Dolby Access app and Dolby Vision Demo Files - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #61 of 81 Old 06-15-2019, 09:06 AM
zeonstar's Avatar
Quoted: 371 Post(s)
Liked: 89
Originally Posted by richardsim7 View Post
The full disc is Dolby Vision, we just have no way to play it unless you have an Oppo 203
The mp4 version only has DD+ because mp4 doesn't support HD Audio codecs (TrueHD/DTS-HD)
Unless your disc is a weird fake, it sounds like an issue with your player. Is there no "audio" button on your Blu-Ray player remote to switch tracks? How do you normally do it?
Yeah it crossed my mind it could be fake though it really doesn’t look like it. But then again I have no real way to tell. I mean the disc at least is Dolby Vision.
I have an x800m2 and a UBK90. I tried it on both with no way to change the audio on either. They both have audio buttons which change the audio just fine on other movies.
I did discover that if I try to play the disc with Dolby Vision turned OFF the disc defaults to an alternate audio track saying the disc is meant to be played in Dolby Vision.
zeonstar is offline
post #62 of 81 Old 06-16-2019, 03:33 PM
Liked: 0
Sorry for late reply. I encoded it to HDR quality and uploaded to youtube for quick check. And you can find download link under video if u want to test on your tv.
This is still old 1080p upscaled to 4k. I can see some one already uploaded bluray in torrents. I will try to upscale original 4k video to 8k and upload to youtube. So youtube not going compress it so hard and you can watch in good quality on youtube if you choose 4k res(YouTube not compressing videos so hard if you uploading in higher res). And again sorry for late reply i had lost my ssd so i needed to render new video.
//Edited
I checked new video. Its seems its little bit different from old version. It have few changes. But coolest part of the black screen is left!
kepalas is offline
post #63 of 81 Old 06-17-2019, 12:45 PM
AdamAttewell's Avatar
Quoted: 649 Post(s)
Liked: 133
Yeah that won't work, mkv doesn't support Dolby Vision
Richard, I am downloading that torrent now, if I burn it to a blu ray & attempt to play it in my UB820 it should play in Dolby Vision on my A1E correct?
AdamAttewell is online now
post #64 of 81 Old 06-17-2019, 12:46 PM
richardsim7's Avatar
Quoted: 1311 Post(s)
Liked: 1682
Assuming you have a UHD-BD burner, then...maybe?
richardsim7 is offline
post #65 of 81 Old 06-17-2019, 01:29 PM
Quoted: 649 Post(s)
Liked: 133
I do have a UHD-BD burner but only have BD-R DL discs that are 50GB in size but this ISO is only 24GB
So the only thing stopping this working is that fact that I dont have a BD-XL disc if that is a requirement for the player to play Dolby Vision content.
post #66 of 81 Old 06-17-2019, 02:01 PM
Liked: 1682
In theory, yeah, because HDR10 etc isn't in the Blu-Ray spec so wouldn't work on a regular BD-R disc
post #67 of 81 Old 06-17-2019, 02:14 PM
Quoted: 649 Post(s)
Liked: 133
I guess there is only one way to find out & that's to burn it & see. Just a waste of a disk if it does not.
richardsim7 likes this.
post #68 of 81 Old 06-17-2019, 02:15 PM
Liked: 1682
aka A Coaster
AdamAttewell likes this.
post #69 of 81 Old 06-17-2019, 04:11 PM
Quoted: 649 Post(s)
Liked: 133
aka A Coaster
So not a total fail, the disk plays but only in HDR10 not in Dolby Vision & displays a message on screen.
I have the Dolby Vision setting enabled on the Panny so I can only think that my AVR cant pass Dolby Vision?
Going to try connecting the player directly to the TV & see what happens.
EDIT: Looks like my hunch was right after connecting the player direct to the TV everything plays in Dolby Vision as intended.
So Dolby Vision does not required BD-XL discs either.
post #70 of 81 Old 06-17-2019, 04:54 PM
Liked: 1682
Fairly certain your AVR does pass Dolby Vision, that's strange...
post #71 of 81 Old 06-17-2019, 06:42 PM
Quoted: 224 Post(s)
Liked: 620
Originally Posted by Johann Viebrock View Post
Website with complete UHD Disc Torrent:
http://37.1.207.65/torrent/704083/do...-dolby-vision/
Gesendet von meinem SM-G960F mit Tapatalk
Thank you for this. I don't have a Blu-Ray burner so I just put the folder onto a USB drive. Both my LG-UBK90 and my LG-B7 played the MTS files in the stream folder fine. Receiver showed I was playing Atmos from both sources. My favorite clip from the Dolby Access app (no longer there), Core Universe, sounded just as good and looked as good as I remember. Despite the sound working well, my TV showed HDR. None of them came up as Dolby Vision. I own Kong: Skull Island, Wonder Woman, and Valerian in 4K. The clips did not sound as good as my 4K discs. The bass seemed to be turned down and the surrounds/heights turned up. Also in Wonder Woman when she is running I noticed some compression blocking and other effects not seen on my 4K disk. Still worth every minute of time I spent with it. Thank You.
TV: LG OLED 65B7A, Receiver: Marantz SR-6012, Blu-Ray Player: LG UBK90, Fronts: JBL S312, Center: JBL S-Center, Surrounds: JBL S38, Top: Yamaha NS-AW1, Subwoofer: 2 PSA S3000i and one PSA XS-30se--- 5.3.4 setup
http://www.blu-ray.com/community/col...&action=hybrid
Joshua Chmiel is offline
post #72 of 81 Old 06-20-2019, 03:08 PM
Quoted: 649 Post(s)
Liked: 133
So after messing with a few settings on the Vertex you are correct my AVR can pass DV no problem.
I may have spoken too soon on the demo disc though, some clips play fine but others after 15 seconds the audio starts to break up & then disappears completely. The video is still present but is choppy sometimes.
The Kong Island & Wonder Woman clips are ones that are effected among others, Core Universe plays all the way through no problem but the audio volume is very low, I have to turn up my master volume well above normal levels.
I thought this was my setup so I plugged my BD player directly into my TV & it does exactly the same so I can only come to the conclusion that this is a problem with the content on the disc itself?
I burned at x2 & verified the disk successfully so I dont know what else I can do to check.
Anyone else burned the torrent to a disk & tried it?
post #73 of 81 Old 06-20-2019, 05:24 PM
Liked: 1682
Yeah, that's normal, it's just recorded low, like 10dB lower than "normal"
post #74 of 81 Old 06-20-2019, 10:55 PM
Quoted: 649 Post(s)
Liked: 133
I presume all the clips play for you in DV & Atmos no problem?
Really got me scratching my head, tried various different cables that pass 4K, 60Hz, 4:4:4 10bit no problem.
It does see like some sort of signal issue as its like its handshaking constantly as the clip plays like the signal is being lost & found.
I mean I even tried a 70cm cable which from my knowledge at that length most cables should have no issue passing any content.
post #75 of 81 Old 06-25-2019, 04:14 AM
Liked: 1
I have this disc and the demos are Dolby Vison / HDR / TrueHD+Atmos / E-AC3+Atmos / AC3.
Dolby Vision is dual layer when found on disc.
The first video stream is 4k and contains the HDR, the second video stream is 1080p and contains the Dolby Vision information to add to the first 4k HDR stream.
Your disc player acts as the "composer".
The USB jack on the LG OLED will play Dolby Vision files (LG demos in the .lge file container) that are single layered (all info is in one stream).
With a UHD disc player you can output Dolby Vision to your compatible TV via HDMI and output TrueHD+Atmos to your Atmos compatible audio receiver.
If you take the m2ts files off the disc and put them on USB you will only get HDR because it's Dolby Vision in dual layer.
Also, you can get Atmos from your TV ARC from the E-AC3 stream if your TV supports it, the latest LG C9 TVs have eARC so they can pass TrueHD+Atmos over ARC.
I have a LG C8 with a Samsung HW-N950 and these are my playing options:
Good: m2ts file on USB plugged into TV > HDMI to soundbar (this gets HDR and E-AC3+Atmos)
Better: m2ts file on Vero 4K+ > HDMI to soundbar > HDMI to TV (this gets HDR and TrueHD+Atmos)
Best: UHD disc in UHD player > HDMI to soundbar > HDMI to TV (this gets Dolby Vision and TrueHD Atmos)
Dolby Vision is better than HDR and TrueHD+Atmos is better than E-AC3+Atmos, but the difference is not drastic.
If you can get HDR with E-AC3+Atmos, you should be pretty content.
*You could mux the dual layer m2ts into a single layer MP4 to get Dolby Vision via USB but the best audio you can get going that route is AC3 5.1.
The only way I know of to get Dolby Vision with TrueHD+Atmos is from a UHD disc player or files through OPPO UDP-203.
LGE demo files will not have TrueHD+Atmos and even if they did you'd need eARC for that anyway.
Maybe one day someone will figure out how to make proper Dolby Vison with TrueHD+Atmos MKV files, but even then, it would require a player with a license from Dolby to act as the DV "conductor".
Kontrarian is offline
post #76 of 81 Old 06-25-2019, 09:35 AM
zeonstar's Avatar
Quoted: 371 Post(s)
Liked: 89
You have the March 2018 UHD Disc? And it plays back the files In Dolby Vision with TrueHD Atmos? Wow. Weird. I have the disc and it just would not play anything other then DD+ Atmos. The Dolby Vision was fine though.
zeonstar is offline
post #77 of 81 Old 06-25-2019, 12:32 PM
Quoted: 649 Post(s)
Liked: 133
I am still having issues with the March 2018 disk with some clips losing sound shortly after starting. I have tried five different cables now between player & TV.
I even purchased a certified HDMI cable but still no difference.
I just cant work out whats causing it, the TV, Player or the disc.
post #78 of 81 Old 06-25-2019, 01:36 PM
Liked: 1682
I wonder if it's a Cinavia problem...
post #79 of 81 Old 06-25-2019, 03:55 PM
Quoted: 649 Post(s)
Liked: 133
When I have had Cinavia problems in the past the audio is muted & a message is displayed on screen.
I dont get a message, it's like there is a bottleneck somewhere.
On the Sony when a handshake occurs with a source the info/status bar appears at the top of the screen.
The same happens when the audio starts to break up & the video becomes choppy the info bar appears at the top the screen like a handshake is happening.
post #80 of 81 Old 06-26-2019, 05:21 AM
Liked: 1
The following is the media info for the stream belonging to "Core Universe" aka "See. Hear. Spectacular.".
Look at the first audio stream, it is Dolby TrueHD + Atmos, second audio stream is E-AC3 + Atmos, and third audio stream is just AC3.
Every demo on the disc has the same specs:
Video 1 = 4K UHD HDR
Video 2 = Dolby Vision
Audio 1 = Dolby TrueHD 7.1 + Atmos
Audio 2 = E-AC3 5.1 + Atmos
Audio 3 = AC3 5.1
Code:
General
Complete name                  : D:\Dolby UHD Demo Disc March 2018\BDMV\STREAM\00003.m2ts
Format                         : BDAV
Format/Info                    : Blu-ray Video
File size                      : 979 MiB
Duration                       : 3 min 8 s
Overall bit rate mode          : Variable
Overall bit rate               : 43.5 Mb/s
Maximum Overall bit rate       : 109 Mb/s
Video #1
Menu ID                        : 1 (0x1)
Format                         : HEVC
Format/Info                    : High Efficiency Video Coding
Format profile                 : Main [email protected]@High
Codec ID                       : 36
Duration                       : 3 min 7 s
Width                          : 3 840 pixels
Height                         : 2 160 pixels
Display aspect ratio           : 16:9
Frame rate                     : 23.976 (24000/1001) FPS
Color space                    : YUV
Chroma subsampling             : 4:2:0 (Type 2)
Bit depth                      : 10 bits
Color range                    : Limited
Color primaries                : BT.2020
Transfer characteristics       : SMPTE ST 2084
Matrix coefficients            : BT.2020 non-constant
Mastering display color primar : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
Mastering display luminance    : min: 0.0050 cd/m2, max: 4000.0000 cd/m2
Maximum Content Light Level    : 1000 cd/m2
Maximum Frame-Average Light Le : 471 cd/m2
Video #2
Menu ID                        : 1 (0x1)
Format                         : HEVC
Codec ID                       : 36
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Color space                    : YUV
Bit depth                      : 10 bits
Audio #1
Menu ID                        : 1 (0x1)
Format                         : TrueHD / AC-3
Format profile                 : TrueHD+Atmos / TrueHD / AC-3
Format settings, Endianness    : Big
Muxing mode                    : Stream extension
Codec ID                       : 131
Bit rate mode                  : Variable / Constant
Bit rate                       : 640 kb/s
Maximum bit rate               : 9 621 kb/s
Channel(s)                     : Object Based / 8 channels / 6 channels
Channel positions              : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                  :  / 48.0 kHz / 48.0 kHz
Frame rate                     : 31.250 FPS (1536 SPF)
Bit depth                      : 16 bits
Stream size                    : 14.3 MiB (1%)
Service kind                   : Complete Main
Audio #2
Menu ID                        : 1 (0x1)
Format                         : E-AC-3
Format/Info                    : Enhanced Audio Coding 3
Format profile                 : E-AC-3+Atmos / E-AC-3
Codec ID                       : 132
Bit rate mode                  : Constant
Bit rate                       : 500 b/s
Channel(s)                     : 15 objects / 6 channels
Channel positions              : 15 objects / Front: L C R, Side: L R, LFE
Sampling rate                  : 48.0 kHz
Frame rate                     : 187.500 FPS (256 SPF)
Compression mode               : Lossy
Stream size                    : 11.5 KiB (0%)
Audio #3
Menu ID                        : 1 (0x1)
Format                         : AC-3
Format/Info                    : Audio Coding 3
Codec ID                       : 129
Bit rate                       : 640 kb/s
Channel(s)                     : 6 channels
Channel positions              : Front: L C R, Side: L R, LFE
Bit depth                      : 16 bits
I'm not sure why you are getting lossy Atmos from your disc.
What player and receiver do you have?
post #81 of 81 Old 06-26-2019, 04:20 PM
zeonstar's Avatar
Quoted: 371 Post(s)
Liked: 89
I have a Sony X800m2. It plays other Dolby Vision discs with lossless audio just fine. Only had the trouble with the 2018 March UHD Demo disc. Maybe I simply had a defective disc.
zeonstar is offline
Reply High Dynamic Range (HDR) & Wide Color Gamut (WCG)
