089
With this tv, it's very under powered. You'll need to use dynamic contrast on medium or high and also bump up your gamma. Make sure smart. Led is on high if you have that also. If these don't work, you'll be stuck with dark hdr forever. You'll need a brighter TV unfortunately.
ray0414 is offline
Reply High Dynamic Range (HDR) & Wide Color Gamut (WCG)
